楼主 # 2024-12-12 10:41:36
已发帖子: 1,438
t113s3连接spi lcd,报错:of_find_compatible_node allwinner,sunxi-lcd_fb1 fai
为啥是lcd_fb1呢?
设备树里用的是lcd_fb0节点啊。
t113s3接了中景园的1.14寸Lcd,接口是spi的,芯片是st7789v。
选用tina2.x sdk里的kld2844b这个驱动,烧录后,屏竟然也能初始化成功,屏幕有雪花点。
但是想运行qt程序,结果没反映。开机信息里有报错:
/# dmesg | grep fail
[    0.538656] of_find_compatible_node allwinner,sunxi-lcd_fb1 fail
[    0.560739] Fb_map_kernel_logo failed!
[    0.661988] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[    0.669318] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[    0.735950] sunxi-rfkill soc@3000000:rfkill@0: get gpio bt_rst failed
[    1.096246] get ehci1-controller wakeup-source is fail.
[    1.387829] get ohci1-controller wakeup-source is fail.
[    2.375189] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    2.862382] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
[    3.195701] get ehci0-controller wakeup-source is fail.
[    3.224771] get ohci0-controller wakeup-source is fail.
[    3.270322] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.280032] cfg80211: failed to load regulatory.db
[    5.895299] configfs-gadget 4100000.udc-controller: failed to start g1: -19
设备树:
  18 &lcd_fb0 {
  17     lcd_used = <1>;
  16
  15     lcd_driver_name = "kld2844b";
  14     lcd_if = <0>;
  13     lcd_data_speed = <60>;
  12     lcd_spi_bus_num = <1>;
  11     lcd_x = <320>;
  10     lcd_y = <240>;
   9     lcd_pwm_used = <0>;
   8     lcd_pixel_fmt = <10>;
   7     lcd_rgb_order = <0>;
   6     fb_bffer_num = <2>;
   5     lcd_backlight = <200>;
   4     lcd_fps = <60>;
   3     lcd_dbi_te = <0>;
   2     lcd_bl_en = <&pio PD 16 1 1 2 1>;
   1     lcd_gpio_0 = <&pio PE 8 1 1 2 1>;
1608     lcd_spi_dc_pin = <&pio PD 14 1 1 2 1>;
完整开机记录:
[210]HELLO! BOOT0 is starting!
[213]BOOT0 commit : 88480af-dirty
[217]set pll start
[218]fix vccio detect value:0xc0
[226]periph0 has been enabled
[229]set pll end
[230][pmu]: bus read error
[233]board init ok
[235]ZQ value = 0x2f
[237]get_pmu_exist() = -1
[239]DRAM BOOT DRIVE INFO: V0.33
[242]DRAM CLK = 936 MHz
[245]DRAM Type = 3 (2:DDR2,3:DDR3)
[248]DRAMC read ODT  off.
[250]DRAM ODT value: 0x42.
[253]ddr_efuse_type: 0xa
[256]DRAM SIZE =128 M
[258]dram_tpr4:0x0
[260]PLL_DDR_CTRL_REG:0xf8004d00
[263]DRAM_CLK_REG:0xc0000000
[266][TIMING DEBUG] MR2= 0x20
[273]DRAM simple test OK.
[276]rtc standby flag is 0x0, super standby flag is 0x0
[281]dram size =128
[284]card no is 2
[285]sdcard 2 line count 4
[288][mmc]: mmc driver ver 2021-05-21 14:47
[297][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[303][mmc]: ***Try MMC card 2***
[326][mmc]: RMCA OK!
[328][mmc]: mmc 2 bias 0
[337][mmc]: MMC 5.1
[339][mmc]: HSSDR52/SDR25 4 bit
[342][mmc]: 50000000 Hz
[344][mmc]: 3700 MB
[346][mmc]: ***SD/MMC 2 init OK!!!***
[417]Loading boot-pkg Succeed(index=0).
