楼主 #1 2020-01-14 14:02:51
vmalloc
老问题,貌似没有生成mtd
按照官方和https://whycan.cn/ 这个帖子,最后boot的时候卡在 Waiting for root device /dev/mtdblock3...
翻遍了帖子,内核配置也对着各位帖子调整了,三天了,无进度,只好前来求救。
编译出来的文件系统只有1.6M,不知道有没有问题.
下面贴出我的log和suniv-f1c100s-licheepi-nano.dts文件
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
   Loading Device Tree to 80e05000, end 80e09f3e ... OK
[    0.000000] Linux version 4.15.0-rc8-90681-g9b2fb662b0c8-dirty (cef@cef) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #11 Tue Jan 14 11:47:38 CST 2020
[    0.000000] Memory: 25940K/32768K available (4096K kernel code, 154K rwdata, 976K rodata, 1024K init, 137K bss, 6828K reserved, 0K cma-reserved)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (5088 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 155 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 138 kB)
[    0.000052] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000132] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000795] Console: colour dummy device 80x30
[    0.000899] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070276] pid_max: default: 32768 minimum: 301
[    0.070702] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070749] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072212] CPU: Testing write buffer coherency: ok
[    0.074172] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076877] devtmpfs: initialized
[    0.083291] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.083365] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083647] pinctrl core: initialized pinctrl subsystem
[    0.086440] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.111241] SCSI subsystem initialized
[    0.112450] usbcore: registered new interface driver usbfs
[    0.112636] usbcore: registered new interface driver hub
[    0.112843] usbcore: registered new device driver usb
[    0.113419] pps_core: LinuxPPS API ver. 1 registered
[    0.113450] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.114726] clocksource: Switched to clocksource timer
[    0.146924] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.159435] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.160015] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.166308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.166359] io scheduler noop registered
[    0.166379] io scheduler deadline registered
[    0.166833] io scheduler cfq registered (default)
[    0.166871] io scheduler mq-deadline registered
[    0.166894] io scheduler kyber registered
[    0.177873] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.368896] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.376619] console [ttyS0] disabled
[    0.396898] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[    0.751616] console [ttyS0] enabled
[    0.794019] brd: module loaded
[    0.820427] loop: module loaded
[    0.824559] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.831244] ehci-platform: EHCI generic platform driver
[    0.836892] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.843129] ohci-platform: OHCI generic platform driver
[    0.849122] i2c /dev entries driver
[    0.854914] usbcore: registered new interface driver usbhid
[    0.860499] usbhid: USB HID core driver
[    0.875105] hctosys: unable to open rtc device (rtc0)
[    0.880772] vcc3v3: disabling
[    0.884881] Waiting for root device /dev/mtdblock3...
[  208.784839] random: crng init done
DTS
/dts-v1/;
#include "suniv-f1c100s.dtsi"
	model = "Lichee Pi Nano";
	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
		     "allwinner,suniv";
	aliases {
		serial0 = &uart0;
		spi0 = &spi0;
	chosen {
	panel: panel {
		compatible = "qiaodian,qd43003c0-40", "simple-panel";
		#address-cells = <1>;
		#size-cells = <0>;
		enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
		port@0 {
			reg = <0>;
			#size-cells = <0>;
			panel_input: endpoint@0 {
				reg = <0>;
	reg_vcc3v3: vcc3v3 {
		regulator-name = "vcc3v3";
&de {
&mmc0 {
	vmmc-supply = <&reg_vcc3v3>;
	bus-width = <4>;
	broken-cd;
&otg_sram {
&spi0 {
    pinctrl-names = "default";
    pinctrl-0 = <&spi0_pins_a>;
    flash: w25q128@0 {
        #size-cells = <1>;
        reg = <0>;
        partitions {
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x100000>;
                read-only;
            partition@100000 {
                label = "dtb";
