楼主 #1 2021-01-06 14:57:50
feng888
已发帖子: 59
V3s 下载到sdram 启动系统,卡在这里,如何排查问题?
[ 146.164081] mmc0: card 9b0e removed
U-Boot SPL 2017.01-rc2 (Jan 06 2021 - 14:51:53)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2017.01-rc2 (Jan 06 2021 - 14:51:53 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
Loading init Ramdisk from Legacy Image at 41a00000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 10522913 Bytes = 10 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Flattened Device Tree blob at 41800000
Loading Ramdisk to 423f6000, end 42dff121 ... OK
Loading Device Tree to 423f0000, end 423f542d ... OK
[ 0.000000] Linux version 4.10.15-licheepi-zero (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #4 SMP Wed Jan 6 14:17:39 CST 2021
[ 0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 14 pages/cpu @c3f63000 s24716 r8192 d24436 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk rw
[ 0.000000] Memory: 44880K/65536K available (6144K kernel code, 194K rwdata, 1232K rodata, 1024K init, 252K bss, 20656K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a30a00 ( 195 kB)
[ 0.000000] .bss : 0xc0a32000 - 0xc0a7104c ( 253 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000017] Switching to timer-based delay loop, resolution 41ns
[ 0.000139] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000345] Console: colour dummy device 80x30
[ 0.000383] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000397] pid_max: default: 32768 minimum: 301
[ 0.000531] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000543] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001250] CPU: Testing write buffer coherency: ok
[ 0.001653] /cpus/cpu@0 missing clock-frequency property
[ 0.001677] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002034] Setting up static identity map for 0x40100000 - 0x40100058
[ 0.002774] smp: Bringing up secondary CPUs ...
[ 0.002793] smp: Brought up 1 node, 1 CPU
[ 0.002801] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002808] CPU: All CPU(s) started in SVC mode.
[ 0.003573] devtmpfs: initialized
[ 0.006462] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006767] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.006922] pinctrl core: initialized pinctrl subsystem
[ 0.007929] NET: Registered protocol family 16
[ 0.008353] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009552] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009567] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.021143] SCSI subsystem initialized
[ 0.021429] usbcore: registered new interface driver usbfs
[ 0.021489] usbcore: registered new interface driver hub
[ 0.021582] usbcore: registered new device driver usb
[ 0.021810] pps_core: LinuxPPS API ver. 1 registered
[ 0.021819] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.021841] PTP clock support registered
[ 0.022054] Advanced Linux Sound Architecture Driver Initialized.
[ 0.023854] clocksource: Switched to clocksource arch_sys_counter
[ 0.034761] NET: Registered protocol family 2
[ 0.035368] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.035399] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.035423] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.035508] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.035555] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.035786] NET: Registered protocol family 1
[ 0.036402] RPC: Registered named UNIX socket transport module.
[ 0.036420] RPC: Registered udp transport module.
[ 0.036426] RPC: Registered tcp transport module.
[ 0.036432] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.036738] Unpacking initramfs...
[ 0.682378] Freeing initrd memory: 10280K
[ 0.684526] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.693335] NFS: Registering the id_resolver key type
[ 0.693381] Key type id_resolver registered
[ 0.693389] Key type id_legacy registered
[ 0.697580] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.697601] io scheduler noop registered
[ 0.697608] io scheduler deadline registered
[ 0.697800] io scheduler cfq registered (default)
[ 0.701986] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.773745] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.777191] console [ttyS0] disabled
[ 0.797471] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[ 1.357892] console [ttyS0] enabled
[ 1.363040] libphy: Fixed MDIO Bus: probed
[ 1.367448] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.374024] ehci-platform: EHCI generic platform driver
[ 1.379328] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.385550] ohci-platform: OHCI generic platform driver
[ 1.391250] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.400680] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.409600] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.416506] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.421040] i2c /dev entries driver
[ 1.425921] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.435471] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.503895] sunxi-mmc 1c0f000.mmc: base:0xc485f000 irq:23
[ 1.563877] sunxi-mmc 1c10000.mmc: base:0xc4863000 irq:24
[ 1.570184] usbcore: registered new interface driver usbhid
[ 1.575839] usbhid: USB HID core driver
[ 1.581175] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.589237] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.596380] NET: Registered protocol family 17
[ 1.600936] Key type dns_resolver registered
[ 1.605450] Registering SWP/SWPB emulation handler
[ 1.618639] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.626623] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.632389] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.641629] hub 1-0:1.0: USB hub found
[ 1.645591] hub 1-0:1.0: 1 port detected
[ 1.650280] using random self ethernet address
[ 1.654833] using random host ethernet address
[ 1.660228] usb0: HOST MAC aa:2e:ed:f2:83:84
[ 1.664676] usb0: MAC 9e:4b:88:92:c1:3d
[ 1.668576] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.676103] g_cdc gadget: g_cdc ready
[ 1.682159] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.691336] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 03:51:52 UTC (13912)
[ 1.699914] vcc5v0: disabling
[ 1.702890] ALSA device list:
[ 1.705913] #0: V3s Audio Codec
[ 1.710656] Freeing unused kernel memory: 1024K
[ 1.718737] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.735121] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.746029] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.758618] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.771584] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.781723] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.792163] mmc1: new high speed SDIO card at address 0001
[ 5.985494] random: fast init done
#2 2021-01-06 15:09:58
raspberryman
已发帖子: 505
Re: V3s 下载到sdram 启动系统,卡在这里,如何排查问题?
没有提示错误,敲回车有反应吗?
楼主 #3 2021-01-06 15:42:10
feng888
已发帖子: 59
raspberryman wrote:
没有提示错误,敲回车有反应吗?
敲回车没反应,插入SD卡可以提示卡容量
#4 2021-01-06 16:15:53
raspberryman
已发帖子: 505
看日志,ramfs解压正常,为什么没有运行初始化进程呢?
#5 2021-04-12 17:10:13
大帅
已发帖子: 169
Image Name: uInitrd
是不是rootfs太大了
#6 2021-04-12 18:07:28
心情复杂
已发帖子: 37
0x41a00000+ 10522913 = 0x42409121
Load地址是 0x423f6000 估计RamDisk后面有一部分被覆盖了吧
