楼主 # 2026-05-23 11:58:24
QL2017
F133-A Uboot启动失败
完整启动Log:
[34]HELLO! BOOT0 is starting!
[37]BOOT0 commit : 88480af
[40]set pll start
[42]periph0 has been enabled
[44]set pll end
[46][pmu]: bus read error
[48]board init ok
[50]ZQ value = 0x2e
[52]get_pmu_exist() = -1
[54]DRAM BOOT DRIVE INFO: V0.33
[57]DRAM CLK = 528 MHz
[59]DRAM Type = 2 (2:DDR2,3:DDR3)
[62]DRAMC read ODT off.
[65]DRAM ODT off.
[67]ddr_efuse_type: 0xa
[69]DRAM SIZE =64 M
[71]dram_tpr4:0x0
[73]PLL_DDR_CTRL_REG:0xf8002b00
[76]DRAM_CLK_REG:0xc0000000
[78][TIMING DEBUG] MR2= 0x0
[83]DRAM simple test OK.
[85]dram size =64
[87]spinor id is: ef 40 18, read cmd: 0b
[90]Succeed in reading toc file head.
[94]The size of toc is 100000.
[265]Entry_name = opensbi
[268]Entry_name = u-boot
[272]Entry_name = dtb
[275]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-3-ge39e937
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,?
U-Boot 2018.07-ge987def5-dirty (May 23 2026 - 09:41:24 +0800) Allwinner Technology
[00.360]DRAM: 64 MiB
[00.362]Relocation Offset is: 01ee8000
[00.367]secure enable bit: 0
[00.369]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
sunxi flash map init
SPI ALL: ready
[00.380]flash init start
[00.382]workmode = 0,storage type = 3
[00.389]sunxi_upper_lock, invalid address!
[00.392]spi sample_mode:1 sample_delay:1a
[00.397]spi sunxi_slave->max_hz:100000000
SF: Detected w25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
[00.409]sunxi flash init ok
[00.411]line:703 init_clocks
[00.415]drv_disp_init
[00.426]drv_disp_init finish
[00.430]Loading Environment from SUNXI_FLASH... OK
[00.443]boot_gui_init:start
[00.446]set disp.dev2_output_type fail. using defval=0
不知道哪里的问题,是屏幕驱动的问题吗
