16M spiflash 系统
uboot裁减到122K 内核2.3M rootfs 2M 移植加入tslib,使用jffs2文件系统。我目前优化办法就是各种裁减,然后内核速度改到了800Mhz,SPI速度改到了108M。
uboot等待时间改成0S,uboot启动到内核需要3S ,内核和文件系统启动需要9S ,加起来上电启动到littlegl demo 需要 12S!
12S这个时间还是太长,请问各位大神,还有什么办法可以加快开机速度,请各位不吝赐教谢谢!![]()
下面是我的分区规划
mtd0 192KB spl+uboot 0x0000000-0x0030000 : “uboot”
mtd1 64KB dtb文件 0x0030000-0x0040000 : “dtb”
mtd2 2.375MB linux内核 0x0040000-0x02A0000 : “kernel”
mtd3 剩余 根文件系统 0x02A0000-0x1000000 : “rootfs”下面是我系统启动打印的logo日志
U-Boot SPL 2018.01-05679-g013ca457fd-dirty (Jan 29 2020 - 15:37:30)
DRAM: 64 MiB
Trying to boot from MMC1
MMC Device 0 not found
spl: could not find mmc device. error: -19
Trying to boot from sunxi SPI
U-Boot 2018.01-05679-g013ca457fd-dirty (Jan 29 2020 - 15:37:30 +0800) Allwinnery
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC:
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Unknown command 'usb' - try 'help'
device 0 offset 0x30000, size 0x4000
SF: 16384 bytes @ 0x30000 Read: OK
device 0 offset 0x40000, size 0x260000
SF: 2490368 bytes @ 0x40000 Read: OK
Loading Device Tree to 816fa000, end 816ff0f2 ... OK
[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (yan@yan-Z5) (gcc versio0
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: vt.global_cursor_default=0 console=ttyS0,112
[ 0.000000] Memory: 57308K/65536K available (4096K kernel code, 170K rwdata,)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (5088 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 171 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 216 kB)
[ 0.000041] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 8947s
[ 0.000090] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, maxs
[ 0.000485] Console: colour dummy device 80x30
[ 0.000553] Calibrating delay loop... 395.67 BogoMIPS (lpj=1978368)
[ 0.120222] pid_max: default: 32768 minimum: 301
[ 0.120430] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.120458] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.121308] CPU: Testing write buffer coherency: ok
[ 0.122694] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.124450] devtmpfs: initialized
[ 0.128221] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.128268] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.128417] pinctrl core: initialized pinctrl subsystem
[ 0.130332] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.131639] cpuidle: using governor menu
[ 0.145336] SCSI subsystem initialized
[ 0.145821] Advanced Linux Sound Architecture Driver Initialized.
[ 0.146040] clocksource: Switched to clocksource timer
[ 0.167062] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.168800] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.174759] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.185175] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.185212] io scheduler noop registered
[ 0.185223] io scheduler deadline registered
[ 0.185746] io scheduler cfq registered (default)
[ 0.185772] io scheduler mq-deadline registered
[ 0.185783] io scheduler kyber registered
[ 0.192577] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.325981] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.331286] console [ttyS0] disabled
[ 0.351550] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 24, base_baud = 6A
[ 0.694320] console [ttyS0] enabled
[ 0.702503] panel-simple panel: panel supply power not found, using dummy rer
[ 0.711471] SCSI Media Changer driver v0.25
[ 0.718451] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.723210] 4 ofpart partitions found on MTD device spi0.0
[ 0.728785] Creating 4 MTD partitions on "spi0.0":
[ 0.733586] 0x000000000000-0x000000030000 : "u-boot"
[ 0.740702] 0x000000030000-0x000000040000 : "dtb"
[ 0.747377] 0x000000040000-0x0000002a0000 : "kernel"
[ 0.754202] 0x0000002a0000-0x000001040000 : "rootfs"
[ 0.759287] mtd: partition "rootfs" extends beyond the end of device "spi0.00
[ 0.771218] i2c /dev entries driver
[ 0.776825] input: ns2009_ts as /devices/platform/soc/1c27000.i2c/i2c-0/0-000
[ 0.846154] sunxi-mmc 1c0f000.mmc: base:0x0d7490d4 irq:20
[ 0.873560] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc)
[ 0.882275] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0)
[ 0.890041] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.896677] [drm] No driver support for vblank timestamp query.
[ 0.945303] Console: switching to colour frame buffer device 60x34
[ 0.970499] sun4i-drm display-engine: fb0: frame buffer device
[ 0.977443] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on0
[ 0.985746] vcc3v3: disabling
[ 0.988841] ALSA device list:
[ 0.991814] #0: Loopback 1
[ 1.096244] random: crng init done
[ 1.412503] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 1.420587] devtmpfs: mounted
[ 1.428004] Freeing unused kernel memory: 1024K
mount: mounting tmpfs on /dev/shm failed: Invalid argument
mount: mounting tmpfs on /tmp failed: Invalid argument
mount: mounting tmpfs on /run failed: Invalid argument
hostname: applet not found
Starting syslogd: OK
Starting klogd: OK
Starting mdev...
Starting network: ifup: applet not found
FAIL
[8.500100]: root login on 'ttyS0'
helloworld!
#下面是我的测试镜像f1c100s-img.tar.gz里面包含测试镜像,编译好的uboot,内核,文件系统,还有config配置文件,16M flash可以直接烧录flashimg.bin,支持F1C100S和F1C200S,上电以后显示linux 开机LOGO,然后自动加载 demo程序
-rw-r--r-- 1 yan yan 93K 1月 29 23:35 buildroot-2019.5.1.config
-rw-r--r-- 1 yan yan 8.0M 1月 29 23:28 flashimg.bin
-rw-r--r-- 1 yan yan 5.3M 1月 29 23:27 jffs2.img
-rw-r--r-- 1 yan yan 66K 1月 29 23:34 linux.config
-rw-r--r-- 1 yan yan 234 1月 29 23:29 mtd.hklm.txt
-rw-r--r-- 1 yan yan 2.0M 1月 29 23:27 rootfs.tar
-rw-r--r-- 1 yan yan 8.3K 1月 29 23:27 suniv-f1c100s-licheepi-nano.dtb
-rw-r--r-- 1 yan yan 122K 1月 29 23:28 u-boot.bin
-rw-r--r-- 1 yan yan 24K 1月 29 23:34 uboot.config
-rw-r--r-- 1 yan yan 156K 1月 29 23:27 u-boot-sunxi-with-spl.bin
-rwxr-xr-x 1 yan yan 85 1月 29 23:29 write-all-spiimg.sh
-rwxr-xr-x 1 yan yan 2.3M 1月 29 23:27 zImage最后附上我的测试视频,和我自己设计的开发板美照,手工焊接QFN着实难焊 。![]()
最近编辑记录 颜水花生 (2020-01-30 01:02:28)
linux设备树你的 spi 速度是多少?
等等,有点不对劲,
这里貌似超过16M了?
还是我前面那个回复,
可以把根文件系统改小一点,比如5M,
这样扫描区域就没辣么大,可以节省一点点时间。
还有,lvgl应用放 /etc/init.d/S90app 里面,记得加后台运行符号。
等等,有点不对劲,
这里貌似超过16M了?
