楼主 #1 2019-03-29 21:17:30
已发帖子: 9,513
围观网友 @FMer 手焊 eMMC, 并成功启动 V3s Linux
楼主 #2 2019-03-29 21:18:09
已发帖子: 9,513
Re: 围观网友 @FMer 手焊 eMMC, 并成功启动 V3s Linux
楼主 #3 2019-03-29 21:18:32
已发帖子: 9,513
楼主 #4 2019-03-29 21:20:24
已发帖子: 9,513
楼主 #5 2019-03-29 21:21:10
已发帖子: 9,513
楼主 #6 2019-03-29 21:21:38
已发帖子: 9,513
楼主 #7 2019-03-29 21:24:13
已发帖子: 9,513
楼主 #8 2019-03-29 21:31:22
已发帖子: 9,513
#9 2019-04-01 15:09:37
slangel
威武~~~我用SD NAND 也成功了!
#10 2019-04-02 14:00:49
已发帖子: 1,417
BGA封装怎么焊?热风枪吹?
#11 2019-04-02 14:05:24
Gentlepig wrote:
BGA封装怎么焊?热风枪吹?
如果芯片没有植球,那淘宝买那种emmc小钢网,刷锡膏,刷助焊剂。
不过芯片最好是植球的
#12 2021-12-02 14:56:45
p846603105
为啥我程序烧在sd卡里可以启动,但烧录在emmc上启动不了,可以加载Uboot,但无法加载内核。用的也是153的emmc转接板
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 3e438070fde631e17b3b48bac99fa62eff57123b
fel flag  = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x00000000
rtc[7] value = 0x00000000
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 360 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
dram size =64
card boot number = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2014-12-10 21:20:39
[mmc]: ***Try SD card 0***
[mmc]: mmc 0 cmd 8 timeout, err 00000100
[mmc]: mmc 0 cmd 8 err 00000100
[mmc]: mmc 0 send if cond failed
[mmc]: mmc 0 cmd 55 timeout, err 00000100
[mmc]: mmc 0 cmd 55 err 00000100
[mmc]: mmc 0 send app cmd failed
[mmc]: ***Try MMC card 0***
[mmc]: MMC ver 4.5
[mmc]: SD/MMC Card: 4bit, capacity: 3728MB
[mmc]: vendor: Man 0090014a Snr 010ce958
[mmc]: product: H4G2a
[mmc]: revision: 1.1
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000a8000.
sum=04d8aa9b
src_sum=04d8aa9b
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
[      0.348]
U-Boot 2011.09-rc1-00000-g3e43807-dirty (Nov 20 2021 - 14:22:03) Allwinner Tech
[      0.357]version: 1.1.0
[      0.359]uboot commit : 3e438070fde631e17b3b48bac99fa62eff57123b
[      0.368]pmbus:   ready
not set main pmu id
axp_probe error
[      0.374]PMU: pll1 408 Mhz,PLL6=600 Mhz
AXI=204 Mhz,AHB=204 Mhz, APB1=102 Mhz
set power on vol to default
dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
find power_sply to end
vbus exist
no battery, limit to dc
no key input
dram_para_set start
dram_para_set end
[      0.505]DRAM:  64 MiB
relocation Offset is: 0309c000
save config for small mem_size
workmode = 0
storage type = 1
MMC:     0
[      0.604][mmc]: mmc driver ver 2015-04-13 14:50:00
[      0.609][mmc]: get sdc_phy_wipe fail.
[      0.612][mmc]: get sdc0 sdc_erase fail.
