楼主 #1 2019-12-20 13:30:28
aodzip
已发帖子: 130
新人第一帖,发个S3的核心板(AXP209+S3)
一个AXP209和一个S3,存储和WiFi都没有……
PE部分引出,右侧FPC是全部PD,左侧FPC是全部AUDIO相关,其余的引脚都在半孔上。
欢迎老前辈点评
(BGA焊到头秃
(注册了账号一直再论坛里搜刮资料也没发过帖子,被删号了怎么办?
Schematic
ALLWINNERS3.zip
PS
感谢HQEmbed设计的优秀的开发板和提供的资料
最近编辑记录 aodzip (2019-12-20 13:48:27)
#2 2019-12-20 13:39:27
好想做个有钱人
Re: 新人第一帖,发个S3的核心板(AXP209+S3)
挺漂亮的,谢谢分享, 能不能嫖一个 axp209 的原理图?
#3 2019-12-20 13:41:49
晕哥小弟
已发帖子: 311
漂亮.
楼主 #4 2019-12-20 13:44:24
aodzip
已发帖子: 130
我从Sochip的标案上拆下来的
#5 2019-12-20 13:50:39
aodzip wrote:
我从Sochip的标案上拆下来的
优秀,四层的吧?
楼主 #6 2019-12-20 13:52:11
aodzip
已发帖子: 130
优秀,四层的吧?
嗯,是四层的
(其实PCB Layout是找的外包……
楼主 #7 2019-12-20 13:55:43
aodzip
已发帖子: 130
U-Boot SPL 2019.10 (Nov 21 2019 - 11:20:56 +0800)
DRAM: 128 MiB
Trying to boot from MMC1
U-Boot 2019.10 (Nov 21 2019 - 11:20:56 +0800) Allwinner Technology
CPU:   Allwinner S3 (SUN8I 1681)
Model: hqembed core s3 v02
DRAM:  128 MiB
MMC:   mmc@01c0f000: 0, mmc@01c11000: 1
Loading Environment from FAT... Card did not respond to voltage select!
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
291 bytes read in 1 ms (284.2 KiB/s)
4724056 bytes read in 218 ms (20.7 MiB/s)
13452 bytes read in 3 ms (4.3 MiB/s)
   Loading Device Tree to 42df9000, end 42dff48b ... OK
[    0.000000] Linux version 5.3.12 (aodzip@ThinkPad-X1) (gcc version 8.3.0 (Buildroot 2019.11-rc2)) #24 SMP Sat Nov 23 10:45:45 CST 2019
[    0.000000] OF: fdt: Machine model: hqembed s3 lcd050ips
[    0.000000] cma: Reserved 16 MiB at 0x46c00000
[    0.000000] percpu: Embedded 15 pages/cpu s30412 r8192 d22836 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Memory: 102540K/131072K available (7168K kernel code, 331K rwdata, 1744K rodata, 1024K init, 252K bss, 12148K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] random: get_random_bytes called from start_kernel+0x2fc/0x488 with crng_init=0
[    0.000271] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000532] Console: colour dummy device 80x30
[    0.000602] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000621] pid_max: default: 32768 minimum: 301
[    0.000797] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000813] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001743] CPU: Testing write buffer coherency: ok
[    0.002323] /cpus/cpu@0 missing clock-frequency property
[    0.002357] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003201] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003436] rcu: Hierarchical SRCU implementation.
[    0.004010] smp: Bringing up secondary CPUs ...
[    0.004032] smp: Brought up 1 node, 1 CPU
[    0.004042] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.004049] CPU: All CPU(s) started in HYP mode.
[    0.004054] CPU: Virtualization extensions available.
[    0.004998] devtmpfs: initialized
[    0.008952] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.009287] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.009324] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.010333] pinctrl core: initialized pinctrl subsystem
[    0.011738] NET: Registered protocol family 16
[    0.013335] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.014634] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.014657] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.041995] SCSI subsystem initialized
[    0.042306] usbcore: registered new interface driver usbfs
[    0.042365] usbcore: registered new interface driver hub
[    0.042436] usbcore: registered new device driver usb
[    0.042708] mc: Linux media interface: v0.10
[    0.042757] videodev: Linux video capture interface: v2.00
[    0.042795] pps_core: LinuxPPS API ver. 1 registered
[    0.042801] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.042837] PTP clock support registered
[    0.043162] Advanced Linux Sound Architecture Driver Initialized.