对哦,:lol: 看了下,是设备树那里搞错了呢,改成0XD60000就好了
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins_a>;
spi-max-frequency = <108000000>;
flash: w25q128@0 {
#address-cells = <1>;
#size-cells = <1>;
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x00000 0x30000>;
read-only;
partition@100000 {
label = "dtb";
reg = <0x30000 0x10000>;
read-only;
partition@110000 {
label = "kernel";
reg = <0x40000 0x260000>;
read-only;
partition@510000 {
label = "rootfs";
reg = <0x2A0000 0xDA0000>;
};离线
超级萌新 wrote:
还是我前面那个回复,
可以把根文件系统改小一点,比如5M,
这样扫描区域就没辣么大,可以节省一点点时间。还有,lvgl应用放 /etc/init.d/S90app 里面,记得加后台运行符号。
好的谢谢,根文件系统改小我试过哦,我把根文件系统改成了5M,对比了下发现不明显哦,时间没有明显提升。lvgl应用我没加后台符号,不过我不执行lvgl开机时间也要那么长,加了lvgl demo程序加载大概需要2S时间。
这是我改的,测试发现开机时间一模一样,没啥变化
[ 0.733537] 0x000000000000-0x000000030000 : "u-boot"
[ 0.740647] 0x000000030000-0x000000040000 : "dtb"
[ 0.747326] 0x000000040000-0x0000002a0000 : "kernel"
[ 0.754149] 0x0000002a0000-0x000000800000 : "rootfs"
Starting mdev...
FAIL
helloworld!
# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 5.4M 3.1M 2.3M 58% /
#最近编辑记录 颜水花生 (2020-01-30 00:06:43)
用sdnand,要快很多
BTW,楼主板子很不错
板子真漂亮。
发到展览馆吧
看你的log,可以屏蔽uboot的emmc,在.comfig里面可以删除,估计能提高0.0x秒
/etc/init.d/S90app 改成 /etc/init.d/S01app,可以最先执行lvgl app
内核是用gz压缩方式?改成xz方式会快一点
为什么?请教这个如何设置?
同请教,如何修改内核压缩方式呢?我用的默认的设置,百度了以下没找到答案,谢谢 ![]()
好的谢谢,我试试看 ![]()
达克罗德 wrote:
用sdnand,要快很多
是的SD快很多,速度达到要求,但是项目成本有要求,SD贵很多呀 ![]()
感谢支招,用了你的方法,果然提速了差不多4S 牛掰 ![]()
我觉得这个ttyS0 init占用太多时间了,能不能改短一点
在内核常规设置选项里面
General setup --->Kernel compression mode (Gzip)
将gzip改为xz模式
ippen wrote:
在内核常规设置选项里面
将gzip改为xz模式
多谢指教,mark
是的哦,350ms有点太长了,各位大神知道如何优化麻
ippen wrote:
在内核常规设置选项里面
将gzip改为xz模式
谢谢,这就试试 ![]()
ippen wrote:
在内核常规设置选项里面
将gzip改为xz模式
刚刚试了下,发现速度倒是没什么差别,修改前8.8S,修改后还是一样8.8S。但是体积小了好多,从2.3M变成1.7M了,感谢支招 ![]()
sf load zImage 的时候, 可以加载小一点, 0.6M大概节省 0.x 秒.
感谢提醒,试了下
果然如此,现在启动到界面需要8S
最近编辑记录 颜水花生 (2020-01-30 12:41:46)
我把SPI速度改到了128M,速度好像没有提升,使用了楼上各种方法,目前启动到 lvgl demo需要8S, uboot启动2S,内核启动完成7.4S 一共9.4S
下面是启动logo
U-Boot SPL 2018.01-05679-g013ca457fd-dirty (Jan 30 2020 - 12:55:16)
DRAM: 64 MiB
U-Boot 2018.01-05679-g013ca457fd-dirty (Jan 30 2020 - 12:55:16 +0800) Allwinnery
DRAM: 64 MiB
MMC:
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
device 0 offset 0x40000, size 0x1c0000
SF: 1835008 bytes @ 0x40000 Read: OK
[ 0.120459] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.124451] devtmpfs: initialized
[ 0.128223] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.128269] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.128419] pinctrl core: initialized pinctrl subsystem
[ 0.130335] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.131642] cpuidle: using governor menu
[ 0.145353] SCSI subsystem initialized
[ 0.145835] Advanced Linux Sound Architecture Driver Initialized.
[ 0.146060] clocksource: Switched to clocksource timer
[ 0.167073] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.168823] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.174770] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.185229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.185265] io scheduler noop registered
[ 0.185276] io scheduler deadline registered
[ 0.185797] io scheduler cfq registered (default)
[ 0.185824] io scheduler mq-deadline registered
[ 0.185835] io scheduler kyber registered
[ 0.192663] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.326036] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.331324] console [ttyS0] disabled
[ 0.351583] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 24, base_baud = 6A
[ 0.694356] console [ttyS0] enabled
[ 0.702548] panel-simple panel: panel supply power not found, using dummy rer
[ 0.711511] SCSI Media Changer driver v0.25
[ 0.718500] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.723263] 4 ofpart partitions found on MTD device spi0.0
[ 0.728833] Creating 4 MTD partitions on "spi0.0":
[ 0.733637] 0x000000000000-0x000000030000 : "u-boot"
[ 0.740726] 0x000000030000-0x000000040000 : "dtb"
[ 0.747401] 0x000000040000-0x0000002a0000 : "kernel"
[ 0.754230] 0x0000002a0000-0x000001000000 : "rootfs"
[ 0.761495] i2c /dev entries driver
[ 0.767097] input: ns2009_ts as /devices/platform/soc/1c27000.i2c/i2c-0/0-000
[ 0.836175] sunxi-mmc 1c0f000.mmc: base:0x0d7490d4 irq:20
[ 0.863654] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc)
[ 0.872360] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0)
[ 0.880128] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.886773] [drm] No driver support for vblank timestamp query.
[ 0.935414] Console: switching to colour frame buffer device 60x34
[ 0.960615] sun4i-drm display-engine: fb0: frame buffer device
[ 0.967563] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on0
[ 0.975881] vcc3v3: disabling
[ 0.978979] ALSA device list:
[ 0.981951] #0: Loopback 1
[ 1.086998] random: crng init done
[ 1.422609] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 1.430718] devtmpfs: mounted
[ 1.438129] Freeing unused kernel memory: 1024K
S01app start!
Starting klogd: OK
login[74]: root login on 'ttyS0'
helloworld!
# The framebuffer device was opened successfully.
480x272, 32bpp
The framebuffer device was mapped to memory successfully.
Frame buffer hor. res: 480, ver. res: 272离线
超级萌新 wrote:
看你的log,可以屏蔽uboot的emmc,在.config里面可以删除,估计能提高0.0x秒
这里还浪费了一点点时间,
还有你的 lvgl app有没有 strip ?体积多大?
根文件系统还缺这几个目录, 最好手动建立一下.
smartcar wrote:
这里还浪费了一点点时间,
spl: could not find mmc device. error: -19还有你的 lvgl app有没有 strip ?体积多大?
