楼主 #1 2021-05-17 14:03:47
lignin
已发帖子: 143
LINGLONG开机串口输出
Watchdog Status: 0 , boot from normal
[EMI] MDL number = 0
[EMI] PCDDR3
get dram size from AUXADC1 515 1
[EMI] Use Common DDR3 x16 emi settings
[EMI] Config emi settings:
EMI_CONA=0x1010,   EMI_CONH=0x3
EMI_RAMK0=0x10000000, EMI_RAMK1=0x0
EMI_CONA=0x1010
EMI_CONF=0x4210000
EMI_CONH=0x3
[DramcSwImpedanceCal] FINAL: DRVP=7, DRVN=6
PCDDR3 Pinmux
SSC OFF
DRAM Clock: 1584MHz
[Write Leveling]
WriteLevelingMoveDQSInsteadOfCLK
Dram Type= 4, Freqency= 1600, rank 0
odt_onoff= 0, Byte mode= 0, Read_DBI= 0, Write DBI= 0
WL Clk delay = 0, CA CLK delay = 0
No need to update CA/CS delay because the CLK delay is small than CA training.
Final Clk output delay = 0
R0 FINAL: WriteLeveling DQS:(2, 0) OEN:(1, 2) DQS0 delay =  36
R0 FINAL: WriteLeveling DQS:(2, 0) OEN:(1, 2) DQS1 delay =  32
[DramcWriteLeveling] ====Done====
[Gating]
[Byte 0]First pass (1, 3, 8)
[Byte 1]First pass (1, 3, 8)
[Byte 0]Bigger pass win(1, 4, 31)  Pass tap=55
[Byte 1]Bigger pass win(1, 5, 3)  Pass tap=59
    dqs input gating widnow, final delay value
    Frequency=1600  rank=0
R0 FINAL: GW best DQS0 P0 delay(2T, 0.5T, PI) = (1, 4, 3) [tap = 55]
R0 FINAL: GW best DQS1 P0 delay(2T, 0.5T, PI) = (1, 4, 5) [tap = 59]
R0 FINAL: GW best DQS0 P1 delay(2T, 0.5T, PI) = (1, 6, 3)
R0 FINAL: GW best DQS1 P1 delay(2T, 0.5T, PI) = (1, 6, 5)
[DramcRxdqsGatingCal] ====Done====
[DATLAT]
DATLAT Default value = 0xf
5, 0xFFFF, sum=0
6, 0xFFFF, sum=0
7, 0xFFFF, sum=0
8, 0xFFFF, sum=0
9, 0xFFFF, sum=0
10, 0xFFFF, sum=0
11, 0xFFFF, sum=0
12, 0xFFFF, sum=0
13, 0x0, sum=1
14, 0x0, sum=2
15, 0x0, sum=3
16, 0x0, sum=4
17, 0x0, sum=5
pattern=5 first_step=13 total pass=6 best_step=15
R0 FINAL: DATLAT = 15 [13 ~ 18]
[DramcRxdatlatCal] ====Done====
[RX]
RX Window Sum 593
R0 FINAL: RX Bit 0, 11 (-8 ~ 31) 40
R0 FINAL: RX Bit 1, 10 (-8 ~ 28) 37
R0 FINAL: RX Bit 2, 11 (-7 ~ 30) 38
R0 FINAL: RX Bit 3, 8 (-11 ~ 27) 39
R0 FINAL: RX Bit 4, 13 (-5 ~ 31) 37
R0 FINAL: RX Bit 5, 14 (-5 ~ 33) 39
R0 FINAL: RX Bit 6, 14 (-4 ~ 33) 38
R0 FINAL: RX Bit 7, 14 (-4 ~ 33) 38