[    0.043847] Bluetooth: Core ver 2.22
[    0.043942] NET: Registered protocol family 31
[    0.043953] Bluetooth: HCI device and connection manager initialized
[    0.043980] Bluetooth: HCI socket layer initialized
[    0.043991] Bluetooth: L2CAP socket layer initialized
[    0.044020] Bluetooth: SCO socket layer initialized
[    0.045128] clocksource: Switched to clocksource arch_sys_counter
[    0.057312] thermal_sys: Registered thermal governor 'step_wise'
[    0.057742] NET: Registered protocol family 2
[    0.058457] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.058493] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.058519] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.058543] TCP: Hash tables configured (established 1024 bind 1024)
[    0.058718] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.058775] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.059059] NET: Registered protocol family 1
[    0.060024] RPC: Registered named UNIX socket transport module.
[    0.060048] RPC: Registered udp transport module.
[    0.060055] RPC: Registered tcp transport module.
[    0.060060] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.062782] Initialise system trusted keyrings
[    0.063209] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.071872] NFS: Registering the id_resolver key type
[    0.071941] Key type id_resolver registered
[    0.071949] Key type id_legacy registered
[    0.107522] Key type asymmetric registered
[    0.107546] Asymmetric key parser 'x509' registered
[    0.107682] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.107695] io scheduler mq-deadline registered
[    0.107703] io scheduler kyber registered
[    0.113381] sun8i-s3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.189291] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.191908] sun8i-s3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.193146] printk: console [ttyS0] disabled
[    0.213472] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 38, base_baud = 1500000) is a U6_16550A
[    0.824007] printk: console [ttyS0] enabled
[    0.828872] sun8i-s3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    0.860201] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 39, base_baud = 1500000) is a U6_16550A
[    0.891112] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 40, base_baud = 1500000) is a U6_16550A
[    0.926605] libphy: Fixed MDIO Bus: probed
[    0.930720] CAN device driver interface
[    0.935253] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.941069] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.947386] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.954620] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.961911] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.966896] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.973678] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.979348] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.985018] dwmac-sun8i 1c30000.ethernet: device MAC address 4e:77:44:ce:75:99
[    0.992503] libphy: stmmac: probed
[    0.996790] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    1.003069] libphy: mdio_mux: probed
[    1.006775] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    1.013134] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    1.020371] libphy: mdio_mux: probed
[    1.024441] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.031096] ehci-platform: EHCI generic platform driver
[    1.036699] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.042317] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.050608] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[    1.085114] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.092420] hub 1-0:1.0: USB hub found
[    1.096425] hub 1-0:1.0: 1 port detected
[    1.101062] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.107399] ohci-platform: OHCI generic platform driver
[    1.113037] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.119775] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.127985] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[    1.200269] hub 2-0:1.0: USB hub found
[    1.204112] hub 2-0:1.0: 1 port detected
[    1.211527] usbcore: registered new interface driver usb-storage
[    1.217833] usbcore: registered new interface driver usbserial_generic
[    1.224395] usbserial: USB Serial support registered for generic
[    1.231051] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.242635] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.248488] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.257763] hub 3-0:1.0: USB hub found
