楼主 # 2024-03-08 12:12:59
memory
已发帖子: 719
D1s 用新买的SPI FLASH W25N01GVZEIG 烧录失败,换一片又可以
[1184]fes begin commit:88480af-dirty
[1187]set pll start
[1189]periph0 has been enabled
[1192]set pll end
[1193][pmu]: bus read error
[1196]board init ok
[1198]beign to init dram
[1200]ZQ value = 0x2f
[1202]get_pmu_exist() = -1
[1205]ddr_efuse_type: 0xa
[1207]trefi:7.8ms
[1209][AUTO DEBUG] single rank and full DQ!
[1213]ddr_efuse_type: 0xa
[1216]trefi:7.8ms
[1218][AUTO DEBUG] rank 0 row = 13
[1221][AUTO DEBUG] rank 0 bank = 4
[1224][AUTO DEBUG] rank 0 page size = 2 KB
[1228]DRAM BOOT DRIVE INFO: V0.33
[1231]DRAM CLK = 528 MHz
[1234]DRAM Type = 2 (2:DDR2,3:DDR3)
[1237]DRAMC read ODT  off.
[1239]DRAM ODT off.
[1241]ddr_efuse_type: 0xa
[1244]DRAM SIZE =64 M
[1246]dram_tpr4:0x0
[1248]PLL_DDR_CTRL_REG:0xf8002b00
[1251]DRAM_CLK_REG:0xc0000000
[1254][TIMING DEBUG] MR2= 0x0
[1258]DRAM simple test OK.
[1261]init dram ok
U-Boot 2018.05-g24521d6-dirty (Mar 07 2024 - 23:26:39 +0800) Allwinner Technology
[04.340]DRAM:  64 MiB
[04.345]Relocation Offset is: 01ee0000
[04.375]secure enable bit: 0
[04.381]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[04.387]flash init start
[04.390]workmode = 16,storage type = 0
try card 0
set card number 0
get card number 0
[04.397][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
[04.407][mmc]: get sdc_type fail and use default host:tm1.
FDT ERROR:fdt_get_all_pin:get property handle pinctrl-0 error:FDT_ERR_INTERNAL
[04.423][mmc]: get card0 default pin fail
[04.433][mmc]: can't find node "mmc0",will add new node
[04.438][mmc]: fdt err returned <no error>
[04.441][mmc]: Using default timing para
[04.445][mmc]: sunxi mmc pin set failed!
[04.449]error card no error
[04.451][mmc]: MMC Device -1 not found
fail to find one useful mmc card2
try emmc fail
[04.469]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
[04.475]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
[04.540]sunxi-spinand-phy: request spi0 gpio ok
[04.544]sunxi-spinand-phy: request general tx dma channel ok!
[04.550]sunxi-spinand-phy: request general rx dma channel ok!
[04.555]sunxi-spinand-phy: set spic0 clk to 20 Mhz
[04.560]sunxi-spinand-phy: init spic0 clk ok
sspi->base_addr = 0x4025000, the SPI control register:
[VER] 0x4025000 = 0x00010001, [GCR] 0x4025004 = 0x00000083, [TCR] 0x4025008 = 0x00000184
[ICR] 0x4025010 = 0x00000f00, [ISR] 0x4025014 = 0x00000032, [FCR] 0x4025018 = 0x00200020
[FSR] 0x402501c = 0x00000000, [WCR] 0x4025020 = 0x00000000, [CCR] 0x4025024 = 0x00000002
[SDC] 0x4025028 = 0x00002000, [BCR] 0x4025030 = 0x00000000, [TCR] 0x4025034 = 0x00000000
[BCC] 0x4025038 = 0x00000000, [DMA] 0x4025088 = 0x000000e5
[04.606]sunxi-spinand-phy: not detect any munufacture from id table
[04.622]sunxi-spinand-phy: get spi-nand Model from fdt fail
[04.627]sunxi-spinand-phy: get phy info from fdt fail
[04.632]sunxi-spinand-phy: not detect munufacture from fdt
[04.637]sunxi-spinand-phy: detect munufacture from id table: Winbond
[04.643]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[04.649]sunxi-spinand-phy: ========== arch info ==========
[04.654]sunxi-spinand-phy: Model:               W25N01GVZEIG
[04.660]sunxi-spinand-phy: Munufacture:         Winbond
[04.664]sunxi-spinand-phy: DieCntPerChip:       1
[04.669]sunxi-spinand-phy: BlkCntPerDie:        1024
[04.674]sunxi-spinand-phy: PageCntPerBlk:       64
[04.678]sunxi-spinand-phy: SectCntPerPage:      4
[04.683]sunxi-spinand-phy: OobSizePerPage:      64
[04.687]sunxi-spinand-phy: BadBlockFlag:        0x0
[04.692]sunxi-spinand-phy: OperationOpt:        0x7
[04.696]sunxi-spinand-phy: MaxEraseTimes:       65000
[04.701]sunxi-spinand-phy: EccFlag:             0x0
[04.706]sunxi-spinand-phy: EccType:             2
[04.710]sunxi-spinand-phy: EccProtectedType:    3
[04.714]sunxi-spinand-phy: ========================================
[04.720]sunxi-spinand-phy:
[04.723]sunxi-spinand-phy: ========== physical info ==========
[04.728]sunxi-spinand-phy: TotalSize:    128 M
[04.733]sunxi-spinand-phy: SectorSize:   512 B
[04.737]sunxi-spinand-phy: PageSize:     2 K
[04.741]sunxi-spinand-phy: BlockSize:    128 K
[04.745]sunxi-spinand-phy: OOBSize:      64 B
[04.749]sunxi-spinand-phy: ========================================
[04.755]sunxi-spinand-phy:
[04.757]sunxi-spinand-phy: ========== logical info ==========
[04.763]sunxi-spinand-phy: TotalSize:    128 M
[04.767]sunxi-spinand-phy: SectorSize:   512 B
[04.771]sunxi-spinand-phy: PageSize:     4 K
[04.775]sunxi-spinand-phy: BlockSize:    256 K
[04.779]sunxi-spinand-phy: OOBSize:      128 B
[04.784]sunxi-spinand-phy: ========================================
[04.800]sunxi-spinand-phy: set spic0 clk to 6 Mhz
[04.804]sunxi-spinand-phy: block lock register: 0x00
[04.809]sunxi-spinand-phy: feature register: 0x19
[04.814]sunxi-spinand-phy: sunxi physic nand init end
[04.824]Loading Environment from SUNXI_FLASH... OK
[04.838]try to burn key
[04.841]out of usb burn from boot: not need burn key
[04.846]Net:   [04.847]No ethernet found.
sunxi work mode=0x10
run usb efex
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x9
set address 0x9 ok
set address 0xa
set address 0xa ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
origin_erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 8
part[0] name      :boot-resource
part[0] classname :DISK
part[0] addrlo    :0x8000
part[0] lenlo     :0x1f8
part[0] user_type :32768
part[0] keydata   :0
part[0] ro        :0
part[1] name      :env
part[1] classname :DISK
part[1] addrlo    :0x81f8
part[1] lenlo     :0x1f8
part[1] user_type :32768
part[1] keydata   :0
part[1] ro        :0
part[2] name      :env-redund
part[2] classname :DISK
part[2] addrlo    :0x83f0
part[2] lenlo     :0x1f8
part[2] user_type :32768
part[2] keydata   :0
part[2] ro        :0
part[3] name      :boot
part[3] classname :DISK
part[3] addrlo    :0x85e8
part[3] lenlo     :0x5000
part[3] user_type :32768
part[3] keydata   :0
part[3] ro        :0
part[4] name      :rootfs
part[4] classname :DISK
part[4] addrlo    :0xd5e8
part[4] lenlo     :0x173c0
part[4] user_type :32768
part[4] keydata   :0
part[4] ro        :0
part[5] name      :recovery
part[5] classname :DISK
part[5] addrlo    :0x249a8
part[5] lenlo     :0x5780
part[5] user_type :32768
part[5] keydata   :0
part[5] ro        :0
part[6] name      :rootfs_data
part[6] classname :DISK
part[6] addrlo    :0x2a128
part[6] lenlo     :0x2800
part[6] user_type :32768
part[6] keydata   :0
part[6] ro        :0
part[7] name      :UDISK
part[7] classname :DISK
part[7] addrlo    :0x2c928
part[7] lenlo     :0x0
part[7] user_type :0
part[7] keydata   :0
part[7] ro        :0
common1(partition3) need it, here is a weak func
total part: 9
mbr 0, 8000, 8000
boot-resource 1, 1f8, 8000
env 2, 1f8, 8000
env-redund 3, 1f8, 8000
boot 4, 5000, 8000
rootfs 5, 173c0, 8000
recovery 6, 5780, 8000
rootfs_data 7, 2800, 8000
UDISK 8, 0, 0
[08.764]erase blk 0 to blk 32
[08.767]blk 0 is bad, skip to erase
need erase flash: 1
[08.796]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
device nand0 <nand>, # parts = 4
 #: name                size            offset          mask_flags
 0: boot0               0x00100000      0x00000000      1
 1: uboot               0x00300000      0x00100000      1
 2: secure_storage      0x00100000      0x00400000      1
 3: sys                 0x07b00000      0x00500000      0
active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
defaults:
mtdids  : nand0=nand
[08.856]MTD info (4)
[08.858]pagesize: 0x1000
[08.860]blksize: 0x40000
[08.863]num  offset     bytes      name
[08.866]0    0x00000000 0x00100000 boot0
[08.870]1    0x00100000 0x00300000 uboot
[08.874]2    0x00400000 0x00100000 secure_storage
[08.878]3    0x00500000 0x07b00000 sys
