楼主 # 2021-12-13 23:28:32
memory
已发帖子: 716
V3s跑Tina,这是 spi nand flash挂了吗?
[      0.402]
U-Boot 2011.09-rc1-00000-geb34904-dirty (Nov 28 2021 - 17:50:12) Allwinner Technology
[      0.411]version: 1.1.0
[      0.414]uboot commit : eb3490458843de28cd4abb59d2013438b3d0f101
ready
set power on vol to default
no battery, limit to dc
no key input
dram_para_set start
dram_para_set end
In:    Out:   Err:   Net:   Warning: failed to set MAC address
read boot or recovery all
   Verifying Checksum ... OK
OK
OK
[    0.000000] Linux version 3.4.39 (whycan@ubuntu) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #122 Mon Dec 13 22:28:18 CST 2021
[    0.000000] Machine: sun8i
[    0.000000] ion_reserve_common: ion reserve: [0x45c00000, 0x48000000]!
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat c0702414, node_mem_map c073f000
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32512 pages, LIFO batch:7
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/nandd loglevel=8
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 128MB = 128MB total
[    0.000000] Memory: 85452k/85452k available, 45620k reserved, 0K highmem
[    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0680000   (6624 kB)
[    0.000000]       .init : 0xc0680000 - 0xc06aa000   ( 168 kB)
[    0.000000]       .data : 0xc06aa000 - 0xc0702b60   ( 355 kB)
[    0.000000]        .bss : 0xc0702b84 - 0xc073e56c   ( 239 kB)
[    0.000000] NR_IRQS:544
[    0.000000] 524 ahb1 set parent pll_periph0d2
[    0.000269] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000321] pid_max: default: 32768 minimum: 301
[    0.000586] Mount-cache hash table entries: 512
[    0.001452] CPU: Testing write buffer coherency: ok
[    0.001799] Setting up static identity map for 0x404d2aa8 - 0x404d2b00
[    0.002830] devtmpfs: initialized
[    0.005857] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006224] pinctrl core: initialized pinctrl subsystem
[    0.007079] NET: Registered protocol family 16
[    0.007562] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.007654] script_sysfs_init success
[    0.007728] sunxi_dump_init success
[    0.009258] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.011114] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.012396] tsc2003 device registered
[    0.012993] [sunxi-module]: [sunxi-module.0] probe success
[    0.013079] script config pll_isp to 360 Mhz
[    0.013130] Not Found clk pll_video in script
[    0.013162] script config pll_ve to 360 Mhz
[    0.013203] Not Found clk pll_periph0 in script
[    0.013225] Not Found clk pll_de in script
[    0.013240] sunxi_default_clk_init
[    0.013259] try to set pll6ahb1 to 200000000
[    0.013283] Error not get clk pll6ahb1
[    0.013310] Error not get clk pll6ahb1try to set ahb1 to 200000000
[    0.013353] try to set apb1 to 100000000
[    0.013742] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.026983] bio: create slab <bio-0> at 0
[    0.027410] pwm module init!
[    0.030471] ion_mem.size = 37748736
[    0.031493] SCSI subsystem initialized
[    0.031962] usbcore: registered new interface driver usbfs
[    0.032120] usbcore: registered new interface driver hub
[    0.032355] usbcore: registered new device driver usb
[    0.032614] twi_chan_cfg()341 - [twi0] has no twi_speed!
[    0.032640] twi_chan_cfg()352 - [twi0] has no twi_regulator.
[    0.032667] twi_chan_cfg()341 - [twi1] has no twi_speed!
[    0.032690] twi_chan_cfg()352 - [twi1] has no twi_regulator.
[    0.033629] Linux video capture interface: v2.00
[    0.034054] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.035689] cfg80211: Calling CRDA to update world regulatory domain
[    0.037887] Switching to clocksource arch_sys_counter
[    0.049239] NET: Registered protocol family 2
[    0.049731] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.050679] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.050864] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.050964] TCP: Hash tables configured (established 4096 bind 4096)
[    0.050988] TCP: reno registered
[    0.051014] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.051062] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.051577] NET: Registered protocol family 1
[    0.052139] RPC: Registered named UNIX socket transport module.
