使用F1C200S TINA3.5 SPINAND 在windows下的PhoenixSuit V1.19烧写固件,现象是:
1,空的nand第一次似乎提示烧写成功,但启动失败。
2,第二次以及之后的烧写就会失败。
3,配置以及按照官方nor切换nand的指南进行修改配置了。
4,板子换了全新空白nand 上去,也是一样的现象。
5,以下是第一次和第二次两次烧录的日志输出。
[0]beign to init dram
[23]init dram ok
U-Boot 2014.07 (Jul 31 2018 - 14:59:19) Allwinner Technology
uboot commit : 6604446f7bddb8fe53f2b993100929f92a5f4d6e
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[2.651]pmbus: ready
axp: get node[/soc/pmu0] error
axp_probe error
[2.658]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
DRAM: 32 MiB
[2.667]fdt addr: 0x809e77a0
[2.669]gd->fdt_size: 0xc360
Relocation Offset is: 01524000
int sunxi_dma_init---
irq enable
[2.739]flash init start
workmode = 16,storage type = 3
try card 1
[2.745][mmc]: mmc driver ver 2018-6-1 17:39:00
SUNXI SD/MMC: 1
[2.762][mmc]: ************Try SD card 1************
[mmc]: mmc 1 cmd 8 timeout, err 100
[mmc]: smc 1 err, cmd 8, RTO
[mmc]: mmc 1 close bus gating and reset
[mmc]: mmc 1 mmc cmd 8 err 0x00000100
[2.780][mmc]: mmc send if cond failed
[mmc]: mmc 1 cmd 55 timeout, err 100
[mmc]: smc 1 err, cmd 55, RTO
[mmc]: mmc 1 mmc cmd 55 err 0x00000100
[2.798][mmc]: send app cmd failed
[2.801][mmc]: ************Try MMC card 1************
[mmc]: mmc 1 cmd 1 timeout, err 100
[mmc]: smc 1 err, cmd 1, RTO
[mmc]: mmc 1 mmc cmd 1 err 0x00000100
[2.823][mmc]: read op condition failed
[2.826][mmc]: mmc send op cond failed
[2.833][mmc]: ************SD/MMC 1 init error!!!************
[2.839][mmc]: mmc_init_boot: mmc int fail
[2.842][mmc]: mmc_init: mmc init fail, err -17
MMC init failed
try emmc fail
[2.849]NAND_UbootProbe start...
[2.852]NB1 : enter phy init
[2.855]nand_physic_init
[2.859]nand0: get node offset error
[2.862]init nctri NAND PIORequest error!
[2.866]nand_physic_init, init nctri error
[2.870]nand_physic_init init_parameter error
[2.874]nand_physic_init error -1
[2.877]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[2.884]uboot: nand version: 3 6008 20180610 1300
[2.901]request spi gpio ok!
irq enable
[2.906]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c7c
[2.914]request general tx dma channel ok!
[2.917]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[2.925]request general rx dma channel ok!
[2.929]SPI nand ID: 21aaef 0
[2.931][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[2.938]nand : get id number_ctl from script:0x55aaaa55
[2.943]_UpdateExtAccessFreqPara: no para.
[2.947]PHY_Scan_DelayMode, it is a free page(type 0), block 8
[2.952]PHY_Scan_DelayMode, it is a free page(type 0), block 9
[2.958]PHY_Scan_DelayMode, it is a free page(type 0), block 10
[2.963]PHY_Scan_DelayMode, it is a free page(type 0), block 11
[2.969]PHY_Scan_DelayMode, it is a free page(type 0), block 12
[2.975]PHY_Scan_DelayMode, it is a free page(type 0), block 13
[2.980]PHY_Scan_DelayMode, it is a free page(type 0), block 14
[2.986]PHY_Scan_DelayMode, it is a free page(type 0), block 15
[2.992]PHY_Scan_DelayMode, it is a free page(type 0), block 16
[2.997]PHY_Scan_DelayMode, it is a free page(type 0), block 17
_get_spic_clk_v1: sclk0=0x64
[3.006]PHY_Scan_DelayMode: no right delay mode,set default clk 30MHz
[3.012]physic_info_read start!!
[3.015]physic_info_get_offset start!!
[3.027]can't find uboot head
[3.029]_GetOldPhysicArch: chip 0, block 20, page 0, oob: 0xff, 0xff, 0xff, 0xff
[3.036]_GetOldPhysicArch: find a good block, but no physic arch info.
[3.043]NAND_ReadPhyArch: blank page!
[3.046]
[3.047][SCAN_DBG] ==============Nand Architecture Parameter==============
[3.054][SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[3.059][SCAN_DBG] Nand Chip Count: 0x1
[3.064][SCAN_DBG] Nand Chip Connect: 0x1
[3.068][SCAN_DBG] Sector Count Of Page: 0x4
[3.072][SCAN_DBG] Page Count Of Block: 0x40
[3.076][SCAN_DBG] Block Count Of Die: 0x400
[3.081][SCAN_DBG] Plane Count Of Die: 0x2
[3.085][SCAN_DBG] Die Count Of Chip: 0x1
[3.089][SCAN_DBG] Bank Count Of Chip: 0x1
[3.093][SCAN_DBG] Optional Operation: 0x6d
[3.098][SCAN_DBG] Access Frequence: 0x32
[3.102][SCAN_DBG] =======================================================
[3.117]nand secure storage fail: 0,0
[3.120]NB1 : nand phy init ok
[3.123]NB1 : enter phy Exit
nand release dma:81db8c7c
nand release dma:0
sunxi dma exit
[3.131]NAND_UbootProbe end: 0x0
nand found
read mbr copy[0] failed
read mbr copy[1] failed
read mbr copy[2] failed
read mbr copy[3] failed
[3.143]flash init end
[3.145]try to burn key
[3.150]inter uboot shell
work mode=0x10
run usb efex
delay time 2500
irq enable
sunxi_dma_install_int ok
usb init ok
set address 0xd
set address 0xd
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x0
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 8
part[0] name :bootlogo
part[0] classname :DISK
part[0] addrlo :0x2000
part[0] lenlo :0x800
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] classname :DISK
part[1] addrlo :0x2800
part[1] lenlo :0x200
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] name :boot
part[2] classname :DISK
part[2] addrlo :0x2a00
part[2] lenlo :0x3000
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :rootfs
part[3] classname :DISK
part[3] addrlo :0x5a00
part[3] lenlo :0x15c70
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] name :rootfs_data
part[4] classname :DISK
part[4] addrlo :0x1b670
part[4] lenlo :0xc800
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :misc
part[5] classname :DISK
part[5] addrlo :0x27e70
part[5] lenlo :0x200
part[5] user_type :32768
part[5] keydata :0
part[5] ro :0
part[6] name :private
part[6] classname :DISK
part[6] addrlo :0x28070
part[6] lenlo :0x200
part[6] user_type :32768
part[6] keydata :0
part[6] ro :0
part[7] name :UDISK
part[7] classname :DISK
part[7] addrlo :0x28270
part[7] lenlo :0x0
part[7] user_type :33024
part[7] keydata :0
part[7] ro :0
total part: 9
mbr 0, 2000, 8000
bootlogo 1, 800, 8000
env 2, 200, 8000
boot 3, 3000, 8000
rootfs 4, 15c70, 8000
rootfs_data 5, c800, 8000
misc 6, 200, 8000
private 7, 200, 8000
UDISK 8, 0, 8100
[6.846]erase_flag = 0
[6.848]NB1 : enter phy init
[6.851]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[6.858]uboot: nand version: 3 6008 20180610 1300
[6.875]request spi gpio ok!
