楼主 # 2023-02-18 04:26:41
Simn
已发帖子: 33
F1C200S SPI->ST7789
需要帮助。 传输 SPI FIFO 数据时遇到问题,每 64 字节加载一次会使传输延迟 35 毫秒。 如何不间断地传输数据?
#1 2023-02-18 09:17:55
dykxjh
已发帖子: 190
Re: F1C200S SPI->ST7789
代码贴出来看看 啊
楼主 #2 2023-02-18 15:43:15
Simn
已发帖子: 33
dykxjh wrote:
代码贴出来看看 啊
void spi_write(unsigned char *buffer, int length)
  int i;
  int cnt;
  while(length)
    if(length <= 64)
      cnt = length;
      cnt = 64;
    //number of bytes burst
    *SPI0_MBC = cnt;
    //number of bytes to transmit
    *SPI0_MTC = cnt;
    *SPI0_BCC = cnt;
    //Load FIFO
    for(i=0;i<cnt;++i)
      *SPI0_TXD_BYTE = *buffer++;
    //Start
    *SPI0_TCR |= SPI_TCR_XCH_START;
    length -= cnt;
    while(*SPI0_TCR & SPI_TCR_XCH_START);
    *SPI0_FCR |= SPI_FCR_RX_FIFO_RST;
    while(*SPI0_FCR & SPI_FCR_RX_FIFO_RST);
void LCD_Fill(uint16_t Color)
    uint16_t i, j;
    for (i = 0; i < LCD_WIDTH; i++)
        for (j = 0; j < LCD_HEIGHT; j++)
            *(volatile uint16_t *) (disp_buf + j * LCD_WIDTH + i) = Color;
    SetAddressWindow(0, 0, LCD_WIDTH - 1, LCD_HEIGHT - 1);
    spi_write(disp_buf,LCD_WIDTH * LCD_HEIGHT*2);
#3 2023-02-18 20:25:31
dykxjh
已发帖子: 190
改成DMA传输不香吗
最近编辑记录 dykxjh (2023-02-18 20:25:43)
楼主 #4 2023-02-20 02:47:41
Simn
已发帖子: 33
dykxjh wrote:
改成DMA传输不香吗
我不明白如何启动 DMA->SPI。 有如何做到这一点的例子吗?
楼主 #5 2023-02-24 23:33:26
Simn
已发帖子: 33
配置 DMA SPI 再次出现问题。 发送前 64 个字节,然后挂起 while(NDMA0->CR & NDMA_CFG_BUSY_STATUS)SPI1_RXD_BYTE;问题是什么?
https://whycan.com/t_3405.html
NDMA0->CR = NDMA_CFG_DRQ_SPI1_TX      |
                NDMA_CFG_DRQ_SDRAM_MEMORY |
                NDMA_CFG_ADDRESS_IO_MODE  |
                NDMA_CFG_WAIT_STATE2;
    NDMA0->SAR =&disp_buf;
    NDMA0->DAR = SPI1_TXD_BYTE;
    *SPI1_FCR = SPI_FCR_RF_RST         |
                SPI_FCR_TX_FIFO_RST    |
                SPI_FCR_TF_DRQ_EN      |
                SPI_FCR_TX_TRIG_LEV_64 |
                SPI_FCR_RX_FIFO_RST    |
                SPI_FCR_RX_TRIG_LEV_1;
void flushDMA()
    *SPI1_MBC = *SPI1_MTC = *SPI1_BCC = NDMA0->BCR = 170*320*2;
     NDMA0->CR |=NDMA_CFG_LOADING;
    *SPI1_TCR &= ~SPI_TCR_SS_LEVEL_HIGH;
    *SPI1_TCR |= SPI_TCR_XCH_START;
    while(NDMA0->CR & NDMA_CFG_BUSY_STATUS) SPI1_RXD_BYTE;
    *SPI1_ISR |= SPI_ISR_TC;
    while(!(*SPI1_ISR&SPI_ISR_TC)SPI1_RXD_BYTE;
    *SPI1_TCR |= SPI_TCR_SS_LEVEL_HIGH;
#6 2023-02-25 09:43:27
dykxjh
已发帖子: 190
是不是接收FIFO满了,数据没有及时取走? 可以配置忽略接收FIFO状态
楼主 #7 2023-02-26 00:58:52
Simn
已发帖子: 33
是的,这确实是 RX FIFO 溢出感谢您的提示。 但主要问题仍然存在,每个 64B 都有 34uS 的暂停。 我不明白为什么,关于 DMA 功能的信息很少
楼主 #8 2023-02-28 01:41:52
Simn
已发帖子: 33
终于问题解决了。 现在我需要设置一个 DMA 中断并删除 dma 完成等待函数“while(NDMA0->CR & NDMA_CFG_BUSY_STATUS)*SPI1_FCR |= SPI_FCR_RX_FIFO_RST;”
#9 2023-03-08 15:29:31
gary
已发帖子: 54
直接用MCU I8080接口的屏就行了
#10 2024-03-01 22:02:53
视觉℡
已发帖子: 43
Simn wrote:
终于问题解决了。 现在我需要设置一个 DMA 中断并删除 dma 完成等待函数“while(NDMA0->CR & NDMA_CFG_BUSY_STATUS)*SPI1_FCR |= SPI_FCR_RX_FIFO_RST;”/files/members/7990/dma3.jpg/files/members/7990/spi.mp4
楼主请教怎么解决SPI传输中间暂停问题的?