[    0.052167] RPC: Registered udp transport module.
[    0.052186] RPC: Registered tcp transport module.
[    0.052204] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.052540] [pm]aw_pm_init!
[    0.052567] standby_mode = 1.
[    0.052583] wakeup src cnt is : 3.
[    0.052681] sunxi_reg_init enter
[    0.055273] VFS: Disk quotas dquot_6.5.2
[    0.055391] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.056175] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.056777] NTFS driver 2.1.30 [Flags: R/W].
[    0.056962] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.057399] msgmni has been set to 166
[    0.059793] io scheduler noop registered
[    0.059820] io scheduler deadline registered
[    0.059966] io scheduler cfq registered (default)
[    0.059993] [DISP]disp_module_init
[    0.060878] cmdline,disp=
[    0.061914] rotation_sw module is config as no used
[    0.061970] [DISP] disp_get_rotation_sw,line:78:disp 0 out of range? g_rot_sw=0
[    0.062004] [DISP] disp_init_connections,line:289:NULL pointer: 0, 0
[    0.062168] fb_para.width = 240,fb_para.height = 240,fb_para.buffer_num = 2
[    0.063060] info->var.bits_per_pixel = 32
[    0.063087] [DISP] Fb_map_kernel_logo,line:924:Fb_map_kernel_logo failed!LCD_power_on 88 ..........
[    0.067242] LCD_power_on 89 ++++++++++++++++++++++++
[    0.068739] [DISP]disp_module_init finish
[    0.069212] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.069250] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.069282] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.070351] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.070383] sw_uart_pm()890 - uart0 clk is already enable
[    0.070422] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.263987] LCD_panel_init 122 ..........
[    0.803708] LCD_panel_init 123 ++++++++++++++++++++++++
[    0.809666] lcd_panel_st7789s_init 183 ++++++++++++++++++++++++
[    0.816432] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.826239] console [ttyS0] enabled
[    0.830876] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    0.838139] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.846627] [rf_pm]: failed to fetch wifi configuration!
[    0.852691] sunxi-rf-pm: probe of sunxi-rf-pm.0 failed with error -1
[    0.859882] [wifi_pm]: get wl_reg_on gpio failed
[    0.865369] [wifi_pm]: wifi gpio init is OK !!
[    0.870459] [rfkill]: init no bt used in configuration
[    0.877356] spinand type err! 0[NAND]nand init start, spinand_used_flag is -1066850196
[    0.886318] spinand_cache_level err! 0spinand_capacity_level err! 0
[    0.893378] NandHwInit: Start Nand Hardware initializing .....
[    0.899920] kernel:nand version: 2 25 20150917 1145
[    0.905541] pin count:4
[    0.908443] request tx DMA
[    0.911508] request general tx dma channel ok!
[    0.916489] request rx DMA
[    0.919521] request general rx dma channel ok!
[    0.924566] NAND_ClkRequest: get pll6 rate 600000000HZ
[    0.930404] SPI nand ID: 12c212c2 12c212c2
[    0.935019] [SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffcfffff
[    0.943049] spinand, spinand_id_number_ctl, nand type err! 0
[    0.949395] _UpdateExtAccessFreqPara: no para.
[    0.954679] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.964543] PHY_Scan_DelayMode: right delay mode 0x0
[    0.970524] PHY_Scan_DelayMode: right delay mode 0x800
[    0.976321] PHY_Scan_DelayMode: right delay mode,clk 75 MHz, bit[13]=0,bit[11]=1
[    0.984950] _GetOldPhysicArch: chip 0, block 20, page 0, oob: 0x0, 0x50, 0x48, 0x59
[    0.993566] _GetOldPhysicArch: get old physic arch ok, 0x6d 0x2!
[    1.000335] NAND_ReadPhyArch: get old physic arch ok, use old cfg, now:0x2 0x6d - old:0x2 0x6d!
