楼主 #1 2018-09-20 11:48:07
无情一刀
已发帖子: 723
flash启动可以启动 但是中间出现好多的没有找到一些地址数据
打印出来的数据是下面 不知道是不是正常的
sun8i-v3s-licheepi-zero-dock.dtb 和sun8i-v3s-licheepi-zero.dtb 这两个文件有什么区别吗
烧写sun8i-v3s-licheepi-zero.dtb 根本就起不来
[ 8.675427] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00970024: 0x7487 instead
[ 8.684899] jffs2: Further such events for this erase block will not be printed
[ 8.706326] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980000: 0x7c74 instead
[ 8.715840] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980004: 0xb555 instead
[ 8.725330] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980008: 0xee00 instead
[ 8.734808] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0098000c: 0x0481 instead
[ 8.744283] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980010: 0x9c68 instead
[ 8.753757] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980014: 0xe84d instead
[ 8.763231] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980018: 0x0f0c instead
[ 8.772704] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0098001c: 0x54b4 instead
[ 8.782179] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980020: 0xc40b instead
[ 8.791654] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00980024: 0xd61f instead
[ 8.801125] jffs2: Further such events for this erase block will not be printed
[ 8.822518] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990000: 0x122e instead
[ 8.832059] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990004: 0xeffa instead
[ 8.841544] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990008: 0xfced instead
[ 8.851021] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0099000c: 0x1851 instead
[ 8.860530] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990010: 0xbebc instead
[ 8.870010] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990014: 0xcff0 instead
[ 8.879486] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990018: 0xc93c instead
[ 8.888962] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0099001c: 0x3f3b instead
[ 8.898438] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990020: 0x8700 instead
[ 8.907935] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00990024: 0x42c0 instead
[ 8.917412] jffs2: Further such events for this erase block will not be printed
[ 8.938819] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0000: 0x21c8 instead
[ 8.948356] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0004: 0x4b75 instead
[ 8.957842] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0008: 0x86de instead
[ 8.967320] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a000c: 0xd81f instead
[ 8.976795] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0010: 0xf575 instead
[ 8.986261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0014: 0x5504 instead
[ 8.995737] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0018: 0x85c3 instead
[ 9.005211] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a001c: 0x01a6 instead
[ 9.014686] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0020: 0xe961 instead
[ 9.024162] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009a0024: 0x09b5 instead
[ 9.033634] jffs2: Further such events for this erase block will not be printed
[ 9.052925] jffs2: Empty flash at 0x009ac2e0 ends at 0x009ac400
[ 9.059720] jffs2: Empty flash at 0x009acbe4 ends at 0x009acbf8
[ 9.066409] jffs2: Empty flash at 0x009acc00 ends at 0x009acc14
[ 9.073057] jffs2: Empty flash at 0x009acc1c ends at 0x009acc30
[ 9.079776] jffs2: Empty flash at 0x009acc38 ends at 0x009acc4c
[ 9.087969] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0018: 0x0f00 instead
[ 9.097466] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b001c: 0xfcd7 instead
[ 9.106944] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0038: 0x6e9b instead
[ 9.116417] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b003c: 0x2ad1 instead
[ 9.125882] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0040: 0xf9cb instead
[ 9.135382] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0044: 0x4b1d instead
[ 9.144864] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0048: 0xeb84 instead
[ 9.154340] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b004c: 0x2cd1 instead
[ 9.163815] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0050: 0x5bf3 instead
[ 9.173309] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x009b0054: 0xd899 instead
[ 9.182785] jffs2: Further such events for this erase block will not be printed
[ 9.207207] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 9.214250] devtmpfs: mounted
[ 9.218639] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting mdev...
Starting network: OK
Welcome to Lichee Pi
Lichee login: root
c d..
-sh: c: not found
cd ..
ls
bin lib media proc sbin usr
dev lib32 mnt root sys var
etc linuxrc opt run tmp yang
最近编辑记录 无情一刀 (2018-09-20 11:53:49)
#2 2018-09-20 11:53:29
已发帖子: 9,513
Re: flash启动可以启动 但是中间出现好多的没有找到一些地址数据
你的 flash 是什么型号?
#3 2018-09-20 11:54:38
已发帖子: 9,513
https://whycan.cn/t_1662.html
从能用的镜像抽出文件,一个一个替换排除问题
楼主 #4 2018-09-20 11:55:21
无情一刀
已发帖子: 723
你的 flash 是什么型号?
我的flash型号是mx25L12835F
楼主 #5 2018-09-20 11:56:38
无情一刀
已发帖子: 723
无情一刀 wrote:
你的 flash 是什么型号?
主要两个板子同一样的flash 一样的镜像 另外一个可以跑起来没有问题
#6 2018-09-20 11:59:57
已发帖子: 9,513
把能跑的flash读出来, 或者把jffs2分区读出来,写回到有问题的板子。
楼主 #7 2018-09-20 12:04:41
无情一刀
已发帖子: 723
现在我用TF卡烧写没有 然后我把卡拔掉 重启 从flash里面去读可以起来但是只会启动一次 ,然后再重启的时候就起不来了
#8 2018-09-20 13:33:37
已发帖子: 9,513
没看懂, 你用什么软件烧写 jffs2 的?
楼主 #9 2018-09-20 13:35:58
无情一刀
已发帖子: 723
为什么我把屏幕接上就可以了
最近编辑记录 无情一刀 (2018-09-20 13:40:28)
#10 2018-09-20 13:46:18
已发帖子: 9,513
和屏幕应该没什么关系,SYNC LCD 是单向数据传输,并不会影响CPU和存储.
楼主 #11 2018-09-20 14:00:22
无情一刀
已发帖子: 723
插上屏幕会有这些
但是不插上是没有上面的这些信息的
所有就是不知道为什么了
#12 2018-09-20 14:23:03
已发帖子: 9,513
有可能spi 频率的原因,
在 dts/dtsi 里面找到spi flash, 把频率降到 16Mhz 试一试.
