楼主 # 2024-08-18 16:49:40
Aluminum
已发帖子: 0
拜求大佬帮我看看我编译f1c200s的uboot遇到的问题
以下是我编译的日志
lsq@DESKTOP-ONM0QIQ:~/ZeroExpiloterOS/u-boot$ make -j8
  CHK     include/config/uboot.release
  CHK     include/generated/timestamp_autogenerated.h
  PYMOD   scripts/dtc/pylibfdt/_libfdt.so
  HOSTCC  scripts/dtc/dtc-parser.tab.o
  UPD     include/generated/timestamp_autogenerated.h
/home/lsq/ZeroExpiloterOS/u-boot/scripts/dtc/pylibfdt/setup.py:21: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
  from distutils.core import setup, Extension
  CHK     include/generated/version_autogenerated.h
  CC      lib/asm-offsets.s
  CC      arch/arm/lib/asm-offsets.s
  HOSTLD  scripts/dtc/dtc
  CHK     include/generated/generic-asm-offsets.h
  CHK     include/generated/asm-offsets.h
  HOSTCC  tools/mkenvimage.o
  HOSTCC  tools/fit_image.o
  HOSTCC  tools/image-host.o
  HOSTCC  tools/dumpimage.o
  HOSTCC  tools/mkimage.o
  HOSTCC  tools/sunxi-spl-image-builder.o
  HOSTLD  tools/mkenvimage
  HOSTLD  tools/sunxi-spl-image-builder
  HOSTLD  tools/dumpimage
  HOSTLD  tools/mkimage
  CC      arch/arm/cpu/arm926ejs/cpu.o
  CC      board/sunxi/board.o
  CC      arch/arm/mach-sunxi/board.o
  CC      disk/part.o
  CC      arch/arm/lib/bootm-fdt.o
  CC      cmd/boot.o
  CC      common/init/board_init.o
  CC      arch/arm/cpu/arm926ejs/cache.o
  CC      arch/arm/lib/bootm.o
  LD      common/init/built-in.o
  CC      cmd/bootm.o
  CC      arch/arm/mach-sunxi/clock.o
  CC      common/main.o
  LD      board/sunxi/built-in.o
  CC      disk/part_dos.o
  CC      disk/part_iso.o
  CC      arch/arm/cpu/arm926ejs/sunxi/timer.o
  CC      arch/arm/mach-sunxi/cpu_info.o
  CC      common/exports.o
  CC      cmd/help.o
  CC      arch/arm/lib/zimage.o
  CC      arch/arm/mach-sunxi/dram_helpers.o
  LD      arch/arm/cpu/arm926ejs/sunxi/built-in.o
  CC      cmd/version.o
  CC      disk/part_efi.o
  CC      common/cli_hush.o
  LD      arch/arm/cpu/arm926ejs/built-in.o
  CC      common/autoboot.o
  CC      arch/arm/lib/sections.o
  CC      cmd/blk_common.o
  CC      arch/arm/mach-sunxi/pinmux.o
  CC      common/board_f.o
  CC      arch/arm/lib/stack.o
  CC      cmd/source.o
  CC      arch/arm/lib/interrupts.o
  CC      arch/arm/mach-sunxi/usb_phy.o
  CC      common/board_r.o
  CHK     include/config.h
  CFG     u-boot.cfg
  CC      cmd/bdinfo.o
  CC      arch/arm/mach-sunxi/clock_sun6i.o
  CC      common/board_info.o
  CC      arch/arm/lib/reset.o
  CC      cmd/bootefi.o
  LD      disk/built-in.o
  CC      cmd/bootz.o
  CC      arch/arm/lib/cache.o
  CC      common/bootm.o
  CC      common/bootm_os.o
  CC      common/fdt_support.o
  CC      drivers/block/blk_legacy.o
  LD      arch/arm/mach-sunxi/built-in.o
  CC      cmd/console.o
  CC      common/miiphyutil.o
  CC      arch/arm/lib/cache-cp15.o
  CC      common/usb.o
  CC      drivers/gpio/gpio-uclass.o
  LD      drivers/block/built-in.o
  CC      cmd/echo.o
  CC      drivers/core/device.o
  CC      arch/arm/lib/psci-dt.o
  CC      drivers/core/fdtaddr.o
  CC      cmd/elf.o
  CC      arch/arm/lib/div0.o
  CC      cmd/exit.o