[    1.010103]
[    1.010110]
[    1.013435] [SCAN_DBG] ==============Nand Architecture Parameter==============
[    1.021552] [SCAN_DBG]    Nand Chip ID:         0xffff12c2 0xffffffff
[    1.028774] [SCAN_DBG]    Nand Chip Count:      0x1
[    1.034257] [SCAN_DBG]    Nand Chip Connect:    0x1
[    1.039725] [SCAN_DBG]    Sector Count Of Page: 0x4
[    1.045218] [SCAN_DBG]    Page Count Of Block:  0x40
[    1.050801] [SCAN_DBG]    Block Count Of Die:   0x400
[    1.056463] [SCAN_DBG]    Plane Count Of Die:   0x2
[    1.061946] [SCAN_DBG]    Die Count Of Chip:    0x1
[    1.067414] [SCAN_DBG]    Bank Count Of Chip:   0x1
[    1.072896] [SCAN_DBG]    Optional Operation:   0x6d
[    1.078462] [SCAN_DBG]    Access Frequence:     0x4b
[    1.084043] [SCAN_DBG] =======================================================
[    1.084060]
[    1.093820]
[    1.095489] [FORMAT_DBG] ===========Logical Architecture Parameter===========
[    1.103504] [FORMAT_DBG]    Page Count of Logic Block:  0x40
[    1.109851] [FORMAT_DBG]    Sector Count of Logic Page: 0x8
[    1.116104] [FORMAT_DBG]    Block Count of Die:         0x200
[    1.122560] [FORMAT_DBG]    Die Count:                  0x1
[    1.128807] [FORMAT_DBG] ===================================================
[    1.136761] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.148082] nand:found factory_bad_block(new version) table in block:26!
[    1.155629] nand:support secure storage
[    1.174085] secure storage updata ok!
[    1.178196] nand secure storage ok: 21,22
[    1.182716] NandHwInit: End Nand Hardware initializing ..... OK!
[    1.190992] nand:found factory_bad_block(new version) table in block:26!
[    1.198509] nand:support secure storage
[    1.202833] start block:23
[    1.206119] [NE]mbr read 12
[    1.209683] [NE]mbr read ok!
[    1.212937] [NE]mbr read end!
[    1.216277] [NE]mbr partition start!
[    1.220751] [NE]mbr partition ok!
[    1.224469] [NE]mbr partition end!
[    1.228298] [NE]new nand info init!!
[    1.232593] [NE]mbr read 12
[    1.236150] [NE]mbr read ok!
[    1.239396] [NE]mbr read end!
[    1.242757] [NE]get mbr_data table
[    1.247253] [ND]ok  get factory_bad_block table!
[    1.252458] [ND]factory bad block:0 215!
[    1.257544] [NE]new_bad_block table new format!
[    1.263070] [ND]ok get a new bad table!
[    1.268040] [ND]build all_phy partition start!
[    1.273044] [NE]mbr partition start!
[    1.277466] [NE]mbr partition ok!
[    1.281210] [NE]mbr partition end!
[    1.285030] [NE]partition_num: 0,size :0x36400,cross_talk 0
[    1.291301] [NE]part mbr size: 0x800 type: 0
[    1.296090] [NE]part bootloader size: 0x4000 type: 0
[    1.301673] [NE]part env size: 0x400 type: 0
[    1.306462] [NE]part boot size: 0x4000 type: 0
[    1.311460] [NE]part system size: 0x2d000 type: 0
[    1.316736] [NE]part UDISK size: 0x800 type: 0
[    1.321739] st7789v3 init over![ND]factory bad block:0,215 PartitionNO:0
[    1.329368] [ND]build 1 phy_partition !
