楼主 #1 2018-02-08 08:51:05
已发帖子: 9,486
X1000 phoenix 添加 旋转编码器驱动程序
  1. X1000/platform/kernel/arch/mips/xburst/soc-x1000/chip-x1000/phoenix/common/board_base.c
添加平台驱动与平台设备代码:
#include <linux/input.h>
#include <linux/rotary_encoder.h>
//#define GPIO_ROTARY_A 1
//#define GPIO_ROTARY_B 2
static struct rotary_encoder_platform_data my_rotary_encoder_info = {
	.steps		= 24,
	.axis		= ABS_X,
	.relative_axis	= false,
	.rollover	= false,
	.gpio_a		= GPIO_PC(5), //GPIO_ROTARY_A, 填入实际引脚A
	.gpio_b		= GPIO_PC(4), //GPIO_ROTARY_B, 填入实际引脚B
	.inverted_a	= 0,
	.inverted_b	= 0,
	.half_period	= false,
	//.wakeup_source	= false,
static struct platform_device rotary_encoder_device = {
	.name		= "rotary-encoder",
	.id		= 0,
	.dev		= {
		.platform_data = &my_rotary_encoder_info,
添加设备:
DEF_DEVICE(&rotary_encoder_device, 0, 0),
  1. make menuconfig
勾选旋转编码器驱动:
              Device Drivers  --->      Input device support  --->  Miscellaneous devices
--->     <*>   Rotary encoders connected to GPIO pins
选中用户接口, 使驱动产生 /dev/input/eventX 设备
              Device Drivers  --->      Input device support  --->    <*>   Event interface
  1. 下载编译 http://elinux.org/images/9/93/Evtest.c
    执行 evtest /dev/input/eventX
#2 2019-03-16 09:27:13
Re: X1000 phoenix 添加 旋转编码器驱动程序
这个顶起,我打算在V3s也加上旋转编码器。
是不是两个脚都要接中断脚上?
#3 2019-03-16 09:32:42
已发帖子: 649
旋转编码器,正交解码,让我想起了飞思卡尔智能车
#4 2019-03-16 10:23:37
一看就是参加过竞赛的
#5 2019-03-16 10:24:17
jimmy
已发帖子: 316
Linux里面驱动真全,这个都有
