楼主 # 2024-10-08 19:12:53
sgyl
配置好v851s是spi设备树和内核驱动,但是找不到dev/fb0,有dev/spidev1.0
参考这个文档配置的帧缓存器 aw-ol.com 全志v851s使用fbtft驱动0.96寸st7735屏分享
设备树配置
&spi1 {
	clock-frequency = <100000000>;
	pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
	pinctrl-1 = <&spi1_pins_c>;
	spi_slave_mode = <0>;
	spi_dbi_enable = <0>;
	spi1_cs_number = <1>;
	spi1_cs_bitmap = <1>;
	spi_board1@0 {
		device_type = "spi_board1";//"spi_dbi";
		compatible = "rohm,dh2228fv";
		spi-max-frequency = <0x5f5e100>;
		reg = <0x0>;
		spi-rx-bus-width = <0x4>;
		spi-tx-bus-width = <0x4>;
		status = "disabled";
	st77916@0{
        //compatible = "rohm,dh2228fv"; /* 兼容性字符串,指定使用的设备驱动程序 */ 、、用则个会生成spidev1.0
		compatible = "sitronix,st77916";//这个也是跟着他配置的,在spidev.c里也添加了
[ins]
static const struct of_device_id spidev_dt_ids[] = {
	{ .compatible = "rohm,dh2228fv" },
	{ .compatible = "lineartechnology,ltc2488" },
	{ .compatible = "sitronix,st77916" },
[/ins]
		//compatible = "lineartechnology,ltc2488";
		reg = <0>;
		spi-max-frequency = <32000000>;
		fps = <33>; /* 每秒帧数 (Frames Per Second),这里设置为33帧*/
		rotate = <0>;
		buswidth = <8>; /* 总线宽度,这里设定为4位 */
		//dc-gpios = <&pio  3 1 GPIO_ACTIVE_HIGH>;      /* 数据/命令引脚,指向第3组GPIO的第1个引脚,活动高电平 */
		reset-gpios = <&pio 3 8 GPIO_ACTIVE_HIGH>;    /* 复位引脚,指向第3组GPIO的第8个引脚,活动高电平 */
		led-gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>;	 /* LED引脚,指向第3组GPIO的第20个引脚,活动高电平 */
		debug = <0x0>;
通过make kernel_menuconfig 配置了
Device Drivers  --->SPI support -》SUNXI SPI Controller (不配置这个会报错,make不成功)
                                              -》User mode SPI device driver support(之前配置spi设备时,配置的)
Device Drivers  --->Graphics support  ---> Frame buffer Devices  ---><*> Support for frame buffer devices  --->(就只配置了这个,要不然下面的不会出现)
Device Drivers  ---> [*] Staging drivers  ---><*>   Support for small TFT LCD display modules(第二个配置了才会出现)  --->  <*>   FB driver for the ST77916 LCD Controller  和 <*>   Module to for adding FBTFT devices
然后我只想lvgl例程就卡在了sunxifb_init()这里打不开/dev/fb0(报错没有这个文件),我的dev下根本没有fb0,有一个spidev1.0,用spidev1.0报错 no a tty
问题应该就是没有生成fb0,需要哪些配置吗?
