楼主 # 2024-08-21 13:45:44
已发帖子: 1,438
daplink源码,为何boot程序里也有SCB->VTOR设置?
这是在main_bootloader.c文件里:
264 int main(void)
  1 {
  2     // initialize vendor sdk
  3     sdk_init();
  4     // init leds and button
  5     gpio_init();
  6     // init settings
  7     config_init();
  8     // Hook for custom boards initialisation
  9     board_bootloader_init();
 10
 11     // check for invalid app image or rst button press. Should be checksum or CRC but NVIC validation is better than nothing.
 12     // If the interface has set the hold in bootloader setting don't jump to app
 13     if (!reset_button_pressed()
 14             && g_board_info.target_cfg
 15             && validate_bin_nvic((uint8_t *)g_board_info.target_cfg->flash_regions[0].start)
 16             && !config_ram_get_initial_hold_in_bl()) {
 17         // change to the new vector table
 18         SCB->VTOR = g_board_info.target_cfg->flash_regions[0].start; //bootloaders should only have one flash region for interface
 19         // modify stack pointer and start app
 20         modify_stack_pointer_and_start_app((*(uint32_t *)(g_board_info.target_cfg->flash_regions[0].start)),
 21                 (*(uint32_t *)(g_board_info.target_cfg->flash_regions[0].start + 4)));
 22     }
这是在main_interface.c文件里:
551 int main(void)
  1 {
  2     // Explicitly set the vector table since the bootloader might not set
  3     // it to what we expect.
  4 #if DAPLINK_ROM_BL_SIZE > 0
  5     SCB->VTOR = SCB_VTOR_TBLOFF_Msk & DAPLINK_ROM_IF_START;
  6 #endif
  7     // initialize vendor sdk
  8     sdk_init();
  9
 10     // Initialize CMSIS-RTOS
 11     osKernelInitialize();
这是boot里设置的中断向量表的实际地址,文件在stm32f103xb_bl.c:
37  // stm32f103 target information
  1 target_cfg_t target_device = {
  2     .version                    = kTargetConfigVersion,
  3     .sectors_info               = sectors_info,
  4     .sector_info_length         = (sizeof(sectors_info))/(sizeof(sector_info_t)),
  5     .flash_regions[0].start     = 0x08000000 + KB(48),
  6     .flash_regions[0].end       = 0x08000000 + KB(128),
  7     .flash_regions[0].flags     = kRegionIsDefault,
  8     .ram_regions[0].start       = 0x20000000,
  9     .ram_regions[0].end         = 0x20005000,
 10     /* .flash_algo not needed for bootloader */
 11 };
我看到的iap应用,都是只在app程序里设置SCB->VTOR,为何daplink源码里的boot程序这里,在跳转iap之前,为何也设置了SCB->VTOR?
