楼主 # 2023-03-10 14:30:43
已发帖子: 1,438
socketcan,用write()发送,连续发送多条数据时,容易返回-1错误。
请教,socketcan,用write()发送,连续发送多条数据时,容易返回-1错误。
write加一句qDebug()打印发送的数据后,可以了,但偶尔还是会出,概率极小。感觉是相当于加了个延时等待。
socketcan有没有判断是否可写的功能?
oid NuvotonCan::socketCanSend(uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3, uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7)
   1 {
   2     memset(&can1SendFrame, 0, sizeof(struct can_frame));
   3     can1SendFrame.can_id = (0x1b60f5f4 & CAN_EFF_MASK) | CAN_EFF_FLAG;
   4     can1SendFrame.can_dlc = 8;
   5     can1SendFrame.data[0] = d0;
   6     can1SendFrame.data[1] = d1;
   7     can1SendFrame.data[2] = d2;
   8     can1SendFrame.data[3] = d3;
   9     can1SendFrame.data[4] = d4;
  10     can1SendFrame.data[5] = d5;
  11     can1SendFrame.data[6] = d6;
  12     can1SendFrame.data[7] = d7;
  13
  14     int ret;
  15     ret = write(can1Socket, &can1SendFrame, sizeof(can1SendFrame));
  16     if (ret == -1)
  17     {
  18         qDebug() << "write error!" << ret << endl;
  19     }
  20     else
  21     {
               qDebug("socketcan send ok: %x, %02x, %02x, %02x, %02x, %02x, %02x, %02x, %02x", can1SendFrame.can_id, can1SendFrame.data[0]
   7     }
   6 }
楼主 #1 2023-03-10 15:06:39
已发帖子: 1,438
Re: socketcan,用write()发送,连续发送多条数据时,容易返回-1错误。
受群里两位朋友指点,改成这样可以了。
   int ret;        │  ▶ bin/
     1     uint8_t count = 0;        │  ▶ x86/
     2     while (write(can1Socket, &can1SendFrame, sizeof(can1SendFrame)) < 0 && count < 100)           │    aescrypto.cpp
     3     {        │    can.c
     4         qDebug() << "socketcan write failed, delay";                                              │    cantest*
     5         count++;        │    main.cpp*
     6         delayMs(1);        │    nuvotoncan.cpp*
     7     }
