楼主 # 2023-05-16 18:14:31
Ozelot
所在地: Ukraine
已发帖子: 54
Bare metal USB-host example (F1C100S)
This is a simple USB Host implementation in bare metal with supporting Mass Storage Device. In this example, the program reads a file from the drive and copies its contents to another file: GitHub
#1 2023-05-16 21:41:53
lanlanzhilian
已发帖子: 171
Re: Bare metal USB-host example (F1C100S)
Very tasty
#2 2023-05-31 20:20:26
Neil
This is a very nice topic.
楼主 #3 2023-06-05 18:23:59
Ozelot
所在地: Ukraine
已发帖子: 54
Example of using USB-Ethernet adapter and lwIP-library.
Adapters based on the RTL8152B chip are supported. The driver from u-boot was taken as the base. This program runs on bare metal and depends on the lwIP TCP/IP stack. In this example, the available services are ping, iperf, and http server. At the same time, iperf demonstrated the use of a bandwidth of more than 90Mbits/sec.
Link: GitHub
#6 2024-07-20 10:26:04
三哥
楼主,我用了你的代码,读U盘时卡在这里,能帮忙看一下是什么问题不?谢谢
bulk_in()函数里面,执行wait_csr()时一直不能返回