[    1.333686] [ND]nand_info->type :0
[    1.337498] [ND]nand_info->SectorNumsPerPage :8
[    1.342592] [ND]nand_info->BytesUserData :16
[    1.347379] [ND]nand_info->PageNumsPerBlk :64
[    1.352276] [ND]nand_info->BlkPerChip :512
[    1.356867] [ND]nand_info->FirstBuild :0
[    1.361278] [ND]nand_info->FullBitmap :-1066681228
[    1.366649] [ND]nand_info->bad_block_addr.Chip_NO :0
[    1.372228] [ND]nand_info->bad_block_addr.Block_NO :13
[    1.377989] [ND]nand_info->mbr_block_addr.Chip_NO :0
[    1.383568] [ND]nand_info->mbr_block_addr.Block_NO :12
[    1.389329] [ND]nand_info->no_used_block_addr.Chip_NO :0
[    1.395298] [ND]nand_info->no_used_block_addr.Block_NO :16
[    1.401462] [ND]nand_info->new_bad_block_addr.Chip_NO :0
[    1.407417] [ND]nand_info->new_bad_block_addr.Block_NO :14
[    1.413582] [ND]nand_info->new_bad_page_addr :65535
[    1.419050] [ND]nand_info->partition_nums :1
[    1.423854] [ND]sizeof partition:1192
[    1.427959] [ND]nand_info->partition:0:
[    1.432273] [ND]size:0x36400
[    1.435500] [ND]cross_talk:0x0
[    1.438921] [ND]attribute:0x0
[    1.442261] [ND]start: chip:0 block:16
[    1.446464] [ND]end  : chip:0 block:511
[    1.451234] [ND]nand_partition0
[    1.454877] [ND]nftl start:496,62
[    1.458712] [ND]first
[    1.485312] [ND]bad block: 199
[    1.524369] [ND]before second 495 434.
[    1.528673] LCD_bl_open 104 ..........
[    1.532916] LCD_bl_open 105 ++++++++++++++++++++++++
[    1.538614] [DISP] disp_lcd_pwm_enable,line:1023:pwm device hdl is NULL
[    1.703907] [NE]smart->version:aaaaaa01;
[    1.708318] [NE]smart->total_recv_read_sectors:9022;
[    1.713912] [NE]smart->total_recv_write_sectors:184534;
[    1.719770] [NE]smart->total_real_read_pages:1245;
[    1.725157] [NE]smart->total_real_write_pages:23552;
[    1.730737] [NE]smart->total_recv_discard_sectors:0;
[    1.736303] [NE]smart->total_real_discard_sectors:0;
[    1.741883] [NE]smart->total_recv_read_claim_pages:0;
[    1.747546] [NE]smart->total_gc_times:0;
[    1.751956] [NE]smart->total_gc_pages:0;
[    1.756353] [NE]smart->total_wl_times:0;
[    1.760763] [NE]smart->total_real_read_error_pages:0;
[    1.766426] [NE]smart->total_real_write_error_pages:0;
[    1.772201] [NE]smart->total_normal_power_cycles:2;
[    1.777669] [NE]smart->total_unusual_power_cycles:0;
[    1.783248] [NE]smart->max_block_erase_times:0;
[    1.788326] [NE]smart->min_block_erase_times:0;
[    1.793418] [NE]smart->max_block_used_counter:0;
[    1.798594] [NE]smart->min_block_used_counter:0;
[    1.803783] [NE]smart->read_reclaim_utc:0;
[    1.811149] [NE]recover_phy_page_mapping no used page 5!!
[    1.817209] [ND]recover 126 5
[    1.820561] [ND]A64 nand2.0 version:0009
[    1.825057] [ND]zone->nand_chip->blk_per_chip: 496
[    1.830542] [ND]zone->nand_chip->bytes_per_page: 4096
[    1.836303] [ND]zone->nand_chip->pages_per_blk: 64
[    1.841786] [ND]zone->nand_chip->max_erase_times: 3000
[    1.847645] [ND]zone->nand_chip->support_read_reclaim: 1
[    1.853711] [ND]zone->test: 0
[    1.857133] [ND]zone->zone_no: 0
[    1.860860] [ND]zone->zone_attr: 0
[    1.864762] [ND]zone->blocks: 495
[    1.868574] [ND]zone->bad_block: 1
[    1.872498] [ND]zone->logic_cap_in_sects: 222208
[    1.877771] [ND]zone->backup_cap_in_sects: 31232
[    1.883058] [ND]zone->free_block_num: 126
[    1.887651] [ND]zone->gc_strategy.start_gc_free_blocks: 12
[    1.893912] [ND]zone->gc_strategy.stop_gc_free_blocks: 40
