楼主 #1 2021-04-07 00:04:24
saub
已发帖子: 102
发现一个比较牛B的芯片,RDA8810M,这个芯片不仅内置256MDDR2,还内置了512Mflash,用来跑linux+QT妥妥的
淘宝售价10元左右,性价比逆天了啊,有没有大佬感兴趣的?
用来跑linux+QT妥妥的。跑安卓也问题不大了
香橙派2G就是用的这个芯片,
功能如下,该有的基本都有了,
1.1 PLATFORM FEATURES
+ AP MCU subsystem
 - ARM Cortex-A5 32-bit RISC processor, with FPU and SIMD NEON engine, up to 1G Hz
 - 32kB L1 I-cache and 32kB L1 D-cache- 256kB unified L2 cache
 - In-house VOC DSP for voice and image process
 - 64-bit AXI fabric, up to 400MHz
 - 64kB on-chip ROM for system boot
 - 64kB on-chip SRAM for internal use
+ memory interface
 - Integrated 2Gb LPDDR2 SDRAM          //256M  LPDDR2  SDRAM
 - Integrated 4Gb 8Bit 2.8V 4K SLC Nand Flash        //512M nand flash,做产品成本可以压到极至了
 - Two SDIO interfaces, for TF cards and WIFI
 - support 4.4.1 EMMC interface
 - support SPI-NAND and SPI-NOR
+ Connectivity
 - Support 3 SIM cards and both 1.8V and 3.0V device
 - USB2.0 high-speed OTG
 - 3 UARTs for GPS, BT, FM, and debugging interfaces
 - 3 SPI for peripheral devices
 - 3 I2C for peripheral devices
 - 1 I2S for peripheral devices
 - 4 10-bit GPADC for sampling peripheral signals
 - 64 GPIOs, includes 16 interruptable GPIOs
 - Pulse Width Modulation (PWM) 1 PWL, 1 PWT and 1 LPG
 - 2 memory card controller
 - 8x8 Keypad scanner with multiple key detection, support ADC serial interface Keypad
1.2 MODEM FEATURES
+ System CPU(XCUP)
 - RDA RISC Core 32x32 bits
 - 16/32 bit instruction set
 - 4KB I-cache and 4KB D-cache
+ Base Band CPU (BCPU)
 - RDA RISC Core32x32 bits
 - 1KB I-cache and 1KB D-cache
 - GSM/GPRS Dedicated accelerators
 - RF Interface (RF IF)
 - DigRF interface for communication with the integrated transceiver
 - EGPRS class 12
+ RF Transceiver
 - Quad bands integrated transceiver
 - Integrated RF transceiver, Saw-Less, only needs external PA.
 - Digital low-IF receiver
 - Direct modulation transmitter
 - Frequency synthesizer
 - Integrated VCO, loop filters, etc.
 - Digital AFC
 - DigRF interface between digital baseband and transceiver
 - RF FEM control
+ Voice and Modem codec
 - Supports HR, FR, EFR, AMR voice codec
 - Integrated microphone bias
 - DTMF and Comfort Tone generator
 - 4 samples In and Out Fifos
 - I2S / DAI Interface
 - Serial Input / Output at 8/16 ks/s
 - Can be used for test purpose in DAI mode
 - Audio Interface To ABB
 - 13 bit RX Data from audio ADC
 - 16 bit TX Data to stereo DAC
1.3 MULTI-MEDIA FEATURES
+ LCD display
 - Support LCD module interface with 8/16/24 bit parallel interface or SPI series interface
 - Support RGB565/666/888 interface
 - Typical image sizes: QCIF, QVGA, WQVGA, CIF,VGA,WVGA,FWVGA
 - Support DSI interface, up to 1GHz
 - Support image size up to qHD
 - 4-layers blending graphical engine capable of resizing and YUV2RGB conversion
 - Support 2chip select
+ Image signal processor
 - Support 8-bit parallel or 1/2/4-bit series interface
 - Support CSI-2 interface, up to 1GHz
 - Support up to 5Mpix sensor
+ Vide
 - Separate video processor
 - Decodes up to 1080p 30fps
 - Encodes up to 1080p 30fps for H.264 format
+ Graphics
 - Separate graphic processor, Vivante’s GC860
 - support OpenGLES1.1/2.0
 - support OpenVG1.4
 - support DirectFB
 - support GDI/DirecShow
 - 30Triangle/s, 250Pixel/s
+ Audio
 - 2 channels voice ADC, 8kHz, 13 bits/sample for headset and on-board microphone
 - Voice DAC, 8kHz, 13 bits/sample for receiver
 - High fidelity Stereo DAC, up to 48kHz, 16 bits per sample
 - Stereo Audio speaker driver
 - 1.5W differential output stereo amplifier for loudspeaker, Class K
 - Stereo analog audio line input
1.4 POWER MANAGEMENT FEATURES
+ Power Management
 - Power On reset control
 - Internal 32K OSC for standby/ shutoff/ sleep state
 - Integrated Li-ion battery charger (from USB or AC charger)
 - Integrated all internal voltages from VBAT
 - Provide all LDOs for external components
 - Integrated 4 DC-DC, 1 BOOST
 - Integrated LCD backlight controller
 - Integrated Touch screen controller
 - Integrated RGB, keypad backlight controller
最近编辑记录 saub (2021-04-07 00:10:54)
#2 2021-04-07 04:16:14
david
已发帖子: 397
Re: 发现一个比较牛B的芯片,RDA8810M,这个芯片不仅内置256MDDR2,还内置了512Mflash,用来跑linux+QT妥妥的
这芯片停产了 尾货 没资料 没支持 才这么便宜
楼主 #3 2021-04-07 07:16:12
saub
已发帖子: 102
哦?,原来如此,那香橙派2G是哪里来的芯片呢?
#4 2021-04-07 09:22:03
xk100
已发帖子: 75
#5 2021-04-07 09:37:21
阿黄
已发帖子: 299
以前的手机芯片
#6 2021-04-07 09:39:01
raspberryman
已发帖子: 503
用香橙派开发板把项目开发到一半,同事说可能停产了,到处打听确实停产了,都停产了,推广个锤子啊
楼主 #7 2021-04-07 09:50:11
saub
已发帖子: 102
ᥬ?᭄我也是无意看到这个芯片,没了解清楚,见谅哈!
但为什么香橙派还在卖这款呢?香橙派OrangePi 2G-IOT电脑开发板WIFI+蓝牙2G模块RDA芯片,他们哪里来的芯片?难道都是用的二手拆机芯片?那也太不负责任了吧
最近编辑记录 saub (2021-04-07 09:52:36)
#8 2021-04-07 09:52:11
raspberryman
已发帖子: 503
兄台我不是说你,是说那个卖开发板的。
#9 2021-04-07 14:43:35
cloudxxcloud
这种芯片就和单片机一样了,都集成了
#10 2021-04-07 14:49:08
Quotation
已发帖子: 307
这太方便了,现在还有没有这样的SoC可用了?
#11 2021-04-07 14:59:24
bingyinhaha
早就停产了,而且A5 性能太差。
#12 2021-04-08 18:25:35
sy373466062
已发帖子: 132
为啥都不多搞一些这么好的芯片。
