楼主 # 2025-05-25 11:00:20
memory
已发帖子: 716
T113 uboot可以通过外部gpio配置选择lcd配置,但是linux没有实现
brandy/brandy-2.0/u-boot-2018/arch/arm/dts/sun8iw20p1-soc-system.dts
添加:
		lcd0_1: lcd0_1@5461000 {
device/config/chips/t113_s4/configs/pt1/uboot-board.dts
添加lcd配置
&lcd0 {
        lcd_used            = <1>;
        lcd_driver_name     = "lcd_639";
        lcd_backlight       = <100>;
        lcd_if              = <4>;
        lcd_x               = <800>;
        lcd_y               = <1280>;
        lcd_width           = <52>;
        lcd_height          = <52>;
        lcd_dclk_freq       = <72>;
        lcd_pwm_used        = <1>;
        lcd_pwm_ch          = <4>;
        lcd_pwm_freq        = <1000>;
        lcd_pwm_pol         = <0>;
        lcd_pwm_max_limit   = <255>;
        lcd_hbp             = <50>;
        lcd_ht              = <895>;
        lcd_hspw            = <4>;
        lcd_vbp             = <30>;
        lcd_vt              = <1340>;
        lcd_vspw            = <4>;
        lcd_dsi_if          = <0>;
        lcd_dsi_lane        = <4>;
        lcd_lvds_if         = <0>;
        lcd_lvds_colordepth = <0>;
        lcd_lvds_mode       = <0>;
        lcd_frm             = <0>;
        lcd_hv_clk_phase    = <0>;
        lcd_hv_sync_polarity= <0>;
        lcd_io_phase        = <0x0000>;
        lcd_gamma_en        = <0>;
        lcd_bright_curve_en = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        lcd_fsync_act_time  = <1000>;
        lcd_fsync_dis_time  = <1000>;
        lcd_fsync_pol       = <0>;
        deu_mode            = <0>;
        lcdgamma4iep        = <22>;
        smart_color         = <90>;
        lcd_gpio_0 =  <&pio PD 21 GPIO_ACTIVE_HIGH>;
        pinctrl-0 = <&dsi4lane_pins_a>;
        pinctrl-1 = <&dsi4lane_pins_b>;
&lcd0_1 {
        lcd_used            = <1>;
        lcd_driver_name     = "lcd_630";
        lcd_if              = <4>;
        lcd_x               = <720>;
        lcd_y               = <1280>;
        lcd_width           = <52>;
        lcd_height          = <52>;
        lcd_dclk_freq       = <68>;
        lcd_pwm_used        = <1>;
        lcd_pwm_ch          = <4>;
        lcd_pwm_pol         = <0>;
        lcd_hbp             = <64>;
        lcd_ht              = <820>;
        lcd_hspw            = <4>;
        lcd_vbp             = <30>;
        lcd_vt              = <1380>;
        lcd_vspw            = <4>;
        lcd_dsi_if          = <0>;
        lcd_dsi_lane        = <4>;
        lcd_lvds_if         = <0>;
        lcd_frm             = <0>;
        lcd_gamma_en        = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        deu_mode            = <0>;
        smart_color         = <90>;
lcd_639.c
static void LCD_panel_try_switch(u32 sel)
        printf("switch to lcd0_1 ................. \n");
		lcd_power_off(sel);
		sunxi_lcd_switch_compat_panel(sel, 1);/*switch to lcd0_1*/
static s32 lcd_open_flow(u32 sel)
	LCD_OPEN_FUNC(sel, lcd_power_on, 10);
	LCD_OPEN_FUNC(sel, LCD_panel_try_switch, 0);   //must delay 0
	LCD_OPEN_FUNC(sel, lcd_panel_init, 10);
	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
	LCD_OPEN_FUNC(sel, lcd_bl_open, 0);
启动日志:
[22]HELLO! BOOT0 is starting!
[25]BOOT0 commit : 2386bdb825
[27]set pll start
[33]periph0 has been enabled
[36]set pll end
[38][pmu]: bus read error
[40]board init ok
[42]enable_jtag
[44]ZQ value = 0x2f
[45]get_pmu_exist() = -1
[48]DRAM BOOT DRIVE INFO: V0.34
[51]DRAM CLK = 792 MHz
[53]DRAM Type = 3 (2:DDR2,3:DDR3)
[56]DRAMC ZQ value: 0x7b7bfb
[59]DRAM ODT value: 0x42.
