楼主 # 2024-07-24 16:46:58
memory
已发帖子: 716
A133 运行 Qt5 OpenGL cellphone 出错
qml: THREE.Canvas3DRenderer 74
[   12.863097] [XRADIO_ERR] sbus_sdio_init failed
[   12.871683] xradio_core_init failed (-110)!
modprobe: can't load module xr829 (kernel/drivers/net/wireless/xr829/xr829.ko): Connection timed out
/etc/init.d/S95wifi: line 5: wpa_supplicant: not found
# [   13.116632] PVR_K:  5: ------[ RGX Device: Start ]------
[   13.122706] PVR_K:  5: ------[ Driver Info ]------
[   13.128201] PVR_K:  5: UM info: 1.11 @  5516664 (release) build options: 0x80002010
[   13.136856] PVR_K:  5: KM info: 1.11 @  5516664 (release) build options: 0x00002010
[   13.136867] PVR_K:  5: FW info: 1.11 @  5516664 (release) build options: 0x80002010
[   13.136871] PVR_K:  5: Comparison of UM/KM components: MATCHING
[   13.136876] PVR_K:  5: KM Arch: 64 Bit
[   13.136881] PVR_K:  5: UM Connected Clients: 64 Bit
[   13.136886] PVR_K:  5: ------[ RGX Summary ]------
[   13.136892] PVR_K:  5: RGX BVNC: 22.102.54.38
[   13.136897] PVR_K:  5: RGX Device State: Active
[   13.136901] PVR_K:  5: RGX Power State: ON
[   13.136910] PVR_K:  5: BIF0 - OK
[   13.136920] PVR_K:  5: RGX FW State: OK (HWRState 0x00000001: HWR OK;)
[   13.136931] PVR_K:  5: RGX FW Power State: RGXFWIF_POW_ON (APM enabled: 4 ok, 0 denied, 0 non-idle, 1 retry, 0 other, 5 total. Latency: 100 ms)
[   13.136942] PVR_K:  5: RGX DVFS: 0 frequency changes. Current frequency: 504.001 MHz (sampled at 13009679088)
[   13.136949] PVR_K:  5: RGX FW OS 0 - State: active; Freelists: Ok
[   13.136998] PVR_K:  5: Number of HWR: GP(5/5+0), 2D(0/0+0), TA(0/0+0), 3D(0/0+0), CDM(0/0+0), FALSE(0,0,0,0,0)
[   13.137015] PVR_K:  5: DM 0 (GP)
[   13.137026] PVR_K:  5:   Recovery 1: PID = 0, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00000010
[   13.137034] PVR_K:  5:               CRTimer = 0x000000e46acc, OSTimer = 13.054685639, CyclesElapsed = 3832204288
[   13.137045] PVR_K:  5:   Recovery 2: PID = 0, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00000010
[   13.137053] PVR_K:  5:               CRTimer = 0x000000e46ced, OSTimer = 13.054962463, CyclesElapsed = 3832343808
[   13.137062] PVR_K:  5:   Recovery 3: PID = 0, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00000010
[   13.137070] PVR_K:  5:               CRTimer = 0x000000e46d35, OSTimer = 13.054999035, CyclesElapsed = 3832362240
[   13.137080] PVR_K:  5:   Recovery 4: PID = 0, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00000010
[   13.137088] PVR_K:  5:               CRTimer = 0x000000e46dcb, OSTimer = 13.055075225, CyclesElapsed = 3832400640
[   13.137097] PVR_K:  5:   Recovery 5: PID = 0, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00000010
[   13.137105] PVR_K:  5:               CRTimer = 0x000000e48732, OSTimer = 13.058378323, CyclesElapsed = 3834065408