好的谢谢,我这就试试,我的程序775K,strip是啥?可以优化速度吗?刚搞lvgl不大懂,请指教
刚刚看了下,根文件有这几个目录的哦,不知道咋会报错
S01app start!
Starting klogd: OK
Starting mdev...
480x272, 32bpp
login[85]: root login on 'ttyS0'
helloworld!
# ls /
bin lib media proc sbin usr
dev lib32 mnt root sys var
etc linuxrc opt run tmp
# 最近编辑记录 颜水花生 (2020-01-30 13:56:16)
Starting kernel ... uboot 主要是 Starting kernel ... 这个地方花的时间太多,差不多2S
这个地方优化空间估计有限, 除非你再把 zImage一部分编译成 ko把文件尺寸降下来.
还有, spi 速度不建议那么高, 60Mhz 左右就可以, 否则可能会导致不稳定, 比如jffs2根文件系统出错.
好的谢谢,我也就测试敢这么玩,项目中不敢 跑这么欢的 ![]()
不知道中科视为他们怎么做到的,可以4S启动到界面。很牛掰
中科世为那个速度得确实不错, 加上全志官方sdk可能优化得更好吧.
不太可能, 除非你的应用接管了 SIG_KILL 软中断命令.
或者试一试这个命令:
killall 应用名
官方的sdk编译出来的内核体积比较小,我记得我编译出uboot+kernek+rootfs总共才2.6M,启动5秒多6秒的样子,不过我没有显示界面的需求,所以内核剪裁比较多,显示部分、声卡全部裁掉了,你可以试一下用官方的sdk
https://elinux.org/images/9/97/Boot_one_second_altenberg.pdf
https://elinux.org/images/6/64/Chris-simmonds-boot-time-elce-2017_0.pdf
这篇文章提供了一些通用的方法,主要是要删掉用不上的驱动,并且把不需要的加载放在后面。
最近编辑记录 jiangming1399 (2020-01-30 14:44:18)
或者试一试这个命令:
killall 应用名
找到问题了,PID 号输入错了,填的VSZ号 ![]()
好的,谢谢,回头试试官方的SDK
https://elinux.org/images/6/64/Chris-simmonds-boot-time-elce-2017_0.pdf这篇文章提供了一些通用的方法,主要是要删掉用不上的驱动,并且把不需要的加载放在后面。
好的,:D 谢谢我参考下
楼主能不能分享一下内核裁剪经验,我怎么裁减zImage都有3M,你的才2.3M,厉害
厚脸皮求上传个.config最好
厚脸皮求上传个.config最好
在家睡到自然醒没钱数尴尬排队厚脸求教程。
厚脸皮求上传个.config最好
我的配置文件已经开源了哦,看帖不认真
哈哈,上面有个压缩包,里面镜像和配置文件都有,改了XZ压缩方式,还可以缩到1.7M
奇怪,昨天明明放上去的呀,咋不见了,我再发一次
最近编辑记录 颜水花生 (2020-01-30 20:19:46)
颜水花生 wrote:
我的配置文件已经开源了哦,看帖不认真
感谢分享, 只是下载有点慢, 一会再仔细研究.
mark一个!!
F1C100这个是ARM9,多少年前的技术了,而且LINUX本身是"庞大"的系统,启动速度不会有太大的优化
LZ考虑下官方的MELIS看看
LZ考虑下官方的MELIS看看
好的,可以尝试一下
这个板子确实漂亮!
楼主最终优化时间能到多少,如果用A33或V3S是不是要快点
最近编辑记录 netwp (2020-02-09 17:06:14)
A33+EMMC也是2秒多,不深度优化是不行的
确实优化的很小。照着配置文件自己编译 Uboot kernel rootfs ,但是把uboot 配置弄进去编译的时候就出错了,难道uboot代码也要修改?下面是报错信息。麻烦指点一下。
LD u-boot
board/sunxi/built-in.o: In function `setup_environment':
/home/du/f1c100s/u-boot/board/sunxi/board.c:699: undefined reference to `eth_env_set_enetaddr'
board/sunxi/built-in.o: In function `board_mmc_init':
/home/du/f1c100s/u-boot/board/sunxi/board.c:488: undefined reference to `sunxi_mmc_init'
cmd/built-in.o: In function `label_boot':
/home/du/f1c100s/u-boot/cmd/pxe.c:796: undefined reference to `do_bootm'
common/built-in.o: In function `usb_kbd_remove':
/home/du/f1c100s/u-boot/common/usb_kbd.c:625: undefined reference to `stdio_deregister_dev'
arm-linux-gnueabi-ld.bfd: BFD (Linaro_Binutils-2017.11) 2.28.2.20170706 assertion fail /home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabi/snapshots/binutils-gdb.git~users~linaro~binutils-2_28-branch/bfd/elf32-arm.c:9514
Makefile:1261: recipe for target 'u-boot' failed
make: *** [u-boot] Error 1离线
目前最终优化 uboot需要2S,linux启动到命令行需要4.5S, 整体启动到LVGL界面需要5S左右,最终还是缩小内核体积,现在内核只有1.2M,外设全部改成驱动挂上去
@1066950103 这地方u-boot解决得不完美,需要自己手工修改代码屏蔽那些无法链接的变量。
晕哥 好的 我试试哈 谢谢晕哥
晕哥 代码改了 能编译通过了 但是遇到奇怪的问题了 这是撒呢
LD spl/lib/built-in.o
LD spl/u-boot-spl
COPY spl/u-boot-spl.bin
MKSUNXI spl/sunxi-spl.bin
BINMAN u-boot-sunxi-with-spl.bin
binman: Node '/binman/u-boot-img': Entry contents size is 0x335a5 (210341) but entry size is 0x1f000 (126976)
Makefile:1148: recipe for target 'u-boot-sunxi-with-spl.bin' failed
make: *** [u-boot-sunxi-with-spl.bin] Error 1
颜水花生 wrote:
我的配置文件已经开源了哦,看帖不认真
能把uboot 代码分享出来不呢!我用这上面的 https://github.com/Lichee-Pi/u-boot/tree/nano-v2018.01 源码编译不通过
LD spl/u-boot-spl
编译出来的uboot体积太大了,使用空间和env环境的地址冲突了,将env环境的地址调大一点
u-boot能直接跑gui吗?
我也一直想u-boot直接跑图形界面,主要是有几个GPIO,SPI,这些外设就可以了,做个简单的控制 可以做到秒启动
LINUX无论如何优化也不可能做到1S内启动图形界面的
可以用xboot
个GPIO,SPI,这些外设就可以了,做个简单的控制 可以做到秒启动LINUX无论如何优化也不可能做到1S内启动图形界面的
直接跑uboot那不就是裸奔了吗
那里面的参数 咋个填写的呢! 感觉不是我理解的那样子个 一个是描述环境变量空间大小 ?一个是描述环境变量空间的偏移地址?
4.5s进Kernel,7秒到命令行是我的极限了……
[0.000000 0.000000]
[0.000567 0.000567] U-Boot SPL 2019.04 (Mar 15 2020 - 20:25:30 +0800)
[0.004723 0.004156] DRAM: 32 MiB
[0.016690 0.011967] SPL: Unsupported Boot Device!