[61]ddr_efuse_type: 0xa
[64]DRAM SIZE = 256 MB
[71]DRAM simple test OK.
[73]rtc standby flag is 0x0, super standby flag is 0x0
[78]dram size =256
[81]4byte mode error
[83]set spi freq:50000000
[86]spi sample_mode:1 sample_delay:1c
[91]spinor id is: ef 40 19, read cmd: 6b
[94]Succeed in reading toc file head.
[98]The size of toc is ec000.
[140]Entry_name        = u-boot
[145]Entry_name        = optee
[149]Entry_name        = dtb
[152]Jump to second Boot.
M/TC: OP-TEE version: aa2ed4e9 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Mon Jan 13 06:39:29 UTC 2025 arm
M/TC: OP-TEE 32bit
E/TC:0 0 search_key_via_name:418 Key 'huk' not found
E/TC:0 0 platform_standby_fdt_parse:126 no pmu0 node
E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
U-Boot 2018.07-gce06dac-dirty (May 24 2025 - 22:57:27 +0800) Allwinner Technology
[00.230]CPU:   Allwinner Family
[00.233]Model: sun8iw20
[00.235]DRAM:  256 MiB
[00.238]Relocation Offset is: 0cf39000
[00.256]secure enable bit: 0
CACHE: Misaligned operation at range [4bef8e68, 4bf18e68]
E/TC:0   generate_smc_mem_map:319 Not enough SMC region, 0x41b07937 byte ta ram left unsecured
E/TC:0   fdt_getprop_u32:340 prop trace_level not found
[00.283]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.289]gic: sec monitor mode
SPI ALL:   ready
[00.294]line:703 init_clocks
[00.297]flash init start
[00.299]workmode = 0,storage type = 3
[00.305]spi sample_mode:1 sample_delay:1c
[00.309]spi sunxi_slave->max_hz:50000000
SF: Detected w25q256( ) with page size 256 Bytes, erase size 64 KiB, total 32 MiB
[00.321]sunxi flash init ok
[00.324]drv_disp_init
partno erro : can't find partition bootloader
[00.361]drv_disp_init finish
[00.366]Loading Environment from SUNXI_FLASH... OK
[00.416]boot_gui_init:start
partno erro : can't find partition Reserve0
lcd 630 init ...............................
[00.709]LCD open finish
bad fb1_cfg[w=0,h=0,bpp=32,format=0]
[00.757]boot_gui_init:finish
[00.764]bmp_name=bootlogo.bmp size 38454
root_partition is rootfs
set root to /dev/mtdblock5
[00.781]update part info
[00.784]update bootcmd
[00.796]change working_fdt 0x4bef8e68 to 0x4bed8e68
[00.824]update dts
[01.537]no vendor_boot partition is found
Android's image name: sun8i_arm
ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
ERROR: reserving fdt memory region failed (addr=4bf43000 size=384000)
[01.578]Starting kernel ...
[01.580]total: 1580 ms
[    0.000000] Linux version 5.4.61 (ubuntu@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Fri May 16 17:43:52 CST 2025
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x42900000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@42900000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 32 MiB at 0x4e000000
[    0.000000] On node 0 totalpages: 63600
[    0.000000]   Normal zone: 512 pages used for memmap
[    0.000000]   Normal zone: 63600 pages, LIFO batch:15
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s30848 r8192 d22400 u61440
[    0.000000] pcpu-alloc: s30848 r8192 d22400 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 63088
[    0.000000] Kernel command line: earlyprintk= clk_ignore_unused initcall_debug=0 console=ttyS4,115200 loglevel=8 root=/dev/mtdblock5 rootfstype=squashfs rootwait init=/init partitions=boot-resource@mtdblock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@mtdblock6 cma=32M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018.07-gce06dac-dirty(05/24/2025-22:57:27) mbr_offset=1032192 disp_reserve=3686400,0x4bf43000 androidboot.dramfreq=792 androidboot.dramsize=256 uboot_backup=ubootA
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Memory: 197340K/254400K available (6144K kernel code, 384K rwdata, 2128K rodata, 1024K init, 166K bss, 24292K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x254/0x3d0 with crng_init=0
[    0.008018] Switching to timer-based delay loop, resolution 41ns
[    0.014212] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.024062] Console: colour dummy device 80x30
[    0.028561] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.038941] pid_max: default: 32768 minimum: 301
[    0.043717] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.051055] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.059425] CPU: Testing write buffer coherency: ok
[    0.064680] /cpus/cpu@0 missing clock-frequency property
[    0.070000] /cpus/cpu@1 missing clock-frequency property
[    0.075353] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.081621] Setting up static identity map for 0x40100000 - 0x40100060
[    0.088312] rcu: Hierarchical SRCU implementation.