[   13.137117] PVR_K:  5: DM 1 (HWRflags 0x00000000: working;)
[   13.137127] PVR_K:  5: DM 2 (HWRflags 0x00000000: working;)
[   13.137136] PVR_K:  5: DM 3 (HWRflags 0x00000000: working;)
[   13.137146] PVR_K:  5: DM 4 (HWRflags 0x00000000: working;)
[   13.137157] PVR_K:  5: ------[ RGX registers ]------
[   13.137165] PVR_K:  5: RGX Register Base Address (Linear):   0xffffff800bc00000
[   13.137170] PVR_K:  5: RGX Register Base Address (Physical): 0x01800000
[   13.137181] PVR_K:  5: CORE_ID                       : 0x0000000008470000
[   13.137187] PVR_K:  5: CORE_REVISION                 : 0x00360026
[   13.137192] PVR_K:  5: DESIGNER_REV_FIELD1           : 0x00000000
[   13.137197] PVR_K:  5: DESIGNER_REV_FIELD2           : 0x00000000
[   13.137202] PVR_K:  5: CHANGESET_NUMBER              : 0x0000000000000000
[   13.137209] PVR_K:  5: CLK_CTRL                      : 0x00002800000a0000
[   13.137214] PVR_K:  5: CLK_STATUS                    : 0x0000000000600000
[   13.137220] PVR_K:  5: CLK_CTRL2                     : 0x0000000000000000
[   13.137226] PVR_K:  5: CLK_STATUS2                   : 0x0000000000000000
[   13.137231] PVR_K:  5: EVENT_STATUS                  : 0x00000010
[   13.137237] PVR_K:  5: TIMER                         : 0x0000000000e50ac1
[   13.137243] PVR_K:  5: BIF_FAULT_BANK0_MMU_STATUS    : 0x00000000
[   13.137248] PVR_K:  5: BIF_FAULT_BANK0_REQ_STATUS    : 0x0000000000000000
[   13.137254] PVR_K:  5: BIF_FAULT_BANK1_MMU_STATUS    : 0x00000000
[   13.137259] PVR_K:  5: BIF_FAULT_BANK1_REQ_STATUS    : 0x0000000000000000
[   13.137264] PVR_K:  5: BIF_MMU_STATUS                : 0x00000000
[   13.137270] PVR_K:  5: BIF_MMU_ENTRY                 : 0x00000000
[   13.137275] PVR_K:  5: BIF_MMU_ENTRY_STATUS          : 0x0000000000000000
[   13.137281] PVR_K:  5: BIF_STATUS_MMU                : 0x00000000
[   13.137286] PVR_K:  5: BIF_READS_EXT_STATUS          : 0x00000000
[   13.137292] PVR_K:  5: BIF_READS_INT_STATUS          : 0x00000000
[   13.137297] PVR_K:  5: BIFPM_STATUS_MMU              : 0x00000000
[   13.137302] PVR_K:  5: BIFPM_READS_EXT_STATUS        : 0x00000000
[   13.137307] PVR_K:  5: BIFPM_READS_INT_STATUS        : 0x00000000
[   13.137311] PVR_K:  5: Warning: BRN44871 is present
[   13.137317] PVR_K:  5: BIF_CAT_BASE_INDEX            : 0x0000000000000101
[   13.137323] PVR_K:  5: BIF_CAT_BASE0                 : 0x0000000000000000
[   13.137329] PVR_K:  5: BIF_CAT_BASE1                 : 0x0000000136ec8000
[   13.137334] PVR_K:  5: BIF_CAT_BASE2                 : 0x0000000000000000
[   13.137340] PVR_K:  5: BIF_CAT_BASE3                 : 0x0000000000000000
[   13.137345] PVR_K:  5: BIF_CAT_BASE4                 : 0x0000000000000000
[   13.137351] PVR_K:  5: BIF_CAT_BASE5                 : 0x0000000000000000
