楼主 #1 2021-03-30 15:31:34
xfdr0805
已发帖子: 350
将PC机上交叉编译好的qt5环境复制到板子上时运行出错 EXT4-fs error (device mmcblk0p2)
ls命令都无法列出,经常碰到 EXT4-fs error (device mmcblk0p2) 这错误,只要我把文件复制到烧录好的SD rootfs分区 读取文件就会有这种错误
# tftp -g -r test 192.168.6.123 test
# vi /etc/profile
# source /etc/profile
# ls
test
# chmod +x test
# ./test
[  133.780334] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.797330] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.815013] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.832520] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.850577] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.868614] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.887334] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.905933] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.925140] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
[  133.944538] EXT4-fs error (device mmcblk0p2): ext4_lookup:1706: inode #32769: comm test: iget: checksum invalid
./test: error while loading shared libraries: libQt5Widgets.so.5: cannot open shared object file: No such file or directory
#2 2021-03-30 15:35:44
raspberryman
已发帖子: 503
Re: 将PC机上交叉编译好的qt5环境复制到板子上时运行出错 EXT4-fs error (device mmcblk0p2)
ext4都提示你根文件系统出错了
#3 2021-03-30 15:38:36
mysteryli
已发帖子: 510
buildroot的问题吧
解压出错了?SD卡接触不好?
楼主 #4 2021-03-30 16:04:56
xfdr0805
已发帖子: 350
raspberryman wrote:
ext4都提示你根文件系统出错了
是的,问题是出错的原因是什么呢?
楼主 #5 2021-03-30 16:08:06
xfdr0805
已发帖子: 350
mysteryli wrote:
buildroot的问题吧
解压出错了?SD卡接触不好?
在使用buildroot 修改根文件系统镜像大小后再编译,也会有类似的错误,,比如从60M 修改为256M 再重新make
输出的镜像会变大,但是DD 到SD卡会 会提示分区损坏,无法挂载,重新make clean也不行,修改为原尺寸就没问题
楼主 #6 2021-03-30 16:14:23
xfdr0805
已发帖子: 350
我换过卡 也是一样,说明buildroot生成的sdcard.img镜像就有问题
我现需要把PC机上交叉编译好的qt5 复制到板子上,
这样拷贝的:
sudo cp -r /opt/qt-5.15.2-arm /media/xfdr/rootfs/opt
mysteryli wrote:
buildroot的问题吧
解压出错了?SD卡接触不好?
#7 2021-03-30 16:20:15
mysteryli
已发帖子: 510
xfdr0805 wrote:
mysteryli wrote:
buildroot的问题吧
解压出错了?SD卡接触不好?
没改过镜像大小..
楼主 #8 2021-03-30 20:02:50
xfdr0805
已发帖子: 350
你编译的qt5 有多大?我就把地图除去了,全部编译完成 我看下有165M 是不是超级大?
mysteryli wrote:
xfdr0805 wrote:
mysteryli wrote:
buildroot的问题吧
解压出错了?SD卡接触不好?
没改过镜像大小..
#9 2021-03-30 20:23:11
mysteryli
已发帖子: 510
没改过镜像大小..
我的好像300多M吧 没注意 我用的SD卡 空间足够用
楼主 #10 2021-03-31 08:16:24
xfdr0805
已发帖子: 350
我用的是1G的卡,如果我不修改rootfs镜像大小,生成的sdimage默认是60M ,写入到SD卡上后,第二个分区也就60M左右,这显示不够啊 于是我手动调整分区到256 然后将rootfs.ext4恢复过去 再将/opt/qt-5.15.2-arm复制过去,插上卡启动是没问题,就是复制过的的qt运行环境却无法访问?很奇怪
mysteryli wrote:
mysteryli wrote:
没改过镜像大小..
#11 2021-03-31 09:06:04
mysteryli
已发帖子: 510
我和你的用法好像不一样啊,我把rootfs.rar解压到第二个分区,也没有啥别的操作啊,直接就用了
#12 2021-03-31 09:31:13
JasonWoo
已发帖子: 84
注意rootfs分区大小。
楼主 #13 2021-03-31 09:55:17
xfdr0805
已发帖子: 350
JasonWoo wrote:
注意rootfs分区大小。
默认是60M 我修改成了256M 生成的rootfs.ext4是变大了,但是实际上文件系统内容是损坏的,改回原大小就没问题,不知道什么原因?现在编译好的qt5没办法复制到板子上去
楼主 #14 2021-03-31 11:55:38
xfdr0805
已发帖子: 350
我把rootfs.ext4 挂载到/mnt下 看了一下,没问题啊,怎么写入到SD卡就出错呢
谁能指点一下呢?
xfdr0805 wrote:
JasonWoo wrote:
注意rootfs分区大小。
最近编辑记录 xfdr0805 (2021-03-31 12:01:43)
#15 2021-03-31 13:09:41
mysteryli
已发帖子: 510
为什么我buildroot编译出来的是rootfs.rar
谁能指点一下呢?
xfdr0805 wrote:
JasonWoo wrote:
注意rootfs分区大小。
/files/members/4881/2021-03-31_120021.png
#16 2021-03-31 13:48:57
阿黄
已发帖子: 299
是不是卡的后段区间中有错误? 先把卡全部格式化呢
楼主 #17 2021-03-31 15:19:30
xfdr0805
已发帖子: 350
我的编译出来也的,rootfs.tar 还有rootfs.ext2 rootfs.ext4 跟你配置有关
谁能指点一下呢?
楼主 #18 2021-03-31 15:20:33
xfdr0805
已发帖子: 350
试过,也不行,难道我这是个例,这种问题好像其它人基本没遇到啊