[    1.261622] hub 3-0:1.0: 1 port detected
[    1.267147] dummy_hcd dummy_hcd.0: USB Host+Gadget Emulator, driver 02 May 2005
[    1.274479] dummy_hcd dummy_hcd.0: Dummy host controller
[    1.279940] dummy_hcd dummy_hcd.0: new USB bus registered, assigned bus number 4
[    1.288616] hub 4-0:1.0: USB hub found
[    1.292464] hub 4-0:1.0: 1 port detected
[    1.298368] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.307610] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.312676] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.317455] i2c /dev entries driver
[    1.322889] sun8i-s3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    1.333176] sun6i-csi f1cb1000.csi: IOBase: 0xC883E000
[    1.339205] link-frequencies 0 value 297000000
[    1.343666] sun6i-csi f1cb1000.csi: bus_type@sun6i_csi_fwnode_parse: 5
[    1.350292] sun6i-csi f1cb1000.csi: CSI2 DPHY
[    1.355865] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.363856] Bluetooth: HCI UART driver ver 2.3
[    1.368386] Bluetooth: HCI UART protocol H4 registered
[    1.374566] sun8i-s3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.386084] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.416179] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.424755] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    1.453759] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.461036] sun8i-s3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    1.482686] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.495704] mmc0: new high speed SDHC card at address aaaa
[    1.503176] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.508323] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    1.517007] usbcore: registered new interface driver usbhid
[    1.522588] usbhid: USB HID core driver
[    1.529608] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[    1.537304] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.543918]  mmcblk0: p1 p2
[    1.549948] NET: Registered protocol family 17
[    1.554429] can: controller area network core (rev 20170425 abi 9)
[    1.560908] NET: Registered protocol family 29
[    1.565427] can: raw protocol (rev 20170425)
[    1.569698] can: broadcast manager protocol (rev 20170425 t)
[    1.575386] can: netlink gateway (rev 20170425) max_hops=1
[    1.581223] Key type dns_resolver registered
[    1.585698] Registering SWP/SWPB emulation handler
[    1.591638] Loading compiled-in X.509 certificates
[    1.603457] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
[    1.612210] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory: -17
[    1.622926] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.631690] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
[    1.639937] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.651572] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.658352] ALSA device list:
[    1.661331]   #0: V3s Audio Codec
[    1.665581] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.674248] cfg80211: failed to load regulatory.db
[    1.689725] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.698132] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.708289] devtmpfs: mounted
[    1.712608] Freeing unused kernel memory: 1024K
[    1.717392] Run /sbin/init as init process
[    1.919412] random: fast init done
[    1.925018] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: [    2.167331] random: dd: uninitialized urandom read (512 bytes read)
OK
Starting network: OK
Welcome to HQEmbed Core S3 V02
buildroot login:
起一下之前给HQEmbed那个板子烧的TF卡。
#8 2019-12-20 13:56:07
aodzip wrote:
嗯,是四层的
求推荐外包,年底忙晕了,没外援估计会屎掉了。
楼主 #9 2019-12-20 13:59:17
aodzip
已发帖子: 130
EDA365
#10 2019-12-20 14:00:17
aodzip wrote:
EDA365
这个是外包平台吗?最终是qq/微信沟通吗?还是平台沟通?
楼主 #11 2019-12-20 14:01:28
aodzip
已发帖子: 130
是外包平台,最终是平台拉微信群沟通
#12 2019-12-20 14:04:12
aodzip wrote:
是外包平台,最终是平台拉微信群沟通
方便透露一下layout费用吗?
楼主 #13 2019-12-20 14:05:08
aodzip
已发帖子: 130
smartcar wrote:
方便透露一下layout费用吗?
1358含税
#14 2019-12-20 14:07:45
小智
已发帖子: 113
可以呀,便宜,牛
#15 2019-12-20 14:08:55
这个价格很公道 _
#16 2019-12-20 14:10:11
已发帖子: 857
膜拜,bga怎么焊的,求教程
#17 2019-12-20 14:10:24
aodzip wrote:
1358含税
感谢回复,我也去关注关注。
楼主 #18 2019-12-20 14:16:03
aodzip
已发帖子: 130
kekemuyu wrote:
膜拜,bga怎么焊的,求教程
手机维修视频欢迎你
#19 2019-12-20 14:21:04
kekemuyu wrote:
膜拜,bga怎么焊的,求教程
几个月前b站看到一个修主板视频,实在太牛了,同行修了一半修不好的板子他一步一步修好了,中间换过电阻,换过南桥,各种排除问题,有弹幕说这是同行下的战书,哈哈哈,笑死弟了。
#20 2019-12-20 14:36:05
已发帖子: 1,438
那个铜丝是手绕电感吗?电感量怎么计算?
半孔板去哪里做便宜?