[   13.137357] PVR_K:  5: BIF_CAT_BASE6                 : 0x0000000000000000
[   13.137362] PVR_K:  5: BIF_CAT_BASE7                 : 0x0000000000000000
[   13.137367] PVR_K:  5: BIF_CTRL_INVAL                : 0x00000000
[   13.137372] PVR_K:  5: BIF_CTRL                      : 0x000000C0
[   13.137378] PVR_K:  5: BIF_PM_CAT_BASE_VCE0          : 0x0000000137b45001
[   13.137383] PVR_K:  5: BIF_PM_CAT_BASE_TE0           : 0x0000000137b41001
[   13.137389] PVR_K:  5: BIF_PM_CAT_BASE_ALIST0        : 0x0000000137b1c001
[   13.137395] PVR_K:  5: BIF_PM_CAT_BASE_VCE1          : 0x0000000000000000
[   13.137400] PVR_K:  5: BIF_PM_CAT_BASE_TE1           : 0x0000000000000000
[   13.137405] PVR_K:  5: BIF_PM_CAT_BASE_ALIST1        : 0x0000000000000000
[   13.137410] PVR_K:  5: PERF_TA_PHASE                 : 0x00000001
[   13.137416] PVR_K:  5: PERF_TA_CYCLE                 : 0x00026455
[   13.137421] PVR_K:  5: PERF_3D_PHASE                 : 0x00000000
[   13.137426] PVR_K:  5: PERF_3D_CYCLE                 : 0x00000000
[   13.137432] PVR_K:  5: PERF_TA_OR_3D_CYCLE           : 0x00026455
[   13.137437] PVR_K:  5: PERF_TA_AND_3D_CYCLE          : 0x00000000
[   13.137443] PVR_K:  5: PERF_COMPUTE_PHASE            : 0x00000000
[   13.137448] PVR_K:  5: PERF_COMPUTE_CYCLE            : 0x00000000
[   13.137453] PVR_K:  5: PM_PARTIAL_RENDER_ENABLE      : 0x00000000
[   13.137458] PVR_K:  5: ISP_RENDER                    : 0x00000000
[   13.137463] PVR_K:  5: TLA_STATUS                    : 0x0000000000000000
[   13.137469] PVR_K:  5: MCU_FENCE                     : 0x0000000000000000
[   13.137474] PVR_K:  5: VDM_CONTEXT_STORE_STATUS      : 0x00000000
[   13.137479] PVR_K:  5: VDM_CONTEXT_STORE_TASK0       : 0x0000000000000000
[   13.137485] PVR_K:  5: VDM_CONTEXT_STORE_TASK1       : 0x0000000000000000
[   13.137490] PVR_K:  5: VDM_CONTEXT_STORE_TASK2       : 0x0000000000000000
[   13.137496] PVR_K:  5: VDM_CONTEXT_RESUME_TASK0      : 0x0000000000000000
[   13.137501] PVR_K:  5: VDM_CONTEXT_RESUME_TASK1      : 0x0000000000000000
[   13.137507] PVR_K:  5: VDM_CONTEXT_RESUME_TASK2      : 0x0000000000000000
[   13.137512] PVR_K:  5: ISP_CTL                       : 0x00000000
[   13.137517] PVR_K:  5: ISP_STATUS                    : 0x00000000
[   13.137522] PVR_K:  5: MTS_INTCTX                    : 0x00000000
[   13.137527] PVR_K:  5: MTS_BGCTX                     : 0x00000000
[   13.137532] PVR_K:  5: MTS_BGCTX_COUNTED_SCHEDULE    : 0x00000000
[   13.137537] PVR_K:  5: MTS_SCHEDULE                  : 0x00000000
[   13.137542] PVR_K:  5: MTS_GPU_INT_STATUS            : 0x00004510
[   13.137547] PVR_K:  5: CDM_CONTEXT_STORE_STATUS      : 0x00000000
[   13.137552] PVR_K:  5: CDM_CONTEXT_PDS0              : 0x0000000000000000