#1 2024-10-10 17:45:18
lovexulu
已发帖子: 70
Re: 配置好v851s是spi设备树和内核驱动,但是找不到dev/fb0,有dev/spidev1.0
https://bbs.aw-ol.com/topic/4829/
参考这个帖子。
楼主 #2 2024-10-10 17:59:39
sgyl
我就是参考的这个帖子,配置的设备树和内核,因为我的v851s不支持我需要的屏驱(我需要自己添加屏驱),所以后面的修改我没修改,暂时复制了fb_st7789v改了一下为我的屏驱了,但是就是生成不了,dev/fb0;
#3 2024-10-10 18:16:03
lovexulu
已发帖子: 70
那就添加自己的屏驱动 修改makefile kconfig文件 以便可以选中。按照操作步骤仔细对比代码。还有 没有生成fb0 一定是配置问题!内核根本无法加载设备。后续不用测试。无法加载设备的原因有很多。常见引脚冲突 引脚注册错误,驱动指向错误。驱动未编译进内核,驱动编译了 但是是编译成模块,启动后未加载驱动模块。以及驱动初始化代码不正确,返回错误值,等等,请仔细检查启动日志,可以尝试添加printf 来确认驱动加载执行。
最近编辑记录 lovexulu (2024-10-10 18:20:04)
楼主 #4 2024-10-10 18:22:39
sgyl
这是我设备树配置
spi1_pins_a: spi1@0 {
		allwinner,pins = "PD2", "PD3", "PD4","PD5", "PD6";
		allwinner,pname = "spi1_sclk", "spi1_mosi", "spi1_miso", "spi1_hold", "spi1_wp";
		allwinner,function = "spi1";
		allwinner,muxsel = <6>;
		allwinner,drive = <1>;
		allwinner,pull = <0>;
	spi1_pins_b: spi1@1 {
		allwinner,pins = "PD1";  //"PF25";
		allwinner,pname = "spi1_cs0";
		allwinner,pull = <1>;   // only CS should be pulled up
	spi1_pins_c: spi1@2 {
		allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6";
		allwinner,function = "io_disabled";
		allwinner,muxsel = <0x7>;
&spi1 {
	spi_board1@0 {
		reg = <0x0>;
	st77916@0{
		reg = <0>;
		fps = <30>; /* 每秒帧数 (Frames Per Second),这里设置为33帧*/
		rotate = <0>;
		debug = <0x0>;
这是我内核配置
Device Drivers  --->
		Console display driver support  --->
			[*] Framebuffer Console support
			[*]   Map the console to the primary display device
		<*>   Support for small TFT LCD display modules  --->
		<*>   FB driver for the ST7789V LCD Controller
但我的kenel_menuconfig里面没有(Console display driver support --->)选项,所以下面那两个我也没法配置了。但是我在kennel_menuconfig里面用“?”查找可以找到 Framebuffer Console support Map the console to the primary display device,并且在它提示是kconfig里也看到了,就是我选不了,我查了一下,这两项是: Framebuffer控制台支持 将控制台映射到主显示设备,还是很重要的的。是不是就是因为我没配置这两项,所以才生成不了fb0啊!
#5 2024-10-10 18:44:46
lovexulu
已发帖子: 70
请你仔细对比帖子中的设备树写法,你这是打算使用 dbi模式驱动,但原sdk的主设备树中未配置相关参数。请理解设备树每个配置项的含义。给你个建议,先不要着急修改设备树,你就照搬就好,如果能生成fb0 是否证明你修改的错误呢?
最近编辑记录 lovexulu (2024-10-10 18:50:50)
#6 2024-10-10 18:55:49
lovexulu
已发帖子: 70
还有 请按照帖子修改驱动代码,因为v851s的sdk linux内核版本4.9 fbtft驱动结构体有变动。
楼主 #7 2024-10-10 19:42:05
sgyl
**好的,好的,我按照你说的再试一下。
还有就是我配置好spi后,spidev.c就编译成spide.o了,编译过程有显示,注册spidev函数执行了,顺利生成dev/spidev1.0了。
但是我在这配好spi和framebuffer后,fbtft-core.c都没被编译,肯定生不成fb0。
我再试试。**
#8 2024-10-10 21:24:10
lovexulu
已发帖子: 70
是因为你compatible = "sitronix,st77916";指向错误。借你个chatgpt3.5 它能帮你解 https://39rh47.aitianhu1.top/#/chat/1728471009371 决一下问题。
楼主 #9 2024-10-12 14:49:21
sgyl
[    0.168292] 11111111111111111111111111111111111.
[    0.168298] 解析设备树里的sitronix,st7735r start.
[    0.168307] fbtft_of_value: regwidth = 16
[    0.168311] fbtft_of_value: buswidth = 8
[    0.168316] fbtft_of_value: debug = 1
[    0.168319] fbtft_of_value: rotate = 0
[    0.168323] fbtft_of_value: fps = 30
[    0.168328] 解析设备树里的sitronix,st7735r over.
[    0.168587] 注册 fb_info  star.