R0 FINAL: RX Bit 8, 15 (-3 ~ 34) 38
R0 FINAL: RX Bit 9, 15 (-3 ~ 33) 37
R0 FINAL: RX Bit 10, 13 (-4 ~ 31) 36
R0 FINAL: RX Bit 11, 13 (-5 ~ 32) 38
R0 FINAL: RX Bit 12, 15 (-3 ~ 34) 38
R0 FINAL: RX Bit 13, 12 (-7 ~ 32) 40
R0 FINAL: RX Bit 14, 15 (-4 ~ 34) 39
R0 FINAL: RX Bit 15, 15 (-3 ~ 33) 37
DQS Delay :
DQS0 = 0, DQS1 = 0, DQS2 = 0, DQS3 = 0
DQM Delay :
DQM0 = 11, DQM1 = 14, DQM2 = 0, DQM3 = 0
DQ Delay :
DQ0 =11, DQ1 =10, DQ2 =11, DQ3 =8
DQ4 =13, DQ5 =14, DQ6 =14, DQ7 =14
DQ8 =15, DQ9 =15, DQ10 =13, DQ11 =13
DQ12 =15, DQ13 =12, DQ14 =15, DQ15 =15
________________________________________________________________________
[DramcRxWindowPerbitCal] ====Done====
[TX]
[DramcTxWindowPerbitCal] Frequency=1600, Rank=0, calType=2
[DramcTxWindowPerbitCal] Begin, TX DQ(2, 0),  DQ OEN(1, 2)
TX Window Sum 435
R0 FINAL: TX Bit0 (37~64) 28 50,   Bit8 (37~63) 27 50,
R0 FINAL: TX Bit1 (35~62) 28 48,   Bit9 (37~64) 28 50,
R0 FINAL: TX Bit2 (37~64) 28 50,   Bit10 (36~63) 28 49,
R0 FINAL: TX Bit3 (35~63) 29 49,   Bit11 (37~63) 27 50,
R0 FINAL: TX Bit4 (38~64) 27 51,   Bit12 (38~64) 27 51,
R0 FINAL: TX Bit5 (39~64) 26 51,   Bit13 (36~63) 28 49,
R0 FINAL: TX Bit6 (39~64) 26 51,   Bit14 (38~64) 27 51,
R0 FINAL: TX Bit7 (40~64) 25 52,   Bit15 (38~63) 26 50,
Byte0, PI DQ Delay 50 Delay2 51
Final DQ PI Delay(LargeUI, SmallUI, PI) =(2 ,0, 51)
OEN DQ PI Delay(LargeUI, SmallUI, PI) =(1 ,2, 51)
Byte1, PI DQ Delay 50 Delay2 50
Final DQ PI Delay(LargeUI, SmallUI, PI) =(2 ,0, 50)
OEN DQ PI Delay(LargeUI, SmallUI, PI) =(1 ,2, 50)
[DramcTxWindowPerbitCal] ====Done====
[DramcRxdqsGatingPostProcess] p->frequency 1600
[DramcRxdqsGatingPostProcess] s1ChangeDQSINCTL 0, reg_TX_dly_DQSgated_min 3, u1TXDLY_Cal_min 3
Settings after calibration ...
=== [DramcRunTimeConfig] ===
ZQCS_ENABLE_LP3: ON
LOWPOWER_GOLDEN_SETTINGS(DCM): ON
SPM_CONTROL_AFTERK: ON
TEMP_SENSOR_ENABLE: OFF
ENABLE_PER_BANK_REFRESH: OFF
HW_SAVE_FOR_SR: OFF
0:dram_rank_size:10000000
dram size 0x10000000.
[MEM] complex R/W mem test pass
nand found [PN27G01BBGITG]
[nand] read page 49152 chip 0 UNCORRECT
block768 is a bad block!