  CC      common/usb_hub.o
  CC      drivers/gpio/sunxi_gpio.o
  CC      common/usb_storage.o
  CC      arch/arm/lib/eabi_compat.o
  CC      drivers/core/lists.o
  CC      drivers/core/root.o
  CC      drivers/crypto/fsl/sec.o
  CC      cmd/ext4.o
  CC      arch/arm/lib/reloc_arm_efi.o
  LD      drivers/gpio/built-in.o
  CC      cmd/ext2.o
  LD      drivers/crypto/fsl/built-in.o
  CC      drivers/core/uclass.o
  LD      drivers/crypto/built-in.o
  CC      drivers/core/util.o
  CC      drivers/core/device-remove.o
  CC      cmd/fat.o
  CC      cmd/fdt.o
  LD      arch/arm/lib/built-in.o
  CC      drivers/core/simple-bus.o
  AR      arch/arm/lib/lib.a
  CC      common/splash.o
  CC      drivers/input/keyboard-uclass.o
  CC      drivers/input/input.o
  CC      drivers/input/key_matrix.o
  CC      cmd/flash.o
  CC      drivers/core/dump.o
  CC      cmd/fs.o
  CC      common/menu.o
  CC      drivers/core/of_extra.o
  CC      cmd/gpio.o
  CC      drivers/core/ofnode.o
  CC      cmd/itest.o
  CC      cmd/load.o
  LD      drivers/input/built-in.o
  CC      drivers/mmc/mmc.o
  CC      cmd/mem.o
  CC      drivers/core/read_extra.o
  CC      cmd/mii.o
  CC      drivers/mmc/mmc_legacy.o
  CC      drivers/mmc/mmc_write.o
  CC      common/usb_kbd.o
  CC      drivers/mmc/sunxi_mmc.o
  LD      drivers/core/built-in.o
  CC      cmd/mmc.o
  CC      cmd/net.o
  CC      cmd/part.o
  CC      drivers/serial/serial-uclass.o
  CC      common/cli_readline.o
  CC      cmd/pcmcia.o
  CC      cmd/pxe.o
  CC      drivers/serial/ns16550.o
  CC      drivers/spi/spi.o
  CC      drivers/rtc/date.o
  LD      drivers/mmc/built-in.o
  CC      drivers/usb/common/common.o
  CC      cmd/setexpr.o
  CC      cmd/test.o
  LD      drivers/spi/built-in.o
  CC      common/cli_simple.o
  CC      common/console.o
  LD      drivers/serial/built-in.o
  CC      common/dlmalloc.o
  LD      drivers/rtc/built-in.o
  LD      drivers/usb/common/built-in.o
  CC      common/malloc_simple.o
  LD      drivers/built-in.o
  CC      drivers/usb/gadget/epautoconf.o
  CC      cmd/usb.o
  CC      cmd/disk.o
  CC      drivers/usb/host/usb-uclass.o
  CC      cmd/ximg.o
  CC      cmd/gpt.o
  CC      drivers/usb/gadget/config.o
  CC      common/image.o
  CC      common/image-fdt.o
  CC      cmd/nvedit.o
  CC      drivers/usb/gadget/usbstring.o
  CC      common/memsize.o
  LD      drivers/usb/host/built-in.o
  CC      common/stdio.o
  CC      common/cli.o
  CC      env/common.o
  LD      drivers/usb/gadget/built-in.o
  CC      env/env.o
  CC      common/command.o
  CC      env/attr.o
  CC      env/callback.o
  CC      env/flags.o
  LD      cmd/built-in.o
  CC      env/mmc.o
  CC      fs/fs.o
  CC      fs/ext4/ext4fs.o
  CC      fs/ext4/ext4_common.o
  CC      fs/fat/fat_write.o
  CC      lib/efi_loader/efi_image_loader.o
  CC      common/s_record.o
  CC      common/xyzModem.o
  LD      env/built-in.o
  CC      lib/efi_loader/efi_boottime.o
  CC      fs/ext4/dev.o
  CC      fs/fs_internal.o
  CC      net/checksum.o
  CC      lib/efi_loader/efi_runtime.o
  CC      net/arp.o
  LD      fs/ext4/built-in.o
