楼主 # 2022-06-16 11:31:33
xwings
咨询下给位大佬一个zero摄像头的问题
我是用5.10的linux
在配置的时候只要勾选了,
Device Drivers > Multimedia support > Media drivers > V4L platform devices
<*> Allwinner V3s Camera Sensor Interface driver
启动的时候就没有显示了,第一个界面可以看到logo ,然后第二个界面就不行了,慢慢的屏幕就变黑了,这个是什么原因呢
楼主 #1 2022-06-21 12:10:58
xwings
Re: 咨询下给位大佬一个zero摄像头的问题
我是这样配置的
修改显示屏驱动方式
	// chosen {
	// 	#address-cells = <1>;
	// 	#size-cells = <1>;
	// 	ranges;
	// 	framebuffer-lcd {
	// 		compatible = "allwinner,simple-framebuffer",
	// 			     "simple-framebuffer";
	// 		allwinner,pipeline = "mixer0-lcd0";
	// 		clocks = <&display_clocks CLK_MIXER0>,
	// 			 <&ccu CLK_TCON0>;
	// 		status = "disabled";
	chosen {
		#size-cells = <1>;
		ranges;
		simplefb_lcd: framebuffer@0 {
			allwinner,pipeline = "de0-lcd0";
			clocks = <&ccu CLK_BUS_TCON0>, <&display_clocks 0>,
				 <&display_clocks 6>, <&ccu CLK_TCON0>;
驱动摄像头
sun8i-v3s.dtsi
			/omit-if-no-ref/
			csi1_mclk_pin: csi1-mclk-pin {
				pins = "PE1";
				function = "csi";
            //增加//////////////////////////////////
			csi1_clk: csi1-clk@0 {
				pins = "PE0","PE2","PE3";
				bias-disable;
				function = "csi";
			csi1_8bit: csi1-8bit@0 {
				pins 	 = "PE6","PE7","PE8","PE9","PE10","PE11","PE12","PE13","PE14","PE15";
				bias-disable;
				function = "csi";
			csi1_mclk: csi1-mclk@0 {
				pins = "PE1";
				bias-disable;
				function = "csi";
			i2c0_pins: i2c0-pins {
				pins = "PB6", "PB7";
				function = "i2c0";
            /omit-if-no-ref/
			i2c1_pe_pins: i2c1-pe-pins {
				pins = "PE21", "PE22";
				function = "i2c1";
			i2c1_pins: i2c1-pins {
				function = "i2c1";
        uart2: serial@1c28800 {
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
			pinctrl-0 = <&uart2_pins>;
			pinctrl-names = "default";
		dma: dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x01c02000 0x1000>;
			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_DMA>;
			resets = <&ccu RST_BUS_DMA>;
			#dma-cells = <1>;
		codec_analog: codec-analog@01c23000 {
			compatible = "allwinner,sun8i-v3s-codec-analog";
			reg = <0x01c23000 0x4>;
		codec: codec@01c22c00 {
			#sound-dai-cells = <0>;
			compatible = "allwinner,sun8i-v3s-codec";
			reg = <0x01c22c00 0x400>;
			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>;
			clock-names = "apb", "codec";
			resets = <&ccu RST_BUS_CODEC>;
			dmas = <&dma 15>, <&dma 15>;
			dma-names = "rx", "tx";
			allwinner,codec-analog-controls = <&codec_analog>;
        csi1: camera@1cb4000 {
			compatible = "allwinner,sun8i-v3s-csi";
			reg = <0x01cb4000 0x3000>;
			interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_CSI>,
				 <&ccu CLK_CSI1_SCLK>,
				 <&ccu CLK_DRAM_CSI>;
			clock-names = "bus", "mod", "ram";
			resets = <&ccu RST_BUS_CSI>;
			status = "okay";  // "disabled"修改为"okay"
sun8i-v3s-licheepi-zero-dock.dts
&mmc1 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
//增加----------------------------------------------------------------
&csi1 {
	pinctrl-0 = <&csi1_clk &csi1_8bit>;
	port {
		csi1_ep: endpoint {
		remote-endpoint = <&ov2640_0>;
		hsync-active = <0>;
		vsync-active = <0>;
		bus-width = <10>;
	    	pclk-sample = <1>;
&i2c1 {
    	pinctrl-0 = <&i2c1_pins>;
		clock-frequency = <400000>;
	ov2640: camera@30 {
		compatible = "ovti,ov2640";
		reg = <0x30>;
		pinctrl-0 = <&csi1_mclk_pin>;
		clocks = <&ccu CLK_CSI1_MCLK>;
		clock-names = "xvclk";
		assigned-clocks = <&ccu CLK_CSI1_MCLK>;
		assigned-clock-rates = <24000000>;
		port {
			ov2640_0: endpoint {
				remote-endpoint = <&csi1_ep>;
				bus-width = <10>;
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
修改配置文件
> Device Drivers > Multimedia support > Media device types
    [ *] Platform-specific devices
    <*>   Video Multiplexer
> Device Drivers > Multimedia support > Media drivers > Memory-to-memory multimedia devices
    <*>   Deinterlace
    <*>   Allwinner Deinterlace
    <*>   Allwinner DE2 rotation driver
> Device Drivers > Multimedia support > Media ancillary drivers > Camera sensor devices
    {*} OmniVision OV2640 sensor support
    <*> OmniVision OV7670 sensor support
楼主 #2 2022-06-21 12:11:29
xwings
这样配置对不对呢?
楼主 #3 2022-06-27 11:47:56
xwings
荔枝派zero + 底板的 是不是dvp摄像头和显示屏不能共用呢?
#4 2022-06-27 11:56:00
已发帖子: 3,408
是的,DVP和RGB不能共用,R11可以共用。
楼主 #6 2022-06-27 12:39:19
xwings
荔枝派nano可以同时使用摄像头和显示屏吗
#7 2022-06-27 12:54:56
已发帖子: 3,408
F1C芯片可以,但是荔枝派nano可能不行。
芒果派的tiny200开发板可以同时用。
楼主 #8 2022-06-27 13:01:13
xwings
好的 ,感谢 smile
#9 2022-06-28 10:35:17
mysteryli
已发帖子: 510
具体是什么原因呢 是因为芒果派用的RGB666?引脚冲突吗
楼主 #10 2022-06-28 23:22:45
xwings
还没有研究原理图,是不是脚复用的问题...