[    0.168591] fbtft_register_framebuffer00000000000.
[    0.168595] 987987987987.
[    0.168597] 8888888888888888888.
[    0.168599] 777777777777777777.
[    0.168646] OF: /soc@03000000/spi@04026000/st77916@0: arguments longer than p
roperty
[    0.168657] fb_st77916 spi1.0: failed to get 'reset-gpios' from DT
[    0.168660] fbtft_register_framebuffer11111111
[    0.168662] fbtft_register_framebuffer      err
[    0.168664] 注册 fb_info  over.
[    0.178790] fb_st77916: probe of spi1.0 failed with error -22
**这是我的启动日志:可以看到我的fbtft-core.此文件已经执行了,去注册framebuffer,最终生成fb0(怎么感觉还行是spi1.0啊)
[ 0.168646] /soc@03000000/spi@04026000/st77916@0: arguments longer than p
roperty
[ 0.168657] fb_st77916 spi1.0: failed to get 'reset-gpios' from DT这两行是日志报的错误,其他一下是我printk打印判断是什么引起的错误(还没找到)
最终我判断应该是我设备树://dc-gpios = <&pio 3 6 GPIO_ACTIVE_HIGH>;
reset-gpios的参数错了(AI也是这样说的)**
参考 https://whycan.com/t_6477.html#p63255
你这不是gpios设备树参数太多咩。报错了呗, 你用的sdk应该和他们用的不同,具体gpios的配置情况可以参考已有的例子,如果没有的话可以找下
Documentation\devicetree\bindings 下面对设备树描述的txt看例子怎么使用设备树。就拿贴子上晕哥说的那个buildroot-tiny200 这个的来说,你看你这句
gpios = <&pio 5 5 GPIO_ACTIVE_LOW>; 你这个应该就是这个sdk里面设备树写法。这个&pio中的pio你可以在suniv-f1c100s.dtsi这里找到pio的配置,其中就有compatible = "allwinner,suniv-f1c100s-pinctrl"这个。然后你在Documentation\devicetree\bindings这里面搜索"allwinner,suniv-f1c100s-pinctrl"你就可以打开allwinner,sunxi-pinctrl.txt。这里面就说明了每个参数是什么,并且有一个demo示例。不同的SDK是略有不同的。我知道的tina就不同。
**根据这个帖子,我是设备树里的gpios参数太多了,让我到Documentation\devicetree\bindings下面找到设备树参数说明,还有例程。
未通过find . -name "bindings"查找到“Documentation”这个文件夹大写的只有两个路径
./lichee/linux-4.9/modules/gpu/mali-midgard/kernel_mode/driver/Documentation/devicetree/bindings
在这个路径下有: bindings/arm/mali-midgard.txt
bindings/arm/memory_group_manager.txt
bindings/arm/smc-protected-mode-switcher.txt
bindings/power/mali-opp.txt
5个文件
./lichee/linux-4.9/modules/gpu/mali-bifrost/driver/Documentation/devicetree/bindings
3个文件
我都打开看了一下没有我需要的关于spi设备树配置的。是不是我找错了啊?