[    1.900076] [ND]zone->gc_strategy.gc_page: 0
[    1.904960] [ND]zone->gc_strategy.process: 1
[    1.909843] [ND]zone->prio_gc.prio_type : 0
[    1.914644] [ND]zone->zone_start_phy_block->phy_block.Block_NO: 0
[    1.921589] [ND]zone->zone_end_phy_block->phy_block.Block_NO: 495
[    1.928520] [ND]zone->zone_phy_page_map_for_gc: c55f2800
[    1.934588] [ND]zone->current_block.user_info: c55ad000
[    1.940558] [ND]zone->current_block.block_info: c55e91b8
[    1.946612] [ND]zone->current_block.block_info->phy_block.Block_NO: 126
[    1.954140] [ND]zone->current_block.page_used: 5
[    1.959414] [ND]zone->current_block.block_info->block_used_count: 368
[    1.966748] [ND]zone->read_reclaim_complete: 0
[    1.971842] [ND]zone->temp_page_buf: c55e7000
[    1.976823] [ND]zone->max_erase_num: 1
[    1.981136] [ND]zone->cache.cache_totals: 0
[    1.985923] [ND]zone->cfg->nftl_dont_use_cache: 1
[    1.991308] [ND]zone->cfg->nftl_use_cache_sort: 1
[    1.996680] [ND]zone->cfg->nftl_support_gc_read_reclaim: 1
[    2.002945] [ND]zone->cfg->nftl_support_wear_leveling: 1
[    2.008997] [ND]zone->cfg->nftl_need_erase: 0
[    2.013993] [ND]zone->cfg->nftl_min_free_block_num: 32
[    2.019852] [ND]zone->cfg->nftl_gc_threshold_free_block_num: a
[    2.026503] [ND]zone->cfg->nftl_min_free_block: a
[    2.031889] [ND]zone->cfg->nftl_gc_threshold_ratio_numerator: 2
[    2.038624] [ND]zone->cfg->nftl_gc_threshold_ratio_denominator: 3
[    2.045568] [ND]zone->cfg->nftl_max_cache_num: 20
[    2.050954] [ND]zone->cfg->nftl_max_cache_write_num: 10
[    2.056910] [ND]zone->cfg->nftl_cross_talk: 0
[    2.061906] [ND]zone->cfg->nftl_read_claim_interval: 1296000
[    2.068349] [NE]smart->version:aaaaaa01;
[    2.072759] [NE]smart->total_recv_read_sectors:9022;
[    2.078325] [NE]smart->total_recv_write_sectors:184534;
[    2.084197] [NE]smart->total_real_read_pages:1251;
[    2.089568] [NE]smart->total_real_write_pages:23552;
[    2.095147] [NE]smart->total_recv_discard_sectors:0;
[    2.100726] [NE]smart->total_real_discard_sectors:0;
[    2.106292] [NE]smart->total_recv_read_claim_pages:0;
[    2.111969] [NE]smart->total_gc_times:0;
[    2.116366] [NE]smart->total_gc_pages:0;
[    2.120776] [NE]smart->total_wl_times:0;
[    2.125173] [NE]smart->total_real_read_error_pages:0;
[    2.130850] [NE]smart->total_real_write_error_pages:0;
[    2.136610] [NE]smart->total_normal_power_cycles:2;
[    2.142093] [NE]smart->total_unusual_power_cycles:0;
[    2.147658] [NE]smart->max_block_erase_times:0;
[    2.152750] [NE]smart->min_block_erase_times:0;
[    2.157829] [NE]smart->max_block_used_counter:0;
[    2.163018] [NE]smart->min_block_used_counter:0;
[    2.168194] [NE]smart->read_reclaim_utc:0;
[    2.172797] [ND]nftl ok!
[    2.175729] [ND]max_erase_times = 65000
[    2.180268] [NAND]nand_dev add mbr
[    2.184090] [NAND]nand_dev add bootloader
[    2.190586]  nanda:
[    2.193417] [NAND]nand_dev add env
[    2.200740]  nandb: unknown partition table
[    2.205926] [NAND]nand_dev add boot
[    2.213312]  nandc: unknown partition table
[    2.218505] [NAND]nand_dev add system
[    2.226063]  nandd: unknown partition table
[    2.231326] [NAND]nand_dev add UDISK
[    2.237279]  nande: unknown partition table
[    2.242704] [NAND]nand init end
[    2.246920] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    2.255163] spi spi0: master is unqueued, this is deprecated
[    2.261848] m25p_probe()966 - Use the Dual Mode Read.