[6.878]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[6.885]request general tx dma channel ok!
[6.889]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[6.896]request general rx dma channel ok!
[6.900]SPI nand ID: 21aaef 0
[6.903][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[6.909]nand : get id number_ctl from script:0x55aaaa55
[6.914]_UpdateExtAccessFreqPara: no para.
[6.918]PHY_Scan_DelayMode, it is a free page(type 0), block 8
[6.924]PHY_Scan_DelayMode, it is a free page(type 0), block 9
[6.929]PHY_Scan_DelayMode, it is a free page(type 0), block 10
[6.935]PHY_Scan_DelayMode, it is a free page(type 0), block 11
[6.940]PHY_Scan_DelayMode, it is a free page(type 0), block 12
[6.946]PHY_Scan_DelayMode, it is a free page(type 0), block 13
[6.952]PHY_Scan_DelayMode, it is a free page(type 0), block 14
[6.957]PHY_Scan_DelayMode, it is a free page(type 0), block 15
[6.963]PHY_Scan_DelayMode, it is a free page(type 0), block 16
[6.969]PHY_Scan_DelayMode, it is a free page(type 0), block 17
[6.977]PHY_Scan_DelayMode: no right delay mode,set default clk 30MHz
[6.983]physic_info_read start!!
[6.986]physic_info_read already!!
[6.989]_GetOldPhysicArch: chip 0, block 20, page 0, oob: 0xff, 0xff, 0xff, 0xff
[6.996]_GetOldPhysicArch: find a good block, but no physic arch info.
[7.002]NAND_ReadPhyArch: blank page!
[7.006]
[7.007][SCAN_DBG] ==============Nand Architecture Parameter==============
[7.013][SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[7.019][SCAN_DBG] Nand Chip Count: 0x1
[7.023][SCAN_DBG] Nand Chip Connect: 0x1
[7.028][SCAN_DBG] Sector Count Of Page: 0x4
[7.032][SCAN_DBG] Page Count Of Block: 0x40
[7.036][SCAN_DBG] Block Count Of Die: 0x400
[7.041][SCAN_DBG] Plane Count Of Die: 0x2
[7.045][SCAN_DBG] Die Count Of Chip: 0x1
[7.049][SCAN_DBG] Bank Count Of Chip: 0x1
[7.053][SCAN_DBG] Optional Operation: 0x6d
[7.058][SCAN_DBG] Access Frequence: 0x32
[7.062][SCAN_DBG] =======================================================
[7.077]nand secure storage fail: 0,0
[7.080]NB1 : nand phy init ok
[7.082]uboot_start_block 8 uboot_next_block 58.
[7.087]check nand version start.
[7.090]Current nand driver version is ff 0 3 1
[7.094]Media version is valid in block 8, version info is ff ff ff ff
[7.100]nand driver version match fail in block 8.
[7.105]nand version = 1
[7.107]has cleared the boot blocks.
[7.114]nand version fail,please select erase nand
[7.119]NAND_Uboot_Erase
[7.121]NB1 : enter phy Exit
nand release dma:81db8c9c
nand release dma:0
not need erase flash
sunxi_sprite_erase_flash, erase_flag=0
private part exist
NAND_UbootInit
[7.136]NAND_UbootInit start
[7.139]NB1: enter NAND_LogicInit
[7.142]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[7.149]uboot: nand version: 3 6008 20180610 1300
[7.166]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[7.173]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[7.185]NAND_ReadPhyArch: blank page!
[7.196]nand secure storage fail: 0,0
[7.199]not burn nand partition table!
[7.305][NE]boot but not data!
[7.311][NE]boot not find mbr table!!!!
[7.315]NB1: nand_info_init fail
[7.317]NAND_UbootInit end: 0xfffffffb
NAND_UbootExit
[7.322]NB1: NAND_LogicExit
nand release dma:0
[7.329]erase_flag = 0
[7.331]NB1 : enter phy init
[7.333]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[7.341]uboot: nand version: 3 6008 20180610 1300
[7.357]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[7.365]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[7.377]NAND_ReadPhyArch: blank page!
[7.393]NB1 : nand phy init ok
[7.396]Media version is valid in block 8, version info is ff ff ff ff
[7.402]nand driver version match fail in block 8.
[7.406]nand version = 1
[7.408]has cleared the boot blocks.
[7.416]nand version fail,please select erase nand
[7.420]NAND_Uboot_Erase
[7.423]NB1 : enter phy Exit
nand release dma:0
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
NAND_UbootInit
[7.434]NAND_UbootInit start
[7.437]NB1: enter NAND_LogicInit
[7.440]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[7.447]uboot: nand version: 3 6008 20180610 1300
[7.464]request spi gpio ok!
[7.466]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[7.474]request general tx dma channel ok!
[7.477]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[7.485]request general rx dma channel ok!
[7.489]SPI nand ID: 21aaef 0
[7.491][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[7.498]nand : get id number_ctl from script:0x55aaaa55
[7.503]_UpdateExtAccessFreqPara: no para.
[7.507]PHY_Scan_DelayMode, it is a free page(type 0), block 8
[7.512]PHY_Scan_DelayMode, it is a free page(type 0), block 9
[7.518]PHY_Scan_DelayMode, it is a free page(type 0), block 10
[7.523]PHY_Scan_DelayMode, it is a free page(type 0), block 11
[7.529]PHY_Scan_DelayMode, it is a free page(type 0), block 12
[7.535]PHY_Scan_DelayMode, it is a free page(type 0), block 13
[7.540]PHY_Scan_DelayMode, it is a free page(type 0), block 14
[7.546]PHY_Scan_DelayMode, it is a free page(type 0), block 15
[7.552]PHY_Scan_DelayMode, it is a free page(type 0), block 16
[7.557]PHY_Scan_DelayMode, it is a free page(type 0), block 17
[7.566]PHY_Scan_DelayMode: no right delay mode,set default clk 30MHz
[7.572]physic_info_read start!!