最近编辑记录 Gentlepig (2019-12-20 14:36:58)
#21 2019-12-20 14:37:02
Freeboy
这价格太值了吧
楼主 #22 2019-12-20 14:40:06
aodzip
已发帖子: 130
Gentlepig wrote:
那个铜丝是手绕电感吗?电感量怎么计算?
半孔板去哪里做便宜?
不是,当采样电阻用的,真的采样电阻忘买了
嘉立创打的,不便宜
#23 2019-12-20 14:48:01
jimmy
已发帖子: 316
据说axp209的输出电压需要找代理商定制?估计就是一个eeprom确定的。
请问你是找哪家做的?
楼主 #24 2019-12-20 14:50:41
aodzip
已发帖子: 130
请问你是找哪家做的?
不用定制的啊,默认的给S3就好用
#25 2019-12-20 15:04:45
好想做个有钱人
aodzip wrote:
不用定制的啊,默认的给S3就好用
我翻了一下 axp209 手册:
2 路同步降压转换器 (DC-DC)
  1. DC-DC2:可在 0.7-2.275V之间调节, 25mV/step, 驱动能力 1.6A, 支持 VRC
  2. DC-DC3:可在 0.7-3.5V之间调节, 25mV/step, 驱动能力 1.2A
5 路线性稳压器 (LDO)
  1. LDO1:30mA,始终有效
  2. LDO2: 低噪声 LDO, 1.8V~3.3V可调节,100mV/step, 驱动能力 200mA
  3. LDO3:0.7-3.5V可调节, 25mV/step, 驱动能力 200mA
  4. LDO4: 低噪声 LDO, 1.8V~3.3V可调节,100mV/step, 驱动能力 200mA
  5. LDO5:低噪声 LDO, 1.8-3.3V可调节, 100mV/step, 驱动能力 50mA
这输出可调范围这么大, 那上电的时候到底是多少v呢?
最近编辑记录 好想做个有钱人 (2019-12-20 15:05:15)
#26 2019-12-20 15:10:45
aodzip wrote:
不用定制的啊,默认的给S3就好用
请问哪里买的?是立创商城吗,我看那里有卖
#27 2019-12-20 15:14:03
Jmhh247
已发帖子: 262
请问,左下角那个是手动绕的电感吗,是的话这操作可以封神了!。。。
楼主 #28 2019-12-20 16:19:48
aodzip
已发帖子: 130
淘宝上随便买的
楼主 #29 2019-12-20 16:20:20
aodzip
已发帖子: 130
不是的,代替采样电阻的
楼主 #30 2019-12-20 16:23:01
aodzip
已发帖子: 130
好想做个有钱人 wrote:
我翻了一下 axp209 手册:
DCDC2 1.25V
DCDC3 3.3V
所有的LDO都是3.3V
加了一路 SY8088 输出的1.5V DDR3供电
#31 2019-12-20 16:26:27
晕哥小弟
已发帖子: 311
如果有EMMC之类的就更加完美了....用SD卡做启动,总感觉不稳定.
楼主 #32 2019-12-20 16:28:49
aodzip
已发帖子: 130
SD卡都没有哈哈,公司用这个核心板的场景可能还挺不一致的,有用SPI Flash的,有用那种128M的贴片NAND的,有用EMMC的,反正用啥存储底板说了算,三路SDIO都引出了。
#33 2019-12-20 16:29:47
晕哥小弟
已发帖子: 311
S3最大可以支持多大的EMMC呢?
楼主 #34 2019-12-20 16:31:06
aodzip
已发帖子: 130
晕哥小弟 wrote:
S3最大可以支持多大的EMMC呢?
还没测试过,不过我感觉既然32G的TF卡都没问题,32G左右的EMMC也应该没问题。
#35 2019-12-20 16:35:08
晕哥小弟
已发帖子: 311
S3是你们自己焊接的,还是找贴片厂?
楼主 #36 2019-12-20 16:35:52
aodzip
已发帖子: 130
晕哥小弟 wrote:
S3是你们自己焊接的,还是找贴片厂?