并且我在我 .dtsi文件下(设备树的)找到spi1: spi@04026000 {compatible = "allwinner,sun8i-spi"; ......}我用grep搜索一下allwinner,sun8i-spi并没有什么收获。**
楼主 #10 2024-10-12 16:44:45
sgyl
fbtft-core.c文件
static int fbtft_request_one_gpio(struct fbtft_par *par,
				  const char *name, int index, int *gpiop)
	struct device *dev = par->info->device;
	struct device_node *node = dev->of_node;
	int gpio, flags, ret = 0;
	enum of_gpio_flags of_flags;
	if (of_find_property(node, name, NULL)) {
		printk(KERN_INFO "of_find_property  11111111111  over.\n");
		gpio = of_get_named_gpio_flags(node, name, index, &of_flags);
		printk(KERN_INFO "of_get_named_gpio_flags  11111111111  over.\n");
		if (gpio == -ENOENT)
		if (gpio == -EPROBE_DEFER)
			return gpio;
		if (gpio < 0) {
			dev_err(dev,
				"failed to get '%s' from DT\n", name);
			return gpio;
現在我找到打印的位置了,
這一步打印了“OF: /soc@03000000/spi@04026000/st77916@0: arguments longer than property”
接着就执行到:if (gpio < 0) {
dev_err(dev,
return gpio;
但是我还是判断不了是什么引起的错误,难受。。。
希望大家帮我看一下,万分感谢。
#11 2024-10-12 17:26:40
lovexulu
已发帖子: 70
第一:按你所说,你并不了解设备树,也不理解设备树,但不妨碍照搬,我这里解释一下你的疑惑,设备树gpio的注册格式 是看linux内核版本的。原厂的sdk内核是4.9版本,因此需要“许多参数”,与原帖子里面是一样的并没有错误。linux4.9以后的版本gpio注册格式就是你写的这样的了。
第二:你能看到gpio注册错误的提示说明离正确驱动不远了。但是吧,我就不理解了你注释掉DC引脚的申请是为啥,spi屏如果没有了DC引脚怎么初始化呢?可能计算机也不能理解这个做法,因此报错了?还有 reset-gpios 等等 这些引脚的名字 其实是可以自己定义的,但是要跟驱动里面获取引脚信息的引脚名字定义相同。你要改名字 也要先找到 引用这些引脚的代码看一下定义的名字。只要名字统一 就可以正确使用。但不建议修改代码中定义的名字。
note:原帖中的修改是可行的,除非你没有按照原帖做以至于没有fb0,最好先打通通路,再说修改,别路不通就改,还不知道为啥改。
#12 2024-10-12 17:33:46
lovexulu
已发帖子: 70
噢 还有一件事!必须关闭uboot的disp2 否则你调到天荒地老也不行。
楼主 #13 2024-10-12 20:02:51
sgyl
首先我通过cboot跳转到uboot下,在make menuconfig 关闭了 Device Drivers --->
[ ] DISP Driver Support(sunxi-disp2) ----
tina-fastboot-v85x/lichee/brandy-2.0/u-boot-2018/configs/sun8iw21p1_fastboot_defconfig(这是我找到的uboot的配置文件)把#CONFIG_DISP2_SUNXI=y(注销了,或者说处于“#”注销下),这应该就是把uboot下的disp2关闭了吧。
[color]在fbtft-core.c文件的fbtft_request_gpios_dt函数下有匹配的名字(有一些列这个函数fbtft_request_one_gpio(par, "reset-gpios", 0, &par->gpio.reset);)"reset-gpios","dc-gpios","cs-gpios","wr-gpios"等等[/color]
[color]我把"dc-gpios"注销掉是因为我的原理图里面没有dc功能的,比较特殊的是有一个LCD_TE,接的是PD7,应该是cs1;其他就是rst;clk;hold;wp;miso;mosi;cs0;pwm10[/color]
情况1:
          我配置成这样reset-gpios = <&pio PD 8 1 1 2 1>;
我的终端(xshell)最终打印[    1.007643] Function entered at [<c013bed1>] from [<c2843b38>]
                       [    1.014185] Code: bad PC value
                       [    1.017607] ---[ end trace 1c5cdc983d9f73cb ]---
                       [    1.022782] Fixing recursive fault but reboot is needed!