[08.881]ubi attach the last part of mtd device: NO.3
[09.011]ubi0: attaching mtd4
[09.198]ubi0: scanning is finished
[09.201]ubi0: empty MTD device detected
[09.251]ubi0: attached mtd4 (name "sys", size 123 MiB)
[09.256]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[09.262]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[09.268]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[09.275]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[09.280]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[09.287]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
[09.294]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
no part need to protect user data
[10.663]erase blk 0 to blk 32
[10.666]blk 0 is bad, skip to erase
[10.688]erase blk 40 to blk 1024
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
force mbr
defaults:
mtdids  : nand0=nand
[11.596]MTD info (4)
[11.598]pagesize: 0x1000
[11.600]blksize: 0x40000
[11.602]num  offset     bytes      name
[11.606]0    0x00000000 0x00100000 boot0
[11.610]1    0x00100000 0x00300000 uboot
[11.613]2    0x00400000 0x00100000 secure_storage
[11.618]3    0x00500000 0x07b00000 sys
[11.621]MBR info (unalign):
[11.624]partno   addr       sects      type       name
[11.628]0        0x00000000 0x00008000 0x00000001 mbr
[11.633]1        0x00008000 0x000001f8 0x00008000 boot-resource
[11.639]2        0x000081f8 0x000001f8 0x00008000 env
[11.644]3        0x000083f0 0x000001f8 0x00008000 env-redund
[11.649]4        0x000085e8 0x00005000 0x00008000 boot
[11.654]5        0x0000d5e8 0x000173c0 0x00008000 rootfs
[11.659]6        0x000249a8 0x00005780 0x00008000 recovery
[11.664]7        0x0002a128 0x00002800 0x00008000 rootfs_data
[11.669]8        0x0002c928 0x00000000 0x00000000 UDISK
[11.674]ubi attach the last part of mtd device: NO.3
[11.679]MBR info (align):
[11.681]partno   addr       sects      type       name
[11.686]0        0x00002800 0x000081f0 0x00000001 mbr
[11.691]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
[11.697]2        0x0000abe8 0x000001f8 0x00008000 env
[11.701]3        0x0000ade0 0x000001f8 0x00008000 env-redund
[11.707]4        0x0000afd8 0x000050b8 0x00008000 boot
[11.712]5        0x00010090 0x00017418 0x00008000 rootfs
[11.717]6        0x000274a8 0x00005898 0x00008000 recovery
[11.722]7        0x0002cd40 0x00002958 0x00008000 rootfs_data
[11.727]8        0x0002f698 0x00000000 0x00000000 UDISK
[11.732]ubi attach the last part of mtd device: NO.3
[11.737]ubi attatch mtd, name: sys
[11.740]ubi0: detaching mtd4
[11.745]ubi0: mtd4 is detached
[11.748]ubi0: attaching mtd4
[11.935]ubi0: scanning is finished
[11.938]ubi0: empty MTD device detected
[11.989]ubi0: attached mtd4 (name "sys", size 123 MiB)
[11.994]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[12.000]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[12.007]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[12.013]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[12.018]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[12.025]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
[12.033]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
Creating static volume mbr of size 17031168
Creating dynamic volume boot-resource of size 258048
Creating dynamic volume env of size 258048
Creating dynamic volume env-redund of size 258048
Creating dynamic volume boot of size 10579968
Creating dynamic volume rootfs of size 48771072
Creating dynamic volume recovery of size 11612160
Creating dynamic volume rootfs_data of size 5419008
No size specified -> Using max size (26578944)
[13.713]reset last volume size to 0xcac8
Creating dynamic volume UDISK of size 26578944
[13.825]fill gap start: volume mbr sects 0x7f80
[27.208]ubi0 warning: ubi_io_read_vid_hdr: bad magic number at PEB 149: 55464d65 instead of 55424921
[27.217]Volume identifier header dump:
[27.221]        magic     55464d65
[27.223]        version   69
[27.225]        vol_type  70
[27.227]        copy_flag 68
[27.229]        compat    68
[27.231]        vol_id    1145324612
[27.234]        lnum      1145324612
[27.236]        data_size 1145566276
[27.239]        used_ebs  1145324614
[27.242]        data_pad  1145324612
[27.245]        sqnum     4919131752989213783
[27.248]        hdr_crc   d5c4fce7
[27.250]Volume identifier header hexdump:
[27.254]ubi0 warning: ubi_eba_read_leb: corrupted VID header at PEB 149, LEB 0:0
[27.262]ubi0 warning: ubi_volume_continue_write: volume 0 on UBI device 0 is corrupt
[27.269]fill gap end: volume mbr
[27.273]update partition map
[27.275]logical area info: 468 258048 last_lba: 235871
read from corrupted volume 0[27.297]mbr magic error: woftwtuu wanted softw411
*** ERROR: Can't read MBR header ***
part_get_info_efi: *** ERROR: Invalid GPT ***
read from corrupted volume 0[27.324]mbr magic error: woftwtuu wanted softw411
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
[27.402]fill gap start: volume boot-resource sects 0x158
[27.600]fill gap end: volume boot-resource
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
FEX_CMD_fes_verify_value 0xee7b20a0
楼主 #1 2024-03-09 22:35:55
memory
已发帖子: 719
Re: D1s 用新买的SPI FLASH W25N01GVZEIG 烧录失败,换一片又可以
[945]fes begin commit:88480af-dirty
[948]set pll start
[954]periph0 has been enabled
[957]set pll end
[959][pmu]: bus read error
[961]board init ok
[963]beign to init dram
[965]ZQ value = 0x2f
[967]get_pmu_exist() = -1
[970]ddr_efuse_type: 0xa
[972]trefi:7.8ms
[974][AUTO DEBUG] single rank and full DQ!
[979]ddr_efuse_type: 0xa
[981]trefi:7.8ms
[983][AUTO DEBUG] rank 0 row = 13
[986][AUTO DEBUG] rank 0 bank = 8
[990][AUTO DEBUG] rank 0 page size = 2 KB
[994]DRAM BOOT DRIVE INFO: V0.33
[997]DRAM CLK = 936 MHz
[999]DRAM Type = 3 (2:DDR2,3:DDR3)
[1002]DRAMC read ODT  off.
[1005]DRAM ODT value: 0x42.
[1007]ddr_efuse_type: 0xa
[1011]DRAM SIZE =128 M
[1013]dram_tpr4:0x0
[1015]PLL_DDR_CTRL_REG:0xf8004d00
[1018]DRAM_CLK_REG:0xc0000000
[1020][TIMING DEBUG] MR2= 0x20
[1025]DRAM simple test OK.
[1027]rtc standby flag is 0x0, super standby flag is 0x0
[1032]init dram ok
U-Boot 2018.05-g24521d6-dirty (Mar 09 2024 - 17:21:03 +0800) Allwinner Technology
[03.307]CPU:   Allwinner Family
[03.310]Model: sun8iw20
I2C:   FDT ERROR:fdt_set_all_pin:[twi0]-->FDT_ERR_BADPATH
FDT ERROR:fdt_set_all_pin:[twi1]-->FDT_ERR_BADPATH
ready
[03.331]DRAM:  128 MiB
[03.335]Relocation Offset is: 04eca000
[03.359]secure enable bit: 0
[03.362]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[03.368]gic: normal mode
[03.370]flash init start
[03.372]workmode = 16,storage type = 0
try card 0
set card number 0
get card number 0
[03.380][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
[03.386][mmc]: get sdc_type fail and use default host:tm1.
[03.392][mmc]: can't find node "mmc0",will add new node
[03.397][mmc]: fdt err returned <no error>
[03.401][mmc]: Using default timing para
[03.404][mmc]: SUNXI SDMMC Controller Version:0x50310
[03.418][mmc]: mmc 0 cmd timeout 100 status 100
[03.422][mmc]: smc 0 err, cmd 8,  RTO
[03.426][mmc]: mmc 0 close bus gating and reset
[03.431][mmc]: mmc 0 cmd timeout 100 status 100
[03.435][mmc]: smc 0 err, cmd 55,  RTO
[03.438][mmc]: mmc 0 close bus gating and reset
[03.447][mmc]: mmc 0 cmd timeout 100 status 100
[03.451][mmc]: smc 0 err, cmd 1,  RTO
[03.454][mmc]: mmc 0 close bus gating and reset
[03.459][mmc]: Card did not respond to voltage select!
[03.463][mmc]: mmc_init: -95, time 54
[03.467][mmc]: mmc_init: mmc init fail, err -95
MMC init failed
try emmc fail
[03.474]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
[03.480]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
[03.488]sunxi-spinand-phy: request spi0 gpio ok
[03.492]sunxi-spinand-phy: request general tx dma channel ok!
[03.497]sunxi-spinand-phy: request general rx dma channel ok!
