楼主 # 2022-07-01 12:32:30
happy
zero spi flash启动时卡在了Starting kernel ...,大神们帮我看下
参考官方文档做flash:http://zero.lichee.pro/%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91/SPI_flash_build.html#
启动时卡在了Starting kernel ,没有任何下文,等多久都没有用
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Jun 30 2022 - 07:09:30)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Jun 30 2022 - 07:09:30 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
   Loading Device Tree to 42dfa000, end 42dffec2 ... OK
#1 2022-07-01 13:50:51
已发帖子: 1,438
Re: zero spi flash启动时卡在了Starting kernel ...,大神们帮我看下
可以考虑进入uboot命令模式,看下bootcmd和bootargs这两个参数。
print bootcmd
print bootargs
或者printenv
楼主 #2 2022-07-01 14:57:05
happy
print bootcmd
print bootargs
或者printenv
printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r}i
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=fel mmc0 usb0 pxe dhcp
bootargs=console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
bootcmd=sf probe 0; sf read 0x41800000 0x100000 0x10000; sf read 0x41000000 0x110000 0x400000; bootz 0x41000000 - 0x41800000
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${f;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=2
bootm_size=0x2e00000
cpu=armv7
dfu_alt_info_ram=kernel ram 0x41000000 0x800000;fdt ram 0x41800000 0x100000;ramdisk ram 0x41B00000 0x1000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x41800000
fdtcontroladdr=43b572a8
fdtfile=sun8i-v3s-licheepi-zero.dtb
kernel_addr_r=0x41000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
preboot=usb start
pxefile_addr_r=0x41A00000
ramdisk_addr_r=0x41B00000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_s;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do ie
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefe
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; ri
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script e
scriptaddr=0x41900000
serial#=12c00003ac5e36ca
soc=sunxi
stderr=serial@01c28000
stdin=serial@01c28000
stdout=serial@01c28000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
Environment size: 4295/32764 bytes
#3 2022-07-01 17:15:42
已发帖子: 1,438
不知道了,匿了...
可以看下烧录的zImage文件有多大,荔枝派是给内核分配了4M空间。
最近编辑记录 Gentlepig (2022-07-01 17:16:48)
#4 2022-07-01 17:34:31
已发帖子: 3,410
boot 前可以用 crc命令计算出文件(内存段)的校验码,和写入文件的校验码比较,如果对不上, 那就是zImage或者dtb有问题了.
楼主 #5 2022-07-01 17:43:19
happy
Gentlepig wrote:
不知道了,匿了...
编译后是4.1M,也有4M,都试过了,也不行
#6 2022-07-01 20:08:57
linux-xc
已发帖子: 29
踩完坑了,可以看看
https://whycan.com/t_8436.html
#7 2022-07-02 08:34:35
已发帖子: 1,438
happy wrote:
Gentlepig wrote:
不知道了,匿了...
超过4M应该是不行的,可以试试将文件系统再裁剪下。
#8 2022-07-02 09:58:01
xfdr0805
已发帖子: 350
uboot和kernel用的不是同一个console 也是这种现象
楼主 #9 2022-07-02 15:16:55
happy
linux-xc wrote:
踩完坑了,可以看看
多谢,发现真的是好多坑
#10 2022-11-13 10:10:20
tocurd
已发帖子: 19
楼主搞定了吗,我也是5.2想从flash启动一直卡在Starting kernel
楼主 #11 2022-11-14 09:02:44
happy
好像是SEC_4K的问题,我没去搞了,卡在alsa编译的问题上