                reg = <0x100000 0x10000>;
                read-only;
            partition@110000 {
                label = "kernel";
                reg = <0x110000 0x400000>;
                read-only;
            partition@510000 {
                label = "rootfs";
                reg = <0x510000 0xAF0000>;
&tcon0 {
	pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
	tcon0_out_lcd: endpoint@0 {
		reg = <0>;
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
#2 2020-01-14 14:12:19
已发帖子: 9,486
Re: 老问题,貌似没有生成mtd
log里面没有发现 spi 相关, 贴下这个文件 suniv-f1c100s.dtsi
楼主 #3 2020-01-14 14:15:19
vmalloc
Re: 老问题,貌似没有生成mtd
是的,我也在怀疑这个。
suniv-f1c100s.dtsi文件是空的,只有一个include
#include "suniv.dtsi"
我顺便贴一下suniv.dtsi
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
	#size-cells = <1>;
	interrupt-parent = <&intc>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: clk-24M {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: clk-32k {
			#clock-cells = <0>;
			clock-frequency = <32768>;
		fake100M: clk-100M {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
			clock-output-names = "fake-100M";
	cpus {
		#address-cells = <0>;
		#size-cells = <0>;
		cpu {
			device_type = "cpu";
	de: display-engine {
		compatible = "allwinner,suniv-display-engine";
		allwinner,pipelines = <&fe0>;
		status = "disabled";
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		sram-controller@1c00000 {
			compatible = "allwinner,sun4i-a10-sram-controller";
			reg = <0x01c00000 0x30>;
			#size-cells = <1>;
			ranges;
			sram_d: sram@10000 {
				compatible = "mmio-sram";
				reg = <0x00010000 0x1000>;
				#size-cells = <1>;
				otg_sram: sram-section@0 {
					reg = <0x0000 0x1000>;
		spi0: spi@1c05000 {
				     "allwinner,sun8i-h3-spi";
			reg = <0x01c05000 0x1000>;
			interrupts = <10>;
			clock-names = "ahb", "mod";
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		spi1: spi@1c06000 {
			reg = <0x01c06000 0x1000>;
			interrupts = <11>;
			clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
			resets = <&ccu RST_BUS_SPI1>;
			#size-cells = <0>;
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,suniv-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <29>;
			clocks = <&ccu CLK_BUS_LCD>,
				 <&ccu CLK_TCON>,
				 <&osc24M>;	/* Still unknown */
				      "tcon-ch0",
				      "tcon-ch1";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_LCD>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,suniv-mmc",
				     "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <23>;
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		mmc1: mmc@1c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <24>;
			#size-cells = <0>;
		ccu: clock@1c20000 {
			compatible = "allwinner,suniv-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
			compatible = "allwinner,suniv-ic";
			reg = <0x01c20400 0x400>;
			interrupt-controller;
			#interrupt-cells = <1>;
		pio: pinctrl@1c20800 {
			compatible = "allwinner,suniv-pinctrl";
			reg = <0x01c20800 0x400>;
			gpio-controller;
			#interrupt-cells = <3>;
			#gpio-cells = <3>;
			spi0_pins_a: spi0-pins-pc {
				function = "spi0";
			lcd_rgb666_pins: lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4",
				       "PD5", "PD6", "PD7", "PD8", "PD9",
				       "PD10", "PD11", "PD12", "PD13", "PD14",
				       "PD15", "PD16", "PD17", "PD18", "PD19",
				       "PD20", "PD21";
				function = "lcd";
			uart0_pins_a: uart-pins-pe {
				pins = "PE0", "PE1";
				function = "uart0";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
		timer@1c20c00 {
			compatible = "allwinner,suniv-timer";
			reg = <0x01c20c00 0x90>;
			interrupts = <13>;
			clocks = <&osc24M>;
		wdt: watchdog@1c20ca0 {
			reg = <0x01c20ca0 0x20>;
		uart0: serial@1c25000 {
			reg = <0x01c25000 0x400>;
			interrupts = <1>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@1c25400 {
			reg = <0x01c25400 0x400>;
			interrupts = <2>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@1c25800 {
			reg = <0x01c25800 0x400>;
			interrupts = <3>;
			reg-shift = <2>;
			reg-io-width = <4>;
		usb_otg: usb@1c13000 {
			reg = <0x01c13000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <26>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@1c13400 {
			reg = <0x01c13400 0x10>;
			reg-names = "phy_ctrl";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		fe0: display-frontend@1e00000 {