[03.503]sunxi-spinand-phy: set spic0 clk to 20 Mhz
[03.507]sunxi-spinand-phy: init spic0 clk ok
[03.553]sunxi-spinand-phy: not detect any munufacture from id table
[03.559]sunxi-spinand-phy: get spi-nand Model from fdt fail
[03.564]sunxi-spinand-phy: get phy info from fdt fail
[03.569]sunxi-spinand-phy: not detect munufacture from fdt
[03.574]sunxi-spinand-phy: detect munufacture from id table: Winbond
[03.580]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[03.586]sunxi-spinand-phy: ========== arch info ==========
[03.591]sunxi-spinand-phy: Model:               W25N01GVZEIG
[03.596]sunxi-spinand-phy: Munufacture:         Winbond
[03.601]sunxi-spinand-phy: DieCntPerChip:       1
[03.606]sunxi-spinand-phy: BlkCntPerDie:        1024
[03.610]sunxi-spinand-phy: PageCntPerBlk:       64
[03.615]sunxi-spinand-phy: SectCntPerPage:      4
[03.619]sunxi-spinand-phy: OobSizePerPage:      64
[03.624]sunxi-spinand-phy: BadBlockFlag:        0x0
[03.628]sunxi-spinand-phy: OperationOpt:        0x7
[03.633]sunxi-spinand-phy: MaxEraseTimes:       65000
[03.638]sunxi-spinand-phy: EccFlag:             0x0
[03.642]sunxi-spinand-phy: EccType:             2
[03.647]sunxi-spinand-phy: EccProtectedType:    3
[03.651]sunxi-spinand-phy: ========================================
[03.657]sunxi-spinand-phy:
[03.660]sunxi-spinand-phy: ========== physical info ==========
[03.665]sunxi-spinand-phy: TotalSize:    128 M
[03.669]sunxi-spinand-phy: SectorSize:   512 B
[03.673]sunxi-spinand-phy: PageSize:     2 K
[03.677]sunxi-spinand-phy: BlockSize:    128 K
[03.682]sunxi-spinand-phy: OOBSize:      64 B
[03.686]sunxi-spinand-phy: ========================================
[03.692]sunxi-spinand-phy:
[03.694]sunxi-spinand-phy: ========== logical info ==========
[03.700]sunxi-spinand-phy: TotalSize:    128 M
[03.704]sunxi-spinand-phy: SectorSize:   512 B
[03.708]sunxi-spinand-phy: PageSize:     4 K
[03.712]sunxi-spinand-phy: BlockSize:    256 K
[03.716]sunxi-spinand-phy: OOBSize:      128 B
[03.720]sunxi-spinand-phy: ========================================
[03.727]sunxi-spinand-phy: set spic0 clk to 100 Mhz
[03.731]sunxi-spinand-phy: block lock register: 0x00
[03.736]sunxi-spinand-phy: feature register: 0x00
[03.740]sunxi-spinand-phy: sunxi physic nand init end
[03.745]Loading Environment from SUNXI_FLASH... OK
[03.750]try to burn key
[03.752]out of usb burn from boot: not need burn key
run usb efex
buf queue page size = 16384
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x3a
set address 0x3a ok
set address 0x3b
set address 0x3b ok
erase_flag = 0x12
total mbr part 8
part[0] lenlo     :0x800
part[0] keydata   :0
part[0] ro        :0
part[1] name      :env
part[1] addrlo    :0x8800
part[1] keydata   :0
part[1] ro        :0
part[2] addrlo    :0x89f8
part[2] keydata   :0
part[2] ro        :0
part[3] name      :boot
part[3] addrlo    :0x8bf0
part[3] lenlo     :0x21e8
part[3] keydata   :0
part[3] ro        :0
part[4] addrlo    :0xadd8
part[4] lenlo     :0x11800
part[4] keydata   :0
part[4] ro        :0
part[5] name      :private
part[5] addrlo    :0x1c5d8
part[5] lenlo     :0x2800
part[5] keydata   :0
part[5] ro        :0
part[6] addrlo    :0x1edd8
part[6] lenlo     :0x15e00
part[6] keydata   :0
part[6] ro        :0
part[7] name      :UDISK
part[7] addrlo    :0x34bd8
part[7] lenlo     :0x0
part[7] user_type :33024
part[7] keydata   :0
part[7] ro        :0
total part: 9
mbr 0, 8000, 8000
boot-resource 1, 800, 8000
env 2, 1f8, 8000
boot 4, 21e8, 8000
rootfs 5, 11800, 8000
private 6, 2800, 8000
rootfs_data 7, 15e00, 8000
UDISK 8, 0, 8100
[07.006]erase blk 0 to blk 32
[07.009]blk 0 is bad, skip to erase
[07.012]blk 1 is bad, skip to erase
[07.016]blk 2 is bad, skip to erase
[07.019]blk 3 is bad, skip to erase
[07.022]blk 4 is bad, skip to erase
[07.025]blk 5 is bad, skip to erase
[07.028]blk 6 is bad, skip to erase
[07.032]blk 7 is bad, skip to erase
[07.035]blk 8 is bad, skip to erase
[07.038]blk 9 is bad, skip to erase
[07.041]blk 10 is bad, skip to erase
[07.045]blk 11 is bad, skip to erase
[07.048]blk 12 is bad, skip to erase
[07.051]blk 13 is bad, skip to erase
[07.054]blk 14 is bad, skip to erase
[07.058]blk 15 is bad, skip to erase
[07.061]blk 16 is bad, skip to erase
[07.064]blk 17 is bad, skip to erase
[07.068]blk 18 is bad, skip to erase
[07.071]blk 19 is bad, skip to erase
[07.074]blk 20 is bad, skip to erase
[07.077]blk 21 is bad, skip to erase
[07.081]blk 22 is bad, skip to erase
[07.084]blk 23 is bad, skip to erase
[07.087]blk 24 is bad, skip to erase
[07.091]blk 25 is bad, skip to erase
[07.094]blk 26 is bad, skip to erase
[07.097]blk 27 is bad, skip to erase
[07.101]blk 28 is bad, skip to erase
[07.104]blk 29 is bad, skip to erase
[07.107]blk 30 is bad, skip to erase
[07.110]blk 31 is bad, skip to erase
need erase flash: 18
[07.116]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
defaults:
mtdids  : nand0=nand
[07.166]MTD info (4)
[07.168]pagesize: 0x1000
[07.170]blksize: 0x40000
[07.172]num  offset     bytes      name
[07.176]0    0x00000000 0x00100000 boot0
[07.180]1    0x00100000 0x00300000 uboot
[07.183]2    0x00400000 0x00100000 secure_storage
[07.188]3    0x00500000 0x07b00000 sys
[07.191]ubi attach the last part of mtd device: NO.3
[07.206]ubi0: attaching mtd4
[07.209]ubi0: scanning is finished
[07.212]ubi0: empty MTD device detected
[07.216]ubi0 error: ubi_early_get_peb: no free eraseblocks
[07.221]ubi0 error: ubi_attach_mtd_dev: failed to attach mtd4, error -28
[07.227]UBI error: cannot attach mtd4
[07.231]UBI error: cannot initialize UBI, error -28
UBI init error 28
Please check, if the correct MTD partition is used (size big enough?)
[07.243]ubi part sys err !
[07.246]erase blk 0 to blk 32
[07.248]blk 0 is bad, skip to erase
[07.251]blk 1 is bad, skip to erase
[07.255]blk 2 is bad, skip to erase
[07.258]blk 3 is bad, skip to erase
[07.261]blk 4 is bad, skip to erase
[07.264]blk 5 is bad, skip to erase
[07.268]blk 6 is bad, skip to erase
[07.271]blk 7 is bad, skip to erase
[07.274]blk 8 is bad, skip to erase
[07.277]blk 9 is bad, skip to erase
[07.280]blk 10 is bad, skip to erase
[07.284]blk 11 is bad, skip to erase
[07.287]blk 12 is bad, skip to erase
[07.290]blk 13 is bad, skip to erase
[07.294]blk 14 is bad, skip to erase
[07.297]blk 15 is bad, skip to erase
[07.300]blk 16 is bad, skip to erase
[07.303]blk 17 is bad, skip to erase
[07.307]blk 18 is bad, skip to erase
[07.310]blk 19 is bad, skip to erase
[07.313]blk 20 is bad, skip to erase
[07.317]blk 21 is bad, skip to erase
[07.320]blk 22 is bad, skip to erase
[07.323]blk 23 is bad, skip to erase
[07.326]blk 24 is bad, skip to erase
[07.330]blk 25 is bad, skip to erase
[07.333]blk 26 is bad, skip to erase
[07.336]blk 27 is bad, skip to erase
[07.340]blk 28 is bad, skip to erase
[07.343]blk 29 is bad, skip to erase
[07.346]blk 30 is bad, skip to erase
[07.349]blk 31 is bad, skip to erase
[07.353]erase blk 40 to blk 1024
[07.356]blk 40 is bad, skip to erase
[07.359]blk 41 is bad, skip to erase
[07.362]blk 42 is bad, skip to erase
[07.366]blk 43 is bad, skip to erase
[07.369]blk 44 is bad, skip to erase
[07.372]blk 45 is bad, skip to erase
[07.375]blk 46 is bad, skip to erase
[07.379]blk 47 is bad, skip to erase
[07.382]blk 48 is bad, skip to erase
[07.385]blk 49 is bad, skip to erase
[07.389]blk 50 is bad, skip to erase
[07.392]blk 51 is bad, skip to erase
[07.395]blk 52 is bad, skip to erase
[07.399]blk 53 is bad, skip to erase
[07.402]blk 54 is bad, skip to erase
[07.405]blk 55 is bad, skip to erase
[07.408]blk 56 is bad, skip to erase
[07.412]blk 57 is bad, skip to erase
[07.415]blk 58 is bad, skip to erase
[07.418]blk 59 is bad, skip to erase
[07.422]blk 60 is bad, skip to erase
[07.425]blk 61 is bad, skip to erase
[07.428]blk 62 is bad, skip to erase
[07.432]blk 63 is bad, skip to erase
[07.435]blk 64 is bad, skip to erase