[420]Entry_name        = u-boot
[426]Entry_name        = optee
[430]Entry_name        = dtb
[433]tunning data addr:0x430003e8
[436]Jump to second Boot.
M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:        m
U-Boot 2018.07-ge987def5-dirty (Dec 07 2024 - 08:25:07 +0800) Allwinner Technology
[00.489]CPU:   Allwinner Family
[00.492]Model: sun8iw20
I2C:   FDT ERROR:fdt_set_all_pin:[twi0]-->FDT_ERR_BADPATH
FDT ERROR:fdt_set_all_pin:[twi1]-->FDT_ERR_BADPATH
ready
[00.513]DRAM:  128 MiB
[00.516]Relocation Offset is: 04eff000
[00.536]secure enable bit: 0
[00.538]smc_tee_inform_fdt failed with: ffff000a
[00.544]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.550]gic: sec monitor mode
sunxi flash map init
[00.555]flash init start
[00.557]workmode = 0,storage type = 2
[00.561][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.567][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.594][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.601]sunxi flash init ok
[00.606]Loading Environment from SUNXI_FLASH... OK
[00.630]Item0 (Map) magic is bad
[00.633]the secure storage item0 copy0 magic is bad
[00.649]Item0 (Map) magic is bad
[00.652]the secure storage item0 copy1 magic is bad
[00.656]Item0 (Map) magic is bad
secure storage read widevine fail
[00.662]secure storage read widevine fail with:-1
secure storage read ec_key fail
[00.670]secure storage read ec_key fail with:-1
secure storage read ec_cert1 fail
[00.677]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[00.684]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[00.692]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[00.699]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[00.707]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[00.714]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[00.722]secure storage read rsa_cert3 fail with:-1
[00.726]out of usb burn from boot: not need burn key
root_partition is rootfs
set root to /dev/mmcblk0p5
[00.736]update part info
[00.739]update bootcmd
[00.741]change working_fdt 0x43ebee70 to 0x43e9ee70
[00.746][mmc]: no mmc-hs400-1_8v!
[00.749][mmc]: delete mmc-hs200-1_8v from dtb
[00.753][mmc]: get max-frequency ok 50000000 Hz
disable nand error: FDT_ERR_BADPATH
[00.770]update dts
[01.859]no vendor_boot partition is found
Android's image name: t113-nezha
[01.870]Starting kernel ...
[01.873][mmc]: mmc exit start
[01.890][mmc]: mmc 2 exit ok
[    0.000000] Linux version 5.4.61 (any@Any-PC) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4        4
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
[    0.000000] cma: Reserved 8 MiB at 0x47800000
[    0.000000] On node 0 totalpages: 32768
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s30348 r8192 d22900 u61440
[    0.000000] pcpu-alloc: s30348 r8192 d22900 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 consol
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Memory: 109708K/131072K available (6144K kernel code, 237K rwdata, 1456K rodata, 1024K init, 112        )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x264/0x3e8 with crng_init=0
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 4407        s
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008024] Switching to timer-based delay loop, resolution 41ns
[    0.014203] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.023903] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=2        )
[    0.034267] pid_max: default: 32768 minimum: 301
[    0.039017] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.046339] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.054652] CPU: Testing write buffer coherency: ok
[    0.059871] /cpus/cpu@0 missing clock-frequency property
[    0.065188] /cpus/cpu@1 missing clock-frequency property
[    0.070526] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.076674] Setting up static identity map for 0x40100000 - 0x40100060
[    0.083336] rcu: Hierarchical SRCU implementation.
[    0.088543] smp: Bringing up secondary CPUs ...
[    0.094165] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.094282] smp: Brought up 1 node, 2 CPUs
[    0.104102] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.110280] CPU: All CPU(s) started in SVC mode.