[0.002319 0.002319] Trying to boot from sunxi SPI
[0.345268 0.342949]
[0.345360 0.000092]
[0.345387 0.000027] U-Boot 2019.04 (Mar 15 2020 - 20:25:30 +0800) Allwinner Technology
[0.351057 0.005670]
[0.351088 0.000031] CPU: Allwinner F Series (SUNIV)
[0.354100 0.003011] Model: Lotlab ACT Monitor
[0.357005 0.002906] DRAM: 32 MiB
[0.879050 0.522044] Setting up a 480x272 lcd console (overscan 0x0)
[0.967089 0.088039] In: serial
[0.968047 0.000958] Out: vga
[0.969033 0.000986] Err: vga
[0.971987 0.002954] Hit any key to stop autoboot: 0
[0.980985 0.008999] SF: Detected w25q64cv with page size 256 Bytes, erase size 4 KiB, total 8 MiB
[0.991056 0.010071] device 0 offset 0x3c000, size 0x4000
[1.015056 0.024000] SF: 16384 bytes @ 0x3c000 Read: OK
[1.019068 0.004012] device 0 offset 0x40000, size 0x240000
[3.719108 2.700040] SF: 2359296 bytes @ 0x40000 Read: OK
[3.724043 0.004935] ## Flattened Device Tree blob at 80c00000
[3.728991 0.004948] Booting using the fdt blob at 0x80c00000
[3.735000 0.006009] Loading Device Tree to 80eab000, end 80eb01a2 ... OK
[3.746073 0.011072]
[3.746195 0.000122] Starting kernel ...
[3.748125 0.001930]
[4.503158 0.755033] [ 0.000000] Booting Linux on physical CPU 0x0
[4.508012 0.004854] [ 0.000000] Linux version 5.2.4 (jim@jim-pc) (gcc version 8.3.0 (Buildroot 2020.02)) #5 Sun Mar 15 20:14:37 CST 2020
[4.518121 0.010109] [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[4.525092 0.006971] [ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[4.530318 0.005226] [ 0.000000] OF: fdt: Machine model: Lichee Pi Nano
[4.535147 0.004828] [ 0.000000] Memory policy: Data cache writeback
[4.540014 0.004868] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[4.546372 0.006358] [ 0.000000] Kernel command line: panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=squashfs init=/sbin/mnt_overlay
[4.557096 0.010724] [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[4.563426 0.006330] [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[4.570290 0.006864] [ 0.000000] Memory: 25868K/32768K available (4096K kernel code, 159K rwdata, 532K rodata, 1024K init, 205K bss, 6900K reserved, 0K cma-reserved)
[4.583270 0.012980] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[4.589105 0.005835] [ 0.000000] random: get_random_bytes called from 0xc0600a84 with crng_init=0
[4.596064 0.006959] [ 0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[4.604088 0.008024] [ 0.000101] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[4.613078 0.008990] [ 0.000568] Console: colour dummy device 80x30
[4.617318 0.004241] [ 0.001027] printk: console [tty0] enabled
[4.621344 0.004025] [ 0.001138] Calibrating delay loop... 334.23 BogoMIPS (lpj=1671168)
[4.628018 0.006675] [ 0.050263] pid_max: default: 32768 minimum: 301
[4.632339 0.004321] [ 0.050425] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[4.639180 0.006841] [ 0.050484] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[4.646232 0.007052] [ 0.051856] CPU: Testing write buffer coherency: ok
[4.651090 0.004858] [ 0.054029] Setting up static identity map for 0x80100000 - 0x8010003c
[4.657220 0.006130] [ 0.056102] devtmpfs: initialized
[4.661073 0.003853] [ 0.070968] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[4.670980 0.009907] [ 0.071114] futex hash table entries: 256 (order: -1, 3072 bytes)
[4.677037 0.006058] [ 0.071270] pinctrl core: initialized pinctrl subsystem
[4.682108 0.005070] [ 0.074046] NET: Registered protocol family 16
[4.686270 0.004162] [ 0.075338] DMA: preallocated 256 KiB pool for atomic coherent allocations
[4.693215 0.006946] [ 0.080370] cpuidle: using governor menu
[4.697250 0.004035] [ 0.126249] clocksource: Switched to clocksource timer
[4.702239 0.004989] [ 0.180323] NET: Registered protocol family 2
[4.707061 0.004822] [ 0.183919] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[4.714263 0.007203] [ 0.184071] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[4.721272 0.007009] [ 0.184151] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[4.728051 0.006779] [ 0.184219] TCP: Hash tables configured (established 1024 bind 1024)
[4.734209 0.006158] [ 0.184535] UDP hash table entries: 256 (order: 0, 4096 bytes)
[4.740157 0.005948] [ 0.184639] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[4.746239 0.006082] [ 0.186047] NET: Registered protocol family 1
[4.751062 0.004823] [ 0.190645] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[4.757162 0.006100] [ 0.192058] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[4.763079 0.005917] [ 0.192167] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[4.769082 0.006003] [ 0.198473] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[4.775056 0.005974] [ 0.250694] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[4.782225 0.007169] [ 0.252818] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[4.793005 0.010780] [ 0.257108] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[4.801214 0.008209] [ 0.344204] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[4.807384 0.006171] [ 0.382288] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[4.816277 0.008893] [ 0.695683] printk: console [ttyS0] enabled
[4.828065 0.011788] [ 0.707818] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[4.850157 0.022091] [ 0.729106] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[4.872073 0.021917] [ 0.750949] m25p80 spi0.0: found s25fl064k, expected w25q64
[4.877286 0.005213] [ 0.756747] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[4.882336 0.005050] [ 0.761652] 5 fixed-partitions partitions found on MTD device spi0.0
[4.889007 0.006670] [ 0.768112] Creating 5 MTD partitions on "spi0.0":
[4.893381 0.004374] [ 0.772955] 0x000000000000-0x00000003c000 : "u-boot"
[4.907049 0.013668] [ 0.786887] 0x00000003c000-0x000000040000 : "dtb"
[4.921066 0.014017] [ 0.800637] 0x000000040000-0x000000280000 : "kernel"
[4.934068 0.013002] [ 0.813192] 0x000000280000-0x000000780000 : "rootfs"
[4.948041 0.013973] [ 0.827617] 0x000000780000-0x000000800000 : "overlay"
[4.968011 0.019970] [ 0.847169] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
[4.980047 0.012037] [ 0.859628] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[4.990011 0.009964] [ 0.869284] Initializing XFRM netlink socket
[4.994210 0.004199] [ 0.873754] NET: Registered protocol family 17
[5.001047 0.006837] [ 0.880207] NET: Registered protocol family 15
[5.016096 0.015049] [ 0.894942] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[5.031058 0.014961] [ 0.910067] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[5.040995 0.009937] [ 0.920745] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc05308a0)
[5.052203 0.011209] [ 0.931292] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc052f508)
[5.060031 0.007827] [ 0.939156] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[5.066326 0.006295] [ 0.945803] [drm] No driver support for vblank timestamp query.