[I2C] id=1,addr: 32, transfer error
[I2C] I2C_ACKERR
[I2C] I2C structure:
[I2C] Id=1,Dma_en=0,Auto_restart=0,Poll_en=1,Op=1
[I2C] Irq_stat=3,source_clk=68250,clk_div=5,speed=100
[I2C] base address 0xffff00000160a000
[I2C] I2C register:
[I2C] SLAVE_ADDR=64,INTR_MASK=f8,INTR_STAT=3,CONTROL=28
[I2C] TRANSFER_LEN=2,TRANSAC_LEN=1,DELAY_LEN=2
[I2C] TIMING=216,START=0,FIFO_STAT=1210,IO_CONFIG=3,HS=0
[I2C] DCM_EN=0,DEBUGSTAT=40,EXT_CONF=8001
[I2C] TRANSFER_LEN_AUX=1,FIFO_THRESH=700,RSV_DEBUG=0
[I2C] DEBUGCTRL=0,CLOCK_DIV=4,SCL_HL_RATIO=c3
[I2C] SCL_HS_HL_RATIO=41,SCL_MIS_COMP_POINT=0
[I2C] STA_STOP_AC_TIME=0,HS_STA_STOP_AC_TIME=0
[I2C] DATA_TIME=0
[I2C] mtk_i2c_write fails(-121).
starting app fitboot
open MISC successfully
lastboot = 0, use A = -1, use B = -1, current = 0
***last succeed boot from A system,upgrade B failed or no upgrade B***
***now boot from system A***
choose first boot partition:BOOTIMG1  , tee choose: TEE1
Verifying tz_ctl Sign
checking tz_ctl - kernel integrity
checking tz_ctl - tee integrity
Verifying bootimg_ctl Sign
checking bootimg_ctl - kernel integrity
checking bootimg_ctl - fdt integrity
Partition [DTBO] is not exist.
LK run time: 1880147 (us)
jump to tz 0x42ff6000
[ATF](0)[1.880730]INFO:    Kernel is AArch64
[ATF](0)[1.882018]NOTICE:  BL3-1: v1.2(debug):4ebda78
[ATF](0)[1.882592]NOTICE:  BL3-1: Built : 17:05:34, Jul 26 2018
[ATF](0)[1.883292]NOTICE:  BL31: v1.2(debug):4ebda78
[ATF](0)[1.883874]NOTICE:  BL31: Built : 17:05:34, Jul 26 2018
[ATF](0)[1.884564]INFO:    [spmc_init]change to SPMC mode !!!
[ATF](0)[1.885247]INFO:    ARM GICv2 driver initialized
[ATF](0)[1.885859]INFO:    BL31: Initializing runtime services
[ATF](0)[1.886558]INFO:    BL31: Initializing BL32
lEMI_MPUS = 20000120, EMI_MPUT = 100fffb0
[DAPC] [TEE] dapc_register_ext_handler is called by Type_2B slave(5)
[ATF](0)[1.888534]INFO:    BL31: Preparing for EL3 exit to normal world
[ATF](0)[1.889302]INFO:    Entry point address = 0x41e00000
[ATF](0)[1.889959]INFO:    SPSR = 0x3c9
[    0.000000] <0>-(0)[0:swapper]Booting Linux on physical CPU 0x0
[    0.000000] <0>-(0)[0:swapper]Initializing cgroup subsys cpu
[    0.000000] <0>-(0)[0:swapper]Initializing cgroup subsys cpuacct
[    0.000000] <0>-(0)[0:swapper]Linux version 4.4.22 (system@server3) (gcc version 6.2.0 (GCC) ) #1 SMP PREEMPT Thu Jul 26 17:07:54 CST 2018
[    0.000000] <0>-(0)[0:swapper]Boot CPU: AArch64 Processor [410fd041]
[    0.000000] <0>-(0)[0:swapper]earlycon: Early serial console at MMIO32 0x11005000 (options '')
[    0.000000] <0>-(0)[0:swapper]bootconsole [uart0] enabled
[    0.000000] <0>-(0)[0:swapper][PHY layout]atf-reserved-memory@43000000   :   0x43000000 - 0x4302ffff (0x30000)
[    0.000000] <0>-(0)[0:swapper][PHY layout]mtee-reserved-memory   :   0x4fd00000 - 0x4fffffff (0x300000)
[    0.000000] <0>-(0)[0:swapper][PHY layout]consys-reserve-memory   :   0x4fa00000 - 0x4fbfffff (0x200000)
[    0.000000] <0>-(0)[0:swapper][WMT-CONSYS-HW][W]reserve_memory_consys_fn: name: consys-reserve-memory, base: 0x4fa00000, size: 0x200000
[    0.000000] <0>-(0)[0:swapper]Reserved memory: initialized node consys-reserve-memory, compatible id mediatek,consys-reserve-memory
