楼主 #1 2019-09-12 11:03:52
zero
已发帖子: 33
v3s zero mount: you must be root
大家有遇到这个问题的吗
[    0.892526] vcc5v0: disabling
[    0.895503] ALSA device list:
[    0.898536]   #0: V3s Audio Codec
[    0.904860] random: fast init done
[    0.945960] random: crng init done
[    3.262277] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    3.269263] devtmpfs: mounted
[    3.273408] Freeing unused kernel memory: 1024K
mkdir: can't create directory '/dev/pts': Permission denied
mkdir: can't create directory '/dev/shm': Permission denied
hostname: sethostname: Operation not permitted
Starting logging: OK
[    4.878819] ------------[ cut here ]------------
[    4.883482] WARNING: CPU: 0 PID: 77 at drivers/mtd/spi-nor/spi-nor.c:1182 sp4
[    4.892651] Writing at offset 76 into a NOR page. Writing partial pages may .
[    4.892657] Modules linked in:
[    4.907309] CPU: 0 PID: 77 Comm: start-stop-daem Not tainted 4.10.15-licheep6
[    4.915126] Hardware name: Allwinner sun8i Family
[    4.919855] [<c010e3bc>] (unwind_backtrace) from [<c010b158>] (show_stack+0x)
[    4.927596] [<c010b158>] (show_stack) from [<c0346864>] (dump_stack+0x84/0x9)
[    4.934813] [<c0346864>] (dump_stack) from [<c011b834>] (__warn+0xe8/0x100)
[    4.941768] [<c011b834>] (__warn) from [<c011b884>] (warn_slowpath_fmt+0x38/)
[    4.949246] [<c011b884>] (warn_slowpath_fmt) from [<c04548a0>] (spi_nor_writ)
[    4.957504] [<c04548a0>] (spi_nor_write) from [<c044b6f4>] (mtd_writev+0xa4/)
[    4.964986] [<c044b6f4>] (mtd_writev) from [<c02fc160>] (jffs2_flash_writev+)
[    4.973072] [<c02fc160>] (jffs2_flash_writev) from [<c02f4fe0>] (jffs2_write)
[    4.981677] [<c02f4fe0>] (jffs2_write_dnode) from [<c02f58f8>] (jffs2_do_cre)
[    4.990020] [<c02f58f8>] (jffs2_do_create) from [<c02eff74>] (jffs2_create+0)
[    4.997932] [<c02eff74>] (jffs2_create) from [<c01ff398>] (path_openat+0x9f4)
[    5.005584] [<c01ff398>] (path_openat) from [<c0200b40>] (do_filp_open+0x60/)
[    5.013062] [<c0200b40>] (do_filp_open) from [<c01eff1c>] (do_sys_open+0x110)
[    5.020713] [<c01eff1c>] (do_sys_open) from [<c0107640>] (ret_fast_syscall+0)
[    5.028508] ---[ end trace 52c20a801dd1be51 ]---
Starting network: ip: RTNETLINK answers: Operation not permitted
ip: SIOCSIFFLAGS: Operation not permitted
FAIL
can't open /dev/console: Permission denied
#2 2019-09-12 11:18:42
jimmy
已发帖子: 316
Re: v3s zero mount: you must be root
一般是 jffs2 镜像地址不对,或者没有烧录完整,或者文件本来就有问题导致的
楼主 #3 2019-09-12 11:29:53
zero
已发帖子: 33
我刚刚替换了jff2,可以正常启动,但是按照教程编译rootfs就出现上边的问题
#4 2019-09-12 11:30:39
我思故我在
已发帖子: 244
对教程理解有误吧, 换个教程吧: https://whycan.cn/t_2179.html
#5 2019-09-12 11:43:25
晕哥小弟
已发帖子: 311
看来还有不少人在玩v3s.
