楼主 #1 2018-09-14 17:01:26
pqfeng
已发帖子: 129
为什么没有mtdblock3?
Log内容如下:
4 cmdlinepart partitions found on MTD device spi32766.0
[ 0.863704] Creating 4 MTD partitions on "spi32766.0":
[ 0.868870] 0x000000000000-0x000000100000 : "uboot"
[ 0.874351] 0x000000100000-0x000000110000 : "dtb"
[ 0.879546] 0x000000110000-0x000000910000 : "kernel"
[ 0.884861] 0x000000910000-0x000001000000 : "rootfs"
[ 0.890672] libphy: Fixed MDIO Bus: probed
[ 0.895257] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.901785] ehci-platform: EHCI generic platform driver
[ 0.907328] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.912959] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.920913] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 0.955216] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.962425] hub 1-0:1.0: USB hub found
[ 0.966369] hub 1-0:1.0: 1 port detected
[ 0.970855] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.977153] ohci-platform: OHCI generic platform driver
[ 0.982697] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.989416] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.997386] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.070300] hub 2-0:1.0: USB hub found
[ 1.074129] hub 2-0:1.0: 1 port detected
[ 1.081670] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.091356] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.098253] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.102825] i2c /dev entries driver
[ 1.107796] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 1.117341] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.185428] sunxi-mmc 1c0f000.mmc: base:0xc406b000 irq:23
[ 1.192420] usbcore: registered new interface driver usbhid
[ 1.198094] usbhid: USB HID core driver
[ 1.203739] NET: Registered protocol family 17
[ 1.208430] Key type dns_resolver registered
[ 1.212850] Registering SWP/SWPB emulation handler
[ 1.223417] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[ 1.234077] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 1.252332] Console: switching to colour frame buffer device 100x30
[ 1.264807] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 1.273357] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.284746] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.290587] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.299677] hub 3-0:1.0: USB hub found
[ 1.303536] hub 3-0:1.0: 1 port detected
[ 1.308735] using random self ethernet address
[ 1.313191] using random host ethernet address
[ 1.318810] usb0: HOST MAC 2e:e2:d3:8c:ab:44
[ 1.323131] usb0: MAC fe:f5:30:5d:80:8c
[ 1.327113] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.334591] g_cdc gadget: g_cdc ready
[ 1.338618] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:02:39 UTC (159)
[ 1.347023] vcc3v0: disabling
[ 1.349998] vcc5v0: disabling
[ 1.352963] ALSA device list:
[ 1.355980] No soundcards found.
[ 1.359563] Warning: unable to open an initial console.
[ 1.367436] Freeing unused kernel memory: 2048K
Welcome to Lichee Pi
Lichee login: root
ls
cd ..
ls
bin lib media proc sbin usr
dev lib32 mnt root sys var
etc linuxrc opt run tmp
mount -t jffs2 /dev/mtd
mtd0 mtd0ro mtd1 mtd1ro mtd2 mtd2ro mtd3 mtd3ro
mount -t jffs2 /dev/mtd3 /mnt/
mount: mounting /dev/mtd3 on /mnt/ failed: No such device
modprob mtdblock3
-sh: modprob: not found
ls
cd dev/
ls
bus ptyv7 ttyd9
console ptyv8 ttyda
cpu_dma_latency ptyv9 ttydb
fb0 ptyva ttydc
full ptyvb ttydd
gpiochip0 ptyvc ttyde
i2c-0 ptyvd ttydf
input ptyve ttye0
kmsg ptyvf ttye1
log ptyw0 ttye2
mem ptyw1 ttye3
memory_bandwidth ptyw2 ttye4
mtd0 ptyw3 ttye5
mtd0ro ptyw4 ttye6
mtd1 ptyw5 ttye7
mtd1ro ptyw6 ttye8
mtd2 ptyw7 ttye9
mtd2ro ptyw8 ttyea
mtd3 ptyw9 ttyeb
mtd3ro ptywa ttyec
network_latency ptywb ttyed
network_throughput ptywc ttyee
楼主 #2 2018-09-14 17:03:08
pqfeng
已发帖子: 129
Re: 为什么没有mtdblock3?
上面内容显示,产生MTD是解析出来了4个区,所以在/dev/下有mtd0,mtd1,mtd2,mtd3,但我通过Mount的方式想把它挂到/mnt目录下,却进行不了。
不知道,要如何进行?mtdblock3,要不要进行格式化?
#3 2018-09-14 17:05:44
已发帖子: 9,513
Re: 为什么没有mtdblock3?
flash_eraseall /dev/mtd3
mkdir -p /mnt/data
mount -t jffs2 /dev/mtdblock3 /mnt/data/
其中 flash_eraseall 是 busybox 里面的命令.