[7.575]physic_info_read already!!
[7.578]_GetOldPhysicArch: chip 0, block 20, page 0, oob: 0xff, 0xff, 0xff, 0xff
[7.585]_GetOldPhysicArch: find a good block, but no physic arch info.
[7.591]NAND_ReadPhyArch: blank page!
[7.594]
[7.595][SCAN_DBG] ==============Nand Architecture Parameter==============
[7.602][SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[7.608][SCAN_DBG] Nand Chip Count: 0x1
[7.612][SCAN_DBG] Nand Chip Connect: 0x1
[7.616][SCAN_DBG] Sector Count Of Page: 0x4
[7.621][SCAN_DBG] Page Count Of Block: 0x40
[7.625][SCAN_DBG] Block Count Of Die: 0x400
[7.629][SCAN_DBG] Plane Count Of Die: 0x2
[7.633][SCAN_DBG] Die Count Of Chip: 0x1
[7.638][SCAN_DBG] Bank Count Of Chip: 0x1
[7.642][SCAN_DBG] Optional Operation: 0x6d
[7.646][SCAN_DBG] Access Frequence: 0x32
[7.651][SCAN_DBG] =======================================================
[7.670]secure storage updata ok!
[7.673]nand secure storage ok: 58,59
[7.676]nand: get CapacityLevel from script, 55aaaa55
[7.681]burn nand partition table! mbr tbl: 0x81debdc4, part_count:9
[7.687]start block:60
[7.689][ND]factory FirstBuild 33
[7.718][ND]erase factory FirstBuild
[7.722][ND]nand_info->SectorNumsPerPage :0x8
[7.726][ND]nand_info->PageNumsPerBlk :0x40
[7.729][ND]nand_info->BlkPerChip :0x200
[7.733][ND]nand_info->ChipNum :0x1
[7.736][NE]print partition 0 !
[7.739][ND]partition->size :-1
[7.742][ND]partition->cross_talk :0
[7.745][ND]partition->attribute :0
[7.748][ND]partition->start.Chip_NO :65535
[7.752][ND]partition->start.Block_NO :65535
[7.756][ND]partition->end.Chip_NO :65535
[7.760][ND]partition->end.Block_NO :65535
[7.764][ND]partition->nand_disk[0].size :8192
[7.768][ND]partition->nand_disk[0].type :0
[7.772][ND]partition->nand_disk[1].size :2048
[7.776][ND]partition->nand_disk[1].type :0
[7.780][ND]partition->nand_disk[2].size :512
[7.784][ND]partition->nand_disk[2].type :0
[7.788][ND]partition->nand_disk[3].size :12288
[7.792][ND]partition->nand_disk[3].type :0
[7.796][ND]partition->nand_disk[4].size :89200
[7.800][ND]partition->nand_disk[4].type :0
[7.804][ND]partition->nand_disk[5].size :51200
[7.808][ND]partition->nand_disk[5].type :0
[7.812][ND]partition->nand_disk[6].size :512
[7.816][ND]partition->nand_disk[6].type :0
[7.820][ND]partition->nand_disk[7].size :512
[7.824][ND]partition->nand_disk[7].type :0
[7.828][ND]partition->nand_disk[8].size :0
[7.832][ND]partition->nand_disk[8].type :0
[7.835][ND]partition->nand_disk[9].size :-1
[7.839][ND]partition->nand_disk[9].type :-1
[7.843][ND]partition->nand_disk[10].size :-1
[7.847][ND]partition->nand_disk[10].type :-1
[7.851][ND]partition->nand_disk[11].size :-1
[7.855][ND]partition->nand_disk[11].type :-1
[7.860][ND]partition->nand_disk[12].size :-1
[7.864][ND]partition->nand_disk[12].type :-1
[7.868][ND]partition->nand_disk[13].size :-1
[7.872][ND]partition->nand_disk[13].type :-1
[7.876][ND]partition->nand_disk[14].size :-1
[7.880][ND]partition->nand_disk[14].type :-1
[7.884][ND]partition->nand_disk[15].size :-1
[7.888][ND]partition->nand_disk[15].type :-1
[7.892][ND]partition->nand_disk[16].size :-1
[7.896][ND]partition->nand_disk[16].type :-1
[7.900][ND]partition->nand_disk[17].size :-1
[7.904][ND]partition->nand_disk[17].type :-1
[7.908][ND]partition->nand_disk[18].size :-1
[7.912][ND]partition->nand_disk[18].type :-1
[7.916][ND]partition->nand_disk[19].size :-1
[7.920][ND]partition->nand_disk[19].type :-1
[7.924][ND]partition->nand_disk[20].size :-1
[7.928][ND]partition->nand_disk[20].type :-1
[7.932][ND]partition->nand_disk[21].size :-1
[7.936][ND]partition->nand_disk[21].type :-1
[7.940][ND]partition->nand_disk[22].size :-1
[7.945][ND]partition->nand_disk[22].type :-1
[7.949][ND]partition->nand_disk[23].size :-1
[7.953][ND]partition->nand_disk[23].type :-1
[7.957][NE]partition_num: 0,size :0xffffffff,cross_talk 0
[7.962][NE]part mbr size: 0x2000 type: 0
[7.966][NE]part bootlogo size: 0x800 type: 0
[7.970][NE]part env size: 0x200 type: 0
[7.973][NE]part boot size: 0x3000 type: 0
[7.977][NE]part rootfs size: 0x15c70 type: 0
[7.981][NE]part rootfs_data size: 0xc800 type: 0
[7.985][NE]part misc size: 0x200 type: 0
[7.989][NE]part private size: 0x200 type: 0
[7.993][NE]part UDISK size: 0x0 type: 0
[8.072][ND]partition->size :224768
[8.075][ND]partition->cross_talk :0
[8.079][ND]partition->attribute :0
[8.082][ND]partition->start.Chip_NO :0
[8.085][ND]partition->start.Block_NO :33
[8.089][ND]partition->end.Chip_NO :0
[8.092][ND]partition->end.Block_NO :511