  CC      test/dm/cmd_dm.o
  CC      lib/efi_loader/efi_console.o
  LD      common/built-in.o
  CC      net/bootp.o
  CC      net/eth-uclass.o
  CC      lib/libfdt/fdt.o
  CC      lib/zlib/zlib.o
  LD      test/dm/built-in.o
  CC      lib/charset.o
  CC      lib/libfdt/fdt_wip.o
  LD      fs/fat/built-in.o
  CC      lib/crc7.o
  CC      lib/efi_loader/efi_memory.o
  LD      fs/built-in.o
  CC      net/eth_common.o
  CC      lib/efi_loader/efi_device_path_to_text.o
  CC      lib/efi_loader/efi_device_path.o
  CC      lib/libfdt/fdt_strerror.o
  CC      lib/efi_loader/efi_file.o
  CC      lib/libfdt/fdt_sw.o
  CC      net/net.o
  CC      lib/efi_loader/efi_variable.o
  CC      lib/libfdt/fdt_empty_tree.o
  CC      lib/libfdt/fdt_addresses.o
  CC      net/nfs.o
  CC      net/ping.o
  CC      lib/efi_loader/efi_bootmgr.o
  CC      lib/efi_loader/efi_watchdog.o
  CC      lib/libfdt/fdt_overlay.o
  CC      net/tftp.o
  LD      lib/zlib/built-in.o
  CC      lib/efi_loader/efi_disk.o
  CC      lib/efi_loader/efi_net.o
  CC      lib/efi_loader/efi_smbios.o
  CC      lib/crc8.o
  CC      lib/crc16.o
  CC      lib/smbios.o
  CC      lib/efi_loader/helloworld.o
  CC      lib/initcall.o
  CC      lib/libfdt/fdt_ro.o
  CC      lib/libfdt/fdt_rw.o
  LD      net/built-in.o
  CC      lib/libfdt/fdt_region.o
  LD      lib/efi_loader/built-in.o
  CC      lib/lmb.o
  CC      lib/ldiv.o
  LD      lib/efi_loader/helloworld_efi.so
  OBJCOPY lib/efi_loader/helloworld.efi
  CC      lib/net_utils.o
  CC      lib/qsort.o
rm lib/efi_loader/helloworld.o lib/efi_loader/helloworld_efi.so
  CC      lib/rc4.o
  CC      lib/list_sort.o
  CC      lib/gunzip.o
  CC      lib/fdtdec_common.o
  CC      lib/fdtdec.o
  CC      lib/hashtable.o
  CC      lib/errno.o
  CC      lib/display_options.o
  LD      lib/libfdt/built-in.o
  CC      lib/crc32.o
  CC      lib/ctype.o
  CC      lib/div64.o
  CC      lib/hang.o
  CC      lib/linux_compat.o
  CC      lib/linux_string.o
  CC      lib/membuff.o
  CC      lib/string.o
  CC      lib/tables_csum.o
  CC      lib/time.o
  CC      lib/uuid.o
  CC      lib/rand.o
  CC      lib/vsprintf.o
  CC      lib/panic.o
  CC      lib/strto.o
  CC      lib/strmhz.o
  LD      lib/built-in.o
  CC      examples/standalone/hello_world.o
  CC      examples/standalone/stubs.o
  LD      examples/standalone/libstubs.o
  LD      examples/standalone/hello_world
  OBJCOPY examples/standalone/hello_world.srec
  OBJCOPY examples/standalone/hello_world.bin
  LD      u-boot
  OBJCOPY u-boot-nodtb.bin
  OBJCOPY u-boot.srec
  SYM     u-boot.sym
  DTC     arch/arm/dts/suniv-f1c100s-licheepi-nano.dtb
Error: arch/arm/dts/.suniv-f1c100s-licheepi-nano.dtb.pre.tmp:59.1-10 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [scripts/Makefile.lib:329: arch/arm/dts/suniv-f1c100s-licheepi-nano.dtb] Error 1
make[1]: *** [dts/Makefile:51: arch/arm/dts/suniv-f1c100s-licheepi-nano.dtb] Error 2
make: *** [Makefile:879: dts/dt.dtb] Error 2
#1 2024-08-18 16:54:04
已发帖子: 9,513
Re: 拜求大佬帮我看看我编译f1c200s的uboot遇到的问题
arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
59行有语法错误