[    0.093595] smp: Bringing up secondary CPUs ...
[    0.099422] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.099578] smp: Brought up 1 node, 2 CPUs
[    0.109413] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.115592] CPU: All CPU(s) started in SVC mode.
[    0.120724] devtmpfs: initialized
[    0.137076] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.145280] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.155177] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.163533] pinctrl core: initialized pinctrl subsystem
[    0.170135] NET: Registered protocol family 16
[    0.176417] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.222596] rtc_ccu: sunxi ccu init OK
[    0.228880] ccu: sunxi ccu init OK
[    0.232823] r_ccu: sunxi ccu init OK
[    0.273847] sun6i-dma 3002000.dma-controller: sunxi dma probed
[    0.282609] iommu: Default domain type: Translated
[    0.287756] sunxi iommu: irq = 24
[    0.292313] SCSI subsystem initialized
[    0.296489] usbcore: registered new interface driver usbfs
[    0.302144] usbcore: registered new interface driver hub
[    0.307599] usbcore: registered new device driver usb
[    0.314156] Advanced Linux Sound Architecture Driver Initialized.
[    0.321268] pwm module init!
[    0.334687] g2d 5410000.g2d: Adding to iommu group 0
[    0.340148] G2D: rcq version initialized.major:251
[    0.345727] input: sunxi-keyboard as /devices/virtual/input/input0
[    0.353390] clocksource: Switched to clocksource arch_sys_counter
[    0.368671] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    0.390033] thermal_sys: Registered thermal governor 'step_wise'
[    0.390595] NET: Registered protocol family 2
[    0.401698] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.410787] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.418524] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.426143] TCP: Hash tables configured (established 2048 bind 2048)
[    0.432637] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.439218] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.446453] NET: Registered protocol family 1
[    0.451953] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[    0.462351] spi spi0: spi0 supply spi not found, using dummy regulator
[    0.469303] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[    0.475513] sunxi_spi_resource_get()2198 - sample_mode:1 sample_delay:28
[    0.482282] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[    0.488752] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base d0821000, irq 40
[    0.498834] Initialise system trusted keyrings
[    0.503582] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[    0.518453] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.524761] ntfs: driver 2.1.32 [Flags: R/W].
[    0.529571] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.566253] Key type asymmetric registered
[    0.570361] Asymmetric key parser 'x509' registered
[    0.575304] io scheduler mq-deadline registered
[    0.579839] io scheduler kyber registered
[    0.583964] atomic64_test: passed
[    0.588803] [DISP]disp_module_init
[    0.592801] disp 5000000.disp: Adding to iommu group 0
[    0.598639] [DISP] disp_init,line:2372:
[    0.598645] smooth display screen:0 type:1 mode:4
[    0.624412] display_fb_request,fb_id:0
[    0.638390] disp_al_manager_apply ouput_type:1
[    0.643156] [DISP] lcd_clk_config,line:777:
[    0.643167] disp 0, clk: pll(432000000),clk(432000000),dclk(72000000) dsi_rate(72000000)
[    0.643167]      clk real:pll(432000000),clk(432000000),dclk(108000000) dsi_rate(150000000)
[    0.644024] [DISP]disp_module_init finish
[    0.648057] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[    0.664997] sunxi_sid_init()783 - insmod ok
[    0.682724] pwm-regulator: supplied by regulator-dummy
[    0.685698] Freeing logo buffer memory: 3600K
[    0.690299] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[    0.702591] uart uart3: uart3 supply uart not found, using dummy regulator
[    0.709972] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
[    0.718654] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[    0.728939] uart uart4: uart4 supply uart not found, using dummy regulator
[    0.736234] uart4: ttyS4 at MMIO 0x2501000 (irq = 35, base_baud = 1500000) is a SUNXI
[    0.744122] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
▒[    0.752102] printk: console [ttyS4] enabled
[    0.761034] printk: bootconsole [earlycon0] disabled
[    0.772905] misc dump reg init
[    0.776961] deinterlace 5400000.deinterlace: Adding to iommu group 0
[    0.784699] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[    0.793492] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[    0.800744] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[    0.808118] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[    0.815567] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[    0.822112] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[    0.829079] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[    0.836829] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=207 assert=1
[    0.844703] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=204 assert=1
[    0.852826] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[    0.860547] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[    0.867352] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[    0.874916] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=38 assert=0
[    0.883105] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[    0.890413] [ADDR_MGT] addr_mgt_probe: success.