[    0.115348] devtmpfs: initialized
[    0.129670] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.137802] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.147674] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.154896] pinctrl core: initialized pinctrl subsystem
[    0.161057] NET: Registered protocol family 16
[    0.166915] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.203130] rtc_ccu: sunxi ccu init OK
[    0.209112] ccu: sunxi ccu init OK
[    0.212922] r_ccu: sunxi ccu init OK
[    0.234050] sun6i-dma 3002000.dma-controller: sunxi dma probed
[    0.241650] iommu: Default domain type: Translated
[    0.246689] sunxi iommu: irq = 24
[    0.250912] SCSI subsystem initialized
[    0.254888] usbcore: registered new interface driver usbfs
[    0.260452] usbcore: registered new interface driver hub
[    0.265850] usbcore: registered new device driver usb
[    0.271965] Advanced Linux Sound Architecture Driver Initialized.
[    0.278797] Bluetooth: Core ver 2.22
[    0.282422] NET: Registered protocol family 31
[    0.286859] Bluetooth: HCI device and connection manager initialized
[    0.293277] Bluetooth: HCI socket layer initialized
[    0.298168] Bluetooth: L2CAP socket layer initialized
[    0.303244] Bluetooth: SCO socket layer initialized
[    0.308817] g2d 5410000.g2d: Adding to iommu group 0
[    0.314170] G2D: rcq version initialized.major:251
[    0.319701] clocksource: Switched to clocksource arch_sys_counter
[    0.334176] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    0.343528] NET: Registered protocol family 2
[    0.348437] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.356841] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.364523] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.371593] TCP: Hash tables configured (established 1024 bind 1024)
[    0.378032] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.384605] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.391794] NET: Registered protocol family 1
[    0.397123] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[    0.407351] sunxi_spi_probe()2890 - [spi1] SPI DBI INTERFACE
[    0.413153] spi spi1: spi1 supply spi not found, using dummy regulator
[    0.419852] sunxi_spi_resource_get()2438 - [spi1] SPI MASTER MODE
[    0.425983] sunxi_spi_resource_get()2476 - Failed to get sample mode
[    0.432359] sunxi_spi_resource_get()2481 - Failed to get sample delay
[    0.438789] sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
[    0.447216] sunxi_spi_clk_init()2527 - [spi1] mclk 100000000
[    0.453485] sunxi_spi_probe()2978 - [spi1]: driver probe succeed, base c881d000, irq 40
[    0.463097] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.474575] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.480612] ntfs: driver 2.1.32 [Flags: R/W].
[    0.514359] io scheduler mq-deadline registered
[    0.518902] io scheduler kyber registered
[    0.523979] [LCD_FB] lcd_fb_init,line:158:
[    0.523982]
[    0.529774] [LCD_FB] lcd_fb_probe,line:65:
[    0.529776]
[    0.538791] [LCD_FB] lcd_fb_script_get_item,line:139:
[    0.538796] of_find_compatible_node allwinner,sunxi-lcd_fb1 fail
[    0.550002] [LCD_FB] disp_lcd_set_panel_funs,line:1096:
[    0.550006] lcd_panel_fun[0].cfg_panel_info is NULL
[    0.560870] [LCD_FB] Fb_map_kernel_logo,line:201:
[    0.560873] Fb_map_kernel_logo failed!
[    0.565689] [LCD_FB] disp_lcd_spi_init,line:845:
[    0.569433] Init spi1:bits_per_word:8 max_speed_hz:60000000 mode:0
[    0.570925] sunxi_sid_init()783 - insmod ok
[    0.585601] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    0.595782] uart uart0: uart0 supply uart not found, using dummy regulator
[    0.602942] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[    0.610827] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
[    0.618808] printk: console [ttyS0] enabled
[    0.627687] printk: bootconsole [earlycon0] disabled
[    0.639030] misc dump reg init
[    0.643611] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[    0.654846] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[    0.662110] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[    0.669439] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[    0.676879] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[    0.683432] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[    0.690389] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[    0.698119] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[    0.705981] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[    0.714112] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[    0.721763] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[    0.728513] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[    0.736068] sunxi-rfkill soc@3000000:rfkill@0: get gpio bt_rst failed
[    0.743874] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[    0.751058] [ADDR_MGT] addr_mgt_probe: success.
