楼主 #1 2018-07-25 15:06:57
lilengqiang
v3s使用tinyalsa,用tinyplay可以播放WAV,用tinycap进行录音要怎么设置tinymix?
ctl     type    num     name                                     value
0       INT     1       Master Playback Volume                   0
1       INT     1       Line Volume                              0
2       INT     1       MIC1_G boost stage output mixer control  3
3       INT     1       MIC2_G boost stage output mixer control  3
4       INT     1       MIC1 boost AMP gain control              4
5       INT     1       MIC2 boost AMP gain control              4
6       INT     1       ADC input gain ctrl                      3
7       BOOL    1       Audio headphone out                      Off
8       BOOL    1       Audio speaker out                        Off
9       BOOL    1       Audio main mic                           Off
10      BOOL    1       Audio sub mic                            Off
11      ENUM    1       Audio record source                      mic1
12      BOOL    1       Audio noise reduced                      Off
13      BOOL    1       Audio linein                             Off
14      BOOL    1       Audio capture route switch               Off
15      BOOL    1       Audio clear path                         Off
16      ENUM    1       Speaker Function                         headset
#2 2018-07-25 15:30:14
已发帖子: 9,513
Re: v3s使用tinyalsa,用tinyplay可以播放WAV,用tinycap进行录音要怎么设置tinymix?
tinycap 当时没测好,荔枝派群主说麦克风焊反了, 如果你试出来分享一下。
#3 2020-09-15 15:36:22
学习的菜鸟
大佬,使用tinycap进行录音,但是并没有成功。有调试出来的吗?
