楼主 #1 2019-12-09 15:28:55
psst
已发帖子: 92
v3s sd卡启动 怎么用PhoenixSuit进行烧写 ?
v3s 用的贴片的sd卡,第一次烧写能用PhoenixSuit吗?如果可以就省事很多了
#2 2019-12-09 15:37:38
已发帖子: 9,513
Re: v3s sd卡启动 怎么用PhoenixSuit进行烧写 ?
楼主 #3 2019-12-09 17:40:53
psst
已发帖子: 92
sd卡是空的,没有系统的条件下也能挂载成u盘吗?我试了,点bat文件闪退了
楼主 #4 2019-12-09 17:49:55
psst
已发帖子: 92
我去掉TF卡,板上 没有spi flash ,是不是上电就进入fel模式,
#5 2019-12-09 18:14:40
已发帖子: 9,513
你的 V3s 没有进usb fel 模式, 是不是 sd nand 里面有 u-boot ? 或者 驱动安装不成功:
https://whycan.cn/t_444.html
楼主 #6 2019-12-09 18:40:17
psst
已发帖子: 92
U-Boot 2019.04-00743-g7d99406 (Apr 26 2019 - 02:24:09 -0400) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   mmc@01c0f000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No working controllers found
(FEL boot)
## Loading init Ramdisk from Legacy Image at 41a00000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    10271913 Bytes = 9.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Loading Ramdisk to 42434000, end 42dffca9 ... OK
   Loading Device Tree to 4242e000, end 42433e4f ... OK
[    0.000000] Linux version 4.13.16-licheepi-zero+ (root@ubuntu) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1)) #15 SMP Wed May 1 09:22:33 EDT 2019
[    0.000000] percpu: Embedded 16 pages/cpu @c3fdf000 s33920 r8192 d23424 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk rw
[    0.000000] Memory: 45028K/65536K available (6144K kernel code, 236K rwdata, 1580K rodata, 1024K init, 253K bss, 20508K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a3b360   ( 237 kB)
[    0.000000]        .bss : 0xc0a42808 - 0xc0a81dcc   ( 254 kB)
[    0.000208] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000417] Console: colour dummy device 80x30
[    0.000450] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000466] pid_max: default: 32768 minimum: 301
[    0.000586] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000600] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001182] CPU: Testing write buffer coherency: ok
[    0.001544] /cpus/cpu@0 missing clock-frequency property
[    0.001569] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002006] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002181] Hierarchical SRCU implementation.
[    0.002662] smp: Bringing up secondary CPUs ...
[    0.002676] smp: Brought up 1 node, 1 CPU
[    0.002685] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002692] CPU: All CPU(s) started in HYP mode.
[    0.002696] CPU: Virtualization extensions available.
[    0.003435] devtmpfs: initialized
[    0.006447] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006734] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006761] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.006926] pinctrl core: initialized pinctrl subsystem
[    0.007760] random: get_random_u32 called from bucket_table_alloc+0xf0/0x250 with crng_init=0
[    0.007895] NET: Registered protocol family 16
[    0.008316] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009354] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009371] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021544] SCSI subsystem initialized
[    0.021821] usbcore: registered new interface driver usbfs
[    0.021888] usbcore: registered new interface driver hub
[    0.021981] usbcore: registered new device driver usb
[    0.022235] Linux video capture interface: v2.00
[    0.022278] pps_core: LinuxPPS API ver. 1 registered
[    0.022286] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.022309] PTP clock support registered
[    0.022518] Advanced Linux Sound Architecture Driver Initialized.
[    0.024309] clocksource: Switched to clocksource arch_sys_counter
[    0.034017] NET: Registered protocol family 2
[    0.034685] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.034721] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.034745] TCP: Hash tables configured (established 1024 bind 1024)
[    0.034873] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.034919] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.035133] NET: Registered protocol family 1
[    0.035560] Unpacking initramfs...