[    0.000000] <0>-(0)[0:swapper][memblock]ram_console-reserve-memory: 0x44400000 - 0x44410000 (0x10000)
[    0.000000] <0>-(0)[0:swapper]Reserved memory: initialized node ram_console-reserved-memory@44400000, compatible id mediatek,ram_console
[    0.000000] <0>-(0)[0:swapper][PHY layout]kernel   :   0x40000000 - 0x42ffffff (0x3000000)
[    0.000000] <0>-(0)[0:swapper][PHY layout]kernel   :   0x43030000 - 0x4f9fffff (0xc9d0000)
[    0.000000] <0>-(0)[0:swapper][PHY layout]kernel   :   0x4fc00000 - 0x4fcfffff (0x100000)
[    0.000000] <0>-(0)[0:swapper]psci: probing for conduit method from DT.
[    0.000000] <0>-(0)[0:swapper]psci: PSCIv1.0 detected in firmware.
[    0.000000] <0>-(0)[0:swapper]psci: Using standard PSCI v0.2 function IDs
[    0.000000] <0>-(0)[0:swapper]psci: Trusted OS migration not required
[    0.000000] <0>-(0)[0:swapper]PERCPU: Embedded 19 pages/cpu @ffffffc00fc6d000 s39832 r8192 d29800 u77824
[    0.000000] <0>-(0)[0:swapper]Detected VIPT I-cache on CPU0
[    0.000000] <0>-(0)[0:swapper]Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 63196
[    0.000000] <0>-(0)[0:swapper][cpu_ntf] <00>ffffff8008116e24 (page_alloc_cpu_notify)
[    0.000000] <0>-(0)[0:swapper]Kernel command line: console=tty0 console=ttyS0,921600n1  earlycon=uart8250,mmio32,0x11005000 ubi.mtd=8 root=ubi0:aud8516p1v2-consys-slc-128-rootfs rootfstype=ubifs vmalloc=496M androidboot.hardware=aud8516p1_linux
[    0.000000] <0>-(0)[0:swapper]PID hash table entries: 1024 (order: 1, 8192 bytes)
[    0.000000] <0>-(0)[0:swapper]Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.000000] <0>-(0)[0:swapper]Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.000000] <0>-(0)[0:swapper]software IO TLB [mem 0x4f9c0000-0x4fa00000] (0MB) mapped at [ffffffc00f9c0000-ffffffc00f9fffff]
[    0.000000] <0>-(0)[0:swapper]Memory: 241460K/256832K available (5868K kernel code, 436K rwdata, 1956K rodata, 368K init, 1170K bss, 15372K reserved, 0K cma-reserved)
[    0.000000] <0>-(0)[0:swapper]Virtual kernel memory layout:
[    0.000000] <0>    modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000] <0>    vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000] <0>      .init : 0xffffff8008829000 - 0xffffff8008885000   (   368 KB)
[    0.000000] <0>      .text : 0xffffff8008080000 - 0xffffff800863c000   (  5872 KB)
[    0.000000] <0>    .rodata : 0xffffff800863c000 - 0xffffff8008829000   (  1972 KB)
[    0.000000] <0>      .data : 0xffffff8008885000 - 0xffffff80088f2140   (   437 KB)
[    0.000000] <0>    vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000] <0>              0xffffffbdc0000000 - 0xffffffbdc03f4000   (     3 MB actual)
[    0.000000] <0>    fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000] <0>    PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000] <0>-(0)[0:swapper][cpu_ntf] <00>ffffff8008147eb0 (slab_cpuup_callback)
[    0.000000] <0>-(0)[0:swapper]SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80080bf1c4 (sched_ilb_notifier)
[    0.000000] <0>-(0)[0:swapper/0]Preemptible hierarchical RCU implementation.
