楼主 # 2023-11-03 22:26:14
memory
已发帖子: 716
请问 gt911 的 _goodix_config_.cfg 是什么格式?
[    3.729884] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[    3.735853] <<-GTP-FUNC->> Func:gtp_i2c_test@Line:2077
[    3.741620] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    3.747493] sunxi_i2c_do_xfer()1968 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.756879] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    3.762921] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    3.768916] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    3.774926] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    3.774958] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    3.791448] sunxi_i2c_do_xfer()1968 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.800994] sunxi_i2c_do_xfer()1968 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.810587] sunxi_i2c_do_xfer()1968 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.820140] sunxi_i2c_do_xfer()1968 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.829527] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
[    3.838811] <<-GTP-FUNC->> Func:gtp_reset_guitar@Line:1377
[    3.844973] <<-GTP-INFO->> Guitar reset
[    3.994557] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.004888] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    4.033544] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.039487] <<-GTP-FUNC->> Func:gtp_read_version@Line:2038
[    4.045655] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.051727] <<-GTP-INFO->> IC Version: 911_1060
[    4.056870] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.069164] <<-GTP-INFO->> X_MAX: 854, Y_MAX: 480, TRIGGER: 0x01
[    4.103586] <<-GTP-INFO->> create proc entry gt9xx_config success
[    4.110423] <<-GTP-INFO->> Ready to run update thread.
[    4.116303] <<-GTP-FUNC->> Func:gtp_request_input_dev@Line:2138
[    4.123378] <<-GTP-DEBUG->> [2268][update_proc]Begin update ......
[    4.130469] input: gt9xxnew_ts as /devices/virtual/input/input1
[    4.130880] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.130889] <<-GTP-INFO->> GTP works in interrupt mode.
[    4.130893] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.130904] <<-GTP-INFO->> Applied memory size:2562.
[    4.130909] <<-GTP-INFO->> I2C function: without pre and end cmd!
[    4.130923] <<-GTP-INFO->> Create proc entry success!
[    4.131576] sunxi-rtc rtc: setting system clock to 1970-01-01 08:37:07 UTC (31027)
[    4.132477] clk: Not disabling unused clocks
[    4.132490] usb-vbus: disabling
[    4.132494] ALSA device list:
[    4.132498]   #0: audiocodec
[    4.132500]   #1: snddaudio0
[    4.145405] <<-GTP-FUNC->> Func:goodix_ts_irq_handler@Line:1339
[    4.145409] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.145448] <<-GTP-FUNC->> Func:goodix_ts_work_func@Line:822
[    4.145452] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.170092] <<-GTP-DEBUG->> [1150]pre_touch:00, finger:80.
[    4.170099] <<-GTP-FUNC->> Func:gtp_i2c_write@Line:449
[    4.176016] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.176037] <<-GTP-FUNC->> Func:goodix_ts_irq_handler@Line:1339
[    4.176040] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.176061] <<-GTP-FUNC->> Func:goodix_ts_work_func@Line:822
[    4.176064] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.239515] <<-GTP-DEBUG->> [1150]pre_touch:00, finger:80.
[    4.239520] <<-GTP-FUNC->> Func:gtp_i2c_write@Line:449
[    4.258292] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.258311] <<-GTP-FUNC->> Func:goodix_ts_irq_handler@Line:1339
[    4.258314] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.258334] <<-GTP-FUNC->> Func:goodix_ts_work_func@Line:822
[    4.258337] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.288334] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.307520] <<-GTP-DEBUG->> [1150]pre_touch:00, finger:80.
[    4.307526] <<-GTP-FUNC->> Func:gtp_i2c_write@Line:449
[    4.324150] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.325278] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.325298] <<-GTP-FUNC->> Func:goodix_ts_irq_handler@Line:1339
[    4.325302] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.325324] <<-GTP-FUNC->> Func:goodix_ts_work_func@Line:822
[    4.325328] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.332662] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.333779] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.333807] <<-GTP-FUNC->> Func:goodix_ts_irq_handler@Line:1339
[    4.333810] <<-GTP-FUNC->> Func:gtp_irq_disable@Line:586
[    4.333829] <<-GTP-FUNC->> Func:goodix_ts_work_func@Line:822
[    4.333832] <<-GTP-FUNC->> Func:gtp_i2c_read@Line:379
[    4.339729] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[    4.350516] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    4.356448] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    4.363155] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    4.369166] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[    4.369200] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    4.369316] <<-GTP-FUNC->> Func:gtp_irq_enable@Line:612
[    4.469162] <<-GTP-DEBUG->> [797]Search for /data/_goodix_update_.bin, /sdcard/_goodix_update_.bin for fw update.(1/50)
[    4.481889] <<-GTP-DEBUG->> [834]Search for /data/_goodix_config_.cfg, /sdcard/_goodix_config_.cfg for config update.(1/50)
#1 2024-02-01 20:23:53
善思维
Re: 请问 gt911 的 _goodix_config_.cfg 是什么格式?
.cfg是文本文件