[    0.756433] dma-buf: Running sanitycheck
[    0.760897] dma-buf: Running dma_fence
[    0.765098] sizeof(dma_fence)=48
[    0.768810] dma-buf: Running dma_fence/sanitycheck
[    0.774213] dma-buf: Running dma_fence/test_signaling
[    0.779918] dma-buf: Running dma_fence/test_add_callback
[    0.785877] dma-buf: Running dma_fence/test_late_add_callback
[    0.792331] dma-buf: Running dma_fence/test_rm_callback
[    0.798191] dma-buf: Running dma_fence/test_late_rm_callback
[    0.804549] dma-buf: Running dma_fence/test_status
[    0.809931] dma-buf: Running dma_fence/test_error
[    0.815205] dma-buf: Running dma_fence/test_wait
[    0.820394] dma-buf: Running dma_fence/test_wait_timeout
[    0.849712] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.849715] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.859708] dma-buf: Running dma_fence/test_stub
[    0.866342] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.866346] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.866353] dma-buf: Running dma_fence/race_signal_callback
[    0.871929] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.871932] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.909742] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.909746] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.929740] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.929743] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.949740] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.949744] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.969709] thread_signal_callback[0] completed 39414 passes, 17554 misses
[    0.977439] thread_signal_callback[1] completed 21892 passes, 29 misses
[    0.984910] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    0.984913] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.009698] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.009701] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.029715] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.029718] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.049705] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.049709] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.069716] thread_signal_callback[0] completed 41379 passes, 41379 misses
[    1.069745] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.069748] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.077498] thread_signal_callback[1] completed 23961 passes, 23961 misses
[    1.088902] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.088905] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.102726] libphy: Fixed MDIO Bus: probed
[    1.108041] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.108044] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.113225] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.124126] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.124129] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.131465] sunxi-ehci: EHCI SUNXI driver
[    1.142907] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.142911] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.147833] get ehci1-controller wakeup-source is fail.
[    1.152987] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.152993] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.158962] sunxi ehci1-controller don't init wakeup source
[    1.170342] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.170345] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.176316] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b4d9d0, 0x:c8827000,        d
[    1.188064] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.188068] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.194025] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using du        r
[    1.211532] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.211536] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.217598] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy        r
[    1.229723] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.229726] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.235555] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.253099] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.253102] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.258691] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.271774] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.271777] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.304281] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.304284] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.315786] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.315789] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.315980] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[    1.327274] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.327277] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.346395] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.346398] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.357880] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.357883] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.359712] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.369326] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.369329] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.377946] hub 1-0:1.0: USB hub found
[    1.382703] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.382705] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.388620] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.388623] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.392855] hub 1-0:1.0: 1 port detected
[    1.404280] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.404283] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.410407] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.415692] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.415695] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.420159] sunxi-ohci: OHCI SUNXI driver
[    1.431557] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.431560] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.438956] get ohci1-controller wakeup-source is fail.
[    1.449958] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.449962] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.454536] sunxi ohci1-controller don't init wakeup source
[    1.460014] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.460017] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.465871] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b4dc60
[    1.477322] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.477325] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.483200] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using du        r
[    1.495013] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.495016] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.501068] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy        r
[    1.510528] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.510530] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.516129] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.516131] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.522284] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.539898] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.539902] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.545776] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.557644] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.557647] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.563456] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[    1.574691] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.574694] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.639472] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.639476] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.650919] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.650922] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.654496] hub 2-0:1.0: USB hub found
[    1.662403] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.662406] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.666655] hub 2-0:1.0: 1 port detected
[    1.678055] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.678058] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.683142] i2c /dev entries driver
[    1.693925] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.693928] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.697914] sunxi cedar version 1.1
[    1.703400] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.703406] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.709453] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.718777] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.718780] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.724714] VE: sunxi_cedar_probe power-domain init!!!
[    1.736475] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.736478] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.742337] VE: install start!!!