然后就死了。
情况2:
我配置成这样dc-gpios = <&pio  3 6 GPIO_ACTIVE_HIGH>; (帖子里我猜他把wp那个引脚配置成dc了,所以我也是,PD6)
我的终端(xshell)(dmesg | less)日志打印OF: /soc@03000000/spi@04026000/st77916@0: arguments longer than property    和   fb_st77916 spi1.0: failed to get 'reset-gpios' from DT
我这边基本已经和那个帖子里的内容保持一致了,因为硬件不同,有一些差异。
有两个大的差异就是1:我的是reset-gpios = <&pio 3 8 GPIO_ACTIVE_HIGH>;
他的是reset-gpios = <&pio PD 4 1 1 2 1>;
2:他的是struct gpio_config gpio_of_flags;其他的是根据这个结构体改的。
我的fbtft-core.c没改,因为我把enum of_gpio_flags of_flags;改成struct gpio_config gpio_of_flags;后,在make就报错找不到struct gpio_config gpio_of_flags,我跳转到gpio_config 的定义下,在/tina-fastboot-v85x--danmuok/lichee/linux-4.9/drivers/media/dvb-frontends/tda1004x.h这个文件下。
我现在也有点迷茫了。。。
楼主 #14 2024-10-12 20:05:36
sgyl
希望lovexulu再帮小弟看一下,非常感谢。麻烦你了。
#15 2024-10-12 21:48:57
lovexulu
已发帖子: 70
那个帖子就是我发的。。。是晕哥喊我来帮你解决这个问题。首先你对spi屏了解稍微有点欠缺,dc引脚是必不可少的,我当时帖子里使用wp是因为当时那一组spi引脚是分配给spi nand的。改用屏的时候就没有改名字。wp确实就是dc脚,spi屏与nand不同,不能缺少dc引脚,除非你是使用9bit模式驱动,但这更复杂,因此 你还是配置dc引脚,厂家给的手册上会写rs等等,你仔细查看手册,控制写入命令/数据的那个脚就是dc脚,没有是无法初始化屏的,初始化进程必须检测有没有这些硬件,如果没有就会返回报错,报错位置大概率是gpio问题!te引脚是个好东西,但是它不是必须的 它是处理撕裂问题的最佳选手。因此 可以不配置te引脚,cs引脚 也不是必须的,它可以在屏端直接对地10K电阻 保持活动状态,但spi引脚注册必须有cs引脚 因此 这个脚必须注册 用不用就看你了。reset-gpios = <&pio PD 4 1 1 2 1> 采用这种写法是正确的,不用考虑。还有就是 你想生成fb0 事实上 跟你接不接屏没多大关系,只要代码中 设备树中描述完整且正确 就会有fb0 因此 你可以先完全抛开 屏的实际硬件,先将设备树关于硬件描述的部分补全,驱动随便指向一个 st7789 之类的驱动程序 ,生成了fb0 代表显示通路已经打通,下一步就是 配置硬件实际连接,保证硬件无误后,就是测试驱动代码的下发。。即修改驱动程序代码。添加debug打印。这部分就很好做了。
总结就是 你想驱动spi屏,需要整理清楚步骤,逐步进行,不可能一步到位。尤其是缺乏基本概念常识情况下,还希望你能按部就班,一步一步来。
楼主 #16 2024-10-16 14:01:41
sgyl
**https://bbs.aw-ol.com/topic/4829/%E5%85%A8%E5%BF%97v851s%E4%BD%BF%E7%94%A8fbtft%E9%A9%B1%E5%8A%A80-96%E5%AF%B8st7735%E5%B1%8F%E5%88%86%E4%BA%AB?_=1728520828826
根据这个帖子配置好后。**
我设备树这边修改了一下
                dc-gpios = <&pio PD 5 1 1 2 0>;
		//reset-gpios = <&pio PD 8 1 1 2 1>;
		led-gpios = <&pio PD 20 1 1 2 1>;
就是把reset-gpios给注销了,然后就生成fb0了。
v851s—datasheet
Function6
(PD1)SP11_CS0/DBI_CSX
(PD2)SPI1_CLK/DBI_SCLK
(PD3)SPI1_MOSI/DBI_SDO
(PD4)SP11_MISO/DBI_SDI/DBI_TE/DBI_ DCX
(PD5)SPI1_HOLD/DBI_DCX/DBI_WRX
(PD6)SPI1_WP/DBI_TE
(PD7)SP11_CS1
因为我的reset引脚连接的是PD8,通过原理图可以看到PD8并没有spi功能,所以我猜测是我配置的reset-gpio溢出了。
还有一点不明的是就是dc引脚,虽然我从我的原理图上没找到dc引脚,但是我从v851s—datasheet上也没找到,但是他支持dc引脚,就应该有spi1_dc吧,没办法,所以我参考的dbi_dcx,配置的PD5。暂时先不管它了,有fb0了就先继续往下吧。
最后很感谢晕哥和lovexulu给予的帮助,好人一生平安
#17 2024-10-16 15:16:01
ubuntu
已发帖子: 342
如果初始化的时候是9bit,那么d/c切换是在spi数据里面。
楼主 #18 2024-10-17 20:40:22
sgyl
当前情况:fb0已经生成,运行lvgl的官方例程lv_examples可以运行,最终停在while(),但是屏幕不亮,一直都不亮(屏幕是好的),我添加的屏驱(fb_st77916)也运行了,3个回调函数都运行了。初步猜测是屏驱初始化有问题,设备树有问题。
我有一份应用层屏驱可以点亮屏幕,它点屏只需要两步:
第一步:复位
         这是复位代码:       void lcd_st77916_reset(void)
                                             system("echo PD8 1 > /sys/kernel/debug/sunxi_pinctrl/function");
