楼主 #1 2019-06-27 16:29:08
已发帖子: 1,438
nuc972移植qt,遇到了一些问题。
官方sdk里的application文件夹下有qt和tslib文件夹。
查看bsp使用手册,tslib没有介绍如何使用,网上搜了下,依次执行:
./autogen-clean.sh
./autogen.sh
./configure --host=arm-linux ac_cv_func_malloc_0_nonnull=yes --cache-file=arm-linux-.cache --prefix=/usr/local/tslib/ make sudo make install(忘了当时用的什么,从网上找了一个)
然后在/usr/local/tslib下生成了tslib文件。
bsp使用手册有qt移植的介绍:
指定 QMAKE_INCDIR 及 QMAKE_LIBDIR,如下:
QMAKE_INCDIR = path to /tslib-1.1/install/include (我改成了usr/loca/tslib/include)
QMAKE_LIBDIR = path to /tslib-1.1/install/lib (我改成了usr/loca/tslib/lib)
然后执行:
$ export MY_CC_QT4_PREFIX=/usr/local/Trolltech/QtEmbedded-4.8.5 (指定qt安装路径)
./configure -prefix ${MY_CC_QT4_PREFIX} -release -opensource -static -qconfig dist -no-exceptions -no-accessibility -no-stl -no-qt3support -no-xmlpatterns -no-multimedia -no-audio-backend -no-phonon -no-phonon-backend -no-svg -no-webkit -no-javascript-jit -no-script -no-scripttools -no-declarative -no-declarative-debug -qt-zlib -qt-freetype -no-gif -qt-libpng -no-libmng -no-libtiff -qt-libjpeg -no-openssl -nomake tools -nomake demos -nomake examples -nomake docs -nomake translations -no-nis -no-cups -no-iconv -no-pch -no-dbus -embedded arm -platform qws/linux-x86-g++ -xplatform qws/linux-nuc970-g++ -no-gtkstyle -no-nas-sound -no-opengl -no-openvg -no-sm -no-xshape -no-xvideo -no-xsync -no-xinerama -no-xcursor -no-xfixes -no-xrandr -no-xrender -no-mitshm -no-fontconfig -no-xinput -no-xkb -no-glib -qt-gfx-linuxfb -qt-mouse-tslib -qt-kbd-linuxinput
结果:
You have not explicitly asked to use pkg-config and are cross-compiling.
pkg-config will not be used to automatically query cflag/lib parameters for
dependencies
The tslib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR and QMAKE_LIBDIR in
/home/any/nuc970bsp/applications/qt-everywhere-opensource-src-4.8.5/mkspecs/qws/linux-nuc970-g++.
查了下说是如有有安装pkg-config,在.configure 后面加-force-pkg-config参数,查了下which pkg-config,机子上有,于是就加后边那个参数。
结果:
You have asked to use pkg-config and are cross-compiling.
Please make sure you have a correctly set-up pkg-config
environment!
Warning: PKG_CONFIG_PATH has not been set. This could mean
the host compiler's .pc files will be used. This is probably
not what you want.
楼主 #2 2019-06-27 16:52:19
已发帖子: 1,438
Re: nuc972移植qt,遇到了一些问题。
以上暂时算是三个问题。
1总有pkg-config这个提示。
加了-force后又来了新的警告。
2.The tslib functionality test failed.
搜了下,先排除qmake.conf的问题,我已经设了。网上有用.configrue时加上-verbose选项,可以看到详细信息。发现:
make: arm-linux-g++: Command not found
我用的是bsp里的安装脚本安装的,自动安装了交叉编译器,arm-linux-gcc好像是个软连接,连接到了arm-nuvoton-linux-uclibceab-gcc。
3.无论前两个问题是否解决,执行make和make install后,Qt-4.8.5文件夹出现在了usr/local/Trolltech目录下。
而我之前指定的是:
最近编辑记录 Gentlepig (2019-06-27 17:01:31)
#3 2019-06-27 17:03:01
这些问题用上了 buildroot 都不是问题,本站可以搜索 buildroot
楼主 #4 2019-06-27 17:10:09
已发帖子: 1,438
以下是qmake.conf文件内容:
1 #
2 # qmake configuration for building with arm-linux-g++
3 #
4
5 include(../../common/linux.conf)
6 include(../../common/gcc-base-unix.conf)
7 include(../../common/g++-unix.conf)
8 include(../../common/qws.conf)
9
10 # modifications to g++.conf
11 QMAKE_CC = arm-linux-gcc
12 QMAKE_CXX = arm-linux-g++
13 QMAKE_LINK = arm-linux-g++
14 QMAKE_LINK_SHLIB = arm-linux-g++
15
16 # modifications to linux.conf
17 QMAKE_AR = arm-linux-ar cqs
18 QMAKE_OBJCOPY = arm-linux-objcopy
19 QMAKE_STRIP = arm-linux-strip
20
21 load(qt_config)
我把
QMAKE_CC = arm-linux-gcc 改成/usr/local/arm-Linux-4.8/bin/arm-Linux-gcc
以下三行同理,结果仍提示arm-Linux-g++命令未找到。
最近编辑记录 Gentlepig (2019-06-27 17:38:17)
楼主 #5 2019-06-27 17:12:24
已发帖子: 1,438
想找些解决办法,涨点经验。
#6 2019-06-27 17:34:05
这个阔以有,感谢分享!