[    0.897147] spi-nor spi0.0: w25q256 (32768 Kbytes)
[    0.903528] 7 sunxipart partitions found on MTD device spi0.0
[    0.909980] Creating 7 MTD partitions on "spi0.0":
[    0.915417] 0x000000000000-0x000000100000 : "uboot"
[    0.924554] 0x000000100000-0x000000120000 : "boot-resource"
[    0.934606] 0x000000120000-0x000000140000 : "env"
[    0.944575] 0x000000140000-0x000000160000 : "env-redund"
[    0.954541] 0x000000160000-0x0000005a0000 : "boot"
[    0.964579] 0x0000005a0000-0x000001050000 : "rootfs"
[    0.974620] 0x000001050000-0x000002000000 : "UDISK"
[    0.985638] libphy: Fixed MDIO Bus: probed
[    0.990244] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.997673] sunxi-ehci: EHCI SUNXI driver
[    1.002695] get drvvbus-en is fail, 22
[    1.006959] get ehci0-controller wakeup-source is fail.
[    1.012944] sunxi ehci0-controller don't init wakeup source
[    1.019318] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b82920, 0x:d083a000, irq_no:35
[    1.031337] [sunxi-ehci0]: Not init ehci0
[    1.036191] get drvvbus-en is fail, 22
[    1.040400] get ehci1-controller wakeup-source is fail.
[    1.046403] sunxi ehci1-controller don't init wakeup source
[    1.052687] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b82e80, 0x:d083e000, irq_no:37
[    1.064983] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[    1.077410] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.084725] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.094818] sunxi-ehci 4200000.ehci1-controller: irq 55, io mem 0x04200000
[    1.123416] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.132224] hub 1-0:1.0: USB hub found
[    1.136520] hub 1-0:1.0: 1 port detected
[    1.141714] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.148708] sunxi-ohci: OHCI SUNXI driver
[    1.153716] get drvvbus-en is fail, 22
[    1.157928] get ohci0-controller wakeup-source is fail.
[    1.163973] sunxi ohci0-controller don't init wakeup source
[    1.170234] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b82bd0
[    1.179930] [sunxi-ohci0]: Not init ohci0
[    1.184827] get drvvbus-en is fail, 22
[    1.189039] get ohci1-controller wakeup-source is fail.
[    1.195037] sunxi ohci1-controller don't init wakeup source
[    1.201297] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b83130
[    1.211238] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[    1.223694] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.230955] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.240924] sunxi-ohci 4200400.ohci1-controller: irq 56, io mem 0x04200400
[    1.318396] hub 2-0:1.0: USB hub found
[    1.322653] hub 2-0:1.0: 1 port detected
[    1.327977] usbcore: registered new interface driver usb-storage
[    1.335350] sunxi_gpadc_init,2228, success
[    1.341290] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[    1.352050] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[    1.363339] sunxi-rtc 7090000.rtc: registered as rtc0
[    1.369088] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[    1.379759] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:51:20 UTC (3080)
[    1.388957] sunxi-rtc 7090000.rtc: Fail to read dts property 'gpr_bootcount_pos'
[    1.397289] reasonbase NULL
[    1.400420] reason large than max, fix to hot reboot, save boot reason
[    1.407754] invalid reason or reasonbase NULL
[    1.412649] sunxi-rtc 7090000.rtc: sunxi rtc probed
[    1.418635] i2c /dev entries driver
[    1.422682] IR NEC protocol handler initialized
[    1.428202] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    1.439607] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
[    1.448813] Registered IR keymap rc_map_sunxi
[    1.453890] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[    1.462613] rc rc0: lirc_dev: driver sunxi-rc-recv registered at minor = 0, raw IR receiver, no transmitter
[    1.473797] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[    1.484160] sunxi cedar version 1.1
[    1.488266] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.494577] VE: sunxi_cedar_probe power-domain init!!!