楼主 #6 2019-09-12 11:48:04
zero
已发帖子: 33
就是这个教程,目前看是权限的问题,不知道如何解决
#7 2019-09-12 13:56:45
我思故我在
已发帖子: 244
根文件系统是 buildroot 产生的吗?
楼主 #8 2019-09-12 15:22:02
zero
已发帖子: 33
是的,使用buildroot
#9 2019-09-12 15:53:16
已发帖子: 9,486
  1. mkfs.jffs2 指令是什么
  2. 把flash读回来,和写入的比较,看是否一致
楼主 #10 2019-09-12 16:01:08
zero
已发帖子: 33
mkfs.jffs2 -s 0x100 -e 0x10000 -p 0xAF0000 -d rootfs/ -o jffs2.img
我读回来看一下
#11 2019-09-12 16:12:47
已发帖子: 9,486
命令没什么问题,要看你给 jffs2分配的地址及大小,与你烧写地址及大小是否匹配。
楼主 #12 2019-09-12 17:47:38
zero
已发帖子: 33
[    4.923685] ------------[ cut here ]------------
[    4.928466] WARNING: CPU: 0 PID: 81 at drivers/mtd/spi-nor/spi-nor.c:1182 sp4
[    4.937543] Writing at offset 112 into a NOR page. Writing partial pages may.
[    4.937546] Modules linked in:
[    4.952252] CPU: 0 PID: 81 Comm: touch Not tainted 4.10.15-licheepi-zero #8
[    4.959200] Hardware name: Allwinner sun8i Family
[    4.963931] [<c010e3bc>] (unwind_backtrace) from [<c010b158>] (show_stack+0x)
[    4.971673] [<c010b158>] (show_stack) from [<c0346864>] (dump_stack+0x84/0x9)
[    4.978891] [<c0346864>] (dump_stack) from [<c011b834>] (__warn+0xe8/0x100)
[    4.985846] [<c011b834>] (__warn) from [<c011b884>] (warn_slowpath_fmt+0x38/)
[    4.993324] [<c011b884>] (warn_slowpath_fmt) from [<c04548a0>] (spi_nor_writ)
[    5.001582] [<c04548a0>] (spi_nor_write) from [<c044b6f4>] (mtd_writev+0xa4/)
[    5.009065] [<c044b6f4>] (mtd_writev) from [<c02fc160>] (jffs2_flash_writev+)
[    5.017151] [<c02fc160>] (jffs2_flash_writev) from [<c02f4fe0>] (jffs2_write)
[    5.025755] [<c02f4fe0>] (jffs2_write_dnode) from [<c02f58f8>] (jffs2_do_cre)
[    5.034099] [<c02f58f8>] (jffs2_do_create) from [<c02eff74>] (jffs2_create+0)
[    5.042010] [<c02eff74>] (jffs2_create) from [<c01ff398>] (path_openat+0x9f4)
[    5.049663] [<c01ff398>] (path_openat) from [<c0200b40>] (do_filp_open+0x60/)
[    5.057141] [<c0200b40>] (do_filp_open) from [<c01eff1c>] (do_sys_open+0x110)
[    5.064793] [<c01eff1c>] (do_sys_open) from [<c0107640>] (ret_fast_syscall+0)
[    5.072592] ---[ end trace 1b65f46d8a6fe49b ]---
Starting network: OK
Welcome to Buildroot
buildroot login: root
# ls
# cd /
# ls
bin      lib      media    proc     sbin     usr
dev      lib32    mnt      root     sys      var
etc      linuxrc  opt      run      tmp
# ls
# cd
楼主 #13 2019-09-12 17:51:18
zero
已发帖子: 33
w25q128 去掉了SECT_4K,用脚本生成的镜像,命令行生成的一直没成功,不知道问什么
楼主 #14 2019-09-12 17:59:06
zero
已发帖子: 33
fs.zip
里面有镜像和脚本
#15 2019-09-12 18:01:21
shaoxi2010
已发帖子: 399
权限问题,实在不行chmod +s busybox走一转就好了
