楼主 #1 2019-07-08 16:43:39
无情一刀
已发帖子: 723
edt_ft5x06在屏幕触摸的过程中出现unable to fetch data error -5
在运行QT的过程了 我定义了一个QLabel 然后我拖动这个QLabel 就会出现下面这个问题 我拖动的过程中只是改变QLabel的位置
aule1=== 0 vaule2 5
MoveCon[ 83.303626] input_mt_report_slot_state
trol X== 0 Y === 5
[ 83.313179] touchscreen_report_pos
[ 83.318503] i2c i2c-0: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x2, status: 0x0, addr: 0x38, flags: 0x0
[ 83.327746] edt_ft5x06 0-0038: Unable to fetch data, error: -5
[ 83.337297] x=== 154 y===72 id === 0 down == 1
[ 83.341776] input_mt_report_slot_state
[ 83.345705] touchscreen_report_pos
[ 83.349597] edt_ft5x06 0-0038: Unable to fetch data, error: -6
#2 2019-07-08 16:53:20
已发帖子: 9,513
Re: edt_ft5x06在屏幕触摸的过程中出现unable to fetch data error -5
https://github.com/torvalds/linux/blob/master/drivers/input/touchscreen/edt-ft5x06.c
error = edt_ft5x06_ts_readwrite(tsdata->client,
sizeof(cmd), &cmd,
datalen, rdbuf);
if (error) {
dev_err_ratelimited(dev, "Unable to fetch data, error: %d\n",
error);
goto out;
https://github.com/torvalds/linux/blob/master/include/uapi/asm-generic/errno-base.h
#define EPERM 1 / Operation not permitted /
#define ENOENT 2 / No such file or directory /
#define ESRCH 3 / No such process /
#define EINTR 4 / Interrupted system call /
#define EIO 5 / I/O error /
#define ENXIO 6 / No such device or address /
#define E2BIG 7 / Argument list too long /
#define ENOEXEC 8 / Exec format error /
检查是不是硬件问题, 供电查起,电压, 波纹, 干扰 ...
楼主 #3 2019-07-08 16:59:36
无情一刀
已发帖子: 723
如果是单纯的点击没有问题 就是在屏幕上面拖动的时候就有问题了 等下让硬件的来看看吧