[07.438]blk 65 is bad, skip to erase
[07.441]blk 66 is bad, skip to erase
[07.445]blk 67 is bad, skip to erase
[07.448]blk 68 is bad, skip to erase
[07.451]blk 69 is bad, skip to erase
[07.455]blk 70 is bad, skip to erase
[07.458]blk 71 is bad, skip to erase
[07.461]blk 72 is bad, skip to erase
[07.464]blk 73 is bad, skip to erase
[07.468]blk 74 is bad, skip to erase
[07.471]blk 75 is bad, skip to erase
[07.474]blk 76 is bad, skip to erase
[07.478]blk 77 is bad, skip to erase
[07.481]blk 78 is bad, skip to erase
[07.484]blk 79 is bad, skip to erase
[07.487]blk 80 is bad, skip to erase
[07.491]blk 81 is bad, skip to erase
[07.494]blk 82 is bad, skip to erase
[07.497]blk 83 is bad, skip to erase
[07.501]blk 84 is bad, skip to erase
[07.504]blk 85 is bad, skip to erase
[07.507]blk 86 is bad, skip to erase
[07.511]blk 87 is bad, skip to erase
[07.514]blk 88 is bad, skip to erase
[07.517]blk 89 is bad, skip to erase
[07.520]blk 90 is bad, skip to erase
[07.524]blk 91 is bad, skip to erase
[07.527]blk 92 is bad, skip to erase
[07.530]blk 93 is bad, skip to erase
[07.534]blk 94 is bad, skip to erase
[07.537]blk 95 is bad, skip to erase
[07.540]blk 96 is bad, skip to erase
[07.543]blk 97 is bad, skip to erase
[07.547]blk 98 is bad, skip to erase
[07.550]blk 99 is bad, skip to erase
[07.553]blk 100 is bad, skip to erase
[07.557]blk 101 is bad, skip to erase
[07.560]blk 102 is bad, skip to erase
[07.563]blk 103 is bad, skip to erase
[07.567]blk 104 is bad, skip to erase
[07.570]blk 105 is bad, skip to erase
[07.574]blk 106 is bad, skip to erase
[07.577]blk 107 is bad, skip to erase
[07.580]blk 108 is bad, skip to erase
[07.584]blk 109 is bad, skip to erase
[07.587]blk 110 is bad, skip to erase
[07.591]blk 111 is bad, skip to erase
[07.594]blk 112 is bad, skip to erase
[07.597]blk 113 is bad, skip to erase
[07.601]blk 114 is bad, skip to erase
[07.604]blk 115 is bad, skip to erase
[07.607]blk 116 is bad, skip to erase
[07.611]blk 117 is bad, skip to erase
[07.614]blk 118 is bad, skip to erase
[07.618]blk 119 is bad, skip to erase
[07.621]blk 120 is bad, skip to erase
[07.624]blk 121 is bad, skip to erase
[07.628]blk 122 is bad, skip to erase
[07.631]blk 123 is bad, skip to erase
[07.634]blk 124 is bad, skip to erase
[07.638]blk 125 is bad, skip to erase
[07.641]blk 126 is bad, skip to erase
[07.645]blk 127 is bad, skip to erase
[07.648]blk 128 is bad, skip to erase
[07.651]blk 129 is bad, skip to erase
[07.655]blk 130 is bad, skip to erase
[07.658]blk 131 is bad, skip to erase
[07.661]blk 132 is bad, skip to erase
[07.665]blk 133 is bad, skip to erase
[07.668]blk 134 is bad, skip to erase
[07.672]blk 135 is bad, skip to erase
[07.675]blk 136 is bad, skip to erase
[07.678]blk 137 is bad, skip to erase
[07.682]blk 138 is bad, skip to erase
[07.685]blk 139 is bad, skip to erase
[07.689]blk 140 is bad, skip to erase
[07.692]blk 141 is bad, skip to erase
[07.695]blk 142 is bad, skip to erase
[07.699]blk 143 is bad, skip to erase
[07.702]blk 144 is bad, skip to erase
[07.705]blk 145 is bad, skip to erase
[07.709]blk 146 is bad, skip to erase
[07.712]blk 147 is bad, skip to erase
[07.716]blk 148 is bad, skip to erase
[07.719]blk 149 is bad, skip to erase
[07.722]blk 150 is bad, skip to erase
[07.726]blk 151 is bad, skip to erase
[07.729]blk 152 is bad, skip to erase
[07.732]blk 153 is bad, skip to erase
[07.736]blk 154 is bad, skip to erase
[07.739]blk 155 is bad, skip to erase
[07.743]blk 156 is bad, skip to erase
[07.746]blk 157 is bad, skip to erase
[07.749]blk 158 is bad, skip to erase
[07.753]blk 159 is bad, skip to erase
[07.756]blk 160 is bad, skip to erase
[07.760]blk 161 is bad, skip to erase
[07.763]blk 162 is bad, skip to erase
[07.766]blk 163 is bad, skip to erase
[07.770]blk 164 is bad, skip to erase
[07.773]blk 165 is bad, skip to erase
[07.776]blk 166 is bad, skip to erase
[07.780]blk 167 is bad, skip to erase
[07.783]blk 168 is bad, skip to erase
[07.787]blk 169 is bad, skip to erase
[07.790]blk 170 is bad, skip to erase
[07.793]blk 171 is bad, skip to erase
[07.797]blk 172 is bad, skip to erase
[07.800]blk 173 is bad, skip to erase
[07.803]blk 174 is bad, skip to erase
[07.807]blk 175 is bad, skip to erase
[07.810]blk 176 is bad, skip to erase
[07.814]blk 177 is bad, skip to erase
[07.817]blk 178 is bad, skip to erase
[07.820]blk 179 is bad, skip to erase
[07.824]blk 180 is bad, skip to erase
[07.827]blk 181 is bad, skip to erase
[07.830]blk 182 is bad, skip to erase
[07.834]blk 183 is bad, skip to erase
[07.837]blk 184 is bad, skip to erase
[07.841]blk 185 is bad, skip to erase
[07.844]blk 186 is bad, skip to erase
[07.847]blk 187 is bad, skip to erase
[07.851]blk 188 is bad, skip to erase
[07.854]blk 189 is bad, skip to erase
[07.858]blk 190 is bad, skip to erase
[07.861]blk 191 is bad, skip to erase
[07.864]blk 192 is bad, skip to erase
[07.868]blk 193 is bad, skip to erase
[07.871]blk 194 is bad, skip to erase
[07.874]blk 195 is bad, skip to erase
[07.878]blk 196 is bad, skip to erase
[07.881]blk 197 is bad, skip to erase
[07.885]blk 198 is bad, skip to erase
[07.888]blk 199 is bad, skip to erase
[07.891]blk 200 is bad, skip to erase
[07.895]blk 201 is bad, skip to erase
[07.898]blk 202 is bad, skip to erase
[07.901]blk 203 is bad, skip to erase
[07.905]blk 204 is bad, skip to erase
[07.908]blk 205 is bad, skip to erase
[07.912]blk 206 is bad, skip to erase
[07.915]blk 207 is bad, skip to erase
[07.918]blk 208 is bad, skip to erase
[07.922]blk 209 is bad, skip to erase
[07.925]blk 210 is bad, skip to erase
[07.929]blk 211 is bad, skip to erase
[07.932]blk 212 is bad, skip to erase
[07.935]blk 213 is bad, skip to erase
[07.939]blk 214 is bad, skip to erase
[07.942]blk 215 is bad, skip to erase
[07.945]blk 216 is bad, skip to erase
[07.949]blk 217 is bad, skip to erase
[07.952]blk 218 is bad, skip to erase
[07.956]blk 219 is bad, skip to erase
[07.959]blk 220 is bad, skip to erase
[07.962]blk 221 is bad, skip to erase
[07.966]blk 222 is bad, skip to erase
[07.969]blk 223 is bad, skip to erase
[07.972]blk 224 is bad, skip to erase
[07.976]blk 225 is bad, skip to erase
[07.979]blk 226 is bad, skip to erase
[07.983]blk 227 is bad, skip to erase
[07.986]blk 228 is bad, skip to erase
[07.989]blk 229 is bad, skip to erase
[07.993]blk 230 is bad, skip to erase
[07.996]blk 231 is bad, skip to erase
[07.999]blk 232 is bad, skip to erase
[08.003]blk 233 is bad, skip to erase
[08.006]blk 234 is bad, skip to erase
[08.010]blk 235 is bad, skip to erase
[08.013]blk 236 is bad, skip to erase
[08.016]blk 237 is bad, skip to erase
[08.020]blk 238 is bad, skip to erase
[08.023]blk 239 is bad, skip to erase
[08.027]blk 240 is bad, skip to erase
[08.030]blk 241 is bad, skip to erase
[08.033]blk 242 is bad, skip to erase
[08.037]blk 243 is bad, skip to erase
[08.040]blk 244 is bad, skip to erase
[08.043]blk 245 is bad, skip to erase
[08.047]blk 246 is bad, skip to erase
[08.050]blk 247 is bad, skip to erase
[08.054]blk 248 is bad, skip to erase
[08.057]blk 249 is bad, skip to erase
[08.060]blk 250 is bad, skip to erase
[08.064]blk 251 is bad, skip to erase
[08.067]blk 252 is bad, skip to erase
[08.070]blk 253 is bad, skip to erase
[08.074]blk 254 is bad, skip to erase
[08.077]blk 255 is bad, skip to erase
[08.081]blk 256 is bad, skip to erase
[08.084]blk 257 is bad, skip to erase
[08.087]blk 258 is bad, skip to erase
[08.091]blk 259 is bad, skip to erase
[08.094]blk 260 is bad, skip to erase
[08.098]blk 261 is bad, skip to erase
[08.101]blk 262 is bad, skip to erase
[08.104]blk 263 is bad, skip to erase
[08.108]blk 264 is bad, skip to erase
[08.111]blk 265 is bad, skip to erase
[08.114]blk 266 is bad, skip to erase
[08.118]blk 267 is bad, skip to erase
[08.121]blk 268 is bad, skip to erase
[08.125]blk 269 is bad, skip to erase
[08.128]blk 270 is bad, skip to erase
[08.131]blk 271 is bad, skip to erase
