楼主 # 2024-08-23 01:02:16
s45123456789
T113的tina编译gtk报错
checking for pango pangocairo gdk-pixbuf-2.0 >= 2.30.0 cairo >= 1.14.0 cairo-gobject >= 1.14.0 gio-unix-2.0 >= 2.49.4 wayland-client >= 1.9.91 wayland-protocols >= 1.7 xkbcommon >= 0.2.0 wayland-cursor >= 1.9.91 wayland-egl cairo cairo epoxy >= 1.0... no
configure: error: Package requirements (pango pangocairo gdk-pixbuf-2.0 >= 2.30.0 cairo >= 1.14.0 cairo-gobject >= 1.14.0 gio-unix-2.0 >= 2.49.4 wayland-client >= 1.9.91 wayland-protocols >= 1.7 xkbcommon >= 0.2.0 wayland-cursor >= 1.9.91 wayland-egl cairo cairo epoxy >= 1.0) were not met:
No package 'wayland-egl' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GDK_DEP_CFLAGS
and GDK_DEP_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
make[3]: *** [Makefile:242: /home/x/work/tina-d1-h/out/t113-100ask/compile_dir/target/gtk+-3.22.10/.configured_nnnnnnnnnnyyy] Error 1
make[3]: Leaving directory '/home/x/work/tina-d1-h/package/gui/gtk/libgtk3'
make[2]: *** [package/Makefile:193: package/gui/gtk/libgtk3/compile] Error 2
make[2]: Leaving directory '/home/x/work/tina-d1-h'
make[1]: *** [package/Makefile:189: /home/x/work/tina-d1-h/out/t113-100ask/staging_dir/target/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/x/work/tina-d1-h'
make: *** [/home/x/work/tina-d1-h/build/toplevel.mk:306: world] Error 2
[2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
make failed to build some targets (53 seconds)
楼主 #1 2024-08-23 01:08:21
s45123456789
Re: T113的tina编译gtk报错
我想试一下 gtk-webkit , 但是这个 waylang 不知道怎么解决,有大佬解惑吗?
#2 2024-08-23 09:40:11
海石生风
已发帖子: 787
T113没有GPU吧,所有没有wayland-egl, 这个是wayland众多后端中的一个。换一个后端即可,T113支持的wayland后端应该有:fbdev、DRM、X11
而wayland是gtk的后端之一,如果要用X11的话,不如直接配置gtk使用X11作为后端。
最近编辑记录 海石生风 (2024-08-23 09:51:40)
楼主 #3 2024-08-23 18:42:01
s45123456789
能否请教一下Tina这个如果想切换wayland为fbdev要在哪里配置?
#4 2024-08-23 19:09:17
已发帖子: 9,486
@s45123456789
T113不支持,A133支持wayland。
楼主 #5 2024-08-24 01:18:37
s45123456789
@s45123456789
哦哦,这样呀。大佬,那T113有什么办法编译出gtk的webkit来用吗?
#6 2024-08-24 06:58:59
已发帖子: 9,486
s45123456789 wrote:
@s45123456789
不建议,估计得卡成ppt
楼主 #7 2024-08-25 22:47:58
s45123456789
这样呀,好吧