[8.096][ND]partition->nand_disk[0].size :8192
[8.100][ND]partition->nand_disk[0].type :0
[8.104][ND]partition->nand_disk[1].size :2048
[8.108][ND]partition->nand_disk[1].type :0
[8.112][ND]partition->nand_disk[2].size :512
[8.116][ND]partition->nand_disk[2].type :0
[8.120][ND]partition->nand_disk[3].size :12288
[8.124][ND]partition->nand_disk[3].type :0
[8.128][ND]partition->nand_disk[4].size :89200
[8.132][ND]partition->nand_disk[4].type :0
[8.136][ND]partition->nand_disk[5].size :51200
[8.140][ND]partition->nand_disk[5].type :0
[8.144][ND]partition->nand_disk[6].size :512
[8.148][ND]partition->nand_disk[6].type :0
[8.152][ND]partition->nand_disk[7].size :512
[8.156][ND]partition->nand_disk[7].type :0
[8.160][ND]partition->nand_disk[8].size :60304
[8.164][ND]partition->nand_disk[8].type :0
[8.168][ND]partition->nand_disk[9].size :-1
[8.172][ND]partition->nand_disk[9].type :-1
[8.176][ND]partition->nand_disk[10].size :-1
[8.180][ND]partition->nand_disk[10].type :-1
[8.184][ND]partition->nand_disk[11].size :-1
[8.188][ND]partition->nand_disk[11].type :-1
[8.192][ND]partition->nand_disk[12].size :-1
[8.196][ND]partition->nand_disk[12].type :-1
[8.200][ND]partition->nand_disk[13].size :-1
[8.204][ND]partition->nand_disk[13].type :-1
[8.208][ND]partition->nand_disk[14].size :-1
[8.212][ND]partition->nand_disk[14].type :-1
[8.217][ND]partition->nand_disk[15].size :-1
[8.221][ND]partition->nand_disk[15].type :-1
[8.225][ND]partition->nand_disk[16].size :-1
[8.229][ND]partition->nand_disk[16].type :-1
[8.233][ND]partition->nand_disk[17].size :-1
[8.237][ND]partition->nand_disk[17].type :-1
[8.241][ND]partition->nand_disk[18].size :-1
[8.245][ND]partition->nand_disk[18].type :-1
[8.249][ND]partition->nand_disk[19].size :-1
[8.253][ND]partition->nand_disk[19].type :-1
[8.257][ND]partition->nand_disk[20].size :-1
[8.261][ND]partition->nand_disk[20].type :-1
[8.265][ND]partition->nand_disk[21].size :-1
[8.269][ND]partition->nand_disk[21].type :-1
[8.273][ND]partition->nand_disk[22].size :-1
[8.277][ND]partition->nand_disk[22].type :-1
[8.281][ND]partition->nand_disk[23].size :-1
[8.285][ND]partition->nand_disk[23].type :-1
[8.289][ND]phy_partition->PartitionNO :0
[8.293][ND]phy_partition->SectorNumsPerPage :8
[8.297][ND]phy_partition->PageNumsPerBlk :64
[8.301][ND]phy_partition->TotalBlkNum :479
[8.305][ND]phy_partition->FullBitmapPerPage :8
[8.309][ND]phy_partition->FreeBlock :0
[8.313][ND]phy_partition->TotalSectors :224768
[8.317][ND]phy_partition->StartBlock.Chip_NO :0
[8.322][ND]phy_partition->StartBlock.Block_NO :33
[8.326][ND]phy_partition->EndBlock.Chip_NO :0
[8.330][ND]phy_partition->EndBlock.Block_NO :511
[8.335][ND]phy_partition->next_phy_partition :0
[8.339][ND]phy_partition->PartitionNO 0 FACTORY BAD BLOCK:
[8.344][ND]phy_partition->PartitionNO 0 NEW BAD BLOCK:
[8.349][ND]build 1 phy_partition !
[8.352][ND]nand_info->type :0
[8.355][ND]nand_info->SectorNumsPerPage :8
[8.359][ND]nand_info->BytesUserData :16
[8.363][ND]nand_info->PageNumsPerBlk :64
[8.366][ND]nand_info->BlkPerChip :512
[8.370][ND]nand_info->FirstBuild :1
[8.373][ND]nand_info->FullBitmap :10
[8.376][ND]nand_info->bad_block_addr.Chip_NO :0
[8.381][ND]nand_info->bad_block_addr.Block_NO :0
[8.385][ND]nand_info->mbr_block_addr.Chip_NO :0
[8.389][ND]nand_info->mbr_block_addr.Block_NO :0
[8.394][ND]nand_info->no_used_block_addr.Chip_NO :0
[8.398][ND]nand_info->no_used_block_addr.Block_NO :33
[8.403][ND]nand_info->new_bad_block_addr.Chip_NO :0
[8.408][ND]nand_info->new_bad_block_addr.Block_NO :0
[8.413][ND]nand_info->new_bad_page_addr :65535
[8.417][ND]nand_info->partition_nums :1
[8.421][ND]sizeof partition:2384
[8.424][ND]nand_info->partition:0:
[8.427][ND]size:0x36e00
[8.429][ND]cross_talk:0x0
[8.431][ND]attribute:0x0
[8.434][ND]start: chip:0 block:33
[8.437][ND]end : chip:0 block:511
[8.440][ND]boot :0x80d265c0
[8.442][ND]boot->magic :0xaa55a5a5
[8.446][ND]boot->len :0x8000
[8.448][ND]boot->no_use_block :0x21
[8.451][ND]boot->uboot_start_block :0x8
[8.455][ND]boot->uboot_next_block :0x3a
[8.459][ND]boot->logic_start_block :0x21
[8.462][ND]mbr len :4096
[8.465][ND]_PARTITION len :2560
[8.468][ND]_NAND_STORAGE_INFO len :512
[8.471][ND]_FACTORY_BLOCK len :2048
[8.474][ND]nand_partition0
[8.477][ND]nftl start:479,40
[8.480][ND]first
[8.558][ND]before second 479 439.
[8.561][ND]all block full!!
[8.564][ND]get a new free block
[8.567][ND]free block nums is 478 !
[8.570][NE]not power on gc 478!
[8.573][ND]nftl ok!