			compatible = "allwinner,suniv-display-frontend";
			reg = <0x01e00000 0x20000>;
			interrupts = <30>;
			clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
				 <&ccu CLK_DRAM_DE_FE>;
			clock-names = "ahb", "mod",
				      "ram";
			resets = <&ccu RST_BUS_DE_FE>;
			ports {
				#size-cells = <0>;
				fe0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					fe0_out_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_in_fe0>;
		be0: display-backend@1e60000 {
			compatible = "allwinner,suniv-display-backend";
			reg = <0x01e60000 0x10000>;
			reg-names = "be";
			interrupts = <31>;
			clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
				 <&ccu CLK_DRAM_DE_BE>;
				      "ram";
			resets = <&ccu RST_BUS_DE_BE>;
			reset-names = "be";
			assigned-clocks = <&ccu CLK_DE_BE>;
			assigned-clock-rates = <300000000>;
			ports {
				#size-cells = <0>;
				be0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					be0_in_fe0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&fe0_out_be0>;
				be0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					be0_out_tcon0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon0_in_be0>;
楼主 #4 2020-01-14 14:16:40
vmalloc
Re: 老问题,貌似没有生成mtd
发现这里sip0是disabled的,我改一下试试
spi0: spi@1c05000 {
			interrupts = <10>;
			#size-cells = <0>;
#5 2020-01-14 14:17:30
已发帖子: 9,486
Re: 老问题,貌似没有生成mtd
可能是这个问题: https://whycan.cn/t_1712.html#p18831
楼主 #6 2020-01-14 14:44:12
vmalloc
Re: 老问题,貌似没有生成mtd
我看到过那个SPI驱动应该选A31,官方的是A10,这是个坑,但是我选过很多次,刚进去怎么被取消了。估计是动其他配置的时候,这个选项的依赖呗修改了。
现在生成mtd了,好像存在问题。
U-Boot 2018.01-05682-gd83b2fefcf-dirty (Jan 14 2020 - 13:37:19 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
[    0.000000] Linux version 4.15.0-rc8-90681-g9b2fb662b0c8-dirty (xw@xw-C246-WU4) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #13 Tue Jan 14 14:33:48 CST 2020
[    0.000128] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000784] Console: colour dummy device 80x30
[    0.000891] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070270] pid_max: default: 32768 minimum: 301
[    0.070677] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070722] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072204] CPU: Testing write buffer coherency: ok
[    0.074170] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076902] devtmpfs: initialized
[    0.083322] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.083393] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083678] pinctrl core: initialized pinctrl subsystem
[    0.086235] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.111023] SCSI subsystem initialized
[    0.112211] usbcore: registered new interface driver usbfs
[    0.112401] usbcore: registered new interface driver hub
[    0.112602] usbcore: registered new device driver usb
[    0.113184] pps_core: LinuxPPS API ver. 1 registered
[    0.113217] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.114494] clocksource: Switched to clocksource timer
[    0.147336] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.159712] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.160293] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[    0.166656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.166709] io scheduler noop registered
[    0.166733] io scheduler deadline registered
[    0.167196] io scheduler cfq registered (default)
[    0.167234] io scheduler mq-deadline registered
[    0.167256] io scheduler kyber registered
[    0.178365] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.373182] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.380918] console [ttyS0] disabled
[    0.401202] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[    0.755416] console [ttyS0] enabled
[    0.797429] brd: module loaded
[    0.823761] loop: module loaded
[    0.830927] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.837038] 4 ofpart partitions found on MTD device spi0.0
[    0.842546] Creating 4 MTD partitions on "spi0.0":
[    0.847516] 0x000000000000-0x000000100000 : "u-boot"
[    0.856711] rfd_ftl: no RFD magic found in 'u-boot'
[    0.864109] ftl_cs: FTL header not found.
[    0.869945] 0x000000100000-0x000000110000 : "dtb"
[    0.876237] ftl_cs: FTL header not found.
[    0.882036] 0x000000110000-0x000000510000 : "kernel"
[    0.899612] rfd_ftl: no RFD magic found in 'kernel'
[    0.907040] ftl_cs: FTL header not found.