[    0.000000] <0>-(0)[0:swapper/0]     Build-time adjustment of leaf fanout to 64.
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80080e5240 (rcu_cpu_notify)
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff8008228b60 (radix_tree_callback)
[    0.000000] <0>-(0)[0:swapper/0]NR_IRQS:64 nr_irqs:64 0
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80082454cc (gic_secondary_init)
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80080e7bd4 (timer_cpu_notify)
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80080e96d0 (hrtimer_cpu_notify)
[    0.000000] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff8008455610 (arch_timer_cpu_notify)
[    0.000000] <0>-(0)[0:swapper/0]Architected cp15 timer(s) running at 13.00MHz (phys).
[    0.000000] <0>-(0)[0:swapper/0]clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
[    0.000006] <0>-(0)[0:swapper/0]sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.001364] <0>-(0)[0:swapper/0]clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 147020034397 ns
[    0.003075] <0>-(0)[0:swapper/0][cpu_ntf] <00>ffffff80080f9bec (hotplug_cfd)
[    0.004044] <0>.(0)[0:swapper/0]ram_console: buffer start: 0xffffff8008020000, size: 0x10000
[    0.012441] <0>.(0)[0:swapper/0]ram_console: CPU notifier status: 0, 0, 0x0, 0
[    0.013386] <0>.(0)[0:swapper/0]ram_console: last init function: 0x0
[    0.014640] <0>.(0)[0:swapper/0]console [ram-1] enabled
[    0.015332] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=52000)
[    0.016688] <0>.(0)[0:swapper/0]pid_max: default: 32768 minimum: 301
[    0.017583] <0>.(0)[0:swapper/0][cpu_ntf] <00>ffffff8008179240 (buffer_cpu_notify)
[    0.018575] <0>.(0)[0:swapper/0]Security Framework initialized
[    0.019369] <0>.(0)[0:swapper/0]Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[    0.020462] <0>.(0)[0:swapper/0]Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[    0.021813] <0>.(0)[0:swapper/0][cpu_ntf] <00>ffffff800811b648 (ratelimit_handler)
[    0.023087] <0>.(0)[0:swapper/0][cpu_ntf] <00>ffffff8008098cdc (smpboot_thread_call)
[    0.024219] <0>-(0)[0:swapper/0]init_heavy_tlb start.
[    0.024891] <0>-(0)[0:swapper/0]init_heavy_tlb: cid=-1 is out of nr=1
[    0.025737] <0>-(0)[0:swapper/0]init_heavy_tlb: cpu=0 thresh_l=0 thresh_h=0 max_capaicy=0
[    0.026807] <0>-(0)[0:swapper/0]init_heavy_tlb: cid=-1 is out of nr=1
[    0.027653] <0>-(0)[0:swapper/0]init_heavy_tlb: cpu=1 thresh_l=0 thresh_h=0 max_capaicy=0
[    0.028723] <0>-(0)[0:swapper/0]init_heavy_tlb: cid=-1 is out of nr=1
[    0.029569] <0>-(0)[0:swapper/0]init_heavy_tlb: cpu=2 thresh_l=0 thresh_h=0 max_capaicy=0
[    0.030639] <0>-(0)[0:swapper/0]init_heavy_tlb: cid=-1 is out of nr=1
[    0.031485] <0>-(0)[0:swapper/0]init_heavy_tlb: cpu=3 thresh_l=0 thresh_h=0 max_capaicy=0
[    0.032666] <0>.(0)[1:swapper/0]ASID allocator initialised with 65536 entries
[    0.033615] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff800809cc90 (cpu_callback)
[    0.036607] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080ae13c (workqueue_cpu_up_callback)
[    0.037694] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080ae42c (workqueue_cpu_down_callback)
[    0.048676] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080b8920 (migration_call)
[    0.049639] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080b61e4 (sched_cpu_active)
[    0.050623] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080b61b0 (sched_cpu_inactive)
[    0.053963] <0>.(0)[1:swapper/0]init_get_max_DRAM_size done. phone_dram_sz: 0x0, kernel_mem_sz: 0x10000000
[    0.055755] <0>.(0)[1:swapper/0][BOOT_REASON] 'boot_reason=' is not found
[    0.057185] <0>.(0)[1:swapper/0]'atag,devinfo' is not found
[    0.070543] <0>.(0)[1:swapper/0]Brought up 4 CPUs
[    0.071167] <0>.(0)[1:swapper/0]SMP: Total of 4 processors activated.
