1.tinymix 查看控制器状态
tinymix contents
Number of controls: 25
ctl type num name value
0 INT 1 DAC Playback Volume 63 (range 0->63)
1 INT 1 Headphone Playback Volume 0 (range 0->63)
2 BOOL 2 Headphone Playback Switch Off, Off
3 INT 1 Line In Playback Volume 0 (range 0->7)
4 INT 1 FM In Playback Volume 0 (range 0->7)
5 INT 1 Mic In Playback Volume 3 (range 0->7)
6 INT 1 Mic Boost Volume 4 (range 0->7)
7 INT 1 ADC Capture Volume 3 (range 0->7)
8 BOOL 1 ADC Mixer Right Out Capture Switch Off
9 BOOL 1 ADC Mixer Left Out Capture Switch Off
10 BOOL 1 ADC Mixer Line In Capture Switch Off
11 BOOL 1 ADC Mixer Right FM In Capture Switch Off
12 BOOL 1 ADC Mixer Left FM In Capture Switch Off
13 BOOL 1 ADC Mixer Mic Capture Switch Off
14 BOOL 1 Left Mixer Right DAC Playback Switch Off
15 BOOL 1 Left Mixer Left DAC Playback Switch Off
16 BOOL 1 Left Mixer FM In Playback Switch Off
17 BOOL 1 Left Mixer Line In Playback Switch Off
18 BOOL 1 Left Mixer Mic In Playback Switch Off
19 BOOL 1 Right Mixer Left DAC Playback Switch Off
20 BOOL 1 Right Mixer Right DAC Playback Switch Off
21 BOOL 1 Right Mixer FM In Playback Switch Off
22 BOOL 1 Right Mixer Line In Playback Switch Off
23 BOOL 1 Right Mixer Mic In Playback Switch Off 2.打开控制器为13的 capture设备
tinymix set 13 1 3.录音
tinycap xixi.wav -t 2 离线
感谢楼主,回去拿出我吃灰的tiny200试一试