[8.575][ND]max_erase_times = 65000
[8.578][ND]nftl_add ok
[8.580]NB1: NAND_LogicInit ok, result = 0x0
[8.584]NAND_UbootInit end: 0x0
nand not need closed
nand already init
FEX_CMD_fes_verify_value, start 0x2000, size high 0x0:low 0x2ee76
FEX_CMD_fes_verify_value 0x13032461
FEX_CMD_fes_verify_value, start 0x2800, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0xea9912bf
FEX_CMD_fes_verify_value, start 0x2a00, size high 0x0:low 0x2f1df8
FEX_CMD_fes_verify_value 0xd6a225c0
FEX_CMD_fes_verify_value, start 0x5a00, size high 0x0:low 0x3c0000
FEX_CMD_fes_verify_value 0x316922c9
NAND_UbootExit
[14.674]NAND_UbootExit
[14.676]NB1: NAND_LogicExit
nand release dma:0
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0xb8000
uboot_pkg magic 0x89119800
uboot size = 0xb8000
storage type = 0
[15.026]NB1 : enter phy init
[15.028]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[15.036]uboot: nand version: 3 6008 20180610 1300
[15.053]request spi gpio ok!
[15.055]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[15.063]request general tx dma channel ok!
[15.066]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[15.074]request general rx dma channel ok!
[15.078]SPI nand ID: 21aaef 0
[15.081][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[15.087]nand : get id number_ctl from script:0x55aaaa55
[15.092]_UpdateExtAccessFreqPara: no para.
[15.096]PHY_Scan_DelayMode, it is a free page(type 0), block 8
[15.102]PHY_Scan_DelayMode, it is a free page(type 0), block 9
[15.108]PHY_Scan_DelayMode, it is a free page(type 0), block 10
[15.113]PHY_Scan_DelayMode, it is a free page(type 0), block 11
[15.119]PHY_Scan_DelayMode, it is a free page(type 0), block 12
[15.125]PHY_Scan_DelayMode, it is a free page(type 0), block 13
[15.131]PHY_Scan_DelayMode, it is a free page(type 0), block 14
[15.136]PHY_Scan_DelayMode, it is a free page(type 0), block 15
[15.142]PHY_Scan_DelayMode, it is a free page(type 0), block 16
[15.148]PHY_Scan_DelayMode, it is a free page(type 0), block 17
[15.156]PHY_Scan_DelayMode: no right delay mode,set default clk 30MHz
[15.162]physic_info_read start!!
[15.165]physic_info_read already!!
[15.169]_GetOldPhysicArch: chip 0, block 20, page 0, oob: 0xff, 0xff, 0xff, 0xff
[15.176]_GetOldPhysicArch: find a good block, but no physic arch info.
[15.182]NAND_ReadPhyArch: blank page!
[15.186]
[15.187][SCAN_DBG] ==============Nand Architecture Parameter==============
[15.193][SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[15.199][SCAN_DBG] Nand Chip Count: 0x1
[15.203][SCAN_DBG] Nand Chip Connect: 0x1
[15.208][SCAN_DBG] Sector Count Of Page: 0x4
[15.212][SCAN_DBG] Page Count Of Block: 0x40
[15.217][SCAN_DBG] Block Count Of Die: 0x400
[15.221][SCAN_DBG] Plane Count Of Die: 0x2
[15.225][SCAN_DBG] Die Count Of Chip: 0x1
[15.230][SCAN_DBG] Bank Count Of Chip: 0x1
[15.234][SCAN_DBG] Optional Operation: 0x6d
[15.238][SCAN_DBG] Access Frequence: 0x32
[15.243][SCAN_DBG] =======================================================
[15.262]secure storage updata ok!
[15.265]nand secure storage ok: 58,59
[15.269]NB1 : nand phy init ok
[15.272]burn uboot one!
[15.274]spinand burn uboot one!
[15.277]spinand burn uboot in many block 0!
[15.282]write uboot many block 8!
[15.323]write uboot many block 9!
[15.364]write uboot many block 10!
[15.406]write uboot many block 11!
[15.447]write uboot many block 12!
[15.488]write uboot many block 13!
[15.520]uboot info: page 48 in block 13.
[15.524]uboot info: page 49 in block 13.
[15.528]uboot info: page 50 in block 13.
[15.532]uboot info: page 51 in block 13.
[15.536]uboot info: page 52 in block 13.
[15.540]uboot info: page 53 in block 13.
[15.544]uboot info: page 54 in block 13.
[15.549]uboot info: page 55 in block 13.
[15.553]uboot info: page 56 in block 13.
[15.557]uboot info: page 57 in block 13.
[15.561]uboot info: page 58 in block 13.
[15.565]uboot info: page 59 in block 13.
[15.569]uboot info: page 60 in block 13.
[15.573]uboot info: page 61 in block 13.
[15.577]uboot info: page 62 in block 13.
[15.581]uboot info: page 63 in block 13.
[15.585]burn uboot one!
[15.588]spinand burn uboot one!
[15.590]spinand burn uboot in many block 1!
[15.597]write uboot many block 14!
[15.639]write uboot many block 15!
[15.680]write uboot many block 16!
[15.722]write uboot many block 17!
[15.763]write uboot many block 18!
[15.804]write uboot many block 19!
[15.836]uboot info: page 48 in block 19.
[15.840]uboot info: page 49 in block 19.
[15.844]uboot info: page 50 in block 19.
[15.848]uboot info: page 51 in block 19.
[15.852]uboot info: page 52 in block 19.
[15.856]uboot info: page 53 in block 19.
[15.860]uboot info: page 54 in block 19.
[15.865]uboot info: page 55 in block 19.
[15.869]uboot info: page 56 in block 19.
[15.873]uboot info: page 57 in block 19.
[15.877]uboot info: page 58 in block 19.
[15.881]uboot info: page 59 in block 19.
[15.885]uboot info: page 60 in block 19.
[15.889]uboot info: page 61 in block 19.
[15.893]uboot info: page 62 in block 19.
[15.897]uboot info: page 63 in block 19.
[15.901]burn uboot one!
[15.904]spinand burn uboot one!
[15.906]spinand burn uboot in many block 2!
[15.916]write uboot many block 20!
[15.957]write uboot many block 21!
[15.998]write uboot many block 22!
[16.040]write uboot many block 23!
[16.081]write uboot many block 24!
[16.122]write uboot many block 25!
[16.154]uboot info: page 48 in block 25.
[16.158]uboot info: page 49 in block 25.
[16.162]uboot info: page 50 in block 25.
[16.166]uboot info: page 51 in block 25.
[16.170]uboot info: page 52 in block 25.
[16.174]uboot info: page 53 in block 25.
[16.178]uboot info: page 54 in block 25.
[16.182]uboot info: page 55 in block 25.
[16.186]uboot info: page 56 in block 25.
[16.191]uboot info: page 57 in block 25.
[16.195]uboot info: page 58 in block 25.
[16.199]uboot info: page 59 in block 25.
[16.203]uboot info: page 60 in block 25.
[16.207]uboot info: page 61 in block 25.
[16.211]uboot info: page 62 in block 25.
[16.215]uboot info: page 63 in block 25.