[08.135]blk 272 is bad, skip to erase
[08.138]blk 273 is bad, skip to erase
[08.141]blk 274 is bad, skip to erase
[08.145]blk 275 is bad, skip to erase
[08.148]blk 276 is bad, skip to erase
[08.152]blk 277 is bad, skip to erase
[08.155]blk 278 is bad, skip to erase
[08.158]blk 279 is bad, skip to erase
[08.162]blk 280 is bad, skip to erase
[08.165]blk 281 is bad, skip to erase
[08.168]blk 282 is bad, skip to erase
[08.172]blk 283 is bad, skip to erase
[08.175]blk 284 is bad, skip to erase
[08.179]blk 285 is bad, skip to erase
[08.182]blk 286 is bad, skip to erase
[08.185]blk 287 is bad, skip to erase
[08.189]blk 288 is bad, skip to erase
[08.192]blk 289 is bad, skip to erase
[08.196]blk 290 is bad, skip to erase
[08.199]blk 291 is bad, skip to erase
[08.202]blk 292 is bad, skip to erase
[08.206]blk 293 is bad, skip to erase
[08.209]blk 294 is bad, skip to erase
[08.212]blk 295 is bad, skip to erase
[08.216]blk 296 is bad, skip to erase
[08.219]blk 297 is bad, skip to erase
[08.223]blk 298 is bad, skip to erase
[08.226]blk 299 is bad, skip to erase
[08.229]blk 300 is bad, skip to erase
[08.233]blk 301 is bad, skip to erase
[08.236]blk 302 is bad, skip to erase
[08.239]blk 303 is bad, skip to erase
[08.243]blk 304 is bad, skip to erase
[08.246]blk 305 is bad, skip to erase
[08.250]blk 306 is bad, skip to erase
[08.253]blk 307 is bad, skip to erase
[08.256]blk 308 is bad, skip to erase
[08.260]blk 309 is bad, skip to erase
[08.263]blk 310 is bad, skip to erase
[08.267]blk 311 is bad, skip to erase
[08.270]blk 312 is bad, skip to erase
[08.273]blk 313 is bad, skip to erase
[08.277]blk 314 is bad, skip to erase
[08.280]blk 315 is bad, skip to erase
[08.283]blk 316 is bad, skip to erase
[08.287]blk 317 is bad, skip to erase
[08.290]blk 318 is bad, skip to erase
[08.294]blk 319 is bad, skip to erase
[08.297]blk 320 is bad, skip to erase
[08.300]blk 321 is bad, skip to erase
[08.304]blk 322 is bad, skip to erase
[08.307]blk 323 is bad, skip to erase
[08.310]blk 324 is bad, skip to erase
[08.314]blk 325 is bad, skip to erase
[08.317]blk 326 is bad, skip to erase
[08.321]blk 327 is bad, skip to erase
[08.324]blk 328 is bad, skip to erase
[08.327]blk 329 is bad, skip to erase
[08.331]blk 330 is bad, skip to erase
[08.334]blk 331 is bad, skip to erase
[08.337]blk 332 is bad, skip to erase
[08.341]blk 333 is bad, skip to erase
[08.344]blk 334 is bad, skip to erase
[08.348]blk 335 is bad, skip to erase
[08.351]blk 336 is bad, skip to erase
[08.354]blk 337 is bad, skip to erase
[08.358]blk 338 is bad, skip to erase
[08.361]blk 339 is bad, skip to erase
[08.365]blk 340 is bad, skip to erase
[08.368]blk 341 is bad, skip to erase
[08.371]blk 342 is bad, skip to erase
[08.375]blk 343 is bad, skip to erase
[08.378]blk 344 is bad, skip to erase
[08.381]blk 345 is bad, skip to erase
[08.385]blk 346 is bad, skip to erase
[08.388]blk 347 is bad, skip to erase
[08.392]blk 348 is bad, skip to erase
[08.395]blk 349 is bad, skip to erase
[08.398]blk 350 is bad, skip to erase
[08.402]blk 351 is bad, skip to erase
[08.405]blk 352 is bad, skip to erase
[08.408]blk 353 is bad, skip to erase
[08.412]blk 354 is bad, skip to erase
[08.415]blk 355 is bad, skip to erase
[08.419]blk 356 is bad, skip to erase
[08.422]blk 357 is bad, skip to erase
[08.425]blk 358 is bad, skip to erase
[08.429]blk 359 is bad, skip to erase
[08.432]blk 360 is bad, skip to erase
[08.436]blk 361 is bad, skip to erase
[08.439]blk 362 is bad, skip to erase
[08.442]blk 363 is bad, skip to erase
[08.446]blk 364 is bad, skip to erase
[08.449]blk 365 is bad, skip to erase
[08.452]blk 366 is bad, skip to erase
[08.456]blk 367 is bad, skip to erase
[08.459]blk 368 is bad, skip to erase
[08.463]blk 369 is bad, skip to erase
[08.466]blk 370 is bad, skip to erase
[08.469]blk 371 is bad, skip to erase
[08.473]blk 372 is bad, skip to erase
[08.476]blk 373 is bad, skip to erase
[08.479]blk 374 is bad, skip to erase
[08.483]blk 375 is bad, skip to erase
[08.486]blk 376 is bad, skip to erase
[08.490]blk 377 is bad, skip to erase
[08.493]blk 378 is bad, skip to erase
[08.496]blk 379 is bad, skip to erase
[08.500]blk 380 is bad, skip to erase
[08.503]blk 381 is bad, skip to erase
[08.506]blk 382 is bad, skip to erase
[08.510]blk 383 is bad, skip to erase
[08.513]blk 384 is bad, skip to erase
[08.517]blk 385 is bad, skip to erase
[08.520]blk 386 is bad, skip to erase
[08.523]blk 387 is bad, skip to erase
[08.527]blk 388 is bad, skip to erase
[08.530]blk 389 is bad, skip to erase
[08.534]blk 390 is bad, skip to erase
[08.537]blk 391 is bad, skip to erase
[08.540]blk 392 is bad, skip to erase
[08.544]blk 393 is bad, skip to erase
[08.547]blk 394 is bad, skip to erase
[08.550]blk 395 is bad, skip to erase
[08.554]blk 396 is bad, skip to erase
[08.557]blk 397 is bad, skip to erase
[08.561]blk 398 is bad, skip to erase
[08.564]blk 399 is bad, skip to erase
[08.567]blk 400 is bad, skip to erase
[08.571]blk 401 is bad, skip to erase
[08.574]blk 402 is bad, skip to erase
[08.577]blk 403 is bad, skip to erase
[08.581]blk 404 is bad, skip to erase
[08.584]blk 405 is bad, skip to erase
[08.588]blk 406 is bad, skip to erase
[08.591]blk 407 is bad, skip to erase
[08.594]blk 408 is bad, skip to erase
[08.598]blk 409 is bad, skip to erase
[08.601]blk 410 is bad, skip to erase
[08.605]blk 411 is bad, skip to erase
[08.608]blk 412 is bad, skip to erase
[08.611]blk 413 is bad, skip to erase
[08.615]blk 414 is bad, skip to erase
[08.618]blk 415 is bad, skip to erase
[08.621]blk 416 is bad, skip to erase
[08.625]blk 417 is bad, skip to erase
[08.628]blk 418 is bad, skip to erase
[08.632]blk 419 is bad, skip to erase
[08.635]blk 420 is bad, skip to erase
[08.638]blk 421 is bad, skip to erase
[08.642]blk 422 is bad, skip to erase
[08.645]blk 423 is bad, skip to erase
[08.648]blk 424 is bad, skip to erase
[08.652]blk 425 is bad, skip to erase
[08.655]blk 426 is bad, skip to erase
[08.659]blk 427 is bad, skip to erase
[08.662]blk 428 is bad, skip to erase
[08.665]blk 429 is bad, skip to erase
[08.669]blk 430 is bad, skip to erase
[08.672]blk 431 is bad, skip to erase
[08.675]blk 432 is bad, skip to erase
[08.679]blk 433 is bad, skip to erase
[08.682]blk 434 is bad, skip to erase
[08.686]blk 435 is bad, skip to erase
[08.689]blk 436 is bad, skip to erase
[08.692]blk 437 is bad, skip to erase
[08.696]blk 438 is bad, skip to erase
[08.699]blk 439 is bad, skip to erase
[08.703]blk 440 is bad, skip to erase
[08.706]blk 441 is bad, skip to erase
[08.709]blk 442 is bad, skip to erase
[08.713]blk 443 is bad, skip to erase
[08.716]blk 444 is bad, skip to erase
[08.719]blk 445 is bad, skip to erase
[08.723]blk 446 is bad, skip to erase
[08.726]blk 447 is bad, skip to erase
[08.730]blk 448 is bad, skip to erase
[08.733]blk 449 is bad, skip to erase
[08.736]blk 450 is bad, skip to erase
[08.740]blk 451 is bad, skip to erase
[08.743]blk 452 is bad, skip to erase
[08.746]blk 453 is bad, skip to erase
[08.750]blk 454 is bad, skip to erase
[08.753]blk 455 is bad, skip to erase
[08.757]blk 456 is bad, skip to erase
[08.760]blk 457 is bad, skip to erase
[08.763]blk 458 is bad, skip to erase
[08.767]blk 459 is bad, skip to erase
[08.770]blk 460 is bad, skip to erase
[08.774]blk 461 is bad, skip to erase
[08.777]blk 462 is bad, skip to erase
[08.780]blk 463 is bad, skip to erase
[08.784]blk 464 is bad, skip to erase
[08.787]blk 465 is bad, skip to erase
[08.790]blk 466 is bad, skip to erase
[08.794]blk 467 is bad, skip to erase
[08.797]blk 468 is bad, skip to erase
[08.801]blk 469 is bad, skip to erase
[08.804]blk 470 is bad, skip to erase
[08.807]blk 471 is bad, skip to erase
[08.811]blk 472 is bad, skip to erase
[08.814]blk 473 is bad, skip to erase
[08.817]blk 474 is bad, skip to erase
[08.821]blk 475 is bad, skip to erase
[08.824]blk 476 is bad, skip to erase
[08.828]blk 477 is bad, skip to erase
[08.831]blk 478 is bad, skip to erase