[    2.267630] NorFlash ID: 0x18425 - 0x8425
[    2.272194] m25p80 spi0.0: unrecognized JEDEC id 018425
[    2.279844] usbcore: registered new interface driver rtl8192cu
[    2.286610] usbcore: registered new interface driver rt2500usb
[    2.293355] usbcore: registered new interface driver rt73usb
[    2.299822] usbcore: registered new interface driver rt2800usb
[    2.306422] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.333878] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.342921] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    2.351590] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    2.370051] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    2.378026] hub 1-0:1.0: USB hub found
[    2.382326] hub 1-0:1.0: 1 port detected
[    2.387615] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.414743] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.423393] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    2.431997] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.495198] hub 2-0:1.0: USB hub found
[    2.499438] hub 2-0:1.0: 1 port detected
[    2.504713] Initializing USB Mass Storage driver...
[    2.510476] usbcore: registered new interface driver usb-storage
[    2.517214] USB Mass Storage support registered.
[    2.522525] usbcore: registered new interface driver ums-cypress
[    2.529340] usbcore: registered new interface driver ums_eneub6250
[    2.536411] usbcore: registered new interface driver ums-freecom
[    2.543245] usbcore: registered new interface driver ums-isd200
[    2.549986] usbcore: registered new interface driver ums-jumpshot
[    2.556977] usbcore: registered new interface driver ums-realtek
[    2.563813] usbcore: registered new interface driver ums-sddr09
[    2.570567] usbcore: registered new interface driver ums-sddr55
[    2.577285] usbcore: registered new interface driver ums-usbat
[    2.584510] file system registered
[    2.591380] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.599106] android_usb gadget: Number of LUNs=1
[    2.604467]  lun0: LUN: removable file: (no medium)
[    2.610904] android_usb gadget: android_usb ready
[    2.616836] mousedev: PS/2 mouse device common for all mice
[    2.623316] sunxikbd_script_init: key para not found, used default para.
[    2.632672] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    2.640253] i2c /dev entries driver
[    2.644843] uvcvideo: Adding mapping Brightness to control 00000000-0000-0000-0000-000000000101/2.
[    2.654997] uvcvideo: Adding mapping Contrast to control 00000000-0000-0000-0000-000000000101/3.
[    2.664876] uvcvideo: Adding mapping Hue to control 00000000-0000-0000-0000-000000000101/6.
[    2.674265] uvcvideo: Adding mapping Saturation to control 00000000-0000-0000-0000-000000000101/7.
[    2.684367] uvcvideo: Adding mapping Sharpness to control 00000000-0000-0000-0000-000000000101/8.
[    2.694345] uvcvideo: Adding mapping Gamma to control 00000000-0000-0000-0000-000000000101/9.
[    2.703931] uvcvideo: Adding mapping Backlight Compensation to control 00000000-0000-0000-0000-000000000101/1.
[    2.715173] uvcvideo: Adding mapping Gain to control 00000000-0000-0000-0000-000000000101/4.
[    2.724678] uvcvideo: Adding mapping Power Line Frequency to control 00000000-0000-0000-0000-000000000101/5.
[    2.735730] uvcvideo: Adding mapping Hue, Auto to control 00000000-0000-0000-0000-000000000101/16.
[    2.745807] uvcvideo: Adding mapping Exposure, Auto to control 00000000-0000-0000-0000-000000000001/2.
[    2.756273] uvcvideo: Adding mapping Exposure, Auto Priority to control 00000000-0000-0000-0000-000000000001/3.
[    2.767617] uvcvideo: Adding mapping Exposure (Absolute) to control 00000000-0000-0000-0000-000000000001/4.
[    2.778568] uvcvideo: Adding mapping White Balance Temperature, Auto to control 00000000-0000-0000-0000-000000000101/11.
[    2.790788] uvcvideo: Adding mapping White Balance Temperature to control 00000000-0000-0000-0000-000000000101/10.