[5.075135 0.008809] [ 0.954805] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[5.092130 0.016994] [ 0.970946] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[5.100040 0.007910] [ 0.979521] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[5.116049 0.016008] [ 0.995243] using random self ethernet address
[5.120280 0.004231] [ 0.999893] using random host ethernet address
[5.132252 0.011971] [ 1.011061] usb0: HOST MAC 6e:38:35:96:dc:b3
[5.136162 0.003910] [ 1.015513] usb0: MAC 3a:97:0e:a2:12:d4
[5.140116 0.003954] [ 1.019570] using random self ethernet address
[5.145041 0.004925] [ 1.024066] using random host ethernet address
[5.149205 0.004164] [ 1.028785] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[5.156180 0.006975] [ 1.035453] g_ether gadget: g_ether ready
[5.163033 0.006853] [ 1.042700] vcc3v3: disabling
[5.176095 0.013062] [ 1.054986] random: fast init done
[5.181042 0.004947] [ 1.060490] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[5.194026 0.012984] [ 1.073359] devtmpfs: mounted
[5.201013 0.006987] [ 1.080565] Freeing unused kernel memory: 1024K
[5.206109 0.005095] [ 1.085259] Run /sbin/mnt_overlay as init process
[5.381470 0.175361] [ 1.260258] random: crng init done
[5.779200 0.397730] [ 1.658367] g_ether gadget: high-speed config #1: CDC Ethernet (ECM)
[5.883472 0.104272] [ 1.762622] overlayfs: upper fs does not support tmpfile.
[5.888996 0.005524] [ 1.768214] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
[6.116461 0.227465] Starting syslogd: OK
[6.150147 0.033685] Starting klogd: OK
[6.186171 0.036024] Running sysctl: OK
[6.339748 0.153577] Saving random seed: OK
[6.400528 0.060780] Starting network: OK
[6.590488 0.189960] Starting udhcpd: OK
[6.631476 0.040988] Starting dropbear sshd: OK
[6.852184 0.220708]
[6.852304 0.000120] Welcome to Buildroot
[6.854232 0.001928] buildroot login:离线
[0.000000 0.000000] [0.000567 0.000567] U-Boot SPL 2019.04 (Mar 15 2020 - 20:25:30 +0800) [0.004723 0.004156] DRAM: 32 MiB [0.016690 0.011967] SPL: Unsupported Boot Device! [0.002319 0.002319] Trying to boot from sunxi SPI [0.345268 0.342949] [0.345360 0.000092] [0.345387 0.000027] U-Boot 2019.04 (Mar 15 2020 - 20:25:30 +0800) Allwinner Technology [0.351057 0.005670] [0.351088 0.000031] CPU: Allwinner F Series (SUNIV) [0.354100 0.003011] Model: Lotlab ACT Monitor [0.357005 0.002906] DRAM: 32 MiB [0.879050 0.522044] Setting up a 480x272 lcd console (overscan 0x0) [0.967089 0.088039] In: serial [0.968047 0.000958] Out: vga [0.969033 0.000986] Err: vga [0.971987 0.002954] Hit any key to stop autoboot: 0 [0.980985 0.008999] SF: Detected w25q64cv with page size 256 Bytes, erase size 4 KiB, total 8 MiB [0.991056 0.010071] device 0 offset 0x3c000, size 0x4000 [1.015056 0.024000] SF: 16384 bytes @ 0x3c000 Read: OK [1.019068 0.004012] device 0 offset 0x40000, size 0x240000 [3.719108 2.700040] SF: 2359296 bytes @ 0x40000 Read: OK [3.724043 0.004935] ## Flattened Device Tree blob at 80c00000 [3.728991 0.004948] Booting using the fdt blob at 0x80c00000 [3.735000 0.006009] Loading Device Tree to 80eab000, end 80eb01a2 ... OK [3.746073 0.011072] [3.746195 0.000122] Starting kernel ... [3.748125 0.001930] [4.503158 0.755033] [ 0.000000] Booting Linux on physical CPU 0x0 [4.508012 0.004854] [ 0.000000] Linux version 5.2.4 (jim@jim-pc) (gcc version 8.3.0 (Buildroot 2020.02)) #5 Sun Mar 15 20:14:37 CST 2020 [4.518121 0.010109] [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f [4.525092 0.006971] [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [4.530318 0.005226] [ 0.000000] OF: fdt: Machine model: Lichee Pi Nano [4.535147 0.004828] [ 0.000000] Memory policy: Data cache writeback [4.540014 0.004868] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128 [4.546372 0.006358] [ 0.000000] Kernel command line: panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=squashfs init=/sbin/mnt_overlay [4.557096 0.010724] [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [4.563426 0.006330] [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [4.570290 0.006864] [ 0.000000] Memory: 25868K/32768K available (4096K kernel code, 159K rwdata, 532K rodata, 1024K init, 205K bss, 6900K reserved, 0K cma-reserved) [4.583270 0.012980] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [4.589105 0.005835] [ 0.000000] random: get_random_bytes called from 0xc0600a84 with crng_init=0 [4.596064 0.006959] [ 0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [4.604088 0.008024] [ 0.000101] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [4.613078 0.008990] [ 0.000568] Console: colour dummy device 80x30 [4.617318 0.004241] [ 0.001027] printk: console [tty0] enabled [4.621344 0.004025] [ 0.001138] Calibrating delay loop... 334.23 BogoMIPS (lpj=1671168) [4.628018 0.006675] [ 0.050263] pid_max: default: 32768 minimum: 301 [4.632339 0.004321] [ 0.050425] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [4.639180 0.006841] [ 0.050484] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [4.646232 0.007052] [ 0.051856] CPU: Testing write buffer coherency: ok [4.651090 0.004858] [ 0.054029] Setting up static identity map for 0x80100000 - 0x8010003c [4.657220 0.006130] [ 0.056102] devtmpfs: initialized [4.661073 0.003853] [ 0.070968] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [4.670980 0.009907] [ 0.071114] futex hash table entries: 256 (order: -1, 3072 bytes) [4.677037 0.006058] [ 0.071270] pinctrl core: initialized pinctrl subsystem [4.682108 0.005070] [ 0.074046] NET: Registered protocol family 16 [4.686270 0.004162] [ 0.075338] DMA: preallocated 256 KiB pool for atomic coherent allocations [4.693215 0.006946] [ 0.080370] cpuidle: using governor menu [4.697250 0.004035] [ 0.126249] clocksource: Switched to clocksource timer [4.702239 0.004989] [ 0.180323] NET: Registered protocol family 2 [4.707061 0.004822] [ 0.183919] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes) [4.714263 0.007203] [ 0.184071] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [4.721272 0.007009] [ 0.184151] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [4.728051 0.006779] [ 0.184219] TCP: Hash tables configured (established 1024 bind 1024) [4.734209 0.006158] [ 0.184535] UDP hash table entries: 256 (order: 0, 4096 bytes) [4.740157 0.005948] [ 0.184639] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [4.746239 0.006082] [ 0.186047] NET: Registered protocol family 1 [4.751062 0.004823] [ 0.190645] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [4.757162 0.006100] [ 0.192058] squashfs: version 4.0 (2009/01/31) Phillip