[08.834]blk 479 is bad, skip to erase
[08.838]blk 480 is bad, skip to erase
[08.841]blk 481 is bad, skip to erase
[08.844]blk 482 is bad, skip to erase
[08.848]blk 483 is bad, skip to erase
[08.851]blk 484 is bad, skip to erase
[08.855]blk 485 is bad, skip to erase
[08.858]blk 486 is bad, skip to erase
[08.861]blk 487 is bad, skip to erase
[08.865]blk 488 is bad, skip to erase
[08.868]blk 489 is bad, skip to erase
[08.872]blk 490 is bad, skip to erase
[08.875]blk 491 is bad, skip to erase
[08.878]blk 492 is bad, skip to erase
[08.882]blk 493 is bad, skip to erase
[08.885]blk 494 is bad, skip to erase
[08.888]blk 495 is bad, skip to erase
[08.892]blk 496 is bad, skip to erase
[08.895]blk 497 is bad, skip to erase
[08.899]blk 498 is bad, skip to erase
[08.902]blk 499 is bad, skip to erase
[08.905]blk 500 is bad, skip to erase
[08.909]blk 501 is bad, skip to erase
[08.912]blk 502 is bad, skip to erase
[08.915]blk 503 is bad, skip to erase
[08.919]blk 504 is bad, skip to erase
[08.922]blk 505 is bad, skip to erase
[08.926]blk 506 is bad, skip to erase
[08.929]blk 507 is bad, skip to erase
[08.932]blk 508 is bad, skip to erase
[08.936]blk 509 is bad, skip to erase
[08.939]blk 510 is bad, skip to erase
[08.943]blk 511 is bad, skip to erase
[08.946]blk 512 is bad, skip to erase
[08.949]blk 513 is bad, skip to erase
[08.953]blk 514 is bad, skip to erase
[08.956]blk 515 is bad, skip to erase
[08.959]blk 516 is bad, skip to erase
[08.963]blk 517 is bad, skip to erase
[08.966]blk 518 is bad, skip to erase
[08.970]blk 519 is bad, skip to erase
[08.973]blk 520 is bad, skip to erase
[08.976]blk 521 is bad, skip to erase
[08.980]blk 522 is bad, skip to erase
[08.983]blk 523 is bad, skip to erase
[08.986]blk 524 is bad, skip to erase
[08.990]blk 525 is bad, skip to erase
[08.993]blk 526 is bad, skip to erase
[08.997]blk 527 is bad, skip to erase
[09.000]blk 528 is bad, skip to erase
[09.003]blk 529 is bad, skip to erase
[09.007]blk 530 is bad, skip to erase
[09.010]blk 531 is bad, skip to erase
[09.013]blk 532 is bad, skip to erase
[09.017]blk 533 is bad, skip to erase
[09.020]blk 534 is bad, skip to erase
[09.024]blk 535 is bad, skip to erase
[09.027]blk 536 is bad, skip to erase
[09.030]blk 537 is bad, skip to erase
[09.034]blk 538 is bad, skip to erase
[09.037]blk 539 is bad, skip to erase
[09.041]blk 540 is bad, skip to erase
[09.044]blk 541 is bad, skip to erase
[09.047]blk 542 is bad, skip to erase
[09.051]blk 543 is bad, skip to erase
[09.054]blk 544 is bad, skip to erase
[09.057]blk 545 is bad, skip to erase
[09.061]blk 546 is bad, skip to erase
[09.064]blk 547 is bad, skip to erase
[09.068]blk 548 is bad, skip to erase
[09.071]blk 549 is bad, skip to erase
[09.074]blk 550 is bad, skip to erase
[09.078]blk 551 is bad, skip to erase
[09.081]blk 552 is bad, skip to erase
[09.084]blk 553 is bad, skip to erase
[09.088]blk 554 is bad, skip to erase
[09.091]blk 555 is bad, skip to erase
[09.095]blk 556 is bad, skip to erase
[09.098]blk 557 is bad, skip to erase
[09.101]blk 558 is bad, skip to erase
[09.105]blk 559 is bad, skip to erase
[09.108]blk 560 is bad, skip to erase
[09.112]blk 561 is bad, skip to erase
[09.115]blk 562 is bad, skip to erase
[09.118]blk 563 is bad, skip to erase
[09.122]blk 564 is bad, skip to erase
[09.125]blk 565 is bad, skip to erase
[09.128]blk 566 is bad, skip to erase
[09.132]blk 567 is bad, skip to erase
[09.135]blk 568 is bad, skip to erase
[09.139]blk 569 is bad, skip to erase
[09.142]blk 570 is bad, skip to erase
[09.145]blk 571 is bad, skip to erase
[09.149]blk 572 is bad, skip to erase
[09.152]blk 573 is bad, skip to erase
[09.155]blk 574 is bad, skip to erase
[09.159]blk 575 is bad, skip to erase
[09.162]blk 576 is bad, skip to erase
[09.166]blk 577 is bad, skip to erase
[09.169]blk 578 is bad, skip to erase
[09.172]blk 579 is bad, skip to erase
[09.176]blk 580 is bad, skip to erase
[09.179]blk 581 is bad, skip to erase
[09.182]blk 582 is bad, skip to erase
[09.186]blk 583 is bad, skip to erase
[09.189]blk 584 is bad, skip to erase
[09.193]blk 585 is bad, skip to erase
[09.196]blk 586 is bad, skip to erase
[09.199]blk 587 is bad, skip to erase
[09.203]blk 588 is bad, skip to erase
[09.206]blk 589 is bad, skip to erase
[09.210]blk 590 is bad, skip to erase
[09.213]blk 591 is bad, skip to erase
[09.216]blk 592 is bad, skip to erase
[09.220]blk 593 is bad, skip to erase
[09.223]blk 594 is bad, skip to erase
[09.226]blk 595 is bad, skip to erase
[09.230]blk 596 is bad, skip to erase
[09.233]blk 597 is bad, skip to erase
[09.237]blk 598 is bad, skip to erase
[09.240]blk 599 is bad, skip to erase
[09.243]blk 600 is bad, skip to erase
[09.247]blk 601 is bad, skip to erase
[09.250]blk 602 is bad, skip to erase
[09.253]blk 603 is bad, skip to erase
[09.257]blk 604 is bad, skip to erase
[09.260]blk 605 is bad, skip to erase
[09.264]blk 606 is bad, skip to erase
[09.267]blk 607 is bad, skip to erase
[09.270]blk 608 is bad, skip to erase
[09.274]blk 609 is bad, skip to erase
[09.277]blk 610 is bad, skip to erase
[09.281]blk 611 is bad, skip to erase
[09.284]blk 612 is bad, skip to erase
[09.287]blk 613 is bad, skip to erase
[09.291]blk 614 is bad, skip to erase
[09.294]blk 615 is bad, skip to erase
[09.297]blk 616 is bad, skip to erase
[09.301]blk 617 is bad, skip to erase
[09.304]blk 618 is bad, skip to erase
[09.308]blk 619 is bad, skip to erase
[09.311]blk 620 is bad, skip to erase
[09.314]blk 621 is bad, skip to erase
[09.318]blk 622 is bad, skip to erase
[09.321]blk 623 is bad, skip to erase
[09.324]blk 624 is bad, skip to erase
[09.328]blk 625 is bad, skip to erase
[09.331]blk 626 is bad, skip to erase
[09.335]blk 627 is bad, skip to erase
[09.338]blk 628 is bad, skip to erase
[09.341]blk 629 is bad, skip to erase
[09.345]blk 630 is bad, skip to erase
[09.348]blk 631 is bad, skip to erase
[09.351]blk 632 is bad, skip to erase
[09.355]blk 633 is bad, skip to erase
[09.358]blk 634 is bad, skip to erase
[09.362]blk 635 is bad, skip to erase
[09.365]blk 636 is bad, skip to erase
[09.368]blk 637 is bad, skip to erase
[09.372]blk 638 is bad, skip to erase
[09.375]blk 639 is bad, skip to erase
[09.379]blk 640 is bad, skip to erase
[09.382]blk 641 is bad, skip to erase
[09.385]blk 642 is bad, skip to erase
[09.389]blk 643 is bad, skip to erase
[09.392]blk 644 is bad, skip to erase
[09.395]blk 645 is bad, skip to erase
[09.399]blk 646 is bad, skip to erase
[09.402]blk 647 is bad, skip to erase
[09.406]blk 648 is bad, skip to erase
[09.409]blk 649 is bad, skip to erase
[09.412]blk 650 is bad, skip to erase
[09.416]blk 651 is bad, skip to erase
[09.419]blk 652 is bad, skip to erase
[09.422]blk 653 is bad, skip to erase
[09.426]blk 654 is bad, skip to erase
[09.429]blk 655 is bad, skip to erase
[09.433]blk 656 is bad, skip to erase
[09.436]blk 657 is bad, skip to erase
[09.439]blk 658 is bad, skip to erase
[09.443]blk 659 is bad, skip to erase
[09.446]blk 660 is bad, skip to erase
[09.450]blk 661 is bad, skip to erase
[09.453]blk 662 is bad, skip to erase
[09.456]blk 663 is bad, skip to erase
[09.460]blk 664 is bad, skip to erase
[09.463]blk 665 is bad, skip to erase
[09.466]blk 666 is bad, skip to erase
[09.470]blk 667 is bad, skip to erase
[09.473]blk 668 is bad, skip to erase
[09.477]blk 669 is bad, skip to erase
[09.480]blk 670 is bad, skip to erase
[09.483]blk 671 is bad, skip to erase
[09.487]blk 672 is bad, skip to erase
[09.490]blk 673 is bad, skip to erase
[09.493]blk 674 is bad, skip to erase
[09.497]blk 675 is bad, skip to erase
[09.500]blk 676 is bad, skip to erase
[09.504]blk 677 is bad, skip to erase
[09.507]blk 678 is bad, skip to erase
[09.510]blk 679 is bad, skip to erase
[09.514]blk 680 is bad, skip to erase
[09.517]blk 681 is bad, skip to erase
[09.520]blk 682 is bad, skip to erase
[09.524]blk 683 is bad, skip to erase
[09.527]blk 684 is bad, skip to erase