[   13.137558] PVR_K:  5: CDM_CONTEXT_PDS1              : 0x0000000000000000
[   13.137564] PVR_K:  5: CDM_TERMINATE_PDS             : 0x0000000000000000
[   13.137569] PVR_K:  5: CDM_TERMINATE_PDS1            : 0x0000000000000000
[   13.137575] PVR_K:  5: SIDEKICK_IDLE                 : 0x0000007E
[   13.137580] PVR_K:  5: SLC_IDLE                      : 0x000000FF
[   13.137585] PVR_K:  5: SLC_STATUS0                   : 0x00000000
[   13.137590] PVR_K:  5: SLC_STATUS1                   : 0x0000000000000000
[   13.137596] PVR_K:  5: SLC_STATUS2                   : 0x0000000000000000
[   13.137601] PVR_K:  5: SLC_CTRL_BYPASS               : 0x01000000
[   13.137607] PVR_K:  5: SLC_CTRL_MISC                 : 0x0000000000200003
[   13.137613] PVR_K:  5: MIPS_ADDR_REMAP1_CONFIG1      : 0x1FC00001
[   13.137618] PVR_K:  5: MIPS_ADDR_REMAP1_CONFIG2      : 0x000000013807400c
[   13.137624] PVR_K:  5: MIPS_ADDR_REMAP2_CONFIG1      : 0x1FC01001
[   13.137629] PVR_K:  5: MIPS_ADDR_REMAP2_CONFIG2      : 0x0000000136c2a00c
[   13.137634] PVR_K:  5: MIPS_ADDR_REMAP3_CONFIG1      : 0x1FC02001
[   13.137641] PVR_K:  5: MIPS_ADDR_REMAP3_CONFIG2      : 0x0000000138a8000c
[   13.137646] PVR_K:  5: MIPS_ADDR_REMAP4_CONFIG1      : 0x1FC00000
[   13.137651] PVR_K:  5: MIPS_ADDR_REMAP4_CONFIG2      : 0x000000000000000c
[   13.137656] PVR_K:  5: MIPS_ADDR_REMAP5_CONFIG1      : 0x00000001
[   13.137662] PVR_K:  5: MIPS_ADDR_REMAP5_CONFIG2      : 0x000000013807400c
[   13.137668] PVR_K:  5: MIPS_WRAPPER_CONFIG           : 0x000000000001cf40
[   13.137673] PVR_K:  5: MIPS_EXCEPTION_STATUS         : 0x00000020
[   13.137843] PVR_K:  5: ---- [ MIPS internal state ] ----
[   13.137848] PVR_K:  5: PC                            : 0xC0015F02
[   13.137854] PVR_K:  5: STATUS_REGISTER               : 0x00481C05
[   13.137862] PVR_K:  5: CAUSE_REGISTER                : 0x00800008
[   13.137868] PVR_K:  5: BAD_REGISTER                  : 0xC0015EFE
[   13.137873] PVR_K:  5: EPC                           : 0xC0015EFE
[   13.137878] PVR_K:  5: SP                            : 0xCF600FE0
[   13.137883] PVR_K:  5: BAD_INSTRUCTION               : 0x00000000
[   13.137889] PVR_K:  5: TLB                           :
[   13.137899] PVR_K:  5:  0) VA 0xCF400000 ( 64k) -> PA0 0x01800000 DV  , PA1 0x00000000    C
[   13.137909] PVR_K:  5:  1) VA 0xCF000000 ( 16k) -> PA0 0x136c00000 DVGC, PA1 0x136c04000 DVGC
[   13.137917] PVR_K:  5:  2) VA 0xCF600000 (  4k) -> PA0 0x136c2b000 DV C, PA1 0x00000000    C
[   13.137925] PVR_K:  5:  3) VA 0xC0032000 (  4k) -> PA0 0x136c27000 DVGC, PA1 0x136c28000 DVGC
[   13.137934] PVR_K:  5:  4) VA 0xC0028000 (  4k) -> PA0 0x136cfd000 DVG , PA1 0x136eba000  VG
[   13.137942] PVR_K:  5:  5) VA 0xC000A000 (  4k) -> PA0 0x136c7c000 DVGC, PA1 0x138a19000 DVGC
