楼主 # 2022-04-13 10:48:51
YuzukiTsuru
芒果派 麻雀 Dual T113使用Buildroot一键构建
资源连接
项目地址:https://github.com/YuzukiHD/Buildroot-YuzukiSBC
同步更新国内镜像:https://gitee.com/GloomyGhost/Buildroot-YuzukiSBC
文档:https://yuzukihd.gloomyghost.com/Buildroot-YuzukiSBC/#/
编译方法
下拉Buildroot
在主站和镜像站中选一个下载就可以了。
git clone https://github.com/yuzukihd/Buildroot-YuzukiSBC      # 主站
git clone https://gitee.com/GloomyGhost/Buildroot-YuzukiSBC    # 镜像站
cd Buildroot-YuzukiSBC
配置环境变量
Buildroot-YuzukiSBC 支持自动切换WSL2编译模式,支持WSL2与虚拟机。暂不支持WSL1
source envsetup.sh
lunch
应用配置文件
make  mangopi_mq_dual_defconfig
编译
make
生成的镜像在output/images/文件夹里
楼主 #1 2022-04-13 10:49:05
YuzukiTsuru
Re: 芒果派 麻雀 Dual T113使用Buildroot一键构建
测试镜像:
百度云:链接:https://pan.baidu.com/s/1dPSaKJQrOMy8X1Xs_604Dw 提取码:awol
奶牛快传:https://cowtransfer.com/s/76711e52ad304f 或 打开【奶牛快传】cowtransfer.com 使用传输口令:gl9jyq 提取;
串口是PE2,PE3
楼主 #2 2022-04-13 10:49:12
YuzukiTsuru
不要用PhoenixCard刷写镜像,用dd,win32imager,ether刷
相关文档
https://yuzukihd.gloomyghost.com/Buildroot-YuzukiSBC/#/?id=flashing-firmware
#3 2022-05-04 09:46:55
kircar
出现一点小插曲...
mkbootimg: not found
解决方案:
sudo apt install -y android-tools-mkbootimg
#4 2022-05-04 09:57:26
kircar
reboot 命令后无法重启,卡死在这里
# reboot
# Stopping swupdate: OK
Stopping network: OK
Stopping iptables: OK
Stopping system message bus: done
Saving random seed: OK
Stopping klogd: OK
Stopping syslogd: OK
umount: devtmpfs busy - remounted read-only
[  323.862951] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
The system is going down NOW!
Sent SIGTERM to all processes
Sent SI[  325.876597] reboot_callback(): empty arg
[  325.881037] [ohci1-controller]: ohci shutdown start
[  325.886538] [ohci1-controller]: ohci shutdown end
[  325.891879] [ehci1-controller]: ehci shutdown start
[  325.897336] [ehci1-controller]: ehci shutdown end
[  325.902617] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
[  325.911163] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
[  325.931933] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[  326.722147] reboot: Restarting system
#5 2022-05-05 10:02:43
已发帖子: 1,409
我的imx6ul执行reboot也无法实现重启。
网上搜过,有的说是和硬件看门狗冲突,有的说uboot里设置个命令就行。
在坑网看到过这么一个帖子:今天确定了一件事情, linux的reboot命令到最后会调用看门狗的restart函数重启
最近编辑记录 Gentlepig (2022-05-05 11:40:55)
#6 2022-05-06 11:15:05
1518119742@qq.com
请问您视频硬解码试过吗?
#7 2022-05-13 15:08:39
bynce
一样的板子。 一样的屏幕 单拍5寸电阻屏旧,480*272分辨率,电阻触摸,外观旧
结果怎么差别这么大.
#8 2022-05-13 15:30:58
abnerl
已发帖子: 70
T113 WiFi速度能达到多少M
#9 2022-05-18 12:38:31
kakatoo
已发帖子: 88
这个支持wifi吗? uboot是通过patch 支持T113吗? 要改Uboot,在哪里改? 合并补丁有点麻烦啊
#10 2022-08-12 00:27:18
how0723
已发帖子: 65
密码多少啊?
#11 2022-08-13 00:02:42
ne_demon
怎么生成nand flash的image?
#12 2023-07-20 20:24:53
hameyou
已发帖子: 262
这个是tina 包吗?
#13 2024-04-12 08:16:19
looklike
YuzukiTsuru wrote:
测试镜像:
串口是PE2,PE3
这里的串口可以在哪里修改的?翻遍整个文件,也没看到关于uboot的串口设置
#14 2024-07-22 12:01:07
darthmike
已发帖子: 31
大佬,测试镜像都失效了,能再发一次吗