[    0.072018] <0>.(0)[1:swapper/0]CPU: All CPU(s) started at EL2
[    0.073113] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080b5d00 (sched_domains_numa_masks_update)
[    0.074269] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080bce74 (cpuset_cpu_active)
[    0.075263] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080bcecc (cpuset_cpu_inactive)
[    0.076282] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80080b7170 (hotplug_hrtick)
[    0.077647] <0>.(0)[1:swapper/0]devtmpfs: initialized
[    0.078578] <0>.(0)[1:swapper/0][cpu_ntf] <00>ffffff80082792f4 (device_hotplug_notifier)
[    0.093688] <0>.(0)[1:swapper/0]clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.095396] <0>.(0)[1:swapper/0]pinctrl core: initialized pinctrl subsystem
[    0.097213] <0>.(0)[1:swapper/0][BOOT_COMMON] 'atag,boot' is not found
[    0.098295] <0>.(0)[1:swapper/0]zone_movable_cma: uninited cma, start zone_movable_cma fail!
[    0.099821] <0>.(0)[1:swapper/0]NET: Registered protocol family 16
[    0.101199] <0>.(0)[1:swapper/0][SPM] spm_base = ffffff8008032000
[    0.102003] <0>.(0)[1:swapper/0][SPM] spm_irq_0 = 6, spm_irq_1 = 7, spm_irq_2 = 8, spm_irq_3 = 9
[    0.104133] <0>.(0)[1:swapper/0][Power/idle] node 'mediatek,mt8167-mfgcfg' not found!
[    0.115210] <1>.(1)[1:swapper/0]cpuidle: using governor mtk_governor
[    0.116178] <1>.(1)[1:swapper/0]vdso: 2 pages (1 code @ ffffff8008641000, 1 data @ ffffff800888d000)
[    0.117570] <1>.(1)[1:swapper/0]DMA: preallocated 256 KiB pool for atomic allocations
[    0.118665] <1>.(1)[1:swapper/0][SPM] PWAKE_EN:1, PCMWDT_EN:0, BYPASS_SYSPWREQ:0, I2C_CHANNEL:2
[    0.119806] <1>.(1)[1:swapper/0][SLP] SLEEP_DPIDLE_EN:1, REPLACE_DEF_WAKESRC:0, SUSPEND_LOG_EN:1
[    0.121140] <1>.(1)[1:swapper/0]### CIRQ init done. ###
[    0.124498] <1>-(1)[1:swapper/0]genirq: Setting trigger mode 2 for irq 17 failed (mtk_sysirq_set_type+0x0/0xc4)
[    0.127651] <1>.(1)[1:swapper/0]mtk_pctrl_init------ ok
[    0.146242] <1>.(1)[1:swapper/0][DAPC] [TEE] dapc_register_ext_handler is called by Type_2B slave(0)
[    0.147713] <1>.(1)[1:swapper/0][TZ_M4U]sec_pt_va=0x0x10a74000, pa=0x4fe74000, align=0x4000
[    0.148814] <1>.(1)[1:swapper/0][TZ_M4U]check port security larb_base: 0xf4016000 0x0
[    0.149845] <1>.(1)[1:swapper/0][TZ_M4U]check port security larb_base: 0xf5001000 0x0
[    0.150890] <1>.(1)[1:swapper/0][TZ_M4U]check port security larb_base: 0xf6010000 0x0
[    0.151935] <1>.(1)[1:swapper/0][TZ_M4U]init done.(secva0x10a25fe0-0x10a25fe0 pa0x4fe25fe0 sz2M)