[   13.137950] PVR_K:  5:  6) VA 0xC000C000 (  4k) -> PA0 0x138ad3000 DVGC, PA1 0x13a08f000 DVGC
[   13.137958] PVR_K:  5:  7) VA 0xC001E000 (  4k) -> PA0 0x138097000 DVG , PA1 0x13803b000 DVG
[   13.137967] PVR_K:  5:  8) VA 0xC1FF0000 (  4k) -> PA0 0x136d15000 DV C, PA1 0x00000000    C
[   13.137975] PVR_K:  5:  9) VA 0xC0010000 (  4k) -> PA0 0x138041000 DVGC, PA1 0x138042000 DVGC
[   13.137983] PVR_K:  5: 10) VA 0xC0012000 (  4k) -> PA0 0x13a09a000 DVGC, PA1 0x13803e000 DVGC
[   13.137991] PVR_K:  5: 11) VA 0x00FF0000 (  4k) -> PA0 0x136c26000 DVG , PA1 0x136c26000 DVG
[   13.137999] PVR_K:  5: 12) VA 0xC0014000 (  4k) -> PA0 0x138040000 DVGC, PA1 0x13803f000 DVGC
[   13.138008] PVR_K:  5: 13) VA 0xC0018000 (  4k) -> PA0 0x136d16000 DVG , PA1 0x138038000 DVG
[   13.138016] PVR_K:  5: 14) VA 0xC0006000 (  4k) -> PA0 0x13a089000 DVGC, PA1 0x138ab8000 DVGC
[   13.138024] PVR_K:  5: 15) VA 0xC0042000 (  4k) -> PA0 0x1375a2000 DVGC, PA1 0x1375a3000 DVGC
[   13.138036] PVR_K:  5: --------------------------------
[   13.138043] PVR_K:  5: RGX Kernel CCB WO:0xF RO:0xF
[   13.138049] PVR_K:  5: RGX Firmware CCB WO:0x1 RO:0x0
[   13.138057] PVR_K:  5: RGX Checkpoint CCB WO:0x6C RO:0x6B (Check State: FW=0X0, HOST=0X0)
[   13.138062] PVR_K:  5: RGX Kernel CCB commands executed = 143
[   13.138067] PVR_K:  5: RGX SLR: Forced UFO updates requested = 0
[   13.138073] PVR_K:  5: Thread0: FW IRQ count = 125
[   13.138078] PVR_K:  5: Last sampled IRQ count in LISR = 125
[   13.138090] PVR_K:  5: FW OS config flags = 0x1000A7 (Ctx switch: TA; 3D; CDM; VDM CS INDEX mode; Medium CSW profile; Power Rascal/Dust; HWR EN;)
[   13.138095] PVR_K:  5: Debug log type: none
[   13.138101] PVR_K:  5: RGX FW thread 0: Trace buffer not yet allocated
[   13.138106] PVR_K:  5: ------[ Full CCB Status ]------
[   13.138116] PVR_K:  5: FWCtx 0xC002D0C0 (TQ_3D-P994-T994-cellphone)
[   13.138120] PVR_K:  5:   `--<Empty>
[   13.138127] PVR_K:  5: FWCtx 0xC002D500 (TQ_3D-P994-T1094-QSGRenderThr)
[   13.138131] PVR_K:  5:   `--<Empty>
[   13.138138] PVR_K:  5: FWCtx 0xC002D180 (TA-P994-T994-cellphone)
[   13.138142] PVR_K:  5:   `--<Empty>
[   13.138148] PVR_K:  5: FWCtx 0xC002D220 (3D-P994-T994-cellphone)
[   13.138156] PVR_K:  5:   |--Waiting FENCE_PR @ 2000 Int=100 Ext=100
[   13.138164] PVR_K:  5:   |  `--Addr:0xc0030058 Val=0x00000003
[   13.138172] PVR_K:  5:   |--Waiting 3D @ 2048 Int=100 Ext=100
[   13.138179] PVR_K:  5:   `--Waiting UPDATE @ 2416 Int=100 Ext=100
[   13.138185] PVR_K:  5:      |--Addr:0xc0030058 Val=0x00000004
[   13.138191] PVR_K:  5:      |--Addr:0xc005305c Val=0x000000bc
[   13.138197] PVR_K:  5:      |--Addr:0xc0053060 Val=0x00000020
[   13.138204] PVR_K:  5:      |--Addr:0xc0053068 Val=0x00000140
[   13.138210] PVR_K:  5:      |--Addr:0xc005306c Val=0x0000002c