[      0.616][mmc]: get sdc_f_max fail,use default 50000000Hz
[      0.622][mmc]: get sdc_ex_dly_used fail,use default dly
[      0.627][mmc]: SUNXI SD/MMC: 0
[      0.639][mmc]: *Try SD card 0*
[      0.643][mmc]: mmc 0 cmd 8 err 100
[      0.648][mmc]: mmc send if cond failed
[      0.652][mmc]: mmc 0 cmd 55 err 100
[      0.657][mmc]: send app cmd failed
[      0.660][mmc]: *Try MMC card 0*
[      0.716][mmc]: CID 0x90014a48 0x34473261 0x11010ce9 0x5817435b
[      0.721][mmc]: MMC ver 4.5
[      0.724][mmc]: mmc clk 50000000
[      0.727][mmc]: SD/MMC Card: 8bit, capacity: 3728MB
[      0.732][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[      0.738][mmc]: ***SD/MMC 0 init OK!!!***
[      0.744][mmc]: mmc 0 data err 2000
[      0.747][mmc]: Read remain data
[      0.753][mmc]:  read block failed
[      0.756][mmc]: block read failed
[      0.759][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
[      0.765][mmc]: secure_feature 0x55
[      0.769][mmc]: secure_removal_type  0x0
[      0.773]sunxi flash init ok
[      0.777][mmc]: mmc 0 data err 2000
[      0.783][mmc]:  read block failed
[      0.786][mmc]: block read failed
read flash error
fail to find part named env
Using default environment
In:    serial
Out:   serial
Err:   serial
mbr not exist
base bootcmd=run setargs_mmc boot_mmc
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run setargs_mmc boot_mmc
Net:   eth0
Warning: eth0 MAC addresses don't match:
Address in SROM is         e2:e1:e1:e1:e1:e1
Address in environment is  02:ac:bd:3f:29:e0
WORK_MODE_BOOT
board_status_probe
adver not need show
sunxi_bmp_logo_display
sunxi flash error: cant get part 0 offset
** Can't read from device 0 **
** Unable to use sunxi_flash 0:1 for fatload **
sunxi bmp info error : unable to open logo file bootlogo.bmp
[      0.856][mmc]: blkcnt should not be 0
read bootlogo partition fail,start_block=0x0,rblock=0x0 ,ret=0
Not a JPG file ?
parse_header failed
Use decode 2x1 sampling
sunxi_read_bootlogo: jpg convert argb
[      0.875]Hit any key to stop autoboot:  0
[      4.131][mmc]: mmc 0 cmd 16 err 100
[      6.132][mmc]: mmc 0,update clk failed
[      6.135][mmc]: Set block len failed
** Unable to use mmc 0:1 for fatload **
Wrong Image Format for bootm command
ERROR: can't get kernel image!
#13 2021-12-02 16:44:11
已发帖子: 3,409
@p846603105
感觉是软硬件兼容的问题, 可以先试一试全志官方推荐的eMMC型号。
#14 2021-12-06 13:20:49
sunxiang
已发帖子: 222
哇酷小二 wrote:
@p846603105
pcb板在哪购买呀,或者是哪有开源文件,我去打样。这个比较适合练习bga焊接。还有晕哥有没有推荐的几个EMMC的型号,简单的列一下,就是可以启动V3S的。
#15 2021-12-06 16:57:10
p846603105
能发个能启动的烧录镜像我试试吗,看看是不是U-boot的问题
#16 2021-12-06 17:05:48
已发帖子: 3,409
@sunxiang
感谢深圳网友 @Tony 友情赠送的 eMMC 转 TF 卡, 发现川宇的USB读卡器(可能是realtek螃蟹方案)不能识别,绿联可以识别
https://whycan.com/t_2778.html#p27077
常见的eMMC型号都可以,有一个比较省钱不省心的方法,去闲鱼上面买车载GPS,基本都有eMMC拆,然后再淘宝买eMMC的简易钢网,就可以植球了。
#17 2023-05-06 14:53:47
ronz
已发帖子: 31
@晕哥 我也搞了个emmc转tf,是按照TF卡的步骤直接分区,烧录对吧?然后直接就能启动?不需要对uboot、kernel做改动?
#18 2023-05-09 10:42:34
ronz
已发帖子: 31
搞定了,重新搞了个emmc就可以起来了
#19 2023-05-14 09:59:43
eric_qiang
请教一下,这样用EMMC转成TF接口有什么优势吗?为什么不直接用TF卡?