[    0.153090] <1>.(1)[1:swapper/0][DAPC] [TEE] dapc_register_ext_handler is called by Type_2B slave(3)
[    0.154289] <1>.(1)[1:swapper/0][DAPC] [TEE] dapc_register_ext_handler is called by Type_2B slave(2)
[    0.155498] <1>.(1)[1:swapper/0][DAPC] [TEE] dapc_register_ext_handler is called by Type_2B slave(6)
[    0.170048] <1>.(1)[1:swapper/0][cpu_ntf] <00>ffffff8008210560 (blk_cpu_notify)
[    0.171024] <1>.(1)[1:swapper/0][cpu_ntf] <00>ffffff8008210c68 (blk_iopoll_cpu_notify)
[    0.172084] <1>.(1)[1:swapper/0][cpu_ntf] <00>ffffff8008216138 (blk_mq_main_cpu_notify)
[    0.173138] <1>.(1)[1:swapper/0][cpu_ntf] <00>ffffff8008213910 (blk_mq_queue_reinit_notify)
[    0.177876] <1>.(1)[1:swapper/0]usbcore: registered new interface driver usbfs
[    0.178891] <1>.(1)[1:swapper/0]usbcore: registered new interface driver hub
[    0.179920] <1>.(1)[1:swapper/0]usbcore: registered new device driver usb
[    0.182101] <1>.(1)[1:swapper/0]Advanced Linux Sound Architecture Driver Initialized.
[    0.183722] <1>.(1)[1:swapper/0][cpu_ntf] <00>ffffff80084dd7dc (dev_cpu_callback)
[    0.185497] <3>.(3)[1:swapper/0]clocksource: Switched to clocksource arch_sys_counter
[    0.188285] <3>.(3)[1:swapper/0]NET: Registered protocol family 2
[    0.189727] <3>.(3)[1:swapper/0]TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.190907] <3>.(3)[1:swapper/0]TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[    0.192006] <3>.(3)[1:swapper/0]TCP: Hash tables configured (established 2048 bind 2048)
[    0.193117] <3>.(3)[1:swapper/0]UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.194140] <3>.(3)[1:swapper/0]UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.195379] <3>.(3)[1:swapper/0]NET: Registered protocol family 1
[    0.198480] <3>.(3)[1:swapper/0]futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.199625] <3>.(3)[1:swapper/0]audit: initializing netlink subsys (disabled)
[    0.200610] <3>.(3)[1:swapper/0]audit: type=2000 audit(0.184:1): initialized
[    0.201664] <3>.(3)[1:swapper/0][cpu_ntf] <00>ffffff800811f050 (cpu_callback)
[    0.213132] <3>.(3)[1:swapper/0]io scheduler noop registered
[    0.213906] <3>.(3)[1:swapper/0]io scheduler deadline registered
[    0.214970] <3>.(3)[1:swapper/0]io scheduler cfq registered (default)
[    0.215857] <3>.(3)[1:swapper/0][cpu_ntf] <00>ffffff8008241b88 (percpu_counter_hotcpu_callback)
[    0.221702] <3>.(3)[1:swapper/0]Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
楼主 #2 2021-05-17 14:22:43
lignin
已发帖子: 143
Re: LINGLONG开机串口输出
楼主 #3 2021-05-17 14:23:33
lignin
已发帖子: 143
Re: LINGLONG开机串口输出
那四个点第二个是芯片的tx脚,波特率为921600,其他未知