[    0.912858] 0x000000510000-0x000001000000 : "rootfs"
[    0.949353] rfd_ftl: no RFD magic found in 'rootfs'
[    0.956873] ftl_cs: FTL header not found.
[    0.963098] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.969775] ehci-platform: EHCI generic platform driver
[    0.975403] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.981642] ohci-platform: OHCI generic platform driver
[    0.987612] i2c /dev entries driver
[    0.993396] usbcore: registered new interface driver usbhid
[    0.999119] usbhid: USB HID core driver
[    1.013923] hctosys: unable to open rtc device (rtc0)
[    1.019725] vcc3v3: disabling
[    1.108587] random: crng init done
[    1.418802] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    1.426794] devtmpfs: mounted
[    1.434205] Freeing unused kernel memory: 1024K
[    3.181227] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
[    3.181227]
[    3.190383] CPU: 0 PID: 1 Comm: init Not tainted 4.15.0-rc8-90681-g9b2fb662b0c8-dirty #13
[    3.198539] Hardware name: Allwinner suniv Family
[    3.203233] Backtrace:
[    3.205745] [<c0105938>] (dump_backtrace) from [<c0105bf8>] (show_stack+0x18/0x1c)
[    3.213306]  r6:c182de70 r5:00000000 r4:c0726ce8
[    3.217962] [<c0105be0>] (show_stack) from [<c044bfec>] (dump_stack+0x20/0x28)
[    3.225208] [<c044bfcc>] (dump_stack) from [<c010f6d8>] (panic+0xc0/0x238)
[    3.232091] [<c010f61c>] (panic) from [<c0110f80>] (do_exit+0x970/0x9a8)
[    3.238789]  r3:c182e000 r2:c182e00c r1:00000004 r0:c058acf4
[    3.244434]  r7:00000000
[    3.246992] [<c0110610>] (do_exit) from [<c0111b40>] (do_group_exit+0x44/0xbc)
[    3.254194]  r7:c1830000
[    3.256764] [<c0111afc>] (do_group_exit) from [<c011ae40>] (get_signal+0x150/0x56c)
[    3.264400]  r4:ffffe000
[    3.266962] [<c011acf0>] (get_signal) from [<c0104e5c>] (do_signal+0xcc/0x40c)
[    3.274185]  r10:00000000 r9:c182c000 r8:b6f10104 r7:b6f10100 r6:ffffff9c r5:c182ded0
[    3.281991]  r4:c182dfb0
[    3.284546] [<c0104d90>] (do_signal) from [<c010537c>] (do_work_pending+0xc0/0xd4)
[    3.292115]  r10:00000000 r9:c182c000 r8:c01027c4 r7:00900000 r6:c182dfb0 r5:c01027c4
[    3.299923]  r4:ffffe000
[    3.302475] [<c01052bc>] (do_work_pending) from [<c0102608>] (slow_work_pending+0xc/0x20)
[    3.310636]  r6:00000000 r5:bef85d60 r4:b6f22f70
[    3.315259] Rebooting in 5 seconds..
[    9.294495] Reboot failed -- System halted
#7 2020-01-14 15:01:33
已发帖子: 9,486
Re: 老问题,貌似没有生成mtd
你的 jffs2 文件系统有问题。
楼主 #8 2020-01-14 15:46:47
vmalloc
Re: 老问题,貌似没有生成mtd
你的 jffs2 文件系统有问题。
重新编译几个了试了,还有吧你从licheepi官方固件中提取出来的烧进去了,还是这样.
#9 2020-01-14 15:55:33
已发帖子: 9,486
Re: 老问题,貌似没有生成mtd
那来个逆向思维吧, 把你的zImage和dtb替换下面的固件的:
https://whycan.cn/t_2689.html
https://whycan.cn/t_3206.html
楼主 #10 2020-01-14 17:32:22
vmalloc
Re: 老问题,貌似没有生成mtd
是内核的问题,应该是改的时间长,改乱了。
我重新下了一个,按照大家的帖子,挨个弄,弄好了。
多谢晕哥的指导