图片上这一面都是我焊的
最近编辑记录 aodzip (2019-12-20 16:36:14)
#37 2019-12-20 16:38:12
晕哥小弟
已发帖子: 311
搜到一个网页. https://www.cnx-software.com/2018/03/30/allwinner-s3-camera-soc-includes-128mb-ram-an-i2s-audio-interface/
里面说支持4G emmc
#38 2019-12-20 16:38:54
晕哥小弟
已发帖子: 311
aodzip wrote:
图片上这一面都是我焊的
你钢网在哪买的? 什么型号的,我近期也准备自己画个S3玩玩.
楼主 #39 2019-12-20 16:40:43
aodzip
已发帖子: 130
我没用钢网,S3样片本身是植好锡的。其他的都是烙铁镀锡加风枪做的
#40 2019-12-20 16:55:18
已发帖子: 857
有连接吗?膜拜一下
#41 2019-12-20 17:09:47
kekemuyu wrote:
有连接吗?膜拜一下
https://b23.tv/av73039430
终于找到了,不服找我。
#42 2019-12-20 20:03:43
好想做个有钱人 wrote:
我翻了一下 axp209 手册:
手册里有写默认输出值,可以按照寄存器默认值计算的。
但注意买的芯片一定是非定制芯片,不然没准输出多少V的电压。
看我这https://whycan.cn/t_3390.html#p30274
最近编辑记录 迪卡 (2019-12-20 20:04:07)
#43 2020-03-23 09:26:53
路人甲
已发帖子: 202
这价格真的碉堡了!
#44 2020-04-22 13:09:24
834492956
厉害,在搞这么底层的东西,准备上自己的操作系统吗
#45 2020-04-22 15:51:01
sochip索智科技-全志代理商方案商
已发帖子: 61
晕哥,S3应该搞不出来双面板,我们layout之前说双面板的话主控BGA下面线走不出来。
优秀,四层的吧?
#46 2020-04-22 15:53:04
sochip索智科技-全志代理商方案商
已发帖子: 61
我比较好奇这个板子量产也是这样吗?好不好生产呀
欢迎老前辈点评
(BGA焊到头秃
/files/members/2138/photo_2019-12-20_13-29-28.jpg
Schematic
ALLWINNERS3.zip
PS
#47 2020-05-08 08:32:35
有梦的地方
已发帖子: 284
aodzip wrote:
1358含税
良心价,以后有设计pcb也考虑考虑外包。
#48 2020-05-08 14:53:25
liuchangyin
已发帖子: 204
自己手焊BGA厉害,焊接这个太麻烦了,最怕的是虚焊
#49 2020-05-17 10:50:26
郝好小小
AXP209的应用手册有吗?需要一个谢谢
#50 2020-05-17 13:02:01
Blueskull
已发帖子: 458
艾奥?维修厮?
#51 2021-06-18 09:21:18
995pc
已发帖子: 54
S3+ axp209,这个人焊接考验技术,用热风枪吹过一个EMMC
#52 2021-06-18 10:19:37
electronic_s
師傅能幫我設計一塊板子是S3 + AXP209 + microsd + wifiBT(RTL8723BS) + USB otg/周邊 + 引出i2c + 引出spi + 引出 audio codec 的小板嗎?
#53 2022-06-24 06:13:07
LinuxGo
已发帖子: 88
你好搂住,用axp这个电源方案 ,又没有遇到过系统插着串口线再上电,电源没有输出的问题?
#55 2022-12-28 15:29:39
josuke
焊接功力深厚!
#56 2022-12-29 17:16:32
ddd10086
优秀,请问有keil版本的软件吗
#57 2023-05-06 22:26:36
0xfff
求一个AXP209的电路图 免费的最好
#58 2023-05-06 22:51:48
已发帖子: 3,410
0xfff wrote:
求一个AXP209的电路图 免费的最好
https://linux-sunxi.org/images/2/20/Banan_pi_BPI-R1_MP_Schematic-SD_V3-20140922.pdf
#60 2023-05-06 22:57:43
0xfff
哇酷小二 wrote:
0xfff wrote:
求一个AXP209的电路图 免费的最好
有AD版的吗?
最近编辑记录 0xfff (2023-05-06 22:58:08)
#61 2023-08-28 09:56:51
oldx
lay板还是需要专业的人,基本上一次就成,自己折腾消耗的精力太大