[    1.742337]
[    1.753687] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.753690] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.759790] VE: cedar-ve the get irq is 41
[    1.759790]
[    1.770408] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.770411] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.776427] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[    1.776427]
[    1.788098] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.788101] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.793963] VE: install end!!!
[    1.793963]
[    1.808810] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.808813] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.814661] VE: sunxi_cedar_probe
[    1.814945] Bluetooth: HCI UART driver ver 2.3
[    1.825358] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.825361] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.831213] Bluetooth: HCI UART protocol H4 registered
[    1.839927] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.839930] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.845483] Bluetooth: HCI UART protocol BCSP registered
[    1.857123] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.857126] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.862981] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[    1.874542] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.874545] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.881231] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[    1.892962] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.892966] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.898710] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[    1.915438] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.915441] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.921186] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
[    1.936542] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.936545] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.942150] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[    1.954333] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.954336] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.959902] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[    1.972127] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.972130] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.977688] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[    1.983544] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    1.983546] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    1.989991] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[    2.001434] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.001438] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.007871] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[    2.019308] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.019311] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.025858] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[    2.037290] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.037293] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.043831] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[    2.055273] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.055276] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.061834] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    2.073255] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.073258] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.080526] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt        B
[    2.091273] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.091277] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.112532] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.128119] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.128123] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.146595] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[    2.157035] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.157039] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.164174] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.170854] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[    2.178623] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.187234] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.187238] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.197167] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    2.214129] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.214132] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.219983] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.226204] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    2.255535] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.255539] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.255554] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    2.267009] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.267012] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.273452] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    2.284907] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.284910] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.291345] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.296933] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    2.302835] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.314385] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.314388] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.321002] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    2.338132] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.338135] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.343991] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    2.350527] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.350529] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.356123] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.356125] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.361978] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    2.374114] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.374116] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.379964] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.385962] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    2.406848] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.409393] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.409396] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.439026] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.443476] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    2.449211] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.458988] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.458991] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.465409] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.475415] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt        B
[    2.480770] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.486648] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.486651] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.496433] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    2.507513] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.507516] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.517333] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.517336] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.522888] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20        B
[    2.536372] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.536376] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.541960] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.553397] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.553400] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.559658] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR        B
[    2.571090] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    2.577336] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR        B
[    2.582320] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.582323] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.594455] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[    2.599545] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt        B
[    2.606182] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52        B
[    2.617199] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.617203] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.623054] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    2.695973] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[    2.697632] mmc0: new DDR MMC card at address 0001
[    2.702341] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[    2.702348] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    2.708680] mmcblk0: mmc0:0001 MK004A 3.61 GiB
[    2.714198] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    2.720899] mmcblk0rpmb: mmc0:0001 MK004A partition 3 4.00 MiB, chardev (248:0)
[    2.725717] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    2.742024]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[    2.747023] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    2.758453] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    2.765031] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.765034] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.769741] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    2.776501] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.776504] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.785933] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt        B
[    2.790785] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.790788] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.796651] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[    2.813371] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    2.813374] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    2.831726] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.862476] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    2.870147] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[    2.877288] sunxi_led_probe()1749 - start
[    2.881837] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[    2.888707] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.900384] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
[    2.903384] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12        B
[    2.910362] sunxi_register_led_classdev()1483 - led_classdev start
[    2.924111] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    2.929894] sunxi_led_probe()1845 - finish
[    2.936465] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    2.940250] [LCD_FB] disp_lcd_pwm_enable,line:401:
[    2.940253] pwm device hdl is NULL
[    2.947211] exFAT: Version 1.3.0
[    2.952337] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    2.967354] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    2.974150] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt        B
[    2.981048] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gai        1
[    2.981048]
[    3.002469] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[    3.013852] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[    3.022951] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[    3.032793] [SNDCODEC][sunxi_card_init][583]:card init finished
[    3.040019] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[    3.050902] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/in        0
[    3.062847] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[    3.071244] NET: Registered protocol family 10
[    3.077142] Segment Routing with IPv6
[    3.081304] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[    3.088721] NET: Registered protocol family 17
[    3.093875] Bluetooth: RFCOMM TTY layer initialized
[    3.099358] Bluetooth: RFCOMM socket layer initialized
[    3.105168] Bluetooth: RFCOMM ver 1.11
[    3.109937] Registering SWP/SWPB emulation handler
[    3.129413] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[    3.139284] sunxi-i2c sunxi-i2c2: probe success
[    3.145963] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[    3.158333] ======cw2015_probe===
[    3.175463] [drivers/power/supply/cw2015_battery.c: 513]trace : -------> cw2015_hw_init mode=00
[    3.188742] [drivers/power/supply/cw2015_battery.c: 594]trace : -------> cw2015_probe
[    3.197639] i2c-gpio i2c4_gpio: using lines 128 (SDA) and 129 (SCL)
[    3.205387] get ehci0-controller wakeup-source is fail.
