楼主 # 2024-12-25 15:38:02
wdawd
V3s spiflash 启动有问题,求大佬指点
U-Boot SPL 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 25 2024 - 03:11:10)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 25 2024 - 03:11:10 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
   Loading Device Tree to 42dfa000, end 42dfffd9 ... OK
[    0.000000] Linux version 5.2.0-licheepi-zero+ (linux@linux) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #8 SMP Wed Dec 25 14:15:21 CST 2024
[    0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[    0.000000] Memory: 55056K/65536K available (6144K kernel code, 290K rwdata, 1640K rodata, 1024K init, 252K bss, 10480K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[    0.000208] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000448] Console: colour dummy device 80x30
[    0.000507] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000522] pid_max: default: 32768 minimum: 301
[    0.000684] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000698] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001504] CPU: Testing write buffer coherency: ok
[    0.002022] /cpus/cpu@0 missing clock-frequency property
[    0.002049] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002832] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003048] rcu: Hierarchical SRCU implementation.
[    0.003578] smp: Bringing up secondary CPUs ...
[    0.003598] smp: Brought up 1 node, 1 CPU
[    0.003607] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003615] CPU: All CPU(s) started in SVC mode.
[    0.004715] devtmpfs: initialized
[    0.008231] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008543] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008573] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008814] pinctrl core: initialized pinctrl subsystem
[    0.009834] NET: Registered protocol family 16
[    0.010432] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.011668] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.011686] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.035733] SCSI subsystem initialized
[    0.036015] usbcore: registered new interface driver usbfs
[    0.036069] usbcore: registered new interface driver hub
[    0.036172] usbcore: registered new device driver usb
[    0.036400] mc: Linux media interface: v0.10
[    0.036439] videodev: Linux video capture interface: v2.00
[    0.037870] clocksource: Switched to clocksource arch_sys_counter
[    0.049569] NET: Registered protocol family 2
[    0.050349] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.050385] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.050409] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.050432] TCP: Hash tables configured (established 1024 bind 1024)
[    0.050568] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.050618] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.050941] NET: Registered protocol family 1
[    0.052770] Initialise system trusted keyrings
[    0.053144] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.059313] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.096763] Key type asymmetric registered
[    0.096785] Asymmetric key parser 'x509' registered
[    0.096898] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.096913] io scheduler mq-deadline registered
[    0.096919] io scheduler kyber registered
[    0.098086] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.101820] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.168460] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.170776] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.171846] printk: console [ttyS0] disabled
[    0.192145] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.704981] printk: console [ttyS0] enabled
[    0.735047] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.746723] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[    0.753154] libphy: Fixed MDIO Bus: probed
[    0.757779] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.763674] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.769934] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[    0.779333] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.786550] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.793788] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.798765] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.805545] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.811211] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.817135] libphy: stmmac: probed
[    0.821297] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.827576] libphy: mdio_mux: probed
[    0.831265] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    0.837619] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    0.844784] libphy: mdio_mux: probed
[    0.848877] usbcore: registered new interface driver asix
[    0.854349] usbcore: registered new interface driver ax88179_178a
[    0.860582] usbcore: registered new interface driver cdc_ether
[    0.866446] usbcore: registered new interface driver net1080
[    0.872182] usbcore: registered new interface driver rndis_host
[    0.878160] usbcore: registered new interface driver cdc_subset
[    0.884098] usbcore: registered new interface driver zaurus
[    0.889746] usbcore: registered new interface driver cdc_ncm
[    0.895399] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.901939] ehci-platform: EHCI generic platform driver
[    0.907436] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.913101] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.921054] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.947869] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.955097] hub 1-0:1.0: USB hub found
[    0.959050] hub 1-0:1.0: 1 port detected
[    0.963633] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.969958] ohci-platform: OHCI generic platform driver
[    0.975532] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.982275] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.990252] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.062931] hub 2-0:1.0: USB hub found
[    1.066772] hub 2-0:1.0: 1 port detected
[    1.074094] usbcore: registered new interface driver usb-storage
[    1.081365] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.090672] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.095736] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.100456] i2c /dev entries driver
[    1.105324] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.115144] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.123833] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.160372] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.167613] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.204511] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.212600] usbcore: registered new interface driver usbhid
[    1.218269] usbhid: USB HID core driver
[    1.222662] Initializing XFRM netlink socket
[    1.226964] NET: Registered protocol family 17
[    1.232092] Registering SWP/SWPB emulation handler
[    1.238148] Loading compiled-in X.509 certificates
[    1.249335] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.260794] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.266556] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.276021] hub 3-0:1.0: USB hub found
[    1.280086] hub 3-0:1.0: 1 port detected
[    1.285527] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:30 UTC (30)
[    1.293920] vcc5v0: disabling
[    1.298227] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[    1.305797] Please append a correct "root=" boot option; here are the available partitions:
[    1.314236] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[    1.322583] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero+ #8
[    1.329706] Hardware name: Allwinner sun8i Family
[    1.334440] [<c010eea4>] (unwind_backtrace) from [<c010b81c>] (show_stack+0x10/0x14)
[    1.342182] [<c010b81c>] (show_stack) from [<c06537b8>] (dump_stack+0x88/0x9c)
[    1.349402] [<c06537b8>] (dump_stack) from [<c011df24>] (panic+0x110/0x2fc)
[    1.356367] [<c011df24>] (panic) from [<c090134c>] (mount_block_root+0x218/0x2f4)
[    1.363846] [<c090134c>] (mount_block_root) from [<c0901600>] (prepare_namespace+0x150/0x194)
[    1.372363] [<c0901600>] (prepare_namespace) from [<c0669ee8>] (kernel_init+0x8/0x10c)
[    1.380274] [<c0669ee8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.387832] Exception stack(0xc3833fb0 to 0xc3833ff8)
[    1.392878] 3fa0:                                     00000000 00000000 00000000 00000000
[    1.401046] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.409212] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.415832] Rebooting in 5 seconds..
#1 2024-12-25 17:24:20
hameyou
已发帖子: 268
Re: V3s spiflash 启动有问题,求大佬指点
根文件系统挂载失败,看看是不是配置的有问题
楼主 #2 2024-12-27 10:00:45
wdawd
问题已经解决了
#3 2026-01-23 23:24:39
zl
已发帖子: 20
wdawd wrote:
问题已经解决了
楼主怎么解决的?我也跟你一样的问题
楼主 #4 2026-01-24 16:12:50
wdawd
我的应该是这个问题导致的,当时改了东西,现在有点记不得了,你就照着这部分查查,应该就可以知道问题在什么地方了
