楼主 # 2021-06-02 20:03:06
TeveT
已发帖子: 149
S3/V3S芯片跑Tina 3.5版本的gpio_keys使用
如题,分享一下
sun8iw8p1-pinctrl.dtsi 添加:
			key_pins: key_pins@0 {
				allwinner,pins= "PB12";
				allwinner,function = "gpio_in";
				allwinner,muxsel = <0>;
				allwinner,drive = <1>;
				allwinner,pull = <1>;
board.dts 添加:
gpio_keys {
	compatible = "gpio-keys";
	pinctrl-names = "default";
	pinctrl-0 = <&key_pins>;
	autorepeat;
	button@1 {
			label = "Key home";
			linux,code =  <158>;
			gpios =  <&pio 1 12 6 1 1 1>;
			gpio-key,wakeup;
			//interrupt-parent = <&pio>;
			//interrupts = <1 12 IRQ_TYPE_EDGE_FALLING>; //PB12
好,接着奏乐,接着舞……
#1 2024-08-12 09:05:42
ahui450331
Re: S3/V3S芯片跑Tina 3.5版本的gpio_keys使用
大佬 你好 我在tina3.5没有找到 V3S板块,请问一下你是用哪个板块来移植的
#2 2024-08-12 09:41:39
hameyou
已发帖子: 262
用R11或R7试试