Lougher [4.763079 0.005917] [ 0.192167] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [4.769082 0.006003] [ 0.198473] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO [4.775056 0.005974] [ 0.250694] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [4.782225 0.007169] [ 0.252818] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator [4.793005 0.010780] [ 0.257108] pwm-backlight backlight: backlight supply power not found, using dummy regulator [4.801214 0.008209] [ 0.344204] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [4.807384 0.006171] [ 0.382288] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A [4.816277 0.008893] [ 0.695683] printk: console [ttyS0] enabled [4.828065 0.011788] [ 0.707818] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator [4.850157 0.022091] [ 0.729106] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator [4.872073 0.021917] [ 0.750949] m25p80 spi0.0: found s25fl064k, expected w25q64 [4.877286 0.005213] [ 0.756747] m25p80 spi0.0: s25fl064k (8192 Kbytes) [4.882336 0.005050] [ 0.761652] 5 fixed-partitions partitions found on MTD device spi0.0 [4.889007 0.006670] [ 0.768112] Creating 5 MTD partitions on "spi0.0": [4.893381 0.004374] [ 0.772955] 0x000000000000-0x00000003c000 : "u-boot" [4.907049 0.013668] [ 0.786887] 0x00000003c000-0x000000040000 : "dtb" [4.921066 0.014017] [ 0.800637] 0x000000040000-0x000000280000 : "kernel" [4.934068 0.013002] [ 0.813192] 0x000000280000-0x000000780000 : "rootfs" [4.948041 0.013973] [ 0.827617] 0x000000780000-0x000000800000 : "overlay" [4.968011 0.019970] [ 0.847169] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers [4.980047 0.012037] [ 0.859628] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [4.990011 0.009964] [ 0.869284] Initializing XFRM netlink socket [4.994210 0.004199] [ 0.873754] NET: Registered protocol family 17 [5.001047 0.006837] [ 0.880207] NET: Registered protocol family 15 [5.016096 0.015049] [ 0.894942] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator [5.031058 0.014961] [ 0.910067] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled [5.040995 0.009937] [ 0.920745] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc05308a0) [5.052203 0.011209] [ 0.931292] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc052f508) [5.060031 0.007827] [ 0.939156] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [5.066326 0.006295] [ 0.945803] [drm] No driver support for vblank timestamp query. [5.075135 0.008809] [ 0.954805] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [5.092130 0.016994] [ 0.970946] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device [5.100040 0.007910] [ 0.979521] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [5.116049 0.016008] [ 0.995243] using random self ethernet address [5.120280 0.004231] [ 0.999893] using random host ethernet address [5.132252 0.011971] [ 1.011061] usb0: HOST MAC 6e:38:35:96:dc:b3 [5.136162 0.003910] [ 1.015513] usb0: MAC 3a:97:0e:a2:12:d4 [5.140116 0.003954] [ 1.019570] using random self ethernet address [5.145041 0.004925] [ 1.024066] using random host ethernet address [5.149205 0.004164] [ 1.028785] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [5.156180 0.006975] [ 1.035453] g_ether gadget: g_ether ready [5.163033 0.006853] [ 1.042700] vcc3v3: disabling [5.176095 0.013062] [ 1.054986] random: fast init done [5.181042 0.004947] [ 1.060490] VFS: Mounted root (squashfs filesystem) readonly on device 31:3. [5.194026 0.012984] [ 1.073359] devtmpfs: mounted [5.201013 0.006987] [ 1.080565] Freeing unused kernel memory: 1024K [5.206109 0.005095] [ 1.085259] Run /sbin/mnt_overlay as init process [5.381470 0.175361] [ 1.260258] random: crng init done [5.779200 0.397730] [ 1.658367] g_ether gadget: high-speed config #1: CDC Ethernet (ECM) [5.883472 0.104272] [ 1.762622] overlayfs: upper fs does not support tmpfile. [5.888996 0.005524] [ 1.768214] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off. [6.116461 0.227465] Starting syslogd: OK [6.150147 0.033685] Starting klogd: OK [6.186171 0.036024] Running sysctl: OK [6.339748 0.153577] Saving random seed: OK [6.400528 0.060780] Starting network: OK [6.590488 0.189960] Starting udhcpd: OK [6.631476 0.040988] Starting dropbear sshd: OK [6.852184 0.220708] [6.852304 0.000120] Welcome to Buildroot [6.854232 0.001928] buildroot login:
你是怎么让Uboot和kernel统一时间打印的?
用grabserial
用grabserial
刚试了一下这工具不错,
装库:
D:\Python\Python37\python.exe -m pip install pyserial
克隆:
git clone https://github.com/zqb-all/grabserial
安装:
D:\Python\Python37\python.exe setup.py install
运行:
D:\Python\Python37\python.exe grabserial
最终优化配置可以分享一下吗?
我用你的uboot.config配置,编译出现错误,是需要修改uboot代码吗?
/root/u-boot/board/sunxi/board.c:699: undefined reference to `eth_env_set_enetaddr'
/root/u-boot/board/sunxi/board.c:488: undefined reference to `sunxi_mmc_init'
/root/u-boot/cmd/pxe.c:796: undefined reference to `do_bootm'
/root/u-boot/common/usb_kbd.c:625: undefined reference to `stdio_deregister_dev'
make: *** [u-boot] Error 1最近编辑记录 kekemuyu (2020-04-09 18:31:04)
U-BOOT是怎么删减到122K的?我去掉很多没用的都还有317K。
这个似乎太慢了,SPI读kernel,2MB用了2.7秒。SPI速度也不该这么慢。 我用SDNAND这里只花了400ms.
优化的速度很快了
没啥好办法,就是把不必要的驱动都去掉,比如你不用usb就禁用掉,还有音频之类的
之前SPI频率没设置好,导致用默认的1MHZ读取,所以才那么慢……这次改了之后,启动到shell只要4.72秒了
[0.000000 0.000000]
[0.000081 0.000081] U-Boot SPL 2019.04 (Apr 17 2020 - 20:28:57 +0800)
[0.004955 0.004874] DRAM: 32 MiB
[0.015868 0.010913] SPL: Unsupported Boot Device!
[0.018527 0.002659] Trying to boot from sunxi SPI
[0.360361 0.341834]
[0.360445 0.000083]
[0.360477 0.000033] U-Boot 2019.04 (Apr 17 2020 - 20:28:57 +0800) Allwinner Technology
[0.365895 0.005418]
[0.365914 0.000019] CPU: Allwinner F Series (SUNIV)
[0.368937 0.003022] Model: Lotlab ACT Monitor
[0.372805 0.003869] DRAM: 32 MiB
[0.894012 0.521207] Setting up a 480x272 lcd console (overscan 0x0)
[0.981311 0.087299] In: serial
[0.981699 0.000388] Out: vga
[0.981949 0.000250] Err: vga
[0.985814 0.003865] Hit any key to stop autoboot: 0
[0.994699 0.008885] SF: Detected w25q64cv with page size 256 Bytes, erase size 4 KiB, total 8 MiB
[1.004777 0.010079] device 0 offset 0x3c000, size 0x4000
[1.014091 0.009314] SF: 16384 bytes @ 0x3c000 Read: OK
[1.018516 0.004424] device 0 offset 0x40000, size 0x240000
[1.591478 0.572962] SF: 2359296 bytes @ 0x40000 Read: OK
[1.595648 0.004170] ## Flattened Device Tree blob at 80c00000
[1.599776 0.004128] Booting using the fdt blob at 0x80c00000
[1.604728 0.004951] Loading Device Tree to 80eab000, end 80eb02de ... OK
[1.618777 0.014050]
[1.618844 0.000067] Starting kernel ...