楼主 #7 2019-06-27 17:44:54
已发帖子: 1,438
这个阔以有,感谢分享!
不是来分享的,是来求助的...
楼主 #8 2019-06-28 10:56:23
已发帖子: 1,438
搜了搜,感觉像是没有指定编译器路径的问题。
那么,如何指定编译器路径?在执行./configure时加-CC=/usr/local/arm_linux_4.8,这样?
另,交叉编译器是执行sdk里的install.sh脚本时,自动安装的。
安装的路径是/usr/local/arm_linux_4.8,使用的是arm-linux-gcc,这个好像是个软连接。我如何知道他的实际路径呢?
$ arm-linux-gcc -v
使用内建 specs。
COLLECT_GCC=arm-linux-gcc
COLLECT_LTO_WRAPPER=/usr/local/arm_linux_4.8/libexec/gcc/arm-nuvoton-linux-uclibceabi/4.8.4/lto-wrapper
目标:arm-nuvoton-linux-uclibceabi
配置为:../configure --prefix=/usr/local/arm_linux_4.8 --target=arm-nuvoton-linux-uclibceabi --enable-static --disable-__cxa_atexit --with-gnu-ld --disable-libssp --disable-multilib --enable-target-optspace --disable-libsanitizer --enable-tls --disable-libmudflap --enable-threads --without-isl --without-cloog --with-float=soft --disable-decimal-float --with-abi=aapcs-linux --with-cpu=arm926ej-s --with-float=soft --with-mode=arm --enable-languages=c,c++ --enable-poison-system-directories --enable-shared --disable-libgomp --with-sysroot=/usr/local/arm_linux_4.8 --with-build-time-tools=/usr/local/arm_linux_4.8/arm-nuvoton-linux-uclibceabi/bin --enable-shared
线程模型:posix
gcc 版本 4.8.4 (GCC)
楼主 #9 2019-06-28 12:20:35
已发帖子: 1,438
qmake.conf文件中,编译器需要指定完整路径。
指定完完整路径后还是不行,/usr/loca/arm_linux_4.8/bin/arm-linux-gcc/g++是个软连接,换成实际指向的文件。
终于配置成功了,可以make了。
楼主 #10 2019-06-29 16:38:33
已发帖子: 1,438
QT例程在宿主机上编译后复制到开发板,执行后没报错,买的屏幕还没到,不知道成功没。
但是在开发板上执行qmake -v,却提示找不到qmake,可在开发板的/usr/local/bin里明明有qmake啊。
同样的还有Python2.7,按教程交叉编译好后,将生成的bin, lib, include三个文件夹,移动到开发板的/usr/下。
结果在目标板上运行输入python,结果却没反应。
已在/etc/profile里设了qt和python的路径。
export LD_LIBRARY_PATH=/lib:/mnt/mmcblk0p2 /mnt/mmcblk0p1/scan_zbar
export PYTHONPATH=/usr/lib/python2.7:$PYTHONPATH
export PYTHONHOME=/usr/lib/python2.7:$PYTHONHOME
export QWS_MOUSE_PROTO=Tslib:/dev/input/event0
export QTEDIR=/usr/local/Trolltech/QtEmbedded-4.8.5
export LD_LIBRARY_PATH=$QTEDIR/lib:$LD_LIBRARY_PATH
export QT_QPA_GENERIC_PLUGINS=tslib
export QT_QPA_FONTDIR=$QTEDIR/lib/fonts
export QT_QPA_PLATFORM=linuxfb:fb=/dev/fb0:size=800x480:mmSize=800x480:offset=0x
export QT_QPA_FB_TSLIB=1
export PATH=$QTEDIR/bin:$PATH
最近编辑记录 Gentlepig (2019-06-29 16:59:23)
楼主 #11 2019-06-29 17:09:03
已发帖子: 1,438
972的bsp里的根文件系统的/etc/profile,里面原来只有两行,后面的都是我加的。
原来的两行是:
1 export LD_LIBRARY_PATH=/lib:/mnt/mmcblk0p2
很好奇,这两行是不是应该合成一行? 第二行没有命令语句吧?
这个,网友解释了下,说第二行是执行scan_zbar这个脚本。
最近编辑记录 Gentlepig (2019-06-29 17:11:50)
#12 2019-06-29 17:11:47
原来的两行是:
第1行是设置全局环境变量,
如果合并到一行就是这样:
估计第2行的 scan_zbar 动态加载了 so 文件,
而 so 文件在 /mnt/mmcblk0p1/ 目录
最近编辑记录 smartcar (2019-06-29 17:12:58)
楼主 #13 2019-06-29 17:16:42
已发帖子: 1,438
smartcar wrote:
原来的两行是:
第1行是设置全局环境变量,
如果合并到一行就是这样:
谢谢,上一个问题,能否解答下?