[16.219]burn uboot one!
[16.221]spinand burn uboot one!
[16.224]spinand burn uboot in many block 3!
[16.236]write uboot many block 26!
[16.277]write uboot many block 27!
[16.318]write uboot many block 28!
[16.360]write uboot many block 29!
[16.401]write uboot many block 30!
[16.442]write uboot many block 31!
[16.473]uboot info: page 48 in block 31.
[16.478]uboot info: page 49 in block 31.
[16.482]uboot info: page 50 in block 31.
[16.486]uboot info: page 51 in block 31.
[16.490]uboot info: page 52 in block 31.
[16.494]uboot info: page 53 in block 31.
[16.498]uboot info: page 54 in block 31.
[16.502]uboot info: page 55 in block 31.
[16.506]uboot info: page 56 in block 31.
[16.510]uboot info: page 57 in block 31.
[16.514]uboot info: page 58 in block 31.
[16.519]uboot info: page 59 in block 31.
[16.523]uboot info: page 60 in block 31.
[16.527]uboot info: page 61 in block 31.
[16.531]uboot info: page 62 in block 31.
[16.535]uboot info: page 63 in block 31.
[16.539]burn uboot one!
[16.541]spinand burn uboot one!
[16.544]spinand burn uboot in many block 4!
[16.558]write uboot many block 32!
[16.599]write uboot many block 33!
[16.640]write uboot many block 34!
[16.682]write uboot many block 35!
[16.723]write uboot many block 36!
[16.764]write uboot many block 37!
[16.795]uboot info: page 48 in block 37.
[16.799]uboot info: page 49 in block 37.
[16.804]uboot info: page 50 in block 37.
[16.808]uboot info: page 51 in block 37.
[16.812]uboot info: page 52 in block 37.
[16.816]uboot info: page 53 in block 37.
[16.820]uboot info: page 54 in block 37.
[16.824]uboot info: page 55 in block 37.
[16.828]uboot info: page 56 in block 37.
[16.832]uboot info: page 57 in block 37.
[16.836]uboot info: page 58 in block 37.
[16.840]uboot info: page 59 in block 37.
[16.845]uboot info: page 60 in block 37.
[16.849]uboot info: page 61 in block 37.
[16.853]uboot info: page 62 in block 37.
[16.857]uboot info: page 63 in block 37.
[16.861]burn uboot one!
[16.863]spinand burn uboot one!
[16.866]spinand burn uboot in many block 5!
[16.882]write uboot many block 38!
[16.923]write uboot many block 39!
[16.964]write uboot many block 40!
[17.005]write uboot many block 41!
[17.047]write uboot many block 42!
[17.088]write uboot many block 43!
[17.119]uboot info: page 48 in block 43.
[17.123]uboot info: page 49 in block 43.
[17.127]uboot info: page 50 in block 43.
[17.131]uboot info: page 51 in block 43.
[17.135]uboot info: page 52 in block 43.
[17.140]uboot info: page 53 in block 43.
[17.144]uboot info: page 54 in block 43.
[17.148]uboot info: page 55 in block 43.
[17.152]uboot info: page 56 in block 43.
[17.156]uboot info: page 57 in block 43.
[17.160]uboot info: page 58 in block 43.
[17.164]uboot info: page 59 in block 43.
[17.168]uboot info: page 60 in block 43.
[17.172]uboot info: page 61 in block 43.
[17.176]uboot info: page 62 in block 43.
[17.180]uboot info: page 63 in block 43.
[17.185]burn uboot one!
[17.187]spinand burn uboot one!
[17.190]spinand burn uboot in many block 6!
[17.208]write uboot many block 44!
[17.249]write uboot many block 45!
[17.290]write uboot many block 46!
[17.331]write uboot many block 47!
[17.373]write uboot many block 48!
[17.414]write uboot many block 49!
[17.445]uboot info: page 48 in block 49.
[17.449]uboot info: page 49 in block 49.
[17.453]uboot info: page 50 in block 49.
[17.457]uboot info: page 51 in block 49.
[17.461]uboot info: page 52 in block 49.
[17.465]uboot info: page 53 in block 49.
[17.470]uboot info: page 54 in block 49.
[17.474]uboot info: page 55 in block 49.
[17.478]uboot info: page 56 in block 49.
[17.482]uboot info: page 57 in block 49.
[17.486]uboot info: page 58 in block 49.
[17.490]uboot info: page 59 in block 49.
[17.494]uboot info: page 60 in block 49.
[17.498]uboot info: page 61 in block 49.
[17.502]uboot info: page 62 in block 49.
[17.506]uboot info: page 63 in block 49.
[17.510]burn uboot one!
[17.513]spinand burn uboot one!
[17.515]spinand burn uboot in many block 7!
[17.536]write uboot many block 50!
[17.578]write uboot many block 51!
[17.619]write uboot many block 52!
[17.660]write uboot many block 53!
[17.701]write uboot many block 54!
[17.742]write uboot many block 55!
[17.774]uboot info: page 48 in block 55.
[17.778]uboot info: page 49 in block 55.
[17.782]uboot info: page 50 in block 55.
[17.786]uboot info: page 51 in block 55.
[17.790]uboot info: page 52 in block 55.
[17.794]uboot info: page 53 in block 55.
[17.798]uboot info: page 54 in block 55.
[17.803]uboot info: page 55 in block 55.
[17.807]uboot info: page 56 in block 55.
[17.811]uboot info: page 57 in block 55.
[17.815]uboot info: page 58 in block 55.
[17.819]uboot info: page 59 in block 55.
[17.823]uboot info: page 60 in block 55.
[17.827]uboot info: page 61 in block 55.
[17.831]uboot info: page 62 in block 55.
[17.835]uboot info: page 63 in block 55.
[17.839]burn uboot one!
[17.842]spinand burn uboot one!
[17.844]spinand burn uboot in many block 8!
[17.866]burn uboot one!
[17.869]spinand burn uboot one!
[17.871]spinand burn uboot in many block 9!
[17.894]burn uboot one!
[17.896]spinand burn uboot one!
[17.899]spinand burn uboot in many block 10!
[17.922]burn uboot one!
[17.924]spinand burn uboot one!
[17.927]spinand burn uboot in many block 11!
[17.950]burn uboot one!
[17.952]spinand burn uboot one!
[17.955]spinand burn uboot in many block 12!
[17.978]burn uboot one!
[17.980]spinand burn uboot one!
[17.983]spinand burn uboot in many block 13!
[18.006]burn uboot one!
[18.008]spinand burn uboot one!
[18.011]spinand burn uboot in many block 14!