[    1.500350] VE: install start!!!
[    1.500350]
[    1.505946] VE: cedar-ve the get irq is 41
[    1.505946]
[    1.512422] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[    1.512422]
[    1.521733] VE: install end!!!
[    1.521733]
[    1.526829] VE: sunxi_cedar_probe
[    1.531880] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.544010] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[    1.553957] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    1.560178] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    1.566547] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    1.572994] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    1.579453] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    1.586007] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    1.592550] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    1.599107] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    1.606152] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    1.611561] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    1.618280] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.629461] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    1.649625] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.674102] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    1.679807] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    1.684049] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[    1.700899] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    1.707143] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[    1.713514] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[    1.719977] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    1.726439] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    1.732992] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    1.739550] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    1.746107] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    1.752707] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    1.762273] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.773506] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[    1.793411] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.817697] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    1.825405] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.832555] usbcore: registered new interface driver usbhid
[    1.838843] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.845731] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.853399] usbhid: USB HID core driver
[    1.860440] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.861639] exFAT: Version 1.3.0
[    1.875422] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.879969] NET: Registered protocol family 10
[    1.885255] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.889937] Segment Routing with IPv6
[    1.896302] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.899704] NET: Registered protocol family 17
[    1.907249] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.911414] 8021q: 802.1Q VLAN Support v1.8
[    1.918158] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    1.923541] Registering SWP/SWPB emulation handler
[    1.939707] Loading compiled-in X.509 certificates
[    1.964564] sunxi-thermal 2009400.ths: sun8iw20 chip id: 29184
[    1.971120] sunxi-thermal 2009400.ths: sun8iw20 t1: 8000
[    1.977245] sunxi-thermal 2009400.ths: sun8iw20 cp version:22
[    1.988375] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[    2.004786] debugfs: Directory 'soc@3000000:codec_plat' with parent 'audiocodec' already present!
[    2.015423] sunxi-snd-mach soc@3000000:codec_mach: 2030000.codec <-> soc@3000000:codec_plat mapping ok
[    2.027256] input: audiocodec Headphones as /devices/platform/soc@3000000/soc@3000000:codec_mach/sound/card0/input2
[    2.039843] [sound  403][MACH simple_parse_of] simple_dai_link_of failed
[    2.047540] [sound  403][MACH simple_parse_of] simple_dai_link_of failed
[    2.055263] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.066752] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.074404] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.083643] clk: Not disabling unused clocks
[    2.084216] cfg80211: failed to load regulatory.db
[    2.088847] ALSA device list:
[    2.097533]   #0: audiocodec
[    2.100769] alloc_fd: slot 0 not NULL!
[    2.167895] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    2.179929] Freeing unused kernel memory: 1024K
[    2.203685] Run /init as init process
[    2.258703] random: fast init done
[    5.500231] random: fgrep: uninitialized urandom read (4 bytes read)
[    5.516774] random: mkdir: uninitialized urandom read (4 bytes read)
[    5.534743] random: sed: uninitialized urandom read (4 bytes read)
[    5.603539]
[    5.603539] insmod_device_driver
[    5.603539]
[    5.614281] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[    7.469946] random: crng init done
[    7.473780] random: 7 urandom warning(s) missed due to ratelimiting
[   15.470764] jffs2: notice: (1009) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (7 unchecked, 13 orphan) and 22 of xref (13 dead, 0 orphan) found.
[   15.685674] overlayfs: upper fs does not support tmpfile.
mount: mounting proc on /proc failed: Device or resource busy
[   17.656374] file system registered
[   17.695166] configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
init adb main
[   17.887423] read descriptors
Handling main()
[   17.890967] read strings
[5]+  Done                       echo /sbin/mdev 1>/proc/sys/kernel/hotplug
[4]   Done                       mkdir -p /mnt/addon2/
# WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 4
[5]   Done                       /bin/setusbconfig adb
[3]   Done                       tinymix set "HPOUT Switch" 1
[1]   Done                       mdev -s
# [1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
WARNING: awplayer <DlOpenPlugin:114>: Invalid plugin,function CedarPluginVDInit not found.
