楼主 #1 2018-12-27 16:03:35
a32425262
已发帖子: 104
alsa 怎么调整麦克风增益
如图硬件是V3s的荔枝派
Mic1 Boost和 ADC Gain又是什么意思呢,实测发现调整是有效果的,但是都调整到100,会有破音
RT,怎么通过alsa调整麦克风增益啊,做到不失真,不破音。
#2 2018-12-27 16:10:27
已发帖子: 9,486
Re: alsa 怎么调整麦克风增益
tinymix contents,最右边那一列可以看到取值范围:
# tinymix contents
Number of controls: 13
ctl     type    num     name                                    value
0       INT     1       DAC Playback Volume                     63 (range 0->63)
1       INT     1       Headphone Playback Volume               63 (range 0->63)
2       BOOL    2       Headphone Playback Switch               On, On
3       INT     1       Mic1 Playback Volume                    3 (range 0->7)
4       INT     1       Mic1 Boost Volume                       4 (range 0->7)
5       INT     1       ADC Gain Capture Volume                 3 (range 0->7)
6       BOOL    2       DAC Playback Switch                     Off, Off
7       BOOL    2       DAC Reversed Playback Switch            Off, Off
8       BOOL    2       Mic1 Playback Switch                    Off, Off
9       BOOL    2       Mixer Capture Switch                    Off, Off
10      BOOL    2       Mixer Reversed Capture Switch           Off, Off
11      BOOL    2       Mic1 Capture Switch                     Off, Off
12      ENUM    2       Headphone Source Playback Route         , DACMixer, , DACMixer