[18.034]burn uboot one!
[18.036]spinand burn uboot one!
[18.039]spinand burn uboot in many block 15!
[18.062]burn uboot one!
[18.064]spinand burn uboot one!
[18.067]spinand burn uboot in many block 16!
[18.090]burn uboot one!
[18.092]spinand burn uboot one!
[18.095]spinand burn uboot in many block 17!
[18.118]burn uboot one!
[18.120]spinand burn uboot one!
[18.123]spinand burn uboot in many block 18!
[18.145]burn uboot one!
[18.148]spinand burn uboot one!
[18.150]spinand burn uboot in many block 19!
[18.173]burn uboot one!
[18.176]spinand burn uboot one!
[18.178]spinand burn uboot in many block 20!
[18.201]burn uboot one!
[18.204]spinand burn uboot one!
[18.206]spinand burn uboot in many block 21!
[18.229]burn uboot one!
[18.232]spinand burn uboot one!
[18.234]spinand burn uboot in many block 22!
[18.257]burn uboot one!
[18.259]spinand burn uboot one!
[18.262]spinand burn uboot in many block 23!
[18.285]burn uboot one!
[18.287]spinand burn uboot one!
[18.290]spinand burn uboot in many block 24!
[18.313]burn uboot one!
[18.315]spinand burn uboot one!
[18.318]spinand burn uboot in many block 25!
[18.341]burn uboot one!
[18.343]spinand burn uboot one!
[18.346]spinand burn uboot in many block 26!
[18.369]burn uboot one!
[18.371]spinand burn uboot one!
[18.374]spinand burn uboot in many block 27!
[18.397]burn uboot one!
[18.399]spinand burn uboot one!
[18.402]spinand burn uboot in many block 28!
[18.425]burn uboot one!
[18.427]spinand burn uboot one!
[18.430]spinand burn uboot in many block 29!
[18.453]burn uboot one!
[18.455]spinand burn uboot one!
[18.458]spinand burn uboot in many block 30!
[18.481]burn uboot one!
[18.483]spinand burn uboot one!
[18.486]spinand burn uboot in many block 31!
[18.509]burn uboot one!
[18.511]spinand burn uboot one!
[18.514]spinand burn uboot in many block 32!
[18.536]burn uboot one!
[18.539]spinand burn uboot one!
[18.541]spinand burn uboot in many block 33!
[18.564]burn uboot one!
[18.567]spinand burn uboot one!
[18.569]spinand burn uboot in many block 34!
[18.592]burn uboot one!
[18.595]spinand burn uboot one!
[18.597]spinand burn uboot in many block 35!
[18.620]burn uboot one!
[18.622]spinand burn uboot one!
[18.625]spinand burn uboot in many block 36!
[18.648]burn uboot one!
[18.650]spinand burn uboot one!
[18.653]spinand burn uboot in many block 37!
[18.676]burn uboot one!
[18.678]spinand burn uboot one!
[18.681]spinand burn uboot in many block 38!
[18.704]burn uboot one!
[18.706]spinand burn uboot one!
[18.709]spinand burn uboot in many block 39!
[18.732]burn uboot one!
[18.734]spinand burn uboot one!
[18.737]spinand burn uboot in many block 40!
[18.760]burn uboot one!
[18.762]spinand burn uboot one!
[18.765]spinand burn uboot in many block 41!
[18.788]burn uboot one!
[18.790]spinand burn uboot one!
[18.793]spinand burn uboot in many block 42!
[18.816]burn uboot one!
[18.818]spinand burn uboot one!
[18.821]spinand burn uboot in many block 43!
[18.844]burn uboot one!
[18.846]spinand burn uboot one!
[18.849]spinand burn uboot in many block 44!
[18.871]burn uboot one!
[18.874]spinand burn uboot one!
[18.876]spinand burn uboot in many block 45!
[18.899]burn uboot one!
[18.902]spinand burn uboot one!
[18.904]spinand burn uboot in many block 46!
[18.927]burn uboot one!
[18.930]spinand burn uboot one!
[18.932]spinand burn uboot in many block 47!
[18.955]burn uboot one!
[18.957]spinand burn uboot one!
[18.960]spinand burn uboot in many block 48!
[18.983]burn uboot one!
[18.985]spinand burn uboot one!
[18.988]spinand burn uboot in many block 49!
[19.011]NB1 : enter phy Exit
nand release dma:0
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0x4000
[19.128]uboot_start_block: 8
[19.131]uboot_next_block: 3a
[19.133]logic_start_block:21
[19.136]nand_specialinfo_page:0
[19.139]nand_specialinfo_offset: 0
[19.142]physic_block_reserved: 6
dram para[0] = ea00018e
dram para[1] = 6f6f6275
dram para[2] = 74
dram para[3] = 17012fe9
dram para[4] = 4000
dram para[5] = a0000
dram para[6] = a0000
dram para[7] = 2e302e33
dram para[8] = 30
dram para[9] = 2e302e31
dram para[10] = 30
dram para[11] = 80800000
dram para[12] = 80000000
dram para[13] = 0
dram para[14] = 0
dram para[15] = 0
dram para[16] = 0
dram para[17] = 0
dram para[18] = 0
dram para[19] = 0
dram para[20] = 0
dram para[21] = 0
dram para[22] = 0
dram para[23] = 0
dram para[24] = 0
dram para[25] = 0
dram para[26] = 0
dram para[27] = 0
dram para[28] = 0
dram para[29] = 0
dram para[30] = 0
dram para[31] = 0
storage type = 0
[19.205]NB1 : enter phy init
[19.208]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[19.215]uboot: nand version: 3 6008 20180610 1300
[19.232]request spi gpio ok!
[19.235]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
[19.242]request general tx dma channel ok!
[19.246]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
[19.254]request general rx dma channel ok!
[19.258]SPI nand ID: 21aaef 0
[19.260][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[19.267]nand : get id number_ctl from script:0x55aaaa55
[19.272]_UpdateExtAccessFreqPara: no para.
[19.276]PHY_Scan_DelayMode: right delay mode 0x0
[19.280]PHY_Scan_DelayMode: right delay mode 0x800
[19.288]PHY_Scan_DelayMode: right delay mode,clk 50 MHz, SPI_TCR = 0x00000984, bit[13]=0,bit[11]=1
[19.296]physic_info_read start!!
[19.299]physic_info_read already!!