                                             system("echo PD8 0 > /sys/kernel/debug/sunxi_pinctrl/data");
                                             usleep(10);
                                             system("echo PD8 1 > /sys/kernel/debug/sunxi_pinctrl/data");
第二步:屏幕初始化
         前提条件:fd = open(“/dev/spidev1.0”, O_RDWR);
                     struct   qspi_lcd_cmd {
                                           uint8_t a ;
                                           uint8_t b ;
                                           uint8_t cmd;
                                           uint8_t c ;
                                           uint8_t param[16];
                   struct   qspi_lcd_cmd   cmd_tbl[] = {
                                                {0x02,0x00,0xf0,0x00,{0x08}},
                                                {0x02,0x00,0xf2,0x00,{0x08}},
                                                {0x02,0x00,0x9B,0x00,{0x51,0x33,0x44,0x55}},
         执行代码:for (int i = 0; i < sizeof(cmd_tbl) / sizeof(struct qspi_lcd_cmd); i++)
                      _transfer(fd, cmd_tbl[i],  NULL, strlen(cmd_tbl[i]))
                      (就是把初始化命令和数据,一次发一行)
         这是部分代码:  static int _transfer(int fd, uint8_t const *tx, uint8_t const *rx, size_t len)
                                   int ret;
                                   int out_fd;
                                   struct spi_ioc_transfer tr = {
                                                .tx_buf = (unsigned long)tx,
                                                .rx_buf = (unsigned long)rx,
                                                .len = len,
                                                .delay_usecs = 0,
                                                .speed_hz = SPI_SPEED,
                                                .bits_per_word = 8,
                                                .tx_nbits = 1,
                                                .rx_nbits = 1
                                     ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);(这个不懂,我猜它是发送的函数,在其他地方看过一次)
                                     if (ret < 1)
                                                 pabort("can't send spi message");
                                                 return -EIO;
现在在fbtft的屏驱:
static int init_display(struct fbtft_par *par)
    printk(KERN_INFO "屏幕初始化 started.\n");
    mdelay(10);
    write_reg(par,0xF0,0x08);(这是最初这样的)
    write_reg(par,0xF2,0x08);(这是最初这样的)
    write_reg(par,0x02,0x00,0xF0,0x00,0x08);(这是我根据最初和我的情况改的)
    write_reg(par,0x02,0x00,0xF2,0x00,0x08);
}(write_reg有3个参数,par,sizeof(0x02,0x00,0xF0,0x00,0x08)/u8 , (0x02,0x00,0xF0,0x00,0x08) 这里经过宏定义,可变变量,变成了两个参数)
static int set_var(struct fbtft_par *par)
	u8 madctl_par = 0;
	if (par->bgr)
		madctl_par |= MADCTL_BGR;