[1.619115 0.000271]
[2.350141 0.731026] [ 0.000000] Booting Linux on physical CPU 0x0
[2.353339 0.003198] [ 0.000000] Linux version 5.2.4 (jim@jim-pc) (gcc version 8.3.0 (Buildroot 2020.02)) #1 Fri Apr 17 16:03:10 CST 2020
[2.364343 0.011004] [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[2.370341 0.005997] [ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[2.375832 0.005491] [ 0.000000] OF: fdt: Machine model: Lichee Pi Nano
[2.381069 0.005237] [ 0.000000] Memory policy: Data cache writeback
[2.386379 0.005310] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[2.392483 0.006103] [ 0.000000] Kernel command line: panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=squashfs init=/sbin/mnt_overlay
[2.403266 0.010783] [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[2.409246 0.005980] [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[2.414662 0.005415] [ 0.000000] Memory: 25868K/32768K available (4096K kernel code, 159K rwdata, 532K rodata, 1024K init, 205K bss, 6900K reserved, 0K cma-reserved)
[2.428816 0.014154] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[2.434347 0.005532] [ 0.000000] random: get_random_bytes called from 0xc0600a84 with crng_init=0
[2.442313 0.007966] [ 0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[2.448554 0.006240] [ 0.000103] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[2.459003 0.010449] [ 0.000530] Console: colour dummy device 80x30
[2.462107 0.003104] [ 0.000961] printk: console [tty0] enabled
[2.467560 0.005453] [ 0.001063] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
[2.473369 0.005809] [ 0.050274] pid_max: default: 32768 minimum: 301
[2.478546 0.005177] [ 0.050431] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[2.484616 0.006070] [ 0.050488] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[2.492521 0.007905] [ 0.051836] CPU: Testing write buffer coherency: ok
[2.495973 0.003452] [ 0.054011] Setting up static identity map for 0x80100000 - 0x8010003c
[2.503781 0.007807] [ 0.056039] devtmpfs: initialized
[2.506730 0.002949] [ 0.070914] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[2.515540 0.008811] [ 0.071055] futex hash table entries: 256 (order: -1, 3072 bytes)
[2.523230 0.007690] [ 0.071200] pinctrl core: initialized pinctrl subsystem
[2.528665 0.005435] [ 0.073526] NET: Registered protocol family 16
[2.532079 0.003413] [ 0.074841] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2.539894 0.007816] [ 0.079693] cpuidle: using governor menu
[2.543061 0.003167] [ 0.125078] clocksource: Switched to clocksource timer
[2.548722 0.005660] [ 0.178353] NET: Registered protocol family 2
[2.551851 0.003129] [ 0.181941] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[2.559968 0.008117] [ 0.182092] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[2.567875 0.007907] [ 0.182175] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[2.573756 0.005881] [ 0.182240] TCP: Hash tables configured (established 1024 bind 1024)
[2.579702 0.005946] [ 0.182553] UDP hash table entries: 256 (order: 0, 4096 bytes)
[2.585088 0.005385] [ 0.182655] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[2.592948 0.007861] [ 0.184044] NET: Registered protocol family 1
[2.596119 0.003170] [ 0.188572] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[2.601933 0.005814] [ 0.190016] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2.609621 0.007689] [ 0.190123] jffs2: version 2.2. (NAND) 2001-2006 Red Hat, Inc.
[2.615380 0.005759] [ 0.196256] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[2.621007 0.005626] [ 0.247807] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[2.627030 0.006023] [ 0.248568] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[2.638022 0.010992] [ 0.251323] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[2.646965 0.008943] [ 0.335831] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[2.652162 0.005197] [ 0.372278] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[2.662772 0.010610] [ 0.685537] printk: console [ttyS0] enabled
[2.673443 0.010671] [ 0.696059] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[2.693179 0.019736] [ 0.715625] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[2.713386 0.020207] [ 0.735987] m25p80 spi0.0: found s25fl064k, expected w25q64
[2.719090 0.005704] [ 0.741680] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[2.722610 0.003520] [ 0.746664] 5 fixed-partitions partitions found on MTD device spi0.0
[2.730417 0.007807] [ 0.753058] Creating 5 MTD partitions on "spi0.0":
[2.734192 0.003775] [ 0.757955] 0x000000000000-0x00000003c000 : "u-boot"
[2.749183 0.014991] [ 0.771745] 0x00000003c000-0x000000040000 : "dtb"
[2.763125 0.013942] [ 0.785552] 0x000000040000-0x000000280000 : "kernel"
[2.777174 0.014049] [ 0.799569] 0x000000280000-0x000000780000 : "rootfs"
[2.793167 0.015993] [ 0.815553] 0x000000780000-0x000000800000 : "overlay"
[2.810735 0.017568] [ 0.833326] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
[2.823409 0.012674] [ 0.845894] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[2.834450 0.011041] [ 0.857047] Initializing XFRM netlink socket
[2.837862 0.003412] [ 0.861570] NET: Registered protocol family 17
[2.845357 0.007494] [ 0.868002] NET: Registered protocol family 15
[2.860150 0.014793] [ 0.882686] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[2.875217 0.015067] [ 0.897785] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[2.884561 0.009344] [ 0.908447] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc05308a0)
[2.896362 0.011801] [ 0.919005] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc052f508)
[2.902674 0.006312] [ 0.926870] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[2.910596 0.007922] [ 0.933515] [drm] No driver support for vblank timestamp query.
[2.919911 0.009315] [ 0.942445] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[2.935894 0.015983] [ 0.958518] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[2.943292 0.007398] [ 0.967079] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[2.960226 0.016934] [ 0.982810] using random self ethernet address
[2.963835 0.003608] [ 0.987453] using random host ethernet address
[2.976130 0.012295] [ 0.998613] usb0: HOST MAC 5e:b0:50:1e:38:d0
[2.979740 0.003609] [ 1.003061] usb0: MAC 36:03:f5:46:dc:54
[2.983214 0.003474] [ 1.007124] using random self ethernet address
[2.988200 0.004986] [ 1.011616] using random host ethernet address
[2.993549 0.005349] [ 1.016334] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[2.999682 0.006133] [ 1.022994] g_ether gadget: g_ether ready
[3.007613 0.007931] [ 1.030254] vcc3v3: disabling
[3.018141 0.010529] [ 1.040721] random: fast init done
[3.023640 0.005499] [ 1.046263] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[3.041610 0.017971] [ 1.064226] devtmpfs: mounted
[3.048696 0.007086] [ 1.071328] Freeing unused kernel memory: 1024K
[3.052474 0.003778] [ 1.076110] Run /sbin/mnt_overlay as init process
[3.189843 0.137369] [ 1.212072] random: crng init done
[3.577372 0.387528] [ 1.599975] g_ether gadget: high-speed config #1: CDC Ethernet (ECM)
[3.709996 0.132624] [ 1.732544] overlayfs: upper fs does not support tmpfile.