[19.302]
[19.304][SCAN_DBG] ==============Nand Architecture Parameter==============
[19.310][SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[19.316][SCAN_DBG] Nand Chip Count: 0x1
[19.320][SCAN_DBG] Nand Chip Connect: 0x1
[19.325][SCAN_DBG] Sector Count Of Page: 0x4
[19.329][SCAN_DBG] Page Count Of Block: 0x40
[19.333][SCAN_DBG] Block Count Of Die: 0x400
[19.338][SCAN_DBG] Plane Count Of Die: 0x1
[19.342][SCAN_DBG] Die Count Of Chip: 0x1
[19.347][SCAN_DBG] Bank Count Of Chip: 0x1
[19.351][SCAN_DBG] Optional Operation: 0x60
[19.355][SCAN_DBG] Access Frequence: 0x0
[19.360][SCAN_DBG] =======================================================
[19.387]secure storage updata ok!
[19.390]nand secure storage ok: 58,59
[19.394]NB1 : nand phy init ok
[19.397]burn boot0 normal mode!
[19.399]SPINAND burn boot0!
[19.402]boot0 count 0!
[19.441]SPINAND burn boot0!
[19.443]boot0 count 1!
[19.482]SPINAND burn boot0!
[19.484]boot0 count 2!
[19.523]SPINAND burn boot0!
[19.525]boot0 count 3!
[19.564]SPINAND burn boot0!
[19.566]boot0 count 4!
[19.605]SPINAND burn boot0!
[19.607]boot0 count 5!
[19.646]SPINAND burn boot0!
[19.649]boot0 count 6!
[19.687]SPINAND burn boot0!
[19.690]boot0 count 7!
[19.728]NB1 : enter phy Exit
nand release dma:0
sunxi_efex_next_action=2
exit usb
sunxi dma exit
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
set next mode 14
nand not opened
sunxi dma exit
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
[60]dram size =64
[62](GPIO_BASE_ADDR + 0x48): 0x00002222
[65](GPIO_BASE_ADDR + 0x5c): 0x00000055
[69](GPIO_BASE_ADDR + 0x64): 0x00000004
[72]CCMU_BASE_ADDR + 0x2c0 0x00104040
[76]CCMU_BASE_ADDR + 0x60 0x00104040
[79]SPIC0_BASE_ADDR+0x24: 0x00001004
[82]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 58
[87]block from 8 to 58
[567]Check is correct.
[578]Ready to disable icache.
[581]Jump to secend Boot.
i2c_init: by cpux
i2c_init ok
[0.629]pmbus: ready
axp_probe error
[0.636]PMU: cpux 408 Mhz,AXI=408 Mhz
key value = 4294967295, fel_key = [256,426]
DRAM: 64 MiB
Relocation Offset is: 03524000
irq enable
workmode = 0,storage type = 0
[0.719]NAND: NAND_UbootInit
[0.721]NAND_UbootInit start
[0.724]NB1: enter NAND_LogicInit
[0.729]nand0: get node offset error
[0.732]init nctri NAND PIORequest error!
[0.735]nand_physic_init, init nctri error
[0.739]nand_physic_init init_parameter error
[0.743]nand_physic_init error -1
[0.746]SpiNandHwInit: Start Nand Hardware initializing Jun 9 2018 19:05:34.....
[0.754]uboot: nand version: 3 6008 20180610 1300
irq enable
[0.773]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db8c7c
[0.781]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db8c9c
[0.818]not burn nand partition table!
[0.821][ND]not enough block:479,878!!
[0.825][NE]build phy partition 0 error!
[0.828][NE]build all phy partition fail!
[0.949][NE]not find mbr table!!!!
[0.952]NB1: nand_info_init fail
[0.955]NAND_UbootInit end: 0xfffffffb
[0.958]nand init fail
initcall sequence 83dacb6c failed at call 80809fec
Error reading from serial device第二次 末尾的日志
562][PHY_DBG] Find a bad block (NO. 0x3f0) in the Die 0x0
[18.568]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f1 page 0x0
[18.574][PHY_DBG] Find a bad block (NO. 0x3f1) in the Die 0x0
[18.579]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f2 page 0x0
[18.585][PHY_DBG] Find a bad block (NO. 0x3f2) in the Die 0x0
[18.591]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f3 page 0x0
[18.597][PHY_DBG] Find a bad block (NO. 0x3f3) in the Die 0x0
[18.603]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f4 page 0x0
[18.609][PHY_DBG] Find a bad block (NO. 0x3f4) in the Die 0x0
[18.614]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f5 page 0x0
[18.620][PHY_DBG] Find a bad block (NO. 0x3f5) in the Die 0x0
[18.626]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f6 page 0x0
[18.632][PHY_DBG] Find a bad block (NO. 0x3f6) in the Die 0x0
[18.638]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f7 page 0x0
[18.644][PHY_DBG] Find a bad block (NO. 0x3f7) in the Die 0x0
[18.649]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f8 page 0x0
[18.656][PHY_DBG] Find a bad block (NO. 0x3f8) in the Die 0x0
[18.661]PHY_PageReadSpare bad flag: bank 0x0 block 0x3f9 page 0x0
[18.667][PHY_DBG] Find a bad block (NO. 0x3f9) in the Die 0x0
[18.673]PHY_PageReadSpare bad flag: bank 0x0 block 0x3fa page 0x0
[18.679][PHY_DBG] Find a bad block (NO. 0x3fa) in the Die 0x0
[18.685]PHY_PageReadSpare bad flag: bank 0x0 block 0x3fb page 0x0
[18.691][PHY_DBG] Find a bad block (NO. 0x3fb) in the Die 0x0
[18.696]PHY_PageReadSpare bad flag: bank 0x0 block 0x3fc page 0x0
[18.702][PHY_DBG] Find a bad block (NO. 0x3fc) in the Die 0x0
[18.708]PHY_PageReadSpare bad flag: bank 0x0 block 0x3fd page 0x0
[18.714][PHY_DBG] Find a bad block (NO. 0x3fd) in the Die 0x0
[18.720]PHY_PageReadSpare bad flag: bank 0x0 block 0x3fe page 0x0
[18.726][PHY_DBG] Find a bad block (NO. 0x3fe) in the Die 0x0
[18.731]PHY_PageReadSpare bad flag: bank 0x0 block 0x3ff page 0x0
[18.737][PHY_DBG] Find a bad block (NO. 0x3ff) in the Die 0x0
[18.743][NE]not find mbr table!!!!
[18.746]NB1: nand_info_init fail
[18.749]NAND_UbootInit end: 0xfffffffb
sunxi sprite init fail when downlaod mbr离线
我也遇到同样的情况
楼主,你好,能看一下spi nor切换spi nand是怎么配置的吗,只改了sys_config.fex好像不行
@qinhao4832
楼主,问题解决了不
好像要改好多东西