	switch (par->info->var.rotate) {
	case 0:
		break;
	case 90:
		madctl_par |= (MADCTL_MV | MADCTL_MY);
		break;
	case 180:
		madctl_par |= (MADCTL_MX | MADCTL_MY);
		break;
	case 270:
		madctl_par |= (MADCTL_MV | MADCTL_MX);
		break;
	default:
		return -EINVAL;
	write_reg(par, MIPI_DCS_SET_ADDRESS_MODE, madctl_par);
static int set_gamma(struct fbtft_par *par, unsigned long *curves)
	int i;
	int j;
	int c; /* curve index offset */
	const u8 gamma_par_mask[] = {
		0xFF, /* V63[3:0], V0[3:0]*/
		0x3F, /* V1[5:0] */
		0x3F, /* V2[5:0] */
		0x1F, /* V4[4:0] */
		0x1F, /* V6[4:0] */
		0x3F, /* J0[1:0], V13[3:0] */
		0x7F, /* V20[6:0] */
		0x77, /* V36[2:0], V27[2:0] */
		0x7F, /* V43[6:0] */
		0x3F, /* J1[1:0], V50[3:0] */
		0x1F, /* V57[4:0] */
		0x1F, /* V59[4:0] */
		0x3F, /* V61[5:0] */
		0x3F, /* V62[5:0] */
	for (i = 0; i < par->gamma.num_curves; i++) {
		c = i * par->gamma.num_values;
		for (j = 0; j < par->gamma.num_values; j++)
			curves[c + j] &= gamma_par_mask[j];
		write_reg(
			par, PVGAMCTRL + i,
			curves[c + 0], curves[c + 1], curves[c + 2],
			curves[c + 3], curves[c + 4], curves[c + 5],
			curves[c + 6], curves[c + 7], curves[c + 8],
			curves[c + 9], curves[c + 10], curves[c + 11],
			curves[c + 12], curves[c + 13]);
static int blank(struct fbtft_par *par, bool on)
	if (on)
		write_reg(par, MIPI_DCS_SET_DISPLAY_OFF);
		write_reg(par, MIPI_DCS_SET_DISPLAY_ON);
static struct fbtft_display display = {
	.regwidth = 4,
	.width = 360,
	.height = 360,
	.gamma_num = 2,
	.gamma_len = 14,
	.gamma = DEFAULT_GAMMA,
	.fbtftops = {
		.init_display = init_display,
		.set_var = set_var,
		.set_gamma = set_gamma,
		.blank = blank,
FBTFT_REGISTER_DRIVER(DRVNAME, "sitronix,st77916", &display);
MODULE_ALIAS("spi:" DRVNAME);
MODULE_ALIAS("platform:" DRVNAME);
MODULE_ALIAS("spi:st77916");
MODULE_ALIAS("platform:st77916");
MODULE_DESCRIPTION("FB driver for the st77916 LCD Controller");
MODULE_AUTHOR("Dennis Menschel");
MODULE_LICENSE("GPL");
现在我的需求是怎么把应用层屏驱改成fbtft的驱动层,但是我不会,难受。。。
设备树那边还在尝试。现在改过也不亮。
希望那个大佬帮我看一下,我改的对不对,有哪些需要注意的。
(其实我也想过把应用层驱动添加到库里,我就能直接用了,但是那样可直接在应用层好像没有太大区别,而且我的是fb0,应用层驱动那个是spidev1.0,所以放弃了,还得修改屏驱)
#19 2024-10-17 20:46:09
memory
已发帖子: 716
屏幕初始化正常吗?
cat /dev/urandom > /dev/fb0
有雪花吗?
楼主 #20 2024-10-18 09:38:22
sgyl
首先是:root@(none):/# cat /dev/urandom > /dev/fb0
cat: write error: No space left on device
这个不明白怎么会空间不足,那个空间不足也不知道。
其次是:现在屏幕是不亮的,全程都不亮,是背光的问题吧。
我的关于背光的配置(设备树)只有这一行:led-gpios = <&pio PD 20 1 1 2 0>;(led-gpios = <&pio PD 20 1 1 2 1>;也试过,不行)。根据硬件,vcc接集电级(三极管),PD20接基级,发射级接led_A(应该是共基极电路),pd20为低电位时,导通。
我先找一下背光函数,看有没有执行。(屏驱是执行了的)
#21 2024-10-18 20:55:01
lovexulu
已发帖子: 70
@sgyl
没有reset 你依然无法正确初始化屏!因为一上电 有可能数据引脚上有杂波 cs脚也不确定,因此第一个数据位可能已经发送,后续所有初始化数据都是错误的。即使你的驱动代码正确,也无法正确初始化。因此 初始化代码执行之前必须reset 并延迟120MS。。