[    0.753577] Freeing initrd memory: 10032K
[    0.755565] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.763316] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.765082] random: fast init done
[    0.767909] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.767932] io scheduler noop registered
[    0.767940] io scheduler deadline registered
[    0.768170] io scheduler cfq registered (default)
[    0.768182] io scheduler mq-deadline registered
[    0.768187] io scheduler kyber registered
[    0.772480] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.836644] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.839940] console [ttyS0] disabled
[    0.860216] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    1.437325] console [ttyS0] enabled
[    1.443508] libphy: Fixed MDIO Bus: probed
[    1.448187] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.453980] dwmac-sun8i 1c30000.ethernet: No regulator found
[    1.459756] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    1.465933] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.471585] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.478829] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.484498] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.491710] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.496680] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.503645] libphy: stmmac: probed
[    1.514842] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.521381] ehci-platform: EHCI generic platform driver
[    1.526959] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.532574] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.540566] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    1.574333] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.581521] hub 1-0:1.0: USB hub found
[    1.585466] hub 1-0:1.0: 1 port detected
[    1.589925] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.596220] ohci-platform: OHCI generic platform driver
[    1.601763] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.608483] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.616424] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.689375] hub 2-0:1.0: USB hub found
[    1.693199] hub 2-0:1.0: 1 port detected
[    1.698275] usbcore: registered new interface driver cdc_acm
[    1.703939] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.712147] usbcore: registered new interface driver usb-storage
[    1.718345] usbcore: registered new interface driver usbserial
[    1.724217] usbcore: registered new interface driver usbserial_generic
[    1.730819] usbserial: USB Serial support registered for generic
[    1.736881] usbcore: registered new interface driver ch341
[    1.742392] usbserial: USB Serial support registered for ch341-uart
[    1.748710] usbcore: registered new interface driver cp210x
[    1.754324] usbserial: USB Serial support registered for cp210x
[    1.760299] usbcore: registered new interface driver ftdi_sio
[    1.766103] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.773514] usbcore: registered new interface driver pl2303
[    1.779164] usbserial: USB Serial support registered for pl2303
[    1.785153] usbcore: registered new interface driver usb_serial_simple
[    1.791717] usbserial: USB Serial support registered for carelink
[    1.797868] usbserial: USB Serial support registered for zio
[    1.803552] usbserial: USB Serial support registered for funsoft
[    1.809624] usbserial: USB Serial support registered for flashloader
[    1.816019] usbserial: USB Serial support registered for google
[    1.821960] usbserial: USB Serial support registered for vivopay
[    1.828004] usbserial: USB Serial support registered for moto_modem
[    1.834305] usbserial: USB Serial support registered for novatel_gps
[    1.840680] usbserial: USB Serial support registered for hp4x
[    1.846463] usbserial: USB Serial support registered for suunto
[    1.852422] usbserial: USB Serial support registered for siemens_mpi
[    1.860019] mousedev: PS/2 mouse device common for all mice
[    1.866468] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.875368] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.882163] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.886788] i2c /dev entries driver
[    1.891716] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.900896] usbcore: registered new interface driver uvcvideo
[    1.906716] USB Video Class driver (1.1.1)
[    1.911481] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.974359] sunxi-mmc 1c0f000.mmc: base:0xc48d5000 irq:23
[    2.021225] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.031060] mmc0: new high speed SD card at address 00c3
[    2.036883] sunxi-mmc 1c10000.mmc: base:0xc48d9000 irq:24
[    2.043232] usbcore: registered new interface driver usbhid
[    2.048896] usbhid: USB HID core driver
[    2.053476] mmcblk0: mmc0:00c3 E1601 121 MiB
[    2.059991] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    2.068041] sun4i-codec 1c22c00.codec: Failed to register our card
[    2.074534]  mmcblk0: p1
[    2.082072] NET: Registered protocol family 17
[    2.086799] Registering SWP/SWPB emulation handler
[    2.097043] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    2.108414] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.114179] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    2.123330] hub 3-0:1.0: USB hub found
[    2.127353] hub 3-0:1.0: 1 port detected
[    2.134922] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    2.143400] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:43 UTC (43)
[    2.151770] vcc5v0: disabling
[    2.154810] ALSA device list:
[    2.157779]   #0: V3s Audio Codec
[    2.163055] Freeing unused kernel memory: 1024K
mount: mounting tmpfs on /dev/shm failed: Invalid argument
mount: mounting tmpfs on /tmp failed: Invalid argument
mount: mounting tmpfs on /run failed: Invalid argument
can't open /dev/null: No such file or directory
Starting logging: OK
Starting mdev...
Starting network: OK
[    3.397097] Mass Storage Function, version: 2009/09/11
[    3.402258] LUN: removable file: (no medium)
[    3.406903] LUN: removable file: /dev/mmcblk0
[    3.411264] Number of LUNs=1
[    3.446642] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[    3.453622] g_mass_storage gadget: userspace failed to provide iSerialNumber
[    3.460799] g_mass_storage gadget: g_mass_storage ready
这样是不是可以了,没有变成u盘
#7 2019-12-09 18:51:39
已发帖子: 9,513
PF6有没有受 usb id脚控制?
楼主 #8 2019-12-09 19:14:32
psst
已发帖子: 92
PF6 悬空的
#9 2019-12-09 19:32:58
已发帖子: 9,513
先拉低或者拉高试一试.
楼主 #10 2019-12-10 10:38:10
psst
已发帖子: 92
先拉低或者拉高试一试.
谢谢晕哥指导,PF6 拉高就可以。确实方便多了