[    2.802422] uvcvideo: Adding mapping White Balance Component, Auto to control 00000000-0000-0000-0000-000000000101/13.
[    2.814442] uvcvideo: Adding mapping White Balance Blue Component to control 00000000-0000-0000-0000-000000000101/12.
[    2.826365] uvcvideo: Adding mapping White Balance Red Component to control 00000000-0000-0000-0000-000000000101/12.
[    2.838196] uvcvideo: Adding mapping Focus (absolute) to control 00000000-0000-0000-0000-000000000001/6.
[    2.848875] uvcvideo: Adding mapping Focus, Auto to control 00000000-0000-0000-0000-000000000001/8.
[    2.859055] uvcvideo: Adding mapping Zoom, Absolute to control 00000000-0000-0000-0000-000000000001/11.
[    2.869622] uvcvideo: Adding mapping Zoom, Continuous to control 00000000-0000-0000-0000-000000000001/12.
[    2.880388] uvcvideo: Adding mapping Privacy to control 00000000-0000-0000-0000-000000000001/17.
[    2.890441] usbcore: registered new interface driver uvcvideo
[    2.896885] USB Video Class driver (v1.0.8_SONiX_v2.6.36.04)
[    2.903478] sunxi cedar version 0.1
[    2.907606] [cedar]: install start!!!
[    2.912179] [cedar]: install end!!!
[    2.916160] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.923608] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    2.935092] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    2.942659] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    2.948918] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    2.958399] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Dec 13 2021 at 11:12:54
[    2.969868] [mmc]: get mmc0's IO(sdc_cd) failed
[    2.974996] [mmc]: get mmc0's sdc_power failed
[    2.980037] [mmc]: get mmc1's sdc_power failed
[    2.985039] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    2.993341] [mmc]: *** sunxi_mci_request_mmcio(L1379): sdc0 request io(cd) failed
[    3.001805] [mmc]: *** sunxi_mci_resource_request(L1580): sdc0 request mmcio failed
[    3.010899] [mmc]: *** sunxi_mci_free_mmcio(L1504): sdc0 set cd mulsel failed
[    3.018911] [mmc]: *** sunxi_mci_probe(L3090): sunxi-mmc.0: Failed to get resouce.
[    3.028442] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.041729] sunxi_leds_fetch_sysconfig_para script_parser_fetch "leds_para" leds_used = -1066837212
[    3.051981] =========script_get_err============
[    3.057718] usbcore: registered new interface driver usbhid
[    3.064055] usbhid: USB HID core driver
[    3.069121] usbcore: registered new interface driver snd-usb-audio
[    3.076331] Netfilter messages via NETLINK v0.30.
[    3.081669] nfnl_acct: registering with nfnetlink.
[    3.087156] nf_conntrack version 0.5.0 (1335 buckets, 5340 max)
[    3.094555] ctnetlink v0.93: registering with nfnetlink.
[    3.100664] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.108476] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.115603] xt_time: kernel timezone is -0000
[    3.120567] ip_set: protocol 6
[    3.124470] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.130794] arp_tables: (C) 2002 David S. Miller
[    3.136092] TCP: cubic registered
[    3.140172] NET: Registered protocol family 10
[    3.146825] IPv6 over IPv4 tunneling driver
[    3.152945] NET: Registered protocol family 17
[    3.158199] ThumbEE CPU extension supported.
[    3.163081] Registering SWP/SWPB emulation handler
[    3.170745] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:01:27 UTC (87)
[    3.182227] =========GPS========= :failed to fetch gps configuration!
[    3.189477] ALSA device list:
[    3.192872]   No soundcards found.
[    4.762231] TC Complete wait status timeout!
[    4.767034] wait tc complete timeout!
[    6.335585] TC Complete wait status timeout!
[    6.340388] wait tc complete timeout!
[    6.344502] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[    6.351580] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[    7.923438] TC Complete wait status timeout!
[    7.928240] wait tc complete timeout!
[    9.496813] TC Complete wait status timeout!
[    9.501613] wait tc complete timeout!
[    9.505727] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[    9.512806] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   11.084361] TC Complete wait status timeout!
[   11.089160] wait tc complete timeout!
[   12.657759] TC Complete wait status timeout!