[09.531]blk 685 is bad, skip to erase
[09.534]blk 686 is bad, skip to erase
[09.537]blk 687 is bad, skip to erase
[09.541]blk 688 is bad, skip to erase
[09.544]blk 689 is bad, skip to erase
[09.548]blk 690 is bad, skip to erase
[09.551]blk 691 is bad, skip to erase
[09.554]blk 692 is bad, skip to erase
[09.558]blk 693 is bad, skip to erase
[09.561]blk 694 is bad, skip to erase
[09.564]blk 695 is bad, skip to erase
[09.568]blk 696 is bad, skip to erase
[09.571]blk 697 is bad, skip to erase
[09.575]blk 698 is bad, skip to erase
[09.578]blk 699 is bad, skip to erase
[09.581]blk 700 is bad, skip to erase
[09.585]blk 701 is bad, skip to erase
[09.588]blk 702 is bad, skip to erase
[09.591]blk 703 is bad, skip to erase
[09.595]blk 704 is bad, skip to erase
[09.598]blk 705 is bad, skip to erase
[09.602]blk 706 is bad, skip to erase
[09.605]blk 707 is bad, skip to erase
[09.608]blk 708 is bad, skip to erase
[09.612]blk 709 is bad, skip to erase
[09.615]blk 710 is bad, skip to erase
[09.619]blk 711 is bad, skip to erase
[09.622]blk 712 is bad, skip to erase
[09.625]blk 713 is bad, skip to erase
[09.629]blk 714 is bad, skip to erase
[09.632]blk 715 is bad, skip to erase
[09.635]blk 716 is bad, skip to erase
[09.639]blk 717 is bad, skip to erase
[09.642]blk 718 is bad, skip to erase
[09.646]blk 719 is bad, skip to erase
[09.649]blk 720 is bad, skip to erase
[09.652]blk 721 is bad, skip to erase
[09.656]blk 722 is bad, skip to erase
[09.659]blk 723 is bad, skip to erase
[09.662]blk 724 is bad, skip to erase
[09.666]blk 725 is bad, skip to erase
[09.669]blk 726 is bad, skip to erase
[09.673]blk 727 is bad, skip to erase
[09.676]blk 728 is bad, skip to erase
[09.679]blk 729 is bad, skip to erase
[09.683]blk 730 is bad, skip to erase
[09.686]blk 731 is bad, skip to erase
[09.689]blk 732 is bad, skip to erase
[09.693]blk 733 is bad, skip to erase
[09.696]blk 734 is bad, skip to erase
[09.700]blk 735 is bad, skip to erase
[09.703]blk 736 is bad, skip to erase
[09.706]blk 737 is bad, skip to erase
[09.710]blk 738 is bad, skip to erase
[09.713]blk 739 is bad, skip to erase
[09.717]blk 740 is bad, skip to erase
[09.720]blk 741 is bad, skip to erase
[09.723]blk 742 is bad, skip to erase
[09.727]blk 743 is bad, skip to erase
[09.730]blk 744 is bad, skip to erase
[09.733]blk 745 is bad, skip to erase
[09.737]blk 746 is bad, skip to erase
[09.740]blk 747 is bad, skip to erase
[09.744]blk 748 is bad, skip to erase
[09.747]blk 749 is bad, skip to erase
[09.750]blk 750 is bad, skip to erase
[09.754]blk 751 is bad, skip to erase
[09.757]blk 752 is bad, skip to erase
[09.760]blk 753 is bad, skip to erase
[09.764]blk 754 is bad, skip to erase
[09.767]blk 755 is bad, skip to erase
[09.771]blk 756 is bad, skip to erase
[09.774]blk 757 is bad, skip to erase
[09.777]blk 758 is bad, skip to erase
[09.781]blk 759 is bad, skip to erase
[09.784]blk 760 is bad, skip to erase
[09.788]blk 761 is bad, skip to erase
[09.791]blk 762 is bad, skip to erase
[09.794]blk 763 is bad, skip to erase
[09.798]blk 764 is bad, skip to erase
[09.801]blk 765 is bad, skip to erase
[09.804]blk 766 is bad, skip to erase
[09.808]blk 767 is bad, skip to erase
[09.811]blk 768 is bad, skip to erase
[09.815]blk 769 is bad, skip to erase
[09.818]blk 770 is bad, skip to erase
[09.821]blk 771 is bad, skip to erase
[09.825]blk 772 is bad, skip to erase
[09.828]blk 773 is bad, skip to erase
[09.831]blk 774 is bad, skip to erase
[09.835]blk 775 is bad, skip to erase
[09.838]blk 776 is bad, skip to erase
[09.842]blk 777 is bad, skip to erase
[09.845]blk 778 is bad, skip to erase
[09.848]blk 779 is bad, skip to erase
[09.852]blk 780 is bad, skip to erase
[09.855]blk 781 is bad, skip to erase
[09.858]blk 782 is bad, skip to erase
[09.862]blk 783 is bad, skip to erase
[09.865]blk 784 is bad, skip to erase
[09.869]blk 785 is bad, skip to erase
[09.872]blk 786 is bad, skip to erase
[09.875]blk 787 is bad, skip to erase
[09.879]blk 788 is bad, skip to erase
[09.882]blk 789 is bad, skip to erase
[09.886]blk 790 is bad, skip to erase
[09.889]blk 791 is bad, skip to erase
[09.892]blk 792 is bad, skip to erase
[09.896]blk 793 is bad, skip to erase
[09.899]blk 794 is bad, skip to erase
[09.902]blk 795 is bad, skip to erase
[09.906]blk 796 is bad, skip to erase
[09.909]blk 797 is bad, skip to erase
[09.913]blk 798 is bad, skip to erase
[09.916]blk 799 is bad, skip to erase
[09.919]blk 800 is bad, skip to erase
[09.923]blk 801 is bad, skip to erase
[09.926]blk 802 is bad, skip to erase
[09.929]blk 803 is bad, skip to erase
[09.933]blk 804 is bad, skip to erase
[09.936]blk 805 is bad, skip to erase
[09.940]blk 806 is bad, skip to erase
[09.943]blk 807 is bad, skip to erase
[09.946]blk 808 is bad, skip to erase
[09.950]blk 809 is bad, skip to erase
[09.953]blk 810 is bad, skip to erase
[09.957]blk 811 is bad, skip to erase
[09.960]blk 812 is bad, skip to erase
[09.963]blk 813 is bad, skip to erase
[09.967]blk 814 is bad, skip to erase
[09.970]blk 815 is bad, skip to erase
[09.973]blk 816 is bad, skip to erase
[09.977]blk 817 is bad, skip to erase
[09.980]blk 818 is bad, skip to erase
[09.984]blk 819 is bad, skip to erase
[09.987]blk 820 is bad, skip to erase
[09.990]blk 821 is bad, skip to erase
[09.994]blk 822 is bad, skip to erase
[09.997]blk 823 is bad, skip to erase
[10.000]blk 824 is bad, skip to erase
[10.004]blk 825 is bad, skip to erase
[10.007]blk 826 is bad, skip to erase
[10.011]blk 827 is bad, skip to erase
[10.014]blk 828 is bad, skip to erase
[10.017]blk 829 is bad, skip to erase
[10.021]blk 830 is bad, skip to erase
[10.024]blk 831 is bad, skip to erase
[10.027]blk 832 is bad, skip to erase
[10.031]blk 833 is bad, skip to erase
[10.034]blk 834 is bad, skip to erase
[10.038]blk 835 is bad, skip to erase
[10.041]blk 836 is bad, skip to erase
[10.044]blk 837 is bad, skip to erase
[10.048]blk 838 is bad, skip to erase
[10.051]blk 839 is bad, skip to erase
[10.055]blk 840 is bad, skip to erase
[10.058]blk 841 is bad, skip to erase
[10.061]blk 842 is bad, skip to erase
[10.065]blk 843 is bad, skip to erase
[10.068]blk 844 is bad, skip to erase
[10.071]blk 845 is bad, skip to erase
[10.075]blk 846 is bad, skip to erase
[10.078]blk 847 is bad, skip to erase
[10.082]blk 848 is bad, skip to erase
[10.085]blk 849 is bad, skip to erase
[10.088]blk 850 is bad, skip to erase
[10.092]blk 851 is bad, skip to erase
[10.095]blk 852 is bad, skip to erase
[10.098]blk 853 is bad, skip to erase
[10.102]blk 854 is bad, skip to erase
[10.105]blk 855 is bad, skip to erase
[10.109]blk 856 is bad, skip to erase
[10.112]blk 857 is bad, skip to erase
[10.115]blk 858 is bad, skip to erase
[10.119]blk 859 is bad, skip to erase
[10.122]blk 860 is bad, skip to erase
[10.126]blk 861 is bad, skip to erase
[10.129]blk 862 is bad, skip to erase
[10.132]blk 863 is bad, skip to erase
[10.136]blk 864 is bad, skip to erase
[10.139]blk 865 is bad, skip to erase
[10.142]blk 866 is bad, skip to erase
[10.146]blk 867 is bad, skip to erase
[10.149]blk 868 is bad, skip to erase
[10.153]blk 869 is bad, skip to erase
[10.156]blk 870 is bad, skip to erase
[10.159]blk 871 is bad, skip to erase
[10.163]blk 872 is bad, skip to erase
[10.166]blk 873 is bad, skip to erase
[10.169]blk 874 is bad, skip to erase
[10.173]blk 875 is bad, skip to erase
[10.176]blk 876 is bad, skip to erase
[10.180]blk 877 is bad, skip to erase
[10.183]blk 878 is bad, skip to erase
[10.186]blk 879 is bad, skip to erase
[10.190]blk 880 is bad, skip to erase
[10.193]blk 881 is bad, skip to erase
[10.196]blk 882 is bad, skip to erase
[10.200]blk 883 is bad, skip to erase
[10.203]blk 884 is bad, skip to erase
[10.207]blk 885 is bad, skip to erase
[10.210]blk 886 is bad, skip to erase
[10.213]blk 887 is bad, skip to erase
[10.217]blk 888 is bad, skip to erase
[10.220]blk 889 is bad, skip to erase
[10.224]blk 890 is bad, skip to erase