#14 2019-06-29 17:20:57
你生成的 qmake 是在 这里吗: /usr/local/arm_linux_4.8/bin/qmake ?
楼主 #15 2019-06-29 17:24:08
已发帖子: 1,438
/usr/local/Trolltech/QtEmbedded-4.8.5/bin
在宿主机上交叉编译生成的是/usr/local/Trolltech/QtEmbedded-4.8.5目录,然后将这个目录移到了目标机的相同位置。
而qmake命令在该目录的bin目录下。
echo $PATH
/usr/local/Trolltech/QtEmbedded-4.8.5/bin:/sbin:/usr/sbin:/bin:/usr/bin
最近编辑记录 Gentlepig (2019-06-29 17:25:21)
#16 2019-06-29 17:32:55
/usr/local/Trolltech/QtEmbedded-4.8.5/bin/qmake 执行不了, 对吗?
楼主 #17 2019-06-29 17:35:12
已发帖子: 1,438
执行不了:
/usr/local/Trolltech/QtEmbedded-4.8.5/bin # ./qmake -v
-/bin/sh: ./qmake: not found
#18 2019-06-29 17:56:10
文件存在,但是执行不了对吧?
执行 file qmake 命令,看看是不是arm目标平台?如果是就跑不了,要到arm系统才可以跑
楼主 #19 2019-06-29 18:38:34
已发帖子: 1,438
文件存在,但是执行不了对吧?
就是在目标板nuc972上运行报错,目标板的根文件系统没有file这个指令。
#20 2019-06-29 21:46:17
Gentlepig wrote:
文件存在,但是执行不了对吧?
你上面编译的 qmake 不能在 arm linux 跑, 只能在x86 linux 跑.
qmake 的作用是用来生成 Makefile 的, 你在 arm linux 版本跑没有意义.
楼主 #21 2019-06-29 22:24:50
已发帖子: 1,438
Gentlepig wrote:
文件存在,但是执行不了对吧?
谢啦,大概明白了。
楼主 #22 2019-07-02 09:36:49
已发帖子: 1,438
又遇到了问题,移植pythono和qt的根文件系统打包成yaffs文件系统,大小为130M多。下载到目标板,可以执行qt的例程程序。
后来又做了些改动,然后又新建了个qt工程编译后将生成的可执行文件移到根文件系统里,再打包,发现有150M多了。
然后下载到目标板,执行qt程序,报错。然后发现目标板的qt文件目录里只有个bin文件夹,应该还有include,lib,plugins,mkspecs四个文件夹才对。
以为是在linux下烧录的问题,于是又切到win下用nu-writer烧录,结构目标板的qt目录下是空的了...
楼主 #23 2019-07-04 11:47:54
已发帖子: 1,438
之所以看到qt目录下是空的,原因是上级目录下有两个qt目录,一个是最后烧写进去的,里面有相应目录。另一个是空的。
该问题,通过擦除nand flash解决。
不过,难道每次烧写文件系统镜像都要先擦除吗?
最近编辑记录 Gentlepig (2019-07-04 11:49:36)
楼主 #24 2019-07-20 16:28:37
已发帖子: 1,438
这几天又遇到了些问题,有的解决了,在这里记录下来吧。
qt4的程序加-qws后缀可运行,qt5的加-platform linuxfb可运行。而且,好像可以开机后export QT_QPA_PLATFORM一次设置。
qt5程序编译时,.pro文件需要加QT += widgets.
qt不显示中文字体,可从网上下个字体,存到/usr/share/fonts下(我是用buildroot建的带qt5的文件系统,自己没有设qt相关路径,如果是自己移植的qt,路径可能不是这个)。
qt显示的字体太小,一开始我试着执行程序时指定大字体,效果只是大了一点。后来我搜到这个https://blog.csdn.net/u013968786/article/details/51119588
我的是qt5,于是加了export QT_QPA_PLATFORM=linuxfb:fb=/dev/fb0:size=800x480:mmsize=250x150:offse
t=0x0,问题解决。
#25 2019-07-20 17:05:03
感谢楼主分享!
楼主 #26 2019-07-20 17:38:06
已发帖子: 1,438
感谢楼主分享!
请教个问题:
这句,我建了个qt.sh脚本,指定用#!/bin/sh打开,里面就上边这句。然后在/etc/init.d/rcS的最后加一句,sh .../qt.sh,结果没效果。
于是,我干脆把这句加到/etc/init.d/rcS的最后,结果还是没效果。
我在这句export后面,加了句echo $QT_QPA_PLATFORM,重启后,显示运行了这部分,echo显示的也是正确的。但是,我再手动echo $QT_QPA_PLATFORM,则输出的是空的。好像是,加的这句,只在/etc/init.d/rcS执行的时候有效,rcS执行完了,也就无效了?
最后,加到/etc/profile的最后,有效果。
请教,这是为什么?
#27 2019-07-20 18:46:11
在 init.d 里面执行应该是没有应用Qt环境变量的,所以不能跑,即使跑起来也不属于任何终端,不能用 ctrl + c 中断可执行程序执行。
以上是猜想