[   12.662582] wait tc complete timeout!
[   12.666714] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[   12.673793] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   14.245408] TC Complete wait status timeout!
[   14.250224] wait tc complete timeout!
[   15.818857] TC Complete wait status timeout!
[   15.823657] wait tc complete timeout!
[   15.827771] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[   15.834850] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   17.406156] TC Complete wait status timeout!
[   17.410967] wait tc complete timeout!
[   18.979522] TC Complete wait status timeout!
[   18.984322] wait tc complete timeout!
[   18.988436] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xb
[   18.995515] PHY_PageRead : bank 0 blk 493 pg 11 read timeout
[   20.566761] TC Complete wait status timeout!
[   20.571572] wait tc complete timeout!
[   22.140095] TC Complete wait status timeout!
[   22.144882] wait tc complete timeout!
[   22.148996] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xc
[   22.156074] PHY_PageRead : bank 0 blk 493 pg 12 read timeout
[   23.727225] TC Complete wait status timeout!
[   23.732036] wait tc complete timeout!
[   25.300566] TC Complete wait status timeout!
[   25.305353] wait tc complete timeout!
[   25.309467] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xd
[   25.316547] PHY_PageRead : bank 0 blk 493 pg 13 read timeout
[   26.888137] TC Complete wait status timeout!
[   26.892954] wait tc complete timeout!
[   28.461548] TC Complete wait status timeout!
[   28.466359] wait tc complete timeout!
[   28.470504] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[   28.477536] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   30.049015] TC Complete wait status timeout!
[   30.053828] wait tc complete timeout!
[   30.057941] TX FIFO size error!
[   31.625967] TC Complete wait status timeout!
[   31.630791] wait tc complete timeout!
[   31.634904] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[   31.641983] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   33.213375] TC Complete wait status timeout!
[   33.218172] wait tc complete timeout!
[   34.786900] TC Complete wait status timeout!
[   34.791723] wait tc complete timeout!
[   34.795852] PHY_PageRead bad flag: bank 0x0  block 0x1ed  page 0xa
[   34.802902] PHY_PageRead : bank 0 blk 493 pg 10 read timeout
[   34.809400] List of all partitions:
[   34.813365] 5d00            8192 nanda  (driver?)
[   34.818658] 5d08             512 nandb  (driver?)
[   34.823971] 5d10            8192 nandc  (driver?)
[   34.829260] 5d18           92160 nandd  (driver?)
[   34.834566] 5d20            1024 nande  (driver?)
[   34.839845] No filesystem could mount root, tried:  ext3 ext2 ext4 cramfs squashfs vfat ntfs
[   34.849378] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(93,24)
[   34.858856] Backtrace:
[   34.861666] [<c0013490>] (dump_backtrace+0x0/0x110) from [<c04cc024>] (dump_stack+0x18/0x1c)
[   34.871153]  r6:00008000 r5:c5437029 r4:c5437029 r3:00000001
[   34.877578] [<c04cc00c>] (dump_stack+0x0/0x1c) from [<c04cc22c>] (panic+0x78/0x1cc)
[   34.886216] [<c04cc1b4>] (panic+0x0/0x1cc) from [<c0680cf8>] (mount_block_root+0x1e0/0x224)
[   34.895603]  r3:c5427ef4 r2:00000020 r1:c5427f20 r0:c05d5363
[   34.902017]  r7:c06a3c84
[   34.904898] [<c0680b18>] (mount_block_root+0x0/0x224) from [<c0680e2c>] (mount_root+0xf0/0x110)
[   34.914696] [<c0680d3c>] (mount_root+0x0/0x110) from [<c0680f70>] (prepare_namespace+0x124/0x184)
[   34.924665]  r7:c0702bc0 r6:c06a3c5c r5:c06a3c95 r4:c0702c24
[   34.931107] [<c0680e4c>] (prepare_namespace+0x0/0x184) from [<c06808f0>] (kernel_init+0x16c/0x1a8)
[   34.941173]  r5:c06a3c7c r4:00000007
[   34.945233] [<c0680784>] (kernel_init+0x0/0x1a8) from [<c0031bf8>] (do_exit+0x0/0x660)