[10.227]blk 891 is bad, skip to erase
[10.230]blk 892 is bad, skip to erase
[10.234]blk 893 is bad, skip to erase
[10.237]blk 894 is bad, skip to erase
[10.240]blk 895 is bad, skip to erase
[10.244]blk 896 is bad, skip to erase
[10.247]blk 897 is bad, skip to erase
[10.251]blk 898 is bad, skip to erase
[10.254]blk 899 is bad, skip to erase
[10.257]blk 900 is bad, skip to erase
[10.261]blk 901 is bad, skip to erase
[10.264]blk 902 is bad, skip to erase
[10.267]blk 903 is bad, skip to erase
[10.271]blk 904 is bad, skip to erase
[10.274]blk 905 is bad, skip to erase
[10.278]blk 906 is bad, skip to erase
[10.281]blk 907 is bad, skip to erase
[10.284]blk 908 is bad, skip to erase
[10.288]blk 909 is bad, skip to erase
[10.291]blk 910 is bad, skip to erase
[10.295]blk 911 is bad, skip to erase
[10.298]blk 912 is bad, skip to erase
[10.301]blk 913 is bad, skip to erase
[10.305]blk 914 is bad, skip to erase
[10.308]blk 915 is bad, skip to erase
[10.311]blk 916 is bad, skip to erase
[10.315]blk 917 is bad, skip to erase
[10.318]blk 918 is bad, skip to erase
[10.322]blk 919 is bad, skip to erase
[10.325]blk 920 is bad, skip to erase
[10.328]blk 921 is bad, skip to erase
[10.332]blk 922 is bad, skip to erase
[10.335]blk 923 is bad, skip to erase
[10.338]blk 924 is bad, skip to erase
[10.342]blk 925 is bad, skip to erase
[10.345]blk 926 is bad, skip to erase
[10.349]blk 927 is bad, skip to erase
[10.352]blk 928 is bad, skip to erase
[10.355]blk 929 is bad, skip to erase
[10.359]blk 930 is bad, skip to erase
[10.362]blk 931 is bad, skip to erase
[10.365]blk 932 is bad, skip to erase
[10.369]blk 933 is bad, skip to erase
[10.372]blk 934 is bad, skip to erase
[10.376]blk 935 is bad, skip to erase
[10.379]blk 936 is bad, skip to erase
[10.382]blk 937 is bad, skip to erase
[10.386]blk 938 is bad, skip to erase
[10.389]blk 939 is bad, skip to erase
[10.393]blk 940 is bad, skip to erase
[10.396]blk 941 is bad, skip to erase
[10.399]blk 942 is bad, skip to erase
[10.403]blk 943 is bad, skip to erase
[10.406]blk 944 is bad, skip to erase
[10.409]blk 945 is bad, skip to erase
[10.413]blk 946 is bad, skip to erase
[10.416]blk 947 is bad, skip to erase
[10.420]blk 948 is bad, skip to erase
[10.423]blk 949 is bad, skip to erase
[10.426]blk 950 is bad, skip to erase
[10.430]blk 951 is bad, skip to erase
[10.433]blk 952 is bad, skip to erase
[10.436]blk 953 is bad, skip to erase
[10.440]blk 954 is bad, skip to erase
[10.443]blk 955 is bad, skip to erase
[10.447]blk 956 is bad, skip to erase
[10.450]blk 957 is bad, skip to erase
[10.453]blk 958 is bad, skip to erase
[10.457]blk 959 is bad, skip to erase
[10.460]blk 960 is bad, skip to erase
[10.464]blk 961 is bad, skip to erase
[10.467]blk 962 is bad, skip to erase
[10.470]blk 963 is bad, skip to erase
[10.474]blk 964 is bad, skip to erase
[10.477]blk 965 is bad, skip to erase
[10.480]blk 966 is bad, skip to erase
[10.484]blk 967 is bad, skip to erase
[10.487]blk 968 is bad, skip to erase
[10.491]blk 969 is bad, skip to erase
[10.494]blk 970 is bad, skip to erase
[10.497]blk 971 is bad, skip to erase
[10.501]blk 972 is bad, skip to erase
[10.504]blk 973 is bad, skip to erase
[10.507]blk 974 is bad, skip to erase
[10.511]blk 975 is bad, skip to erase
[10.514]blk 976 is bad, skip to erase
[10.518]blk 977 is bad, skip to erase
[10.521]blk 978 is bad, skip to erase
[10.524]blk 979 is bad, skip to erase
[10.528]blk 980 is bad, skip to erase
[10.531]blk 981 is bad, skip to erase
[10.534]blk 982 is bad, skip to erase
[10.538]blk 983 is bad, skip to erase
[10.541]blk 984 is bad, skip to erase
[10.545]blk 985 is bad, skip to erase
[10.548]blk 986 is bad, skip to erase
[10.551]blk 987 is bad, skip to erase
[10.555]blk 988 is bad, skip to erase
[10.558]blk 989 is bad, skip to erase
[10.562]blk 990 is bad, skip to erase
[10.565]blk 991 is bad, skip to erase
[10.568]blk 992 is bad, skip to erase
[10.572]blk 993 is bad, skip to erase
[10.575]blk 994 is bad, skip to erase
[10.578]blk 995 is bad, skip to erase
[10.582]blk 996 is bad, skip to erase
[10.585]blk 997 is bad, skip to erase
[10.589]blk 998 is bad, skip to erase
[10.592]blk 999 is bad, skip to erase
[10.595]blk 1000 is bad, skip to erase
[10.599]blk 1001 is bad, skip to erase
[10.602]blk 1002 is bad, skip to erase
[10.606]blk 1003 is bad, skip to erase
[10.609]blk 1004 is bad, skip to erase
[10.613]blk 1005 is bad, skip to erase
[10.616]blk 1006 is bad, skip to erase
[10.620]blk 1007 is bad, skip to erase
[10.623]blk 1008 is bad, skip to erase
[10.627]blk 1009 is bad, skip to erase
[10.630]blk 1010 is bad, skip to erase
[10.633]blk 1011 is bad, skip to erase
[10.637]blk 1012 is bad, skip to erase
[10.640]blk 1013 is bad, skip to erase
[10.644]blk 1014 is bad, skip to erase
[10.647]blk 1015 is bad, skip to erase
[10.651]blk 1016 is bad, skip to erase
[10.654]blk 1017 is bad, skip to erase
[10.658]blk 1018 is bad, skip to erase
[10.661]blk 1019 is bad, skip to erase
[10.665]blk 1020 is bad, skip to erase
[10.668]blk 1021 is bad, skip to erase
[10.672]blk 1022 is bad, skip to erase
[10.675]blk 1023 is bad, skip to erase
[10.679]sunxi-spinand: no enough good blk between [40 40) for secure storage
[10.685]get secure storage map err
[10.688]sunxi-spinand: no enough good blk between [40 40) for secure storage
[10.695]erase secure storage block 0 err
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
force mbr
defaults:
mtdids  : nand0=nand
[10.744]MTD info (4)
[10.746]pagesize: 0x1000
[10.748]blksize: 0x40000
[10.750]num  offset     bytes      name
[10.754]0    0x00000000 0x00100000 boot0
[10.758]1    0x00100000 0x00300000 uboot
[10.761]2    0x00400000 0x00100000 secure_storage
[10.766]3    0x00500000 0x07b00000 sys
[10.769]MBR info (unalign):
[10.772]partno   addr       sects      type       name
[10.776]0        0x00000000 0x00008000 0x00000001 mbr
[10.781]1        0x00008000 0x00000800 0x00008000 boot-resource
[10.787]2        0x00008800 0x000001f8 0x00008000 env
[10.792]3        0x000089f8 0x000001f8 0x00008000 env-redund
[10.797]4        0x00008bf0 0x000021e8 0x00008000 boot
[10.802]5        0x0000add8 0x00011800 0x00008000 rootfs
[10.807]6        0x0001c5d8 0x00002800 0x00008000 private
[10.812]7        0x0001edd8 0x00015e00 0x00008000 rootfs_data
[10.817]8        0x00034bd8 0x00000000 0x00008100 UDISK
[10.822]ubi attach the last part of mtd device: NO.3
[10.827]MBR info (align):
[10.829]partno   addr       sects      type       name
[10.834]0        0x00002800 0x000081f0 0x00000001 mbr
[10.839]1        0x0000a9f0 0x000009d8 0x00008000 boot-resource
[10.845]2        0x0000b3c8 0x000001f8 0x00008000 env
[10.849]3        0x0000b5c0 0x000001f8 0x00008000 env-redund
[10.855]4        0x0000b7b8 0x00002370 0x00008000 boot
[10.860]5        0x0000db28 0x00011988 0x00008000 rootfs
[10.865]6        0x0001f4b0 0x00002958 0x00008000 private
[10.870]7        0x00021e08 0x00015e70 0x00008000 rootfs_data
[10.875]8        0x00037c78 0x00000000 0x00008100 UDISK
[10.880]ubi attach the last part of mtd device: NO.3
[10.885]ubi attatch mtd, name: sys
[10.888]ubi0: attaching mtd4
[10.891]ubi0: scanning is finished
[10.894]ubi0: empty MTD device detected
[10.898]ubi0 error: ubi_early_get_peb: no free eraseblocks
[10.903]ubi0 error: ubi_attach_mtd_dev: failed to attach mtd4, error -28
[10.910]UBI error: cannot attach mtd4
[10.913]UBI error: cannot initialize UBI, error -28
UBI init error 28
[10.925]ubi part sys err !
[10.928]initialize sunxi spinand ubi failed
download_standard_gpt:write mbr sectors fail ret = 0
又一个新的不行
#2 2024-03-11 10:00:33
已发帖子: 1,417
我用d133+rt-thread烧录spi nor flash也遇到过问题,你这个是spi nand,可能不一样。
我当时用usb烧录了几次程序后,忽然发现烧录时间变的很快,之前可能40多秒烧录完成,变成了3秒烧录完。然后程序其实还是上一回烧录的程序,本次烧录实际没成功。后来通过sf发现,可以查看spi nor flash的状态寄存器,发现不为0。我对比了下另一块正常的板,该寄存器值为0x00。通过sf status 0 0x00,可以将状态寄存器清零。然后就正常了。这个问题出现过几次,一直没搞懂原因。
最近编辑记录 Gentlepig (2024-03-11 10:01:12)