[   13.138216] PVR_K:  5:      `--Addr:0xc0059079 Val=0x00000519
[   13.138224] PVR_K:  5: FWCtx 0xC002DCC0 (TA-P994-T1094-QSGRenderThread)
[   13.138228] PVR_K:  5:   `--<Empty>
[   13.138234] PVR_K:  5: FWCtx 0xC002DD60 (3D-P994-T1094-QSGRenderThread)
[   13.138238] PVR_K:  5:   `--<Empty>
[   13.138245] PVR_K:  5: FWCtx 0xC002D5C0 (TA-P994-T994-cellphone)
[   13.138249] PVR_K:  5:   `--<Empty>
[   13.138255] PVR_K:  5: FWCtx 0xC002D660 (3D-P994-T994-cellphone)
[   13.138259] PVR_K:  5:   `--<Empty>
[   13.138278] PVR_K:  5: ------[ RGX Device: End ]------
[   13.138417] ------------[ cut here ]------------
[   13.138961] WARNING: CPU: 1 PID: 5 at /opt/A133/tina4/lichee/linux-4.9/modules/gpu/img-rgx/linux/rogue_km/binary_sunxi_linux_nullws_release/target_aarch64/kbuild/services/server/devices/rgx/rgxfwutils.c:4426 RGXCheckFirmwareCCB+0x1b4/0x36c [pvrsrvkm]
[   13.138986] Modules linked in: dc_sunxi(O) pvrsrvkm(O) gt9xxnew_ts
[   13.138991]
[   13.139004] CPU: 1 PID: 5 Comm: kworker/u8:0 Tainted: G           O    4.9.191 #70
[   13.139009] Hardware name: sun50iw10 (DT)
[   13.139511] Workqueue: pvr_misr MISRWrapper [pvrsrvkm]
[   13.139515] task: ffffffc0fb151b80 task.stack: ffffffc0fb18c000
[   13.139998] PC is at RGXCheckFirmwareCCB+0x1b4/0x36c [pvrsrvkm]
[   13.140478] LR is at RGXCheckFirmwareCCB+0x1b4/0x36c [pvrsrvkm]
[   13.140485] pc : [<ffffff8000748620>] lr : [<ffffff8000748620>] pstate: 60000145
[   13.140489] sp : ffffffc0fb18fd00
[   13.140503] x29: ffffffc0fb18fd00 x28: 0000000000000000
[   13.140516] x27: 0000000000000000 x26: 000000000007a11f
[   13.140530] x25: 00000000d543ff9b x24: 0000000000000000
[   13.140539] x23: ffffff800078f480 x22: ffffff800c05a080
[   13.140547] x21: ffffff800c05a040 x20: ffffff800c05a080
[   13.140554] x19: ffffffc0f8bd3280 x18: 000000000000000a
[   13.140562] x17: 0000000000006028 x16: ffffff80007a6dfb
[   13.140569] x15: 0000000000000005 x14: ffffff80007d0b9f
[   13.140577] x13: 00000000fffffff0 x12: ffffff8008ab2132
[   13.140584] x11: ffffff800897e000 x10: 000000000000004c
[   13.140592] x9 : 000000000000028a x8 : ffffffc0fff0593c
[   13.140599] x7 : 0000000000000000 x6 : 0000000000000004
[   13.140606] x5 : 00ffffffffffffff x4 : 0000000000000015
[   13.140613] x3 : ffffff80007ce7a4 x2 : 0000000000000000
[   13.140621] x1 : ffffffc0fb151b80 x0 : 0000000000000001
[   13.140625]
[   13.140625] SP: 0xffffffc0fb18fc80:
[   13.140647] fc80  0c05a080 ffffff80 0078f480 ffffff80 00000000 00000000 d543ff9b 00000000
[   13.140668] fca0  0007a11f 00000000 00000000 00000000 00000000 00000000 fb18fd00 ffffffc0
[   13.140689] fcc0  00748620 ffffff80 fb18fd00 ffffffc0 00748620 ffffff80 60000145 00000000
[   13.140709] fce0  f8bd3280 ffffffc0 0c05a080 ffffff80 ffffffff ffffffff f6ef0f90 ffffffc0
