楼主 #1 2019-09-29 22:45:29
已发帖子: 9,486
感谢 @小智科技 赠送的 TF卡 AP6212 WIFI 模组
购买地址: 还没上架
楼主 #2 2019-09-29 22:46:07
已发帖子: 9,486
Re: 感谢 @小智科技 赠送的 TF卡 AP6212 WIFI 模组
#3 2019-10-05 13:04:46
ippen
已发帖子: 345
晕哥怎么总是发东西引诱大伙呢
#4 2019-10-06 19:31:45
演技担当黄晓明
已发帖子: 189
留图不留种
楼主 #5 2019-10-09 17:08:28
已发帖子: 9,486
# ping www.163.com
PING www.163.com (183.47.233.12): 56 data bytes
64 bytes from 183.47.233.12: seq=0 ttl=47 time=42.783 ms
64 bytes from 183.47.233.12: seq=1 ttl=46 time=47.374 ms
64 bytes from 183.47.233.12: seq=2 ttl=47 time=45.310 ms
64 bytes from 183.47.233.12: seq=3 ttl=46 time=58.623 ms
64 bytes from 183.47.233.12: seq=4 ttl=46 time=51.602 ms
[   25.798286] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
[   25.806257] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   25.812528] sunxi-mmc 1c10000.mmc: send stop command failed
[   25.818882] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
[   25.831074] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
[   25.843893] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   25.855605] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   25.867632] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   25.879965] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   25.892604] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   25.904928] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   26.798518] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
[   26.806480] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   26.812753] sunxi-mmc 1c10000.mmc: send stop command failed
[   26.819020] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
[   26.831204] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
[   26.844023] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   26.856414] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   26.868714] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   26.881046] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   26.893678] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   26.905579] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   27.798723] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
[   27.806688] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   27.812960] sunxi-mmc 1c10000.mmc: send stop command failed
[   27.819195] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
[   27.831384] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
[   27.844183] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   27.856577] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   27.868875] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   27.881207] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
[   27.893841] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
[   27.905578] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
貌似一个关于休眠/复位的错误, https://lore.kernel.org/patchwork/patch/1035997/
因为 TF 座上面没有多余的IO口,所以复位/休眠相关 IO 全部直接硬 上/下拉了。
#6 2019-10-10 08:18:48
在什么板子上跑的?通了?
楼主 #7 2019-10-10 10:53:04
已发帖子: 9,486
迪卡 wrote:
在什么板子上跑的?通了?
V3s, 现在还有问题。
#8 2019-10-10 11:51:29
szchen2006
已发帖子: 216
期待……
#9 2019-10-15 23:09:42
t123yh
https://whycan.cn/t_2522.html
看这个帖子的话应该是需要连接 Reset 脚的。
#10 2019-11-04 13:39:19
804715358@qq.com
已发帖子: 19
大佬,这个板子有没pcb或者淘宝成品最好,急用
#11 2019-11-04 13:44:39
804715358@qq.com
已发帖子: 19
或者晕哥转卖一个也行
购买地址: 还没上架
楼主 #12 2019-11-04 13:59:15
已发帖子: 9,486
前面驱动出了一点问题, 当时没办法判断是软件还是硬件问题。
后面家里搞了一下装修, 现在还不知道还能不能找到, 我回去找找。
#13 2019-11-04 18:50:51
804715358@qq.com
已发帖子: 19
晕哥,麻烦你了,好人一生平安。
#14 2019-11-04 21:38:01
小智科技
已发帖子: 92
804715358@qq.com wrote:
晕哥,麻烦你了,好人一生平安。
不稳定,等测试稳定后会开卖的。
#15 2019-11-21 23:28:13
john78
已发帖子: 223
搞定没,能分享些资料?
楼主 #16 2019-11-21 23:30:14
已发帖子: 9,486
可能是因为线太细, 电流不够引起.
后面空了我在飞线试一试.
资料你搜下本站 AP6212 帖子, 有很多的.我就是按照那个做的.
楼主 #17 2019-11-21 23:32:12
已发帖子: 9,486
#18 2019-11-22 09:05:37
john78
已发帖子: 223
make[1]: 正在进入目录 `/work/v3s/buildroot-2017.02.7/output/build/wpa_supplicant-2.6/wpa_supplicant'
../src/common/sae.o:在函数‘sae_cn_confirm.isra.2’中:
sae.c:(.text+0x168):对‘crypto_bignum_to_bin’未定义的引用
sae.c:(.text+0x198):对‘crypto_bignum_to_bin’未定义的引用
../src/common/sae.o:在函数‘sae_cn_confirm_ffc’中:
sae.c:(.text+0x214):对‘crypto_bignum_to_bin’未定义的引用
sae.c:(.text+0x22c):对‘crypto_bignum_to_bin’未定义的引用
../src/common/sae.o:在函数‘sae_cn_confirm_ecc’中:
sae.c:(.text+0x2a4):对‘crypto_ec_point_to_bin’未定义的引用
sae.c:(.text+0x2c0):对‘crypto_ec_point_to_bin’未定义的引用
../src/common/sae.o:在函数‘sae_derive_pwe_ecc’中:
sae.c:(.text+0x370):对‘crypto_bignum_to_bin’未定义的引用
sae.c:(.text+0x388):对‘crypto_ec_prime_len_bits’未定义的引用
sae.c:(.text+0x40c):对‘crypto_bignum_init_set’未定义的引用
sae.c:(.text+0x420):对‘crypto_bignum_legendre’未定义的引用
sae.c:(.text+0x464):对‘crypto_bignum_deinit’未定义的引用
sae.c:(.text+0x528):对‘crypto_ec_prime_len_bits’未定义的引用
sae.c:(.text+0x5c0):对‘crypto_bignum_init_set’未定义的引用
sae.c:(.text+0x5d8):对‘crypto_ec_point_compute_y_sqr’未定义的引用
sae.c:(.text+0x5f0):对‘crypto_bignum_deinit’未定义的引用
sae.c:(.text+0x600):对‘crypto_bignum_deinit’未定义的引用
sae.c:(.text+0x60c):对‘crypto_bignum_deinit’未定义的引用
sae.c:(.text+0x670):对‘crypto_bignum_init_set’未定义的引用
sae.c:(.text+0x67c):对‘crypto_bignum_is_zero’未定义的引用
sae.c:(.text+0x690):对‘crypto_bignum_deinit’未定义的引用
sae.c:(.text+0x6a4):对‘crypto_bignum_init’未定义的引用
这个是缺少什么?
楼主 #19 2019-11-22 09:19:58
已发帖子: 9,486
#20 2019-11-22 14:20:11
john78
已发帖子: 223
wpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -d
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant/'
ap_scan=1
Priority group 2
id=0 ssid='HiWiFi_12345678'
rfkill: Cannot get wiphy information
WEXT: RFKILL status not available
Could not read interface wlan0 flags: No such device
WEXT: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
还是没有搞定,坑多多
#21 2020-04-27 11:08:43
jambogo
请问那哪里可以买到呢?听说AP6212比较稳。
