楼主 # 2026-05-12 13:07:06
QL2017
已发帖子: 63
[求助]USB副屏方案编译出错
屏幕RGB480*272 触摸GT910 板子D133EBS立创衡山派 我是按照https://aicdoc.artinchip.com/topics/sdk/app/usb-display-config-lite.html的教程一步一步走的,但是一编译就出现 CC packages\artinchip\mpp\base\memory\mpp_mem.c
CC packages\artinchip\mpp\middle_media\base\stream\aic_stream.c
CC packages\artinchip\mpp\middle_media\audio_decoder\decoder\audio_packet_manager.c
CC packages\artinchip\mpp\middle_media\audio_decoder\decoder\audio_frame_manager.c
CC packages\artinchip\mpp\ge\cmdq_ops.c
CC packages\artinchip\thread_stack_trace\thread_stack_trace.c
LINK output\d13x_hspi100-nor_rt-thread_helloworld\images\d13x.elf
d:/hspi/fuping/luban-lite/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: cannot find -lusbd_display_template_e907fdp
collect2.exe: error: ld returned 1 exit status
scons: *** [output\d13x_hspi100-nor_rt-thread_helloworld\images\d13x.elf] Error 1
scons: building terminated because of errors.
这样的报错怎么办,拉主线lubanlite sdk也一样的报错,求助
#1 2026-05-13 08:51:45
soso
已发帖子: 169
Re: [求助]USB副屏方案编译出错
这个不支持这个芯片吧。。。只有一个型号支持,是闭源的
#2 2026-05-13 10:04:45
nilecho
Re: [求助]USB副屏方案编译出错
目前好像只有D215支持UsbDisplay功能
#3 2026-05-13 10:12:10
AICxia
已发帖子: 100
Re: [求助]USB副屏方案编译出错
你好,麻烦提供一下完整的错误日志