[   13.140731] fd00  fb18fd60 ffffffc0 00749a90 ffffff80 f6ee8080 ffffffc0 f8bd3280 ffffffc0
[   13.140752] fd20  fb020080 ffffffc0 00000000 00000000 fb01ed00 ffffffc0 00000000 00000000
[   13.140772] fd40  fb0200a0 ffffffc0 08966000 ffffff80 00000000 00000000 00000000 00000000
[   13.140793] fd60  fb18fd80 ffffffc0 00706578 ffffff80 fb13b080 ffffffc0 f81f4088 ffffffc0
[   13.140797]
[   13.140797] X1: 0xffffffc0fb151b00:
[   13.140818] 1b00  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.140840] 1b20  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.140860] 1b40  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.140881] 1b60  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.140901] 1b80  00000010 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000
[   13.140922] 1ba0  fb18c000 ffffffc0 00000002 04208060 00000000 00000000 00000000 00000000
[   13.140942] 1bc0  00000001 00000001 00000021 00000000 fffee7be 00000000 f8020080 ffffffc0
[   13.140963] 1be0  00000001 00000001 00000078 00000078 00000078 00000000 086f8270 ffffff80
[   13.140969]
[   13.140969] X8: 0xffffffc0fff058bc:
[   13.140990] 58bc  20303636 2d443328 34393950 3939542d 65632d34 68706c6c 29656e6f 0f19ecff
[   13.141011] 58dc  00000003 00170028 66000000 5f525650 20203a4b 20203a35 2d2d6020 706d453c
[   13.141032] 58fc  003e7974 0f1a378a 00000003 002a003c 66000000 5f525650 20203a4b 2d203a35
[   13.141053] 591c  2d2d2d2d 52205b2d 44205847 63697665 45203a65 5d20646e 2d2d2d2d 00002d2d
[   13.141073] 593c  0f1c56d6 00000003 00240034 86000000 2d2d2d2d 2d2d2d2d 2d2d2d2d 7563205b
[   13.141094] 595c  65682074 5d206572 2d2d2d2d 2d2d2d2d 2d2d2d2d 0f24a3ff 00000003 00ee0100
[   13.141115] 597c  86000000 4e524157 3a474e49 55504320 2031203a 3a444950 61203520 6f2f2074
[   13.141136] 599c  412f7470 2f333331 616e6974 696c2f34 65656863 6e696c2f 342d7875 6d2f392e
[   13.141144]
[   13.141144] X19: 0xffffffc0f8bd3200:
[   13.141165] 3200  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.141186] 3220  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.141207] 3240  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.141228] 3260  cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc cccccccc
[   13.141249] 3280  f6ee8080 ffffffc0 0004a070 00000000 2c24ec05 00000002 00000016 00000066
[   13.141274] 32a0  00000036 00000026 ffffffff ffffffff ffffffff 00000008 ffffffff ffffffff
[   13.141312] 32c0  ffffffff ffffffff 00000001 00000004 00000001 00000024 ffffffff ffffffff
[   13.141336] 32e0  00000001 00000001 00000200 00010000 ffffffff 00000028 00000001 00000000
[   13.141344]
[   13.141344] X29: 0xffffffc0fb18fc80:
[   13.141365] fc80  0c05a080 ffffff80 0078f480 ffffff80 00000000 00000000 d543ff9b 00000000
[   13.141385] fca0  0007a11f 00000000 00000000 00000000 00000000 00000000 fb18fd00 ffffffc0