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
ERROR  : awplayer <DlOpenPlugin:105>: dlopen 'libawwmv3.so' fail: libawwmv3.so: cannot open shared object file: No such file or directory
[1970-01-01 08:51:42] INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
INFO   : awplayer <AwParserInit:452>: aw parser init...
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : tina3.5
branch: tina-dev
date  : Mon Jul 15 19:04:59 2019 +0800
Change-Id: I5f6c8a88d7b387a312b7744797a0d5f8ab07ee7a
# xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
xplayer:process message XPLAYER_COMMAND_SET_DI.
# WARNING: awplayer <XPlayerReset:1005>: reset...
xplayer:process message XPLAYER_COMMAND_RESET.
ERROR  : awplayer <PlayerStop:994>: invalid stop operation, player already in stopped status.
# wh=800x1280, vwh=800x2560, bpp=32, rotated=0
Turn on double buffering.
Turn on 2d hardware acceleration.
Turn on 2d hardware acceleration blit.
Turn on 2d hardware acceleration rotate.
finfo.line_length=3200, vinfo.yres=1280
sinfo.rotatefbp_w=800, sinfo.rotatefbp_h=1280
------> sunxifb_alloc=b41ee000
lvgl width=800, height=1280, rotated=0
# unable to open evdev interface:: No such file or directory
# ccode = 7
now play: /mnt/addon2/test1.mp4
INFO   : awplayer <XPlayerThread:1838>: process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_PREPARE.
ERROR  : awplayer <__FileStreamConnect:385>: open file failure, errno(2)
ERROR  : awplayer <CdxParserPrepare:840>: open stream fail, uri(file:///mnt/addon2/test1.mp4)
ERROR  : demuxComponent <DemuxThread:2119>: DEMUX_ERROR_IO
ERROR  : awplayer <XPlayerSetDataSourceUrl:544>: prepare failure, ret(-1004)
TPlayerSetDataSource() return fail.
not prepared!
Screen Width: 800px, Screen Height: 1280px
-/bin/sh: c: not found
[6]-  Done                       modprobe xr819 && wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf 1>/dev/null 2>&1
# cat /sys/class/disp/disp/attr/sys
screen 0:
de_rate 300000000 hz, ref_fps:60
mgr0: 800x1280 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[6]
        lcd output      backlight(255)  fps:60.6         800x1280
        err:0   skip:29 irq:1864        vsync:0 vsync_skip:0
   BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 800,1280; 800,1280; 800,1280] crop[   0,1280, 800,1280] frame[   0,   0, 720,1280] addr[       0,       0,       0] flags[0x       0] trd[0,0]
depth[ 0]
楼主 #1 2025-05-25 18:22:53
memory
已发帖子: 716
Re: T113 uboot可以通过外部gpio配置选择lcd配置,但是linux没有实现
ILI9881C 可以用 mipi cmd 读取 id
	u8 result[16] = {0};
	u32 num = 0;
	sunxi_lcd_delay_ms(100);
	sunxi_lcd_dsi_dcs_write_3para(sel, 0xFF, 0x98, 0x81, 0x01); //切换到page1
	sunxi_lcd_delay_ms(10);
	sunxi_lcd_dsi_set_max_ret_size(sel, 3);
	sunxi_lcd_dsi_dcs_read(sel, 0x00, result, &num);//读寄存器0
	printf("^^^^^^^^^^^^^^^get lcd id 0x%x, num=%d\n", result[0], num);
	sunxi_lcd_dsi_dcs_read(sel, 0x01, result, &num);//读寄存器1
	sunxi_lcd_dsi_dcs_read(sel, 0x02, result, &num);//读寄存器2
日志:
[00.363]drv_disp_init finish
[00.368]Loading Environment from SUNXI_FLASH... OK
[00.417]boot_gui_init:start
^^^^^^^^^^^^^^^get lcd id 0x98, num=1
^^^^^^^^^^^^^^^get lcd id 0x81, num=1
^^^^^^^^^^^^^^^get lcd id 0x1c, num=1
lcd 636 init ...............................
[00.831]LCD open finish