[3.713619 0.003624] [ 1.738142] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
[3.954268 0.240649] Starting syslogd: OK
[3.989470 0.035202] Starting klogd: OK
[4.032711 0.043241] Running sysctl: OK
[4.217460 0.184750] Initializing random number generator: OK
[4.229857 0.012396] Saving random seed: OK
[4.278125 0.048269] Starting network: OK
[4.469963 0.191837] Starting udhcpd: OK
[4.510248 0.040286] Starting dropbear sshd: OK
[4.724422 0.214173]
[4.724488 0.000067] Welcome to Buildroot
[4.724971 0.000482] buildroot login: 离线
在哪里设置呢? u-boot 吗?
歌以咏志 wrote:
在哪里设置呢? u-boot 吗?
uboot设备树
uboot设备树
有道理,默认是1Mbps那就尴尬了,怪不得那么慢。而且还是1bit的spi
最近编辑记录 smartcar (2020-04-17 22:25:51)
这一个的u-boot 与 linux 版本是多少?
这个spi的默认频率是1M,在spi驱动里面可以设置频率,设置高一些速度就快多了
请教一下,
https://github.com/Lichee-Pi/u-boot/blob/nano-v2018.01/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
&spi0 {
flash@0 {
#size-cells = <1>;
reg = <0>;
};这个 spi 速率明明是 40Mhz, 为什么说是 1Mhz 呢?
串口输出波特率提高,也可以快一点(应该)
正在优化代码,看下能不能把空间压小
根据官方文档一直没搞定
请问一下,这个问题您解决了吗?修改了哪里?
你好,请问你这个问题弄明白了吗,我现在也遇到了同样的问题???
正好学习需要用到系统裁剪和移植,有机会好好取经了。
进入U-BOOT图形配置->Environment ---> Environment offset(修改这个值) 我配置的是0X30000也就是最大192K,如果编译出来比这个值大,就要相应的改大
最近编辑记录 颜水花生 (2020-08-13 17:51:39)
你好,这个A33+emmc两秒多是怎么达到的,我现在要七秒钟左右!!!
我把uboot里的mmc支持去掉了,结果编译就各种报错,真是头疼
从启动到kernel完成自解压,可以做到1.7秒完成,
3M大小的内核,应该还有优化的空间
比如把内核的压缩算法换成UCL,根据前人的评测,自解压时间可以缩短40%,体积基本不变
[0.000000 0.000000]
[0.000000 0.000000] U-Boot SPL 2020.07 (Jul 23 2021 - 17:56:01 +0800)
[0.003958 0.003958] DRAM: 32 MiB
[0.016923 0.012966] Trying to boot from sunxi SPI
[0.125636 0.108713]
[0.125636 0.000000]
[0.126635 0.000999] U-Boot 2020.07 (Jul 23 2021 - 17:56:01 +0800) Allwinner Technology
[0.132615 0.005980]
[0.132615 0.000000] CPU: Allwinner F Series (SUNIV)
[0.134644 0.002028] Model: Allwinner F1C100s Generic Device
[0.137670 0.003026] DRAM: 32 MiB
[0.160615 0.022945] In: serial@1c25000
[0.162609 0.001995] Out: serial@1c25000
[0.163607 0.000998] Err: serial@1c25000
[0.167600 0.003993] Hit any key to stop autoboot: 0
[0.172583 0.004983] "Booting from SPI-NOR..."
[0.177580 0.004997] SF: Detected xt25f128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
[0.183727 0.006147] device 0 offset 0x40000, size 0x300000
[0.943240 0.759512] time elapsed: 755
[0.944898 0.001658] SF: 3145728 bytes @ 0x40000 Read: OK
[0.946893 0.001995] ## Loading kernel from FIT Image at 81000000 ...
[0.951885 0.004992] ## Loading fdt from FIT Image at 81000000 ...
[0.955869 0.003984] Booting using the fdt blob at 0x8128b0d8
[0.959863 0.003994] Loading Kernel Image
[0.991094 0.031231] Loading Device Tree to 81e9c000, end 81ea298d ... OK
[1.002053 0.010959]
[1.002053 0.000000] Starting kernel ...
[1.003807 0.001753]
[1.773779 0.769973] [ 0.000000] Booting Linux on physical CPU 0x0最近编辑记录 qdk0901 (2021-07-26 10:11:07)
@jiangming1399
[0.360361 0.341834]你这里spl加载uboot花了340ms,还可以优化
因为spl加载uboot这块分频是32分频,spl clock只有6M
频率提到100M,还可以再节省240ms以上
楼主更新下进展哦,现在4.7s能进console吗?
楼主还有后续吗?
楼主,看你的log,lcd显示用的是drm框架,视频中logo持续到了自己app启动。
我想问drm框架下,logo持续到app是怎么实现的?
楼主有板子的原理图吗 能否分享一个
@jiangming1399
请教下,你这里是接的VGA吗?如果要接VGA显示,需要做什么配置吗?谢谢
小白新人求教uboot中怎么开启logo显示
uboot导入内核的时候有个倒计时等待,不知道你这个代码中是不是优化过的,如果有等待可以在源码中修改掉,这个等待时间一般最少1S
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.5.3-g9c2490ac8-dirty (usr@usr) (gcc version 9.2.0 (GCC)) #35 SMP PREEMPT Wed Dec 1 15:03:57 CST 2021
[ 0.000000] Machine model: i.MX8MM board
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[ 0.000000] printk: bootconsole [ec_imx6q0] enabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000078000000, size 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xbfbc9800-0xbfbcafff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8400000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-
[ 1.057523] [dhd] dhdsdio_probe : the lock is released.
[ 1.057638] [dhd] dhd_module_init: Exit err=0
[ 1.057695] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T05:14:49 UTC (18889)
[ 1.057858] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.059631] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.060969] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.069609] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 1.075831] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.077400] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.079093] devtmpfs: mounted
[ 1.079677] Freeing unused kernel memory: 1600K
[ 1.100132] Run /sbin/init as init process
[ 1.125402] hub 2-1:1.0: USB hub found
[ 1.125407] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
[ 1.125488] hub 2-1:1.0: 4 ports detected
[ 1.471055] start user app
只用了1.5秒左右就进入用户程序了,是IMX8 1800M频率,EMMC存储器,内核没有压缩,压缩解压浪费时间
默认SPI是40M啊 为啥大家都说是1M?改成108M速度有明显提升吗
大牛,还想问问内核速度怎么改成800M?再menuconfig里面吗
@kekemuyu
碰到了同样问题,请问如何解决的?
请问uboot dma加载有用到吗
楼主加油,试过spi nand, 3.2S可以从上电到console
我只是没有替换glibc,按照楼主的.config编译rootfs为啥出来6M多呢 。开机非常慢,求教怎么回事。。。
楼主 ,我好像发现新大陆了,用ft卡ext4文件系统挂载速度比flash的jffs的快很多。
这个可以在config里面修改吗 ?
@qdk0901
你好,你是怎么做到花费这么少时间的
能分享uboot config吗
我从uboot到kernel至少4s
f1c100 spi flash启动
请问buildroot裁剪具体是裁剪那些地方啊,我自己编译还没加什么包生成的rootfs都快10M了,请问怎么解决?
grabserial可以精确测试linux 启动时间,有空也用一下
20年的帖子,25年我还在看,正好也遇到了减少开机时间的问题,目前使用的buildroot-tiny200的sdk,不知道这个问题目前有没有好的解决方案呢?
非常好的帖子,新手跟着实践一次就能学到很多东西