[   13.141406] fcc0  00748620 ffffff80 fb18fd00 ffffffc0 00748620 ffffff80 60000145 00000000
[   13.141426] fce0  f8bd3280 ffffffc0 0c05a080 ffffff80 ffffffff ffffffff f6ef0f90 ffffffc0
[   13.141447] fd00  fb18fd60 ffffffc0 00749a90 ffffff80 f6ee8080 ffffffc0 f8bd3280 ffffffc0
[   13.141467] fd20  fb020080 ffffffc0 00000000 00000000 fb01ed00 ffffffc0 00000000 00000000
[   13.141487] fd40  fb0200a0 ffffffc0 08966000 ffffff80 00000000 00000000 00000000 00000000
[   13.141508] fd60  fb18fd80 ffffffc0 00706578 ffffff80 fb13b080 ffffffc0 f81f4088 ffffffc0
[   13.141510]
[   13.141515] ---[ end trace bf9dd98fbf2e85a1 ]---
[   13.141519] Call trace:
[   13.141525] Exception stack(0xffffffc0fb18fb10 to 0xffffffc0fb18fc40)
[   13.141531] fb00:                                   ffffffc0f8bd3280 0000007fffffffff
[   13.141537] fb20: ffffffc0fb18fd00 ffffff8000748620 0000000060000145 000000000000003d
[   13.141543] fb40: 00000000d543ff9b 000000000007a11f ffffffc0fb18fc20 ffffffc0fb18fc20
[   13.141548] fb60: ffffffc0fb18fbe0 00000000ffffffc8 ffffffc0fb18fc20 ffffff800070dd3c
[   13.141554] fb80: ffffffc0fb18fc20 ffffffc0fb18fc20 ffffffc0fb18fbe0 00000000ffffffc8
[   13.141560] fba0: ffffffc0fb18fc20 ffffffc0fb18fc20 ffffffc0fb18fbd0 ffffff80086e22ec
[   13.141566] fbc0: ffffff80007ce7a0 ffffffc0fb18fc00 0000000000000001 ffffffc0fb151b80
[   13.141572] fbe0: 0000000000000000 ffffff80007ce7a4 0000000000000015 00ffffffffffffff
[   13.141578] fc00: 0000000000000004 0000000000000000 ffffffc0fff0593c 000000000000028a
[   13.141584] fc20: 000000000000004c ffffff800897e000 ffffff8008ab2132 00000000fffffff0
[   13.142079] [<ffffff8000748620>] RGXCheckFirmwareCCB+0x1b4/0x36c [pvrsrvkm]
[   13.142570] [<ffffff8000749a90>] RGX_MISRHandler_Main+0x30/0x54 [pvrsrvkm]
[   13.143076] [<ffffff8000706578>] MISRWrapper+0x18/0x20 [pvrsrvkm]
[   13.143094] [<ffffff80080ac388>] process_one_work+0x1b8/0x29c
[   13.143103] [<ffffff80080ad0e4>] worker_thread+0x290/0x3a4
[   13.143113] [<ffffff80080b1840>] kthread+0xd4/0xe4
[   13.143123] [<ffffff8008083180>] ret_from_fork+0x10/0x50
[   25.881806] PVR_K:(Error):   986: CheckForStalledCCB (force): CCCB has not progressed (ROFF=2000 DOFF=2000 WOFF=3064) for "3D-P994-T994-cellphone"
[   25.896628] PVR_K:  986: Possible stalled client RGX contexts detected: 3D
[   25.904486] PVR_K:  986: Trying to identify stalled context...(force) [0]
[   25.912153] PVR_K:  986: Fence found on context 0xc002d220 '3D-P994-T994-cellphone' @ 2000 has 1 UFOs
[   25.922601] PVR_K:  986:   1/1 FWAddr 0xc0030058 requires 0x3
[   25.929086] PVR_K:  986: SLR disabled for FWCtx 0xC002D220
[   36.121815] PVR_K:(Error):   986: CheckForStalledCCB (force): CCCB has not progressed (ROFF=2000 DOFF=2000 WOFF=3064) for "3D-P994-T994-cellphone"