[    3.211363] sunxi ehci0-controller don't init wakeup source
[    3.217619] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b4d4b0, 0x:c8896000,        b
[    3.229635] [sunxi-ehci0]: Not init ehci0
[    3.234454] get ohci0-controller wakeup-source is fail.
[    3.240422] sunxi ohci0-controller don't init wakeup source
[    3.246675] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b4d740
[    3.256351] [sunxi-ohci0]: Not init ohci0
[    3.261525] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulato        r
[    3.274990] clk: Not disabling unused clocks
[    3.279957] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.289622] cfg80211: failed to load regulatory.db
[    3.295056] ALSA device list:
[    3.298384]   #0: audiocodec
[    3.307968] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
[    3.316461] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[    3.324655] devtmpfs: mounted
[    3.329905] Freeing unused kernel memory: 1024K
[    3.359852] Run /pseudo_init as init process
mount: mounting none on /dev failed: Resource busy
[    3.509310] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
[    3.522173] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
Didn't found ubi volume "env"
Cannot open /dev/ubi0: No such file or directory
Didn't found ubi volume "env-redund"
[    3.558609] random: fast init done
can't run '/etc/preinit': No such file or directory
mount: mounting proc on /proc failed: Resource busy
mount: mounting tmpfs on /run failed: No such file or directory
hostname: can't open '/etc/hostname': No such file or directory
------run rc.preboot file-----
[    3.690478] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
------run rc.modules file-----
------run rc.final file-----
numid=30,iface=MIXER,name='Headphone Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=on
------light up RGB LED-----
[    3.813165] file system registered
[    3.830737] configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
[    3.855946] read descriptors
[    3.859193] read strings
------light up LED-----
------run profile file-----
 _____  _              __     _
|_   _||_| ___  _ _   |  |   |_| ___  _ _  _ _
  | |   _ |   ||   |  |  |__ | ||   || | ||_'_|
  | |  | || | || _ |  |_____||_||_|_||___||_,_|
  |_|  |_||_|_||_|_|  Tina is Based on OpenWrt!
 Tina Linux (Neptune, 61CC0487)
Fri Nov 22 00:00:00 GMT 2024
nodev   debugfs
[    5.086413] random: app: uninitialized urandom read (4 bytes read)
QStandardPaths: wrong permissions on runtime directory /usr/lib/, 0755 instead of 0700
[    5.234450] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    5.234456] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    5.234576] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    5.234578] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    5.234582] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    5.234584] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    5.234628] [LCD_FB] lcd_fb_gpio_set_value,line:304:
[    5.234631] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
No such plugin for spec "tslib:/dev/input/event1"
hello.
[    6.879973] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy r        r
[    7.166708] android_work: sent uevent USB_STATE=CONNECTED
[    7.295067] configfs-gadget gadget: high-speed config #1: c
[    7.301392] android_work: sent uevent USB_STATE=CONFIGURED
[   33.799737] usb1-vbus: disabling
最近编辑记录 Gentlepig (2024-12-12 10:43:55)